So as the title suggests, I have been trying to install the following: CUDA 10.0, CuDNN 7.4 so I can use my GPUs with tensorflow 2.0. I have been trying for days and I can’t seem to properly install them even though I have followed the nvidia installation tutorials. Here is my nvidia-smi output:
| NVIDIA-SMI 430.50 Driver Version: 430.50 CUDA Version: 10.1 |
| 0 GeForce RTX 2070 Off | 00000000:01:00.0 On | N/A |
| 40% 26C P8 8W / 185W | 31MiB / 7979MiB | 1% Default |
| 1 GeForce RTX 2070 Off | 00000000:04:00.0 Off | N/A |
| 41% 24C P8 2W / 185W | 1MiB / 7982MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 861 G /usr/lib/xorg/Xorg 29MiB |
Most recently, I can’t seem to even install cuda and I have been getting the following error:
The following packages have unmet dependencies:
cuda-10-0 : Depends: cuda-runtime-10-0 (>= 10.0.130) but it is not going to be installed
Depends: cuda-demo-suite-10-0 (>= 10.0.130) but it is not going to be installed
I tried installing the first dependency and got another error:
cuda-runtime-10-0 : Depends: cuda-drivers (>= 410.48) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Are the cuda drivers different than the nvidia drivers? Should I be downgrading my drivers to 410.x (I noticed that’s what most people have been using/installing with cuda).
I’m also thinking it may be because I haven’t properly cleaned/uninstalled previous installations, but I have ran sudo apt-get remove cuda* and sudo apt-get purge cuda* after every unsuccessful installation, as well as removing the files in /src/local.
