I am working with a jetson tx2 on an auvidea J120 carrier board. I am currently customizing the ov5693 driver and the device tree for it to work with our own sensor. I did the necessary in the device tree to have the following format : MEDIA_BUS_FMT_UYVY8_1X16.
mode_type = “yuv”;
pixel_phase = “uyvy”;
csi_pixel_bit_depth = “16”;
I get the following from v4l2-ctl --list-formats-ext:
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'UYVY' (UYVY 4:2:2)
Size: Discrete 2592x1944
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 2592x1458
Interval: Discrete 0.008s (120.000 fps)
Size: Discrete 1920x1080
I already commented out the UYVY format I am not using in the vi4_formats.h to avoid duplicate format 59565955 (UYVY) in test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS.
When I do v4l2-compliance -d /dev/video0 I have the following errors :
v4l2-compliance SHA: not available, 64 bits
Compliance test for tegra-video device /dev/video0:
Driver Info:
Driver name : tegra-video
Card type : vi-output, ov5693 7-004e
Bus info : platform:15700000.vi:4
Driver version : 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-vi4
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 0.1.0
Hardware revision: 0x00000003 (3)
Driver version : 0.0.0
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, ov5693 7-004e
Function : V4L2 I/O
Pad 0x01000007 : Sink
Link 0x0200000c: from remote pad 0x1000003 of entity '150c0000.nvcsi--1': Data, Enabled
Required ioctls:
test MC information (see 'Media Driver Info' above): OK
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second /dev/video0 open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Control ioctls (Input 0):
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 21
Format ioctls (Input 0):
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1280): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
warn: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1087): S_FMT cannot handle an invalid pixelformat.
warn: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1088): This may or may not be a problem. For more information see:
warn: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1089): http://www.mail-archive.com/linux-media@vger.kernel.org/msg56550.html
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1103): S_FMT cannot handle an invalid format
test VIDIOC_S_FMT: FAIL
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1692): doioctl(node, VIDIOC_S_FMT, &fmt)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1789): doioctl(node, VIDIOC_S_FMT, &fmt)
test Scaling: FAIL
Codec ioctls (Input 0):
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls (Input 0):
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-buffers.cpp(715): q.create_bufs(node, 1, &fmt) != EINVAL
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
test VIDIOC_EXPBUF: OK
test Requests: OK (Not Supported)
Total for tegra-video device /dev/video0: 45, Succeeded: 41, Failed: 4, Warnings: 3
Can you help me understand where errors are coming from ?
Thank you for your help
The root cause by the duplicate resolution report. That’s the defeat of current camera framework design.
Hi Shane, thank you for your reply. Just for clarification I am using l4t R32.4.4. I’ve removed the duplicate resolutions. Now I have :
Type: Video Capture
But I still have 2 errors from compliance test as you can see below:
Driver Info:
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Serial :
Bus info :
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Required ioctls:
Debug ioctls:
Input ioctls:
Output ioctls:
test VIDIOC_S_FMT: OK
test Scaling: OK (Not Supported)
Total for tegra-video device /dev/video0: 45, Succeeded: 43, Failed: 2, Warnings: 0
Do you know why VIDIOC_G/S_PARM and VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF could fail ?
For VIDIOC_G/S_PARM, I don’t think it is a framerate problem because we manage it by ourself with the sensor.
The reference sensor driver imx274have the same failed I think you can ignore it.
Format ioctls:
fail: v4l2-test-formats.cpp(1184): ret && node->has_frmintervals
fail: v4l2-test-formats.cpp(425): expected EINVAL, but got 16 when getting format for buftype 1
fail: v4l2-test-formats.cpp(1018): Video Capture is valid, but no S_FMT was implemented
fail: v4l2-test-formats.cpp(1550): doioctl(node, VIDIOC_S_FMT, &fmt)
fail: v4l2-test-formats.cpp(1647): doioctl(node, VIDIOC_S_FMT, &fmt)
test Scaling: FAIL
Codec ioctls:
Buffer ioctls:
fail: v4l2-test-buffers.cpp(446): ret && ret != EINVAL
fail: v4l2-test-buffers.cpp(573): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_MMAP support is missing or malfunctioning.
fail: v4l2-test-buffers.cpp(574): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_MMAP support is missing, probably due to earlier failing format tests.
test VIDIOC_EXPBUF: OK (Not Supported)
