Hello everyone,
I am working on an external FPGA-CSI2 camera to stream video using OV5693 driver. I was successfully captured raw video from /dev/video0 by using this command,
v4l2-ctl --set-fmt-video=width=1280,height=720,pixelformat=BGRA --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video0 --stream-to=ov491.raw
The problem is, when I try to stream /dev/video0 on my PC using gstreamer by running this command on PC,
sudo gst-launch-1.0 udpsrc port=5700 ! application/x-rtp, encoding-name=H265, payload=96 ! rtph265depay ! h265parse ! queue ! avdec_h265 ! videoconvert ! fpsdisplaysink sync=false
and this command on Jetson TX2-4GB running L4T 32.4.4,
sudo gst-launch-1.0 v4l2src device=/dev/video0 ! videorate max-rate=50 ! videoconvert ! omxh265enc qp-range=30,50:30,50:30,50 control-rate=4 bitrate=3000000 ! "video/x-h265, stream-format=(string)byte-stream" ! rtph265pay mtu=1400 ! udpsink host=192.168.1.5 port=5700 sync=false async=false
nothing happens:
Jetson console output:
nvidia@localhost:~$ sudo ./gstr.sh
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Framerate set to : 50 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
NVMEDIA: H265 : Profile : 1
PC console output:
useraccount@dell:~$ sudo gst-launch-1.0 udpsrc port=5700 ! application/x-rtp, encoding-name=H265, payload=96 ! rtph265depay ! h265parse ! queue ! avdec_h265 ! videoconvert ! fpsdisplaysink sync=false
Any suggestions? Is there any way to save raw video by using gstreamer? Thank you.
