• Hardware Platform (Jetson / GPU): Tesla T4
• DeepStream Version: 5.1
• TensorRT Version: 7.2.1
• NVIDIA GPU Driver Version (valid for GPU only): 455.32
• Issue Type( questions, new requirements, bugs): Bug
Normally, when i run deepstream-app I have no issue viewing rtsp stream with vlc. But recently there is some changes in the server’s network and I can not view the rtsp stream anymore.
My config (The app run perfectly)
deepstream-app -c config.txt
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://admin:admin123@172.16.30.50:554
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=9093
udp-port=5499
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=30
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[tests]
file-loop=0
I tried to debug the application and here is the output log when vlc connect to the stream:
0:01:02.089612404 20276 0x2cf98a0 WARN rtspmedia rtsp-media.c:2994:wait_preroll: failed to preroll pipeline
0:01:02.089682277 20276 0x2cf98a0 WARN rtspmedia rtsp-media.c:3298:gst_rtsp_media_prepare: failed to preroll pipeline
0:01:02.090997241 20276 0x2cf98a0 ERROR rtspclient rtsp-client.c:1054:find_media: client 0x45277860: can't prepare media
0:01:02.091296503 20276 0x2cf98a0 ERROR rtspclient rtsp-client.c:2910:handle_describe_request: client 0x45277860: no media
vlc log:
[00007f38484cc2a0] live555 demux debug: connection timeout
[00007f38484cc2a0] live555 demux error: Failed to connect with rtsp://localhost:9093/ds-test
[00007f38484cc2a0] main demux debug: no access_demux modules matched
[00007f38484cfca0] main stream debug: creating access: rtsp://localhost:9093/ds-test
[00007f38484cfca0] main stream debug: looking for access module matching "rtsp": 28 candidates
[00007f38484cfca0] satip stream debug: try to open 'rtsp://localhost:9093/ds-test'
[00007f38484cfca0] satip stream debug: connect to host 'localhost'
[00007f38484cfca0] main stream debug: net: connecting to localhost port 9093
[00007f38484cfca0] main stream debug: connection succeeded (socket = 6)
[00007f38484cfca0] main stream debug: net: opening 0.0.0.0 datagram port 9170
[00007f38484cfca0] main stream debug: net: opening 0.0.0.0 datagram port 9171
^C[000055805267a2a0] main libvlc debug: exiting
[000055805267a2a0] main libvlc debug: removing all interfaces
[000055805276c190] [cli] main interface debug: removing module "lua"
[000055805276c190] [cli] lua interface error: Error loading script /usr/lib/x86_64-linux-gnu/vlc/lua/intf/cli.luac: lua/intf/modules/host.lua:289: Interrupted.
[000055805275add0] main interface debug: removing module "hotkeys"
[00005580526763a0] main playlist debug: destroying
[00005580526763a0] main playlist debug: deactivating the playlist
[00005580526763a0] main playlist debug: incoming request - stopping current input
[00007f38484cfca0] satip stream error: read error: Resource temporarily unavailable
[00007f38484cfca0] satip stream error: Failed to setup RTSP session
[00007f38484cfca0] access_realrtsp stream error: cannot connect to localhost:9093
[00007f38484cfca0] main stream error: Connection failed
[00007f38484cfca0] main stream error: VLC could not connect to "localhost:9093".
[00007f38484cfca0] access_realrtsp stream debug: could not connect to: localhost:9093/ds-test
[00007f38484cfca0] main stream debug: no access modules matched
[00005580526763a0] main playlist debug: dead input
[00007f3848000f60] main stream output debug: destroying useless sout
[00007f38484c9f50] main stream out debug: destroying chain... (name=transcode)
[00007f38484c9f50] main stream out debug: removing module "stream_out_transcode"
[00007f38484c9f50] main stream out debug: destroying chain done
[00007f3848001770] main stream out debug: destroying chain... (name=standard)
[00007f3848001770] main stream out debug: removing module "stream_out_standard"
[00007f38484c96f0] main mux debug: removing module "mpjpeg"
[00007f38484c96f0] mpjpeg mux debug: Multipart jpeg muxer closed
[00007f3848002be0] main access out debug: removing module "http"
[00007f3848003a40] main http host debug: HTTP host removed
[00007f3848002be0] http access out debug: Close
