OS: Linux 4.13.0-25-generic
Distro: Ubuntu 17.04
Machine: Inspiron 15 7000
GPU: Nvidia GeForce GTX 1060 Mo
CUDA: 9.1
I carefully followed the instructions to install CUDA 9.1 on Linux
including ensuring the PATH and LD_LIBRARY_PATH variables are set correctly. I can also compile the examples in ~/NVIDIA_CUDA-9.1_Samples and nvcc -V returns version V8.0.61.
In other questions of the forum, the answer to this problem was the upgrade of the driver to a r387 version. But I already have it.
After many attempts, no solution seems to work.
I purged the old installation and I installed CUDA all over again. I carefully checked that not a single step was missed.
Now, nvcc -V returns version 9.1, V9.1.85.
If I use nvidia-smi, I still get NVIDIA-SMI 387.34 Driver Version: 387.34 (the computer where I write this reply and the previous query is a different one from the one where I run Ubuntu, so I am only copying part of the output; I thought that showing NVIDIA-SMI was enough to make the point that the installed driver seems to be 387.34).
If I use cat /proc/driver/nvidia/version I get
NVRM version: NVIDIA UNIX x86_64 Kernel Module 387.34 (plus info on date and GCC version 6.3)
However, after I type deviceQuery, I still get
->CUDA driver version is insufficient for CUDA runtime version
Result=FAIL
My guess is that everything appears to be working correctly, except that your laptop is not enabling the discrete GPU because it is an optimus laptop. You may want to investigate any BIOS options to force the GTX1060 to be always on, or else investigate nvidia prime or bumblebee, to control enablement of the graphics.
if you installed via the package manager method (apt-get) it may be that you have nvidia-prime installed already. You could try the prime-select command to turn on the NVIDIA graphics.
sudo prime-select nvidia
prime-select query
You can also access nvidia prime from the nvidia-settings control panel, if you are running a GUI/desktop
Dear txbob
I have got similar errors. My driver version is 384.111, and I installed CUDA9.1.85_387.26. Then, when doing ./deviceQuery, I also get an error:
→ CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
My computer is DELL PRECISION T7600.
I think the error may be that the driver 384.111 is too low for CUDA9.1.85_387.26. However, what can I do now?
