I am trying to use tensorflow-gpu on my Linux machine. I am using Fedora 30. I already did the work around for gcc.
When I first installed the CUDA toolkit I installed 10.1 instead of 10.0. Now I am trying to uninstall 10.1 so I can get 10.0, But 10.1 seems to persist on ym system ever after uninstall.
Here is the output of all the cuda apps installed on my PC. You can see the driver and only 10.0
$ rpm -qa | grep cuda
libcudnn7-7.6.4.38-1.cuda10.0.x86_64
xorg-x11-drv-nvidia-cuda-430.40-1.fc30.x86_64
cuda-repo-fedora27-10.0.130-1.x86_64
cuda-gcc-c++-8.3.0-1.fc30.x86_64
cuda-gcc-gfortran-8.3.0-1.fc30.x86_64
xorg-x11-drv-nvidia-cuda-libs-430.40-1.fc30.x86_64
cuda-gcc-8.3.0-1.fc30.x86_64
libcudnn7-devel-7.6.4.38-1.cuda10.0.x86_64
Here is me showing that 10.1 is still somehow on my system. (Look at the top right)
$ nvidia-smi
Tue Oct 15 19:30:50 2019
| NVIDIA-SMI 430.40 Driver Version: 430.40 CUDA Version: 10.1 |
| 0 GeForce RTX 2080 Off | 00000000:03:00.0 On | N/A |
| 12% 56C P0 53W / 225W | 693MiB / 7981MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1374 G /usr/libexec/Xorg 55MiB |
| 0 1486 G /usr/bin/gnome-shell 61MiB |
| 0 1918 G /usr/libexec/Xorg 239MiB |
| 0 2052 G /usr/bin/gnome-shell 275MiB |
| 0 2726 G ...uest-channel-token=12173677761247180250 59MiB |
How can I fix this?
