nvidia-smi
Tue May 14 12:06:35 2019
| NVIDIA-SMI 430.09 Driver Version: 430.09 CUDA Version: 10.1 |
| 0 GeForce GTX 105... Off | 00000000:01:00.0 Off | N/A |
| N/A 54C P5 N/A / N/A | 262MiB / 4040MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 9716 G /usr/lib/xorg/Xorg 142MiB |
| 0 9891 G /usr/bin/gnome-shell 117MiB |
Installing cuda 10.1:
sudo sh cuda_10.1.168_418.67_linux.run
and result in this:
= Summary =
Driver: Not Selected
Toolkit: Installed in /usr/local/cuda-10.1/
Samples: Installed in /home/franzin/
Please make sure that
- PATH includes /usr/local/cuda-10.1/bin
- LD_LIBRARY_PATH includes /usr/local/cuda-10.1/lib64, or, add /usr/local/cuda-10.1/lib64 to /etc/ld.so.conf and run ldconfig as root
To uninstall the CUDA Toolkit, run cuda-uninstaller in /usr/local/cuda-10.1/bin
Please see CUDA_Installation_Guide_Linux.pdf in /usr/local/cuda-10.1/doc/pdf for detailed information on setting up CUDA.
***WARNING: Incomplete installation! This installation did not install the CUDA Driver. A driver of version at least 418.00 is required for CUDA 10.1 functionality to work.
To install the driver using this installer, run the following command, replacing <CudaInstaller> with the name of this run file:
sudo <CudaInstaller>.run --silent --driver
Logfile is /var/log/cuda-installer.log
It’s popping up that I need drivers> = 418.0 but I have the 430 as you can see in “nvidia-smi”
How do I solve this?
