I have a ASUS laptop with Ryzen 4900HS and RTX 2060 MAXQ. Winver is 20231 and installed 456.71 driver. I’ve checked
C:\Windows\System32\lxss\lib
/usr/lib/wsl/lib/
/dev/dxg
These all existing.
After I installed cuda_11.1.0_455.23.05_linux.run for samples and make BlackScholes, output raise error
[./BlackScholes] - Starting…
CUDA error at …/…/common/inc/helper_cuda.h:779 code=35(cudaErrorInsufficientDriver) “cudaGetDeviceCount(&device_count)”
./BlackScholes_nvrtc: error while loading shared libraries: libcuda.so.1: cannot open shared object file: No such file or directory
Do I need to install other driver in WSL? When I ran cuda_11.1.0_455.23.05_linux.run there was no option for driver though.
