I have a V4l2 driver working on TX2 (L4T-32.2).
I’m having a strange capture issue when loading the V4l2 sensor driver as Kernel module.
If I compile the driver as built-in, I’m able to capture using different resolutions:
v4l2-ctl -d /dev/video4 --set-fmt-video=width=3840,height=2160,pixelformat=BA10 --set-ctrl bypass_mode=0 --stream-mmap
v4l2-ctl -d /dev/video4 --set-fmt-video=width=1280,height=720,pixelformat=BA10 --set-ctrl bypass_mode=0 --stream-mmap
If I compile the driver as Kernel Module, I’m able to capture using lower resolutions only. Capture errors appears for high resolutions.
Not Working:
This is the trace that I get:
kworker/4:0-36 [004] .... 612.692605: rtcpu_vinotify_event: tstamp:19269659676 tag:CSIMUX_STREAM channel:0xff frame:48 vi_tstamp:19269659297 data:0x00000100
kworker/4:0-36 [004] .... 612.748571: rtcpu_vinotify_event: tstamp:19271510326 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:19271509784 data:0x00000001
kworker/4:0-36 [004] .... 612.748580: rtcpu_vinotify_event: tstamp:19271510550 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:19271509788 data:0x00000000
kworker/4:0-36 [004] .... 612.748583: rtcpu_vinotify_event: tstamp:19271515541 tag:CHANSEL_LOAD_FRAMED channel:0xc4 frame:0 vi_tstamp:19271515161 data:0x08000000
kworker/4:0-36 [004] .... 612.748586: rtcpu_vinotify_event: tstamp:19271671186 tag:CHANSEL_FAULT channel:0x00 frame:0 vi_tstamp:19271670801 data:0x000d0200
kworker/4:0-36 [004] .... 612.748588: rtcpu_vinotify_event: tstamp:19271671684 tag:CHANSEL_LOAD_FRAMED channel:0xc4 frame:0 vi_tstamp:19271671337 data:0x08000000
kworker/4:0-36 [004] .... 612.748590: rtcpu_vinotify_event: tstamp:19271672956 tag:CHANSEL_FAULT_FE channel:0xc4 frame:0 vi_tstamp:19271672356 data:0x00000001
kworker/4:0-36 [004] .... 612.748592: rtcpu_vinotify_event: tstamp:19271673146 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:19271672360 data:0x00000000
I verified that the camera is streaming correctly, however it seems that the problem is in the TX2 side.
I wonder if anyone has seen this issue before?
Thanks,
-Enrique
