I want Video Codec SDK 9.1 (driver version 435) and CUDA on a Ubuntu 18.04… (or any deb based system / ubuntu version)
Installing the Video driver was simple but installing Cuda 10.1 forced driver 418 to be installed meaning Video Codec SDK 9.0.
I did install on a fresh Ubuntu 18.04 with a T4 in it like this →
sudo add-apt-repository -y ppa:graphics-drivers/ppa
sudo apt -y update
sudo apt -y upgrade
sudo apt -y install nvidia-driver-435
(sudo reboot now)
wget http://developer.download.nvidia.com/compute/cuda/10.1/Prod/local_installers/cuda_10.1.243_418.87.00_linux.run
sudo sh cuda_10.1.243_418.87.00_linux.run
Then the CUDA installation complained about there was already a driver present and is not recommending me to continue, then I also had to uncheck the R418 driver install.
The installation completed with errors →
Please see CUDA_Installation_Guide_Linux.pdf in /usr/local/cuda-10.1/doc/pdf for detailed information on setting up CUDA.
***WARNING: Incomplete installation! This installation did not install the CUDA Driver. A driver of version at least 418.00 is required for CUDA 10.1 functionality to work.
To install the driver using this installer, run the following command, replacing <CudaInstaller> with the name of this run file:
sudo <CudaInstaller>.run --silent --driver
Is that just informing me that the driver (R418) was not installed or is there a actual problem? Kind of hard for me as a user to know, when a text saying : WARNING: Incomplete installation! pops up.
When I run the nvidia-smi tool, it says →
Wed Oct 23 15:31:22 2019
| NVIDIA-SMI 435.21 Driver Version: 435.21 CUDA Version: 10.1 |
| 0 Tesla T4 Off | 00000000:00:04.0 Off | 0 |
| N/A 57C P0 28W / 70W | 0MiB / 15109MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Tnx for helping.
/Anders
