Can't use external hdmi port on Quadro P1000 Mobile (gnome, wayland)
I was using my setup previously without issues but I’ve stopped using my HDMI ports a while back as it was crashing my system. Now it doesn’t crash anymore but it fails brining up the nvidia graphics in gnome wayland.
Please note I use nvidia-exec to turn on / off the GPU (GitHub - pedro00dk/nvidia-exec: GPU switching without login out for Nvidia Optimus laptops under Linux).
Mai 11 16:37:34 nk-zbook nvx[907]: 2025-05-11 16:37:34,612 [INFO] client connected
Mai 11 16:37:34 nk-zbook nvx[907]: 2025-05-11 16:37:34,612 [INFO] handle on
Mai 11 16:37:34 nk-zbook nvx[907]: 2025-05-11 16:37:34,613 [INFO] turn on
Mai 11 16:37:34 nk-zbook nvx[907]: 2025-05-11 16:37:34,613 [INFO] pci rescan
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: [10de:1cbb] type 00 class 0x030000 PCIe Endpoint
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00ffffff]
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 1 [mem 0x00000000-0x0fffffff 64bit pref]
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 3 [mem 0x00000000-0x01ffffff 64bit pref]
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 5 [io 0x0000-0x007f]
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: ROM [mem 0x00000000-0x0007ffff pref]
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: Enabling HDA controller
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: vgaarb: bridge control possible
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Mai 11 16:37:34 nk-zbook kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300 PCIe Endpoint
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.1: BAR 0 [mem 0x00000000-0x00003fff]
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.1: Max Payload Size set to 256 (was 128, max 256)
Mai 11 16:37:34 nk-zbook kernel: pcieport 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 1 [mem 0x80000000-0x8fffffff 64bit pref]: assigned
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 3 [mem 0x90000000-0x91ffffff 64bit pref]: assigned
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 0 [mem 0xe5000000-0xe5ffffff]: assigned
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: ROM [mem 0xe6000000-0xe607ffff pref]: assigned
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.1: BAR 0 [mem 0xe6080000-0xe6083fff]: assigned
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.0: BAR 5 [io 0x4000-0x407f]: assigned
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
Mai 11 16:37:34 nk-zbook kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
Mai 11 16:37:34 nk-zbook kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 → 0002)
Mai 11 16:37:34 nk-zbook kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Mai 11 16:37:34 nk-zbook kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Mai 11 16:37:34 nk-zbook nvx[907]: 2025-05-11 16:37:34,671 [INFO] pci devices
Mai 11 16:37:34 nk-zbook kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input33
Mai 11 16:37:34 nk-zbook kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input34
Mai 11 16:37:34 nk-zbook kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input35
Mai 11 16:37:34 nk-zbook kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input36
Mai 11 16:37:34 nk-zbook systemd[2192]: Reached target Sound Card.
Mai 11 16:37:35 nk-zbook nvx[907]: 2025-05-11 16:37:35,097 [INFO] devices: [Config(name: NVIDIA Corporation - GP107GLM [Quadro P1000 Mobile], bus: 0000:01:00.0, bridge: 0000:00:01.0), Config(name: NVIDIA Corporationn - GP107GLM [Quadro P1000 Mobile], bus: 0000:01:00.0, bridge: 0000:00:01.0), Config(name: NVIDIA Corporation - GP107GL High Definition Audio Controller, bus: 0000:01:00.1, bridge: 0000:00:01.0)]>
Mai 11 16:37:35 nk-zbook nvx[907]: 2025-05-11 16:37:35,097 [INFO] turn on device NVIDIA Corporation - GP107GLM [Quadro P1000 Mobile] - 0000:01:00.0 - 0000:00:01.0
Mai 11 16:37:35 nk-zbook nvx[907]: 2025-05-11 16:37:35,098 [INFO] turn on device NVIDIA Corporation - GP107GL High Definition Audio Controller - 0000:01:00.1 - 0000:00:01.0
Mai 11 16:37:35 nk-zbook nvx[907]: 2025-05-11 16:37:35,098 [INFO] load modules
Mai 11 16:37:35 nk-zbook nvx[907]: 2025-05-11 16:37:35,098 [INFO] load module nvidia_modeset
Mai 11 16:37:35 nk-zbook kernel: nvidia: loading out-of-tree module taints kernel.
Mai 11 16:37:35 nk-zbook kernel: nvidia: module license ‘NVIDIA’ taints kernel.
Mai 11 16:37:35 nk-zbook kernel: Disabling lock debugging due to kernel taint
Mai 11 16:37:35 nk-zbook kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Mai 11 16:37:35 nk-zbook kernel: nvidia: module license taints kernel.
Mai 11 16:37:36 nk-zbook kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Mai 11 16:37:36 nk-zbook kernel: nvidia 0000:01:00.0: enabling device (0000 → 0003)
Mai 11 16:37:36 nk-zbook kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
Mai 11 16:37:36 nk-zbook kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 570.133.07 Fri Mar 14 13:12:07 UTC 2025
Mai 11 16:37:36 nk-zbook kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Mai 11 16:37:36 nk-zbook nvx[907]: 2025-05-11 16:37:36,297 [INFO] result: 0 b’’
Mai 11 16:37:36 nk-zbook nvx[907]: 2025-05-11 16:37:36,298 [INFO] load module nvidia_uvm
Mai 11 16:37:36 nk-zbook kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 570.133.07 Fri Mar 14 12:42:57 UTC 2025
Mai 11 16:37:36 nk-zbook nvx[907]: 2025-05-11 16:37:36,554 [INFO] result: 0 b’’
Mai 11 16:37:36 nk-zbook nvx[907]: 2025-05-11 16:37:36,554 [INFO] load module nvidia_drm
Mai 11 16:37:36 nk-zbook kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Mai 11 16:37:37 nk-zbook kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
Mai 11 16:37:37 nk-zbook gnome-shell[2349]: libEGL warning: egl: failed to create dri2 screen
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,236 [INFO] result: 0 b’’
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,236 [INFO] load module nvidia
Mai 11 16:37:37 nk-zbook kernel: nvidia 0000:01:00.0: [drm] fb1: nvidia-drmdrmfb frame buffer device
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,244 [INFO] result: 0 b’’
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,245 [INFO] load module nouveau
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,299 [INFO] result: 0 b’’
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,299 [INFO] pci devices
Mai 11 16:37:37 nk-zbook gnome-shell[2349]: Device ‘/dev/dri/card0’ prefers shadow buffer
Mai 11 16:37:37 nk-zbook gnome-shell[2349]: Added device ‘/dev/dri/card0’ (nvidia-drm) using atomic mode setting.
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,713 [INFO] devices: [Config(name: NVIDIA Corporation - GP107GLM [Quadro P1000 Mobile], bus: 0000:01:00.0, bridge: 0000:00:01.0), Config(name: NVIDIA Corporation - GP107GLM [Quadro P1000 Mobile], bus: 0000:01:00.0, bridge: 0000:00:01.0), Config(name: NVIDIA Corporation - GP107GL High Definition Audio Controller, bus: 0000:01:00.1, bridge: 0000:00:01.0)]
Mai 11 16:37:37 nk-zbook nvx[907]: 2025-05-11 16:37:37,713 [INFO] status: on
Mai 11 16:37:37 nk-zbook gnome-shell[2349]: Failed to initialize accelerated iGPU/dGPU framebuffer sharing: No EGL display
Mai 11 16:37:37 nk-zbook gnome-shell[2349]: Created gbm renderer for ‘/dev/dri/card0’
Mai 11 16:37:37 nk-zbook gnome-shell[2349]: Failed to hotplug secondary gpu ‘/dev/dri/renderD129’: GDBus.Error:System.Error.ENODEV: No such device
nvidia-bug-report.log.gz (2.8 MB)
