Hello there,
I am trying to install CUDA 10.1 update 2 from the official .deb (network) package. It is weird I have been able to install CUDA many times and this is the first time that this issue comes up.
The issue is that when I try to run a program I get the following:
CUDA driver version is insufficient for CUDA runtime version
Ok, I thought that the driver version mismatches CUDA runtime version, but when I saw the table on https://docs.nvidia.com/cuda/cuda-toolkit-release-notes/index.html#major-components I realized that for CUDA 10.1 I need a driver >= 418.39.
Ok, then I checked the nvidia-smi output:
Fri Nov 8 17:34:05 2019
| NVIDIA-SMI 418.87.01 Driver Version: 418.87.01 CUDA Version: N/A |
| 0 GeForce GTX 950M On | 00000000:01:00.0 Off | N/A |
| N/A 49C P0 N/A / N/A | 259MiB / 2004MiB | 64% Default |
So Driver Version: 418.87.01 > 418.39…
What I have also checked is the driver version with
cat /proc/driver/nvidia/version
The output is:
NVRM version: NVIDIA UNIX x86_64 Kernel Module 418.87.01 Wed Sep 25 06:00:38 UTC 2019
GCC version: gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)
What did I do wrong?
Is there a way to fix and to run CUDA applications on my laptop?
Cheers,
