I didn’t succeed to run any of the samples in cuda-9.
I tried different drivers of nvidia, different ubuntu kernel, different cuda version but non of these worked!
My setting is like so:
Ubuntu 16.04 LTS kernel 4.4.0
GeForce GTX 950M
nvidia-smi
Fri Feb 16 23:36:12 2018
| NVIDIA-SMI 384.111 Driver Version: 384.111 |
| 0 GeForce GTX 950M Off | 00000000:01:00.0 Off | N/A |
| N/A 40C P0 N/A / N/A | 177MiB / 4044MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1231 G /usr/lib/xorg/Xorg 138MiB |
| 0 2069 G compiz 35MiB |
| 0 2254 G unity-control-center 1MiB |
cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 384.111 Tue Dec 19 23:51:45 PST 2017
GCC version: gcc version 5.4.1 20160904 (Ubuntu 5.4.1-2ubuntu1~16.04)
I tried for example:
/usr/local/cuda-9.1/samples/0_Simple/matrixMul$ ./matrixMul
And I get that error:
[Matrix Multiply Using CUDA] - Starting...
CUDA error at ../../common/inc/helper_cuda.h:1160 code=35(cudaErrorInsufficientDriver) "cudaGetDeviceCount(&device_count)"
What I’m doing wrong? Do you suggest anything to test?
