This installation did not install the CUDA Driver
| NVIDIA-SMI 530.47 Driver Version: 531.68 CUDA Version: 12.1 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 L… On | 00000000:01:00.0 Off | N/A |
| N/A 67C P0 16W / N/A| 162MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
This is what nvidia-smi showed.
I am trying to install CUDA version 11.1.
During installation it showed.
= Summary =
Driver: Not Selected
Toolkit: Installed in /usr/local/cuda-11.1/
Samples: Installed in /home/kg4991/, but missing recommended libraries
Please make sure that
  • PATH includes /usr/local/cuda-11.1/bin
  • LD_LIBRARY_PATH includes /usr/local/cuda-11.1/lib64, or, add /usr/local/cuda-11.1/lib64 to /etc/ld.so.conf and run ldconfig as root
To uninstall the CUDA Toolkit, run cuda-uninstaller in /usr/local/cuda-11.1/bin
***WARNING: Incomplete installation! This installation did not install the CUDA Driver. A driver of version at least .00 is required for CUDA 11.1 functionality to work.
To install the driver using this installer, run the following command, replacing with the name of this run file:
sudo .run --silent --driver
I am trying to install AMBER22 modelling program which is incompatible with CUDA 12.1
Incompatible CUDA and GNU versions
9.4.0
SO what should I do?
