V4l2-compilance errors (duplicate format 59565955 (UYVY))
I’m writing a sensor driver for an HDMI to CSI-2 converter chip (modified from IMX274 sensor driver).
Linux for Tegra BSP version is R32.3.1
But v4l2-compliance command reported some failures:
Format ioctls:
fail: v4l2-test-formats.cpp(273): duplicate format 59565955 (UYVY)
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
fail: v4l2-test-formats.cpp(1184): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
Total: 43, Succeeded: 41, Failed: 2, Warnings: 0
The output of “v4l2-ctl --list-formats-ext” is
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘UYVY’
Size: Discrete 3840x2160
Interval: Discrete 0.017s (60.000 fps)
Index : 1
Pixel Format: ‘NV16’
Index : 2
It’s curious that there are two more formats and the first one is the same as the third one.
I only defined one UYVY format in the device true:
active_w = “3840”;
active_h = “2160”;
mode_type = “yuv”;
pixel_phase = “uyvy”;
csi_pixel_bit_depth = “16”;
readout_orientation = “0”;
line_length = “3840”;
Anything I can do to fix these failures??
Can you post your device tree and sensor driver to check.
Hi ShaneCCC,
I attached dts file and sensor driver c file here.
The sensor driver is modified from imx274 and I mostly removed i2c related operations.
We connect the hdmi to csi-2 converter chip through data lanes 0/1/2/3 and the first clock lane.
No other i2c / gpio /rst /power related pins are used. CSI-2 output is UYVY format.
In addition to previously mentioned v4l2-compliance and “v4l2-ctl --list-formats-ext” issues, “v4l2-ctl --stream-mmap” also failed.
The kernel dmesg said that there was no reply from camera processor (2500ms timeout) and then VI tried to recover the error.
VI recoveries sometimes success and sometimes fail. If failed, there will be kernel call stack displayed and reboot will hang.
Please check my attached files and let me know how to debug and resolve these issues.
Thanks in advance
/* vim: set noexpandtab: */
#include "common/tegra194-p2888-0001-p2822-0000-common.dtsi"
#define CAM0_RST TEGRA194_MAIN_GPIO(H, 4)
#define CAM1_RST TEGRA194_MAIN_GPIO(T, 6)
	host1x {
		vi@15c10000 {
			num-channels = <2>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					status = "okay";
					lt6911_vi_in0: endpoint {
						status = "okay";
						port-index = <0>;
						bus-width = <4>;
						remote-endpoint = <&lt6911_csi_out0>;
				port@1 {
					reg = <1>;
					status = "okay";
					lt6911_vi_in1: endpoint {
						status = "okay";
						port-index = <2>;
						bus-width = <4>;
						remote-endpoint = <&lt6911_csi_out1>;
		nvcsi@15a00000 {
			num-channels = <2>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				status = "okay";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						status = "okay";
						lt6911_csi_in0: endpoint@0 {
							status = "okay";
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&lt6911_out0>;
					port@1 {
						reg = <1>;
						status = "okay";
						lt6911_csi_out0: endpoint@1 {
							status = "okay";
							remote-endpoint = <&lt6911_vi_in0>;
			channel@1 {
				reg = <1>;
				status = "okay";
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						status = "okay";
						lt6911_csi_in1: endpoint@2 {
							status = "okay";
							port-index = <2>;
							bus-width = <4>;
							remote-endpoint = <&lt6911_out1>;
					port@1 {
						reg = <1>;
						status = "okay";
						lt6911_csi_out1: endpoint@3 {
							status = "okay";
							remote-endpoint = <&lt6911_vi_in1>;
	i2c@3180000 {
		lt6911@10 {
			compatible = "lontium,lt6911";
			/* I2C device address */
			reg = <0x10>;
			/* V4L2 device node location */
			devnode = "video0";
			/* Physical dimensions of sensor */
			physical_w = "3.674";
			physical_h = "2.738";
			sensor_model = "lt6911";
			/* Define any required hw resources needed by driver */
			/* ie. clocks, io pins, power sources */
			avdd-reg = "vana";
			iovdd-reg = "vif";
			dvdd-reg = "vdig";
			/* Defines number of frames to be dropped by driver internally after applying */
			/* sensor crop settings. Some sensors send corrupt frames after applying */
			/* crop co-ordinates */
			/*post_crop_frame_drop = "0";*/
			/* if true, delay gain setting by one frame to be in sync with exposure */
			delayed_gain = "true";
			clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
					 <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
			clock-names = "extperiph1", "pllp_grtba";
			mclk = "extperiph1";
			status = "okay";
			reset-gpios = <&tegra_main_gpio CAM1_RST GPIO_ACTIVE_HIGH>;
			vana-supply = <&p2822_avdd_cam_2v8>;
			vif-supply = <&p2822_vdd_1v8_cvb>;
			/* rework: also enables VDD_1V_SATA_PHY (1.18 V) */
			vdig-supply = <&p2822_vdd_1v8_cvb>;
			mode0 {
				mclk_khz = "24000";
				num_lanes = "4";
				phy_mode = "DPHY";
				discontinuous_clk = "yes";
				dpcm_enable = "false";
				cil_settletime = "0";
				active_w = "3840";
				active_h = "2160";
				mode_type = "yuv";
				pixel_phase = "uyvy";
				csi_pixel_bit_depth = "16";
				readout_orientation = "0";
				line_length = "3840";
				inherent_gain = "1";
				mclk_multiplier = "24";
				pix_clk_hz = "576000000";
				gain_factor = "1000000";
				min_gain_val = "1000000";
				max_gain_val = "44400000";
				step_gain_val = "1";
				default_gain = "1000000";
				min_hdr_ratio = "1";
				max_hdr_ratio = "1";
				framerate_factor = "1000000";
				min_framerate = "1500000";
				max_framerate = "60000000";
				step_framerate = "1";
				default_framerate= "60000000";
				exposure_factor = "1000000";
				min_exp_time = "44";
				max_exp_time = "478696";
				step_exp_time = "1";
				default_exp_time = "16667";/* us */
				embedded_metadata_height = "0";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					lt6911_out0: endpoint {
						port-index = <0>;
						bus-width = <4>;
						remote-endpoint = <&lt6911_csi_in0>;
		lt6911@11 {
			reg = <0x11>;
			devnode ="video1";
			avdd-reg = "vana";
			iovdd-reg = "vif";
			dvdd-reg = "vdig";
			status = "okay";
			mode0 {
				mclk_khz = "24000";
				num_lanes = "4";
				tegra_sinterface = "serial_b";
				phy_mode = "DPHY";
				active_w = "3840";
				active_h = "2160";
				mode_type = "yuv";
				pixel_phase = "yuyv";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					lt6911_out1: endpoint {
						port-index = <2>;
						bus-width = <4>;
						remote-endpoint = <&lt6911_csi_in1>;
	gpio@2200000 {
		camera-control-output-high {
			status = "okay";
			gpio-hog;
			gpios = <CAM1_RST 0>;
			output-high;
			label = "cam1-rst";
#if 0
		camera-control-input {
			status = "okay";
			gpio-hog;
			gpios = <TC358840_INT 0>;
			input;
			label = "cam-input-p2";
#endif
	tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <8>;
		max_lane_speed = <2500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <750000>;
		isp_peak_byte_per_pixel = <2>;
		isp_bw_margin_pct = <25>;
		modules {
			module0 {
				badge = "lt6911_topleft_a";
				position = "topleft";
				status = "okay";
				orientation = "1";
				drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "lt6911 2-0010";
					status = "okay";
					proc-device-tree = "/proc/device-tree/i2c@3180000/lt6911@10";
			module1 {
				badge = "lt6911_topright_a";
				position = "topright";
				status = "okay";
				orientation = "1";
				drivernode0 {
					devname = "lt6911 2-0011";
					status = "okay";
					proc-device-tree = "/proc/device-tree/i2c@3180000/lt6911@11";
 * imx274.c - imx274 sensor driver
 * Copyright (c) 2015-2019, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify it
 * under the terms and conditions of the GNU General Public License,
 * version 2, as published by the Free Software Foundation.
 * This program is distributed in the hope it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <linux/gpio.h>
#include <linux/module.h>
#include <linux/debugfs.h>
#include <linux/seq_file.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <media/tegra_v4l2_camera.h>
#include <media/tegracam_core.h>
#include <media/imx274.h>
#define imx274_reg struct reg_8
enum {
	IMX274_MODE_3840X2160,
	IMX274_MODE_1920X1080,
	IMX274_MODE_3840X2160_DOL_30FPS,
	IMX274_MODE_1920X1080_DOL_60FPS,
static const int imx274_2160p_fr[] = {
        60,
	//30,
static const int imx274_1080p_fr[] = {
	60,
        //30,
static const struct camera_common_frmfmt imx274_frmfmt[] = {
	{{3840, 2160}, imx274_2160p_fr, 1, 0, IMX274_MODE_3840X2160},
	//{{1920, 1080}, imx274_1080p_fr, 1, 0, IMX274_MODE_1920X1080},
#define IMX274_GAIN_FACTOR		1000000
#define IMX274_MIN_GAIN			(1 * IMX274_GAIN_FACTOR)
#define IMX274_MAX_ANALOG_GAIN	(IMX274_MIN_GAIN * 111 / 5)
#define IMX274_MAX_DIGITAL_GAIN	64
#define IMX274_MAX_GAIN	(IMX274_MAX_ANALOG_GAIN * IMX274_MAX_DIGITAL_GAIN)
#define IMX274_SENSOR_INTERNAL_CLK_FREQ	72000000
#define IMX274_4K_MODE_HMAX			263
#define IMX274_4K_MODE_MIN_VMAX		4550
#define IMX274_4K_MODE_OFFSET		112
#define IMX274_DOL_MODE_CLOCKS_OFFSET	112
#define IMX274_DOL_4K_MODE_HMAX	1052
#define IMX274_DOL_4K_MODE_MIN_VMAX	2284
#define IMX274_DOL_4K_MODE_DEFAULT_RHS1	50
#define IMX274_DOL_4K_MIN_SHR_DOL1	6
#define IMX274_DOL_1080P_MODE_HMAX	1040
#define IMX274_DOL_1080P_MODE_MIN_VMAX	1155
#define IMX274_DOL_1080P_MODE_DEFAULT_RHS1	38
#define IMX274_DOL_1080P_MIN_SHR_DOL1	4
#define IMX274_1080P_MODE_HMAX			260
#define IMX274_1080P_MODE_MIN_VMAX		4620
#define IMX274_1080P_MODE_OFFSET		112
#define IMX274_EEPROM_ADDRESS		0x57
#define IMX274_EEPROM_SIZE			256
#define IMX274_EEPROM_STR_SIZE		(IMX274_EEPROM_SIZE * 2)
#define IMX274_EEPROM_BLOCK_SIZE	(1 << 8)
#define IMX274_EEPROM_NUM_BLOCKS \
	(IMX274_EEPROM_SIZE / IMX274_EEPROM_BLOCK_SIZE)
#define IMX274_FUSE_ID_START_ADDR	91
#define IMX274_FUSE_ID_SIZE		8
#define IMX274_FUSE_ID_STR_SIZE		(IMX274_FUSE_ID_SIZE * 2)
static const struct of_device_id lt6911_of_match[] = {
	{ .compatible = "lontium,lt6911", },
MODULE_DEVICE_TABLE(of, lt6911_of_match);
static const u32 ctrl_cid_list[] = {
#if 1
	TEGRA_CAMERA_CID_GAIN,
	TEGRA_CAMERA_CID_EXPOSURE,
	TEGRA_CAMERA_CID_EXPOSURE_SHORT,
#endif
	TEGRA_CAMERA_CID_FRAME_RATE,
#if 1
	TEGRA_CAMERA_CID_GROUP_HOLD,
	TEGRA_CAMERA_CID_HDR_EN,
	TEGRA_CAMERA_CID_FUSE_ID,
#endif
struct imx274 {
	struct i2c_client		*i2c_client;
	struct v4l2_subdev		*subdev;
	const char			*devname;
	struct dentry			*debugfs_dir;
	struct mutex			streaming_lock;
	bool				streaming;
	struct camera_common_eeprom_data eeprom[IMX274_EEPROM_NUM_BLOCKS];
	u8				eeprom_buf[IMX274_EEPROM_STR_SIZE];
	u8				fuse_id[IMX274_FUSE_ID_SIZE];
	u32				frame_length;
	u32				vmax;
	s64				last_exposure_long;
	s64				last_exposure_short;
	s32				group_hold_prev;
	bool				group_hold_en;
	struct regmap			*regmap;
	struct camera_common_data	*s_data;
	struct tegracam_device		*tc_dev;
static const struct regmap_config sensor_regmap_config = {
	.reg_bits = 16,
	.val_bits = 8,
	.cache_type = REGCACHE_RBTREE,
static inline void imx274_get_vmax_regs(imx274_reg *regs,
				u32 vmax)
	regs->addr = IMX274_VMAX_ADDR_MSB;
	regs->val = (vmax >> 16) & 0x0f;
	(regs + 1)->addr = IMX274_VMAX_ADDR_MID;
	(regs + 1)->val = (vmax >> 8) & 0xff;
	(regs + 2)->addr = IMX274_VMAX_ADDR_LSB;
	(regs + 2)->val = (vmax) & 0xff;
static inline void imx274_get_shr_regs(imx274_reg *regs,
				u16 shr)
	regs->addr = IMX274_SHR_ADDR_MSB;
	regs->val = (shr >> 8) & 0xff;
	(regs + 1)->addr = IMX274_SHR_ADDR_LSB;
	(regs + 1)->val = (shr) & 0xff;
static inline void imx274_get_shr_dol1_regs(imx274_reg *regs,
				u16 shr)
	regs->addr = IMX274_SHR_DOL1_ADDR_MSB;
	(regs + 1)->addr = IMX274_SHR_DOL1_ADDR_LSB;
static inline void imx274_get_shr_dol2_regs(imx274_reg *regs,
				u16 shr)
	regs->addr = IMX274_SHR_DOL2_ADDR_MSB;
	(regs + 1)->addr = IMX274_SHR_DOL2_ADDR_LSB;
static inline void imx274_get_gain_reg(imx274_reg *regs,
				u16 gain)
	regs->addr = IMX274_ANALOG_GAIN_ADDR_MSB;
	regs->val = (gain >> 8) & 0xff;
	(regs + 1)->addr = IMX274_ANALOG_GAIN_ADDR_LSB;
	(regs + 1)->val = (gain) & 0xff;
static inline int imx274_read_reg(struct camera_common_data *s_data,
				u16 addr, u8 *val)
	int err = 0;
	u32 reg_val = 0;
	err = regmap_read(s_data->regmap, addr, &reg_val);
	*val = reg_val & 0xFF;
	return err;
static int imx274_write_reg(struct camera_common_data *s_data, u16 addr, u8 val)
	int err;
	struct device *dev = s_data->dev;
	err = regmap_write(s_data->regmap, addr, val);
	if (err)
		dev_err(dev, "%s: i2c write failed, %x = %x\n",
			__func__, addr, val);
	return err;
static int imx274_set_gain(struct tegracam_device *tc_dev, s64 val);
static int imx274_set_frame_rate(struct tegracam_device *tc_dev, s64 val);
static int imx274_set_exposure(struct tegracam_device *tc_dev, s64 val);
static int imx274_set_exposure_shr(struct tegracam_device *tc_dev, s64 val);
static int imx274_set_exposure_shr_dol_short(struct tegracam_device *tc_dev,
			s64 val);
static int imx274_set_exposure_shr_dol_long(struct tegracam_device *tc_dev,
			s64 val);
static bool imx274_in_dol_mode(const struct imx274 *priv);
static int imx274_set_group_hold(struct tegracam_device *tc_dev, bool val)
	struct camera_common_data *s_data = tc_dev->s_data;
	struct imx274 *priv = (struct imx274 *)tc_dev->priv;
	struct device *dev = tc_dev->dev;
	int err;
	priv->group_hold_prev = val;
	return 0;
	const struct sensor_mode_properties *mode =
		&s_data->sensor_props.sensor_modes[s_data->mode];
	imx274_reg reg_list[2];
	int err;
	int i = 0;
	u32 again;
	u8 dgain;
	u16 reg_again;
	u8 reg_dgain;
	dev_dbg(dev, "%s: val: %lld\n", __func__, val);
	if (val < IMX274_MIN_GAIN)
		val = IMX274_MIN_GAIN;
	else if (val > IMX274_MAX_GAIN)
		val = IMX274_MAX_GAIN;
	if  (val > (IMX274_MAX_ANALOG_GAIN * 32)) {
		dgain = 64;
		reg_dgain = 0x06;
	} else if  (val > (IMX274_MAX_ANALOG_GAIN * 16)) {
		dgain = 32;
		reg_dgain = 0x05;
	} else if  (val > (IMX274_MAX_ANALOG_GAIN * 8)) {
		dgain = 16;
		reg_dgain = 0x04;
	} else if  (val > (IMX274_MAX_ANALOG_GAIN * 4)) {
		dgain = 8;
		reg_dgain = 0x03;
	} else if  (val > (IMX274_MAX_ANALOG_GAIN * 2)) {
		dgain = 4;
		reg_dgain = 0x02;
	} else if (val > (IMX274_MAX_ANALOG_GAIN)) {
		dgain = 2;
		reg_dgain = 0x01;
	} else  {
		dgain = 1;
		reg_dgain = 0x00;
	reg_again = 2048 -
		(2048 * dgain * mode->control_properties.gain_factor / val);
	if (reg_again > 1957)
		reg_again = 1957;
	again = val / (dgain * mode->control_properties.gain_factor);
	imx274_get_gain_reg(reg_list, reg_again);
	dev_dbg(dev, "%s: val:%lld, gain:%lld, again:(%d, %d), dgain:(%d, %d)\n",
			__func__,
			val,
			val / IMX274_MIN_GAIN,
			again,
			reg_again,
			dgain,
			reg_dgain);
	/* writing analog gain */
	for (i = 0; i < 2; i++) {
		err = imx274_write_reg(priv->s_data, reg_list[i].addr,
			 reg_list[i].val);
		if (err)
			goto fail;
	/* writing digital gain */
	err = imx274_write_reg(priv->s_data, IMX274_DIGITAL_GAIN_ADDR,
				reg_dgain);
	if (err)
		goto fail;
	return 0;
fail:
	dev_err(dev, "%s: GAIN control error\n", __func__);
	return err;
static
int imx274_set_exposure_shr_dol_short(struct tegracam_device *tc_dev, s64 val)
	struct v4l2_control control;
	int hdr_en;
	u16 rhs1, hmax;
	s32 shr_dol1, min_shr;
	int err;
	int i = 0;
	u64 freq = IMX274_SENSOR_INTERNAL_CLK_FREQ;
	control.id = TEGRA_CAMERA_CID_HDR_EN;
	err = camera_common_g_ctrl(priv->s_data, &control);
	if (err < 0) {
		dev_err(dev, "could not find device ctrl.\n");
		return err;
	hdr_en = switch_ctrl_qmenu[control.value];
	if (hdr_en != SWITCH_ON)  {
		dev_dbg(dev, "%s: SHR DOL1 is ignored for non-HDR mode\n",
			__func__);
		return 0;
	if (s_data->mode == IMX274_MODE_3840X2160_DOL_30FPS) {
		rhs1 = IMX274_DOL_4K_MODE_DEFAULT_RHS1;
		min_shr = IMX274_DOL_4K_MIN_SHR_DOL1;
		hmax = IMX274_DOL_4K_MODE_HMAX;
	} else if (s_data->mode == IMX274_MODE_1920X1080_DOL_60FPS) {
		rhs1 = IMX274_DOL_1080P_MODE_DEFAULT_RHS1;
		min_shr = IMX274_DOL_1080P_MIN_SHR_DOL1;
		hmax = IMX274_DOL_1080P_MODE_HMAX;
	} else {
		dev_err(dev, "%s: error, invalid dol mode\n", __func__);
		err = -EINVAL;
		goto fail;
	priv->last_exposure_short = val;
	shr_dol1 = rhs1 -
		(val * freq /
		mode->control_properties.exposure_factor  -
		IMX274_DOL_MODE_CLOCKS_OFFSET) /
		hmax - 1 / 4;
	if (shr_dol1 <= min_shr)
		shr_dol1 = min_shr;
	if (shr_dol1 > rhs1 - 2)
		shr_dol1 = rhs1 - 2;
	dev_dbg(dev,
		 "%s: et:%d, shr_dol1:%d, rhs1:%d, Pclk:%lld, LL:%d, HMAX:%d\n",
		 __func__,
		(int)(val * 1000000 / mode->control_properties.exposure_factor),
		shr_dol1,
		rhs1,
		mode->signal_properties.pixel_clock.val,
		mode->image_properties.line_length,
		hmax);
	imx274_get_shr_dol1_regs(reg_list, (u16)shr_dol1);
			 reg_list[i].val);
		if (err)
			goto fail;
	return 0;
fail:
	dev_err(dev, "%s: EXPOSURE short control is not set\n", __func__);
	return err;
static
int imx274_set_exposure_shr_dol_long(struct tegracam_device *tc_dev, s64 val)
	u16 hmax, rhs1;
	s32 shr_dol2, min_shr;
	int err;
	int i = 0;
	} else {
		err = -EINVAL;
		goto fail;
	priv->last_exposure_long = val;
	shr_dol2 = priv->vmax  -
		(val * freq /
		hmax - 1 / 4;
	if (shr_dol2 < rhs1 + min_shr)
		shr_dol2 = rhs1 + min_shr;
	if (shr_dol2 > priv->vmax - 4)
		shr_dol2 = priv->vmax - 4;
	dev_dbg(dev,
		 "%s: et:%d, shr_dol2:%d, vmax:%d, Pclk:%lld, LL:%d, HMAX:%d\n",
		 __func__,
		shr_dol2,
		priv->vmax,
		hmax);
	imx274_get_shr_dol2_regs(reg_list, (u16)shr_dol2);
			 reg_list[i].val);
		if (err)
			goto fail;
	return 0;
fail:
	dev_err(dev, "%s: EXPOSURE_SHORT control error\n", __func__);
	return err;
	const struct camera_common_data *s_data = priv->s_data;
	switch (s_data->mode) {
	case IMX274_MODE_3840X2160_DOL_30FPS:
	case IMX274_MODE_1920X1080_DOL_60FPS:
		return true;
	default:
		return false;
	int hdr_en;
	imx274_reg reg_list[3];
	int err;
	int i = 0;
	u8 svr;
	imx274_read_reg(priv->s_data, IMX274_SVR_ADDR, &svr);
		priv->vmax = (u32)(freq *
				mode->control_properties.framerate_factor /
				(val *
				IMX274_DOL_4K_MODE_HMAX));
		if (priv->vmax < IMX274_DOL_4K_MODE_MIN_VMAX)
			priv->vmax = IMX274_DOL_4K_MODE_MIN_VMAX;
				(val *
				IMX274_DOL_1080P_MODE_HMAX));
		if (priv->vmax < IMX274_DOL_1080P_MODE_MIN_VMAX)
			priv->vmax = IMX274_DOL_1080P_MODE_MIN_VMAX;
	} else if (s_data->mode == IMX274_MODE_1920X1080) {
				(val *
				IMX274_1080P_MODE_HMAX));
		if (priv->vmax < IMX274_1080P_MODE_MIN_VMAX)
			priv->vmax = IMX274_1080P_MODE_MIN_VMAX;
	} else {
				(val *
				IMX274_4K_MODE_HMAX));
		if (priv->vmax < IMX274_4K_MODE_MIN_VMAX)
			priv->vmax = IMX274_4K_MODE_MIN_VMAX;
	imx274_get_vmax_regs(reg_list, priv->vmax);
	for (i = 0; i < 3; i++) {
			 reg_list[i].val);
		if (err)
			goto fail;
	dev_dbg(dev, "%s: PCLK:%lld, LL:%d, fps:%lld, VMAX:%d\n", __func__,
			val / mode->control_properties.framerate_factor,
			priv->vmax);
	if (err < 0) {
		return err;
	if ((hdr_en == SWITCH_ON && imx274_in_dol_mode(priv))
		&& (priv->last_exposure_long != 0)) {
		err = imx274_set_exposure_shr_dol_long(tc_dev,
					priv->last_exposure_long);
		if (err)
			dev_err(dev, "%s: error exposure time dol long\n",
				__func__);
		err = imx274_set_exposure_shr_dol_short(tc_dev,
					priv->last_exposure_short);
		if (err)
			dev_err(dev, "%s: error exposure time dol short\n",
				__func__);
	return 0;
fail:
	dev_err(dev, "%s: FRAME_RATE control error\n", __func__);
	return err;
static
u16 imx274_calculate_exposure_shr(struct tegracam_device *tc_dev, s64 val)
	u8 svr;
	u16 shr;
		shr = priv->vmax  -
			(u32) (val * freq /
			IMX274_1080P_MODE_OFFSET) /
			IMX274_1080P_MODE_HMAX;
		if (shr > priv->vmax - 4)
			shr = priv->vmax - 4;
		if (shr < 8)
			shr = 8;
	} else {
		shr = priv->vmax  -
			(u32) (val  * freq /
			IMX274_4K_MODE_OFFSET) /
			IMX274_4K_MODE_HMAX;
		if (shr < 12)
			shr = 12;
	dev_dbg(dev, "%s: shr: %u vmax: %d\n", __func__, shr, priv->vmax);
	return shr;
	int hdr_en;
	int err;
	if (err < 0) {
		return err;
	if (hdr_en == SWITCH_ON && imx274_in_dol_mode(priv)) {
		err = imx274_set_exposure_shr_dol_long(tc_dev, val);
		if (err)
			dev_err(dev,
			"%s: error exposure time dol long override\n", __func__);
	} else {
		err = imx274_set_exposure_shr(tc_dev, val);
		if (err)
			dev_err(dev,
			"%s: error exposure time SHR override\n", __func__);
	return err;
	int err;
	u16 shr;
	int i = 0;
	shr = imx274_calculate_exposure_shr(tc_dev, val);
	imx274_get_shr_regs(reg_list, shr);
			 reg_list[i].val);
		if (err)
			goto fail;
	return 0;
fail:
	dev_err(dev, "%s: Exposure control error\n", __func__);
	return err;
static int imx274_fill_string_ctrl(struct tegracam_device *tc_dev,
				struct v4l2_ctrl *ctrl)
	int i;
	switch (ctrl->id) {
	case TEGRA_CAMERA_CID_FUSE_ID:
		for (i = 0; i < IMX274_FUSE_ID_SIZE; i++)
			sprintf(&ctrl->p_new.p_char[i*2], "%02x",
				priv->fuse_id[i]);
		break;
	default:
		return -EINVAL;
	ctrl->p_cur.p_char = ctrl->p_new.p_char;
	return 0;
static struct tegracam_ctrl_ops imx274_ctrl_ops = {
	.numctrls = ARRAY_SIZE(ctrl_cid_list),
	.ctrl_cid_list = ctrl_cid_list,
#if 1
	.string_ctrl_size = {0, IMX274_FUSE_ID_STR_SIZE},
	.set_gain = imx274_set_gain,
	.set_exposure = imx274_set_exposure,
	.set_exposure_short = imx274_set_exposure_shr_dol_short,
#endif
	.set_frame_rate = imx274_set_frame_rate,
#if 1
	.set_group_hold = imx274_set_group_hold,
	.fill_string_ctrl = imx274_fill_string_ctrl,
#endif
static int imx274_power_on(struct camera_common_data *s_data)
	int err = 0;
	struct camera_common_power_rail *pw = s_data->power;
	struct camera_common_pdata *pdata = s_data->pdata;
	dev_dbg(dev, "%s: power on\n", __func__);
	if (pdata && pdata->power_on) {
		err = pdata->power_on(pw);
		if (err)
			dev_err(dev, "%s failed.\n", __func__);
		else
			pw->state = SWITCH_ON;
		return err;
	if (pw->reset_gpio)
		gpio_set_value(pw->reset_gpio, 0);
	if (pw->af_gpio)
		gpio_set_value(pw->af_gpio, 1);
	if (pw->pwdn_gpio)
		gpio_set_value(pw->pwdn_gpio, 0);
	usleep_range(10, 20);
	if (pw->dvdd)
		err = regulator_enable(pw->dvdd);
	if (err)
		goto imx274_dvdd_fail;
	if (pw->iovdd)
		err = regulator_enable(pw->iovdd);
	if (err)
		goto imx274_iovdd_fail;
	if (pw->avdd)
		err = regulator_enable(pw->avdd);
	if (err)
		goto imx274_avdd_fail;
	usleep_range(1, 2);
	if (pw->reset_gpio)
		gpio_set_value(pw->reset_gpio, 1);
	if (pw->pwdn_gpio)
		gpio_set_value(pw->pwdn_gpio, 1);
	/* 1.2v input is generated on module board, adds more latency */
	usleep_range(10000, 10010);
	return 0;
imx274_dvdd_fail:
	if (pw->af_gpio)
		gpio_set_value(pw->af_gpio, 0);
imx274_iovdd_fail:
	if (pw->dvdd)
		regulator_disable(pw->dvdd);
imx274_avdd_fail:
	if (pw->iovdd)
		regulator_disable(pw->iovdd);
	return -ENODEV;
static int imx274_power_off(struct camera_common_data *s_data)
	int err = 0;
	dev_dbg(dev, "%s: power off\n", __func__);
	if (pdata && pdata->power_off) {
		err = pdata->power_off(pw);
		if (err) {
			return err;
		goto power_off_done;
	usleep_range(1, 2);
	if (pw->reset_gpio)
	if (pw->af_gpio)
	if (pw->pwdn_gpio)
	usleep_range(1, 2);
	if (pw->avdd)
		regulator_disable(pw->avdd);
	if (pw->iovdd)
	if (pw->dvdd)
power_off_done:
	pw->state = SWITCH_OFF;
	return 0;
static int imx274_power_put(struct tegracam_device *tc_dev)
	if (unlikely(!pw))
		return -EFAULT;
	if (likely(pw->avdd))
		devm_regulator_put(pw->avdd);
	if (likely(pw->dvdd))
		devm_regulator_put(pw->dvdd);
	if (likely(pw->iovdd))
		devm_regulator_put(pw->iovdd);
	pw->avdd = NULL;
	pw->dvdd = NULL;
	pw->iovdd = NULL;
	gpio_free(pw->pwdn_gpio);
	gpio_free(pw->reset_gpio);
	gpio_free(pw->af_gpio);
	return 0;
static int imx274_power_get(struct tegracam_device *tc_dev)
	const char *mclk_name;
	const char *parentclk_name;
	struct clk *parent;
	int err = 0;
	mclk_name = pdata->mclk_name ?
		    pdata->mclk_name : "cam_mclk1";
	pw->mclk = devm_clk_get(dev, mclk_name);
	if (IS_ERR(pw->mclk)) {
		dev_err(dev, "unable to get clock %s\n", mclk_name);
		return PTR_ERR(pw->mclk);
	parentclk_name = pdata->parentclk_name;
	if (parentclk_name) {
		parent = devm_clk_get(dev, parentclk_name);
		if (IS_ERR(parent)) {
			dev_err(dev, "unable to get parent clcok %s",
				parentclk_name);
		} else
			clk_set_parent(pw->mclk, parent);
	/* ananlog 2.7v */
	err |= camera_common_regulator_get(dev,
			&pw->avdd, pdata->regulators.avdd);
	/* IO 1.8v */
			&pw->iovdd, pdata->regulators.iovdd);
	/* digital 1.2v, not all imx274 modules draw this from CVB */
	if (pdata->regulators.dvdd != NULL)
			&pw->dvdd, pdata->regulators.dvdd);
	if (!err) {
		pw->reset_gpio = pdata->reset_gpio;
		pw->af_gpio = pdata->af_gpio;
		pw->pwdn_gpio = pdata->pwdn_gpio;
	return err;
static
struct camera_common_pdata *imx274_parse_dt(struct tegracam_device *tc_dev)
	struct device_node *node = dev->of_node;
	struct camera_common_pdata *board_priv_pdata;
	const struct of_device_id *match;
	int err;
	if (!node)
		return NULL;
	match = of_match_device(lt6911_of_match, dev);
	if (!match) {
		dev_err(dev, "Failed to find matching dt id\n");
		return NULL;
	board_priv_pdata = devm_kzalloc(dev,
			   sizeof(*board_priv_pdata), GFP_KERNEL);
	if (!board_priv_pdata)
		return NULL;
	err = of_property_read_string(node, "mclk",
				      &board_priv_pdata->mclk_name);
	if (err)
		dev_err(dev, "mclk not in DT\n");
	board_priv_pdata->reset_gpio = of_get_named_gpio(node,
			"reset-gpios", 0);
	of_property_read_string(node, "avdd-reg",
			&board_priv_pdata->regulators.avdd);
	of_property_read_string(node, "dvdd-reg",
			&board_priv_pdata->regulators.dvdd);
	of_property_read_string(node, "iovdd-reg",
			&board_priv_pdata->regulators.iovdd);
	board_priv_pdata->has_eeprom =
		of_property_read_bool(node, "has-eeprom");
	of_property_read_u32(node, "fuse_id_start_addr",
		&board_priv_pdata->fuse_id_addr);
	return board_priv_pdata;
static int imx274_set_mode(struct tegracam_device *tc_dev)
	struct imx274 *priv = (struct imx274 *)tegracam_get_privdata(tc_dev);
	int err;
	return 0;
static int imx274_start_streaming(struct tegracam_device *tc_dev)
	int err;
	mutex_lock(&priv->streaming_lock);
	priv->streaming = true;
	mutex_unlock(&priv->streaming_lock);
	return 0;
static int imx274_stop_streaming(struct tegracam_device *tc_dev)
	int err;
	priv->streaming = false;
	return 0;
static struct camera_common_sensor_ops imx274_common_ops = {
	.numfrmfmts = ARRAY_SIZE(imx274_frmfmt),
	.frmfmt_table = imx274_frmfmt,
	.power_on = imx274_power_on,
	.power_off = imx274_power_off,
	.write_reg = imx274_write_reg,
	.read_reg = imx274_read_reg,
	.parse_dt = imx274_parse_dt,
	.power_get = imx274_power_get,
	.power_put = imx274_power_put,
	.set_mode = imx274_set_mode,
	.start_streaming = imx274_start_streaming,
	.stop_streaming = imx274_stop_streaming,
static int imx274_eeprom_device_release(struct imx274 *priv)
	int i;
	for (i = 0; i < IMX274_EEPROM_NUM_BLOCKS; i++) {
		if (priv->eeprom[i].i2c_client != NULL) {
			i2c_unregister_device(priv->eeprom[i].i2c_client);
			priv->eeprom[i].i2c_client = NULL;
	return 0;
static int imx274_eeprom_device_init(struct imx274 *priv)
	char *dev_name = "eeprom_imx274";
	struct camera_common_pdata *pdata = priv->s_data->pdata;
	static struct regmap_config eeprom_regmap_config = {
		.reg_bits = 8,
		.val_bits = 8,
	int i;
	int err;
	if (!pdata || !pdata->has_eeprom)
		return -EINVAL;
		priv->eeprom[i].adap = i2c_get_adapter(
				priv->i2c_client->adapter->nr);
		memset(&priv->eeprom[i].brd, 0, sizeof(priv->eeprom[i].brd));
		strncpy(priv->eeprom[i].brd.type, dev_name,
				sizeof(priv->eeprom[i].brd.type));
		priv->eeprom[i].brd.addr = IMX274_EEPROM_ADDRESS + i;
		priv->eeprom[i].i2c_client = i2c_new_device(
				priv->eeprom[i].adap, &priv->eeprom[i].brd);
		priv->eeprom[i].regmap = devm_regmap_init_i2c(
			priv->eeprom[i].i2c_client, &eeprom_regmap_config);
		if (IS_ERR(priv->eeprom[i].regmap)) {
			err = PTR_ERR(priv->eeprom[i].regmap);
			imx274_eeprom_device_release(priv);
			return err;
	return 0;
static int imx274_read_fuse_id(struct imx274 *priv)
	int err, i;
	if (!pdata->has_eeprom)
		return -EINVAL;
		err = regmap_bulk_read(priv->eeprom[i].regmap, 0,
			&priv->eeprom_buf[i * IMX274_EEPROM_BLOCK_SIZE],
			IMX274_EEPROM_BLOCK_SIZE);
		if (err)
			return err;
		priv->fuse_id[i] =
			priv->eeprom_buf[i + pdata->fuse_id_addr];
	return 0;
static int imx274_board_setup(struct imx274 *priv)
	int err = 0;
	if (!s_data->pdata->has_eeprom)
		return 0;
	/* eeprom for fuse id*/
	err = imx274_eeprom_device_init(priv);
	if (err && s_data->pdata->has_eeprom) {
		dev_err(dev,
			"Failed to allocate eeprom reg map: %d\n", err);
		return err;
	err = camera_common_mclk_enable(s_data);
	if (err) {
		dev_err(dev,
			"Error %d turning on mclk\n", err);
		return err;
	err = imx274_power_on(s_data);
	if (err) {
		dev_err(dev,
			"Error %d during power on sensor\n", err);
		return err;
	err = imx274_read_fuse_id(priv);
	if (err) {
		dev_err(dev,
			"Error %d reading fuse id data\n", err);
		goto error;
error:
	imx274_power_off(s_data);
	camera_common_mclk_disable(s_data);
	return err;
static int imx274_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
	struct i2c_client *client = v4l2_get_subdevdata(sd);
	dev_dbg(&client->dev, "%s:\n", __func__);
	return 0;
static const struct v4l2_subdev_internal_ops imx274_subdev_internal_ops = {
	.open = imx274_open,
static int imx274_probe(struct i2c_client *client,
			const struct i2c_device_id *id)
	struct device *dev = &client->dev;
	struct device_node *node = client->dev.of_node;
	struct imx274 *priv;
	int err;
	dev_info(dev, "probing v4l2 sensor.\n");
	if (!IS_ENABLED(CONFIG_OF) || !node)
		return -EINVAL;
	priv = devm_kzalloc(dev,
			sizeof(struct imx274), GFP_KERNEL);
	if (!priv)
		return -ENOMEM;
	tc_dev = devm_kzalloc(dev,
			sizeof(struct tegracam_device), GFP_KERNEL);
	if (!tc_dev)
		return -ENOMEM;
	priv->i2c_client = tc_dev->client = client;
	tc_dev->dev = dev;
	strncpy(tc_dev->name, "imx274", sizeof(tc_dev->name));
	tc_dev->dev_regmap_config = &sensor_regmap_config;
	tc_dev->sensor_ops = &imx274_common_ops;
	tc_dev->v4l2sd_internal_ops = &imx274_subdev_internal_ops;
	tc_dev->tcctrl_ops = &imx274_ctrl_ops;
	mutex_init(&priv->streaming_lock);
	err = tegracam_device_register(tc_dev);
	if (err) {
		dev_err(dev, "tegra camera driver registration failed\n");
		return err;
	priv->tc_dev = tc_dev;
	priv->s_data = tc_dev->s_data;
	priv->subdev = &tc_dev->s_data->subdev;
	tegracam_set_privdata(tc_dev, (void *)priv);
	err = imx274_board_setup(priv);
	if (err) {
		dev_err(dev, "board setup failed\n");
		return err;
	err = tegracam_v4l2subdev_register(tc_dev, true);
	if (err) {
		dev_err(dev, "tegra camera subdev registration failed\n");
		return err;
	dev_info(dev, "Detected IMX274 sensor\n");
	return 0;
static int imx274_remove(struct i2c_client *client)
	struct camera_common_data *s_data = to_camera_common_data(&client->dev);
	struct imx274 *priv = (struct imx274 *)s_data->priv;
	tegracam_v4l2subdev_unregister(priv->tc_dev);
	tegracam_device_unregister(priv->tc_dev);
	mutex_destroy(&priv->streaming_lock);
	return 0;
static const struct i2c_device_id lt6911_id[] = {
	{ "lt6911", 0 },
MODULE_DEVICE_TABLE(i2c, lt6911_id);
static struct i2c_driver lt6911_i2c_driver = {
	.driver = {
		.name = "lt6911",
		.owner = THIS_MODULE,
	.probe = imx274_probe,
	.remove = imx274_remove,
	.id_table = lt6911_id,
module_i2c_driver(lt6911_i2c_driver);
MODULE_DESCRIPTION("LT6911 HDMI2CSI Driver");
MODULE_AUTHOR("Eric Miao");
MODULE_LICENSE("GPL v2");
Got no idea why the “duplicate format” you may need to remove others format from the vi5_formats.h/sensor_common.c/camera_common.c to try.
For the capture failed you may need to get the trace log to get more information.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
v4l2-ctl --stream-mmap --stream-count=10
cat /sys/kernel/debug/tracing/trace
Hi ShaneCCC,
I’m attaching kernel trace log and dmesg log here.
# tracer: nop
# entries-in-buffer/entries-written: 142/142   #P:4
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:5-2319  [000] ....  1633.345853: rtos_queue_peek_from_isr_failed: tstamp:51432495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1633.513826: rtos_queue_peek_from_isr_failed: tstamp:51437495792 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1633.681824: rtos_queue_peek_from_isr_failed: tstamp:51442495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1633.849830: rtos_queue_peek_from_isr_failed: tstamp:51447495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.017821: rtos_queue_peek_from_isr_failed: tstamp:51452495792 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.185821: rtos_queue_peek_from_isr_failed: tstamp:51457495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.353830: rtos_queue_peek_from_isr_failed: tstamp:51462495792 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.465901: rtos_queue_peek_from_isr_failed: tstamp:51467495792 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.633857: rtos_queue_peek_from_isr_failed: tstamp:51472495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.801870: rtos_queue_peek_from_isr_failed: tstamp:51477495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1634.969898: rtos_queue_peek_from_isr_failed: tstamp:51482495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1635.137864: rtos_queue_peek_from_isr_failed: tstamp:51487495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1635.305892: rtos_queue_peek_from_isr_failed: tstamp:51492495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1635.473861: rtos_queue_peek_from_isr_failed: tstamp:51497495790 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1635.585855: rtos_queue_peek_from_isr_failed: tstamp:51502495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1635.753896: rtos_queue_peek_from_isr_failed: tstamp:51507495796 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1635.921838: rtos_queue_peek_from_isr_failed: tstamp:51512495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1636.089875: rtos_queue_peek_from_isr_failed: tstamp:51517495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1636.257875: rtos_queue_peek_from_isr_failed: tstamp:51522495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1636.429846: rtos_queue_peek_from_isr_failed: tstamp:51527495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1636.541883: rtos_queue_peek_from_isr_failed: tstamp:51532495796 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1636.709878: rtos_queue_peek_from_isr_failed: tstamp:51537495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1636.877885: rtos_queue_peek_from_isr_failed: tstamp:51542495790 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1637.045826: rtos_queue_peek_from_isr_failed: tstamp:51547495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1637.213815: rtos_queue_peek_from_isr_failed: tstamp:51552495794 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1637.381856: rtos_queue_peek_from_isr_failed: tstamp:51557495792 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1637.549818: rtos_queue_peek_from_isr_failed: tstamp:51562495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1637.661835: rtos_queue_peek_from_isr_failed: tstamp:51567495791 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1637.829819: rtos_queue_peek_from_isr_failed: tstamp:51572495794 queue:0x0bcbcf78
        v4l2-ctl-9613  [003] ....  1637.997214: tegra_channel_open: vi-output, lt6911 2-0010
        v4l2-ctl-9613  [003] ....  1637.997232: tegra_channel_set_power: lt6911 2-0010 : 0x1
        v4l2-ctl-9613  [003] ....  1637.997245: camera_common_s_power: status : 0x1
     kworker/0:5-2319  [000] ....  1637.997895: rtos_queue_peek_from_isr_failed: tstamp:51577495783 queue:0x0bcbcf78
        v4l2-ctl-9613  [001] ....  1638.007902: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
        v4l2-ctl-9613  [001] ....  1638.007913: csi_s_power: enable : 0x1
        v4l2-ctl-9613  [001] ....  1638.026052: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 13
        v4l2-ctl-9613  [002] ....  1638.027473: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-9613  [001] ....  1638.034496: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
        v4l2-ctl-9613  [001] ....  1638.034503: csi_s_stream: enable : 0x1
        v4l2-ctl-9613  [001] ....  1638.034598: tegra_channel_set_stream: lt6911 2-0010 : 0x1
     kworker/0:5-2319  [000] ....  1638.053841: rtos_queue_send_from_isr_failed: tstamp:51578974275 queue:0x0bcb41f8
     kworker/0:5-2319  [000] ....  1638.053845: rtos_queue_send_from_isr_failed: tstamp:51578974458 queue:0x0bcb8a60
     kworker/0:5-2319  [000] ....  1638.053846: rtos_queue_send_from_isr_failed: tstamp:51578974632 queue:0x0bcba5e0
     kworker/0:5-2319  [000] ....  1638.053848: rtos_queue_send_from_isr_failed: tstamp:51578974804 queue:0x0bcbb3a0
     kworker/0:5-2319  [000] ....  1638.053849: rtos_queue_send_from_isr_failed: tstamp:51578974975 queue:0x0bcbc160
     kworker/0:5-2319  [000] ....  1638.053852: rtcpu_string: tstamp:51578975495 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:5-2319  [000] ....  1638.053917: rtcpu_string: tstamp:51578975730 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
     kworker/0:5-2319  [000] ....  1638.053928: rtcpu_string: tstamp:51578976014 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
     kworker/0:5-2319  [000] ....  1638.053938: rtcpu_string: tstamp:51578976316 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
     kworker/0:5-2319  [000] ....  1638.053947: rtcpu_string: tstamp:51578976574 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
     kworker/0:5-2319  [000] ....  1638.053956: rtcpu_string: tstamp:51578976837 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
     kworker/0:5-2319  [000] ....  1638.053965: rtcpu_string: tstamp:51578977094 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
     kworker/0:5-2319  [000] ....  1638.053974: rtcpu_string: tstamp:51578984813 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
     kworker/0:5-2319  [000] ....  1638.053978: rtcpu_string: tstamp:51578984979 id:0x04010000 str:"on 2.2
     kworker/0:5-2319  [000] ....  1638.053988: rtos_queue_send_from_isr_failed: tstamp:51579005814 queue:0x0bcb41f8
     kworker/0:5-2319  [000] ....  1638.053989: rtos_queue_send_from_isr_failed: tstamp:51579006015 queue:0x0bcb8a60
     kworker/0:5-2319  [000] ....  1638.053991: rtos_queue_send_from_isr_failed: tstamp:51579006198 queue:0x0bcba5e0
     kworker/0:5-2319  [000] ....  1638.053992: rtos_queue_send_from_isr_failed: tstamp:51579006373 queue:0x0bcbb3a0
     kworker/0:5-2319  [000] ....  1638.053993: rtos_queue_send_from_isr_failed: tstamp:51579006544 queue:0x0bcbc160
     kworker/0:5-2319  [000] ....  1638.053995: rtcpu_string: tstamp:51579007522 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
     kworker/0:5-2319  [000] ....  1638.054004: rtos_queue_send_from_isr_failed: tstamp:51579231080 queue:0x0bcb41f8
     kworker/0:5-2319  [000] ....  1638.054006: rtos_queue_send_from_isr_failed: tstamp:51579231240 queue:0x0bcb8a60
     kworker/0:5-2319  [000] ....  1638.054007: rtos_queue_send_from_isr_failed: tstamp:51579231404 queue:0x0bcba5e0
     kworker/0:5-2319  [000] ....  1638.054008: rtos_queue_send_from_isr_failed: tstamp:51579231561 queue:0x0bcbb3a0
     kworker/0:5-2319  [000] ....  1638.054010: rtos_queue_send_from_isr_failed: tstamp:51579231717 queue:0x0bcbc160
     kworker/0:5-2319  [000] ....  1638.054013: rtcpu_vinotify_event: tstamp:51579504420 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:52800439008 data:0x10000000
     kworker/0:5-2319  [000] ....  1638.054015: rtcpu_vinotify_event: tstamp:51579504594 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:52800442848 data:0x31000001
     kworker/0:5-2319  [000] ....  1638.054016: rtcpu_vinotify_event: tstamp:51579504769 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:52800443840 data:0x07020001
     kworker/0:5-2319  [000] ....  1638.054017: rtcpu_vinotify_event: tstamp:51579504916 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:52800489504 data:0x10000000
     kworker/0:5-2319  [000] ....  1638.054019: rtcpu_vinotify_event: tstamp:51579505088 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:52800493408 data:0x31000002
     kworker/0:5-2319  [000] ....  1638.165869: rtos_queue_peek_from_isr_failed: tstamp:51582495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1638.333815: rtos_queue_peek_from_isr_failed: tstamp:51587495786 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1638.501814: rtos_queue_peek_from_isr_failed: tstamp:51592495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1638.669826: rtos_queue_peek_from_isr_failed: tstamp:51597495796 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1638.781821: rtos_queue_peek_from_isr_failed: tstamp:51602495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1638.949860: rtos_queue_peek_from_isr_failed: tstamp:51607495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1639.117864: rtos_queue_peek_from_isr_failed: tstamp:51612495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1639.285854: rtos_queue_peek_from_isr_failed: tstamp:51617495778 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1639.453849: rtos_queue_peek_from_isr_failed: tstamp:51622495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1639.621838: rtos_queue_peek_from_isr_failed: tstamp:51627495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1639.789839: rtos_queue_peek_from_isr_failed: tstamp:51632495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1639.901813: rtos_queue_peek_from_isr_failed: tstamp:51637495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1640.069817: rtos_queue_peek_from_isr_failed: tstamp:51642495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1640.237815: rtos_queue_peek_from_isr_failed: tstamp:51647495786 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1640.405906: rtos_queue_peek_from_isr_failed: tstamp:51652495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1640.573821: rtos_queue_peek_from_isr_failed: tstamp:51657495783 queue:0x0bcbcf78
 vi-output, lt69-9615  [000] ....  1640.617062: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 13
     kworker/0:5-2319  [000] ....  1640.629856: rtos_queue_send_from_isr_failed: tstamp:51659848899 queue:0x0bcb41f8
     kworker/0:5-2319  [000] ....  1640.629862: rtos_queue_send_from_isr_failed: tstamp:51659849061 queue:0x0bcb8a60
     kworker/0:5-2319  [000] ....  1640.629864: rtos_queue_send_from_isr_failed: tstamp:51659849226 queue:0x0bcba5e0
     kworker/0:5-2319  [000] ....  1640.629865: rtos_queue_send_from_isr_failed: tstamp:51659849387 queue:0x0bcbb3a0
     kworker/0:5-2319  [000] ....  1640.629866: rtos_queue_send_from_isr_failed: tstamp:51659849546 queue:0x0bcbc160
     kworker/0:5-2319  [000] ....  1640.629868: rtos_queue_send_from_isr_failed: tstamp:51659930131 queue:0x0bcb41f8
     kworker/0:5-2319  [000] ....  1640.629869: rtos_queue_send_from_isr_failed: tstamp:51659930296 queue:0x0bcb8a60
     kworker/0:5-2319  [000] ....  1640.629870: rtos_queue_send_from_isr_failed: tstamp:51659930459 queue:0x0bcba5e0
     kworker/0:5-2319  [000] ....  1640.629872: rtos_queue_send_from_isr_failed: tstamp:51659930616 queue:0x0bcbb3a0
     kworker/0:5-2319  [000] ....  1640.629873: rtos_queue_send_from_isr_failed: tstamp:51659930774 queue:0x0bcbc160
     kworker/0:5-2319  [000] ....  1640.629876: rtcpu_string: tstamp:51659937890 id:0x04010000 str:"Configuring VI GoS.
     kworker/0:5-2319  [000] ....  1640.629907: rtcpu_string: tstamp:51659938082 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
     kworker/0:5-2319  [000] ....  1640.629918: rtcpu_string: tstamp:51659938348 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
     kworker/0:5-2319  [000] ....  1640.629927: rtcpu_string: tstamp:51659938627 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
     kworker/0:5-2319  [000] ....  1640.629936: rtcpu_string: tstamp:51659938869 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
     kworker/0:5-2319  [000] ....  1640.629945: rtcpu_string: tstamp:51659939112 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
     kworker/0:5-2319  [000] ....  1640.629958: rtcpu_string: tstamp:51659939354 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
     kworker/0:5-2319  [000] ....  1640.741874: rtos_queue_peek_from_isr_failed: tstamp:51662495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1640.909837: rtos_queue_peek_from_isr_failed: tstamp:51667495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1641.021826: rtos_queue_peek_from_isr_failed: tstamp:51672495788 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1641.189827: rtos_queue_peek_from_isr_failed: tstamp:51677495784 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1641.357859: rtos_queue_peek_from_isr_failed: tstamp:51682495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1641.525869: rtos_queue_peek_from_isr_failed: tstamp:51687495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1641.693863: rtos_queue_peek_from_isr_failed: tstamp:51692495783 queue:0x0bcbcf78
     kworker/0:5-2319  [000] ....  1641.861858: rtos_queue_peek_from_isr_failed: tstamp:51697495784 queue:0x0bcbcf78
dmesg output:
[ 1597.430015] lt6911: loading out-of-tree module taints kernel.
[ 1597.431734] lt6911 2-0010: probing v4l2 sensor.
[ 1597.433217] lt6911 2-0010: tegracam sensor driver:imx274_v2.0.6
[ 1597.433340] tegra194-vi5 15c10000.vi: subdev lt6911 2-0010 bound
[ 1597.438612] lt6911 2-0010: Detected IMX274 sensor
[ 1597.438756] lt6911 2-0011: probing v4l2 sensor.
[ 1597.445222] lt6911 2-0011: tegracam sensor driver:imx274_v2.0.6
[ 1597.445304] tegra194-vi5 15c10000.vi: subdev lt6911 2-0011 bound
[ 1597.446612] lt6911 2-0011: Detected IMX274 sensor
[ 1638.053907] [RCE] Configuring VI GoS.
[ 1638.053923] [RCE] VM GOS[#0] addr=0xc2100000
[ 1638.053933] [RCE] VM GOS[#1] addr=0xc2101000
[ 1638.053943] [RCE] VM GOS[#2] addr=0xc2102000
[ 1638.053952] [RCE] VM GOS[#3] addr=0xc2103000
[ 1638.053961] [RCE] VM GOS[#4] addr=0xc2104000
[ 1638.053970] [RCE] VM GOS[#5] addr=0xc2105000
[ 1638.053983] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 1638.054000] [RCE] VI GOS[#0] set to VM GOS[4] base 0xc2104000
[ 1640.613852] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 1640.614037] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 1640.614183] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 1640.617314] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 1640.617540] tegra194-vi5 15c10000.vi: vi capture setup failed
[ 1640.617648] tegra194-vi5 15c10000.vi: fatal: error recovery failed
[ 1640.629896] [RCE] Configuring VI GoS.
[ 1640.629913] [RCE] VM GOS[#0] addr=0xc2100000
[ 1640.629922] [RCE] VM GOS[#1] addr=0xc2101000
[ 1640.629932] [RCE] VM GOS[#2] addr=0xc2102000
[ 1640.629940] [RCE] VM GOS[#3] addr=0xc2103000
[ 1640.629952] [RCE] VM GOS[#4] addr=0xc2104000
[ 1640.629964] [RCE] VM GOS[#5] addr=0xc2105000
From the trace, NVCSI/NV didn’t receive any validate package from MIPI bus.
You may need to probe the signal to confirm it.
Hi ShaneCCC,
I moved on and encountered new issue.
Can you please help check the following error messages and tell us what
we should do next to resolve such issue?
Kernel dmesg output
[  194.819460] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[  195.025331] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3449, flags: 6, err_data 256
[  195.071855] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  195.323611] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 38, err_data 160
[  195.323816] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3464, flags: 0, err_data 256
[  195.325257] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  195.438778] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  195.540268] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 38, err_data 160
[  195.540599] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3479, flags: 0, err_data 256
[  195.540783] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3480, flags: 0, err_data 256
[  195.622254] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  195.688962] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 118, err_data 14680672
[  195.757200] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3328, flags: 6, err_data 256
[  195.762320] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3493, flags: 0, err_data 256
[  195.790520] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[  195.955840] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  195.957436] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 256
[  195.967702] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3505, flags: 0, err_data 256
[  196.005887] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  196.222700] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 118, err_data 14680672
[  196.741272] tegra194-vi5 15c10000.vi: corr_err: discarding frame 11554, flags: 6, err_data 256
[  196.754822] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3552, flags: 0, err_data 256
[  196.789789] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680672
[  197.041374] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 38, err_data 160
Looks like the output package have problem to finish to capture.
Did you check the trace log?
Hi ShaneCCC,
The above error messages are for 4-lane 640x480 UYVY configuration.
After I changed the configuration to 4-lane 1280x720 UYVY, I can capture the stream from hdmi to CSI converter chip.
So 640x480 is not supported currently?
No, 640x480 are supported. It’s could be this configure have problem to get the frame data.
Dear @qjmiao,
I know that this thread has been resolved but I’d like to know if you could share your solution of how to resolve the problem of “duplicate format 59565955” since I have exactly same problem, please ?
Thanks very much in advance,
K.
@khang.letruongg7g8r
I have not tried to fix the “duplicate format” issue.
I think removing some redundant format definition lines from vi5_formats.h could fix the issue.
