Capture image frame rate is slow
open debug config:
kworker/4:2-580 [004] … 282.407980: rtcpu_nvcsi_intr: tstamp:9369218570 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407980: rtcpu_nvcsi_intr: tstamp:9369219109 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407981: rtcpu_nvcsi_intr: tstamp:9369219109 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407981: rtcpu_nvcsi_intr: tstamp:9369219645 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407981: rtcpu_nvcsi_intr: tstamp:9369219645 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407981: rtcpu_nvcsi_intr: tstamp:9369219645 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407981: rtcpu_nvcsi_intr: tstamp:9369220419 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407981: rtcpu_nvcsi_intr: tstamp:9369220419 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369220419 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369221197 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369221197 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369221197 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369221979 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369221979 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407982: rtcpu_nvcsi_intr: tstamp:9369221979 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407983: rtcpu_nvcsi_intr: tstamp:9369222727 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407983: rtcpu_nvcsi_intr: tstamp:9369222727 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407983: rtcpu_nvcsi_intr: tstamp:9369222727 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407983: rtcpu_nvcsi_intr: tstamp:9369223506 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407983: rtcpu_nvcsi_intr: tstamp:9369223506 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407983: rtcpu_nvcsi_intr: tstamp:9369224047 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407984: rtcpu_nvcsi_intr: tstamp:9369224047 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407984: rtcpu_nvcsi_intr: tstamp:9369224624 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:1 vc:0 status:0x00000001
kworker/4:2-580 [004] … 282.407984: rtcpu_nvcsi_intr: tstamp:9369224624 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407984: rtcpu_nvcsi_intr: tstamp:9369224624 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407985: rtcpu_nvcsi_intr: tstamp:9369225368 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407985: rtcpu_nvcsi_intr: tstamp:9369225368 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407985: rtcpu_nvcsi_intr: tstamp:9369225909 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407985: rtcpu_nvcsi_intr: tstamp:9369225909 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407985: rtcpu_nvcsi_intr: tstamp:9369226552 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369226552 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369227355 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369227355 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369227896 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369227896 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:1 vc:0 status:0x00000006
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369227896 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369228680 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000004
kworker/4:2-580 [004] … 282.407986: rtcpu_nvcsi_intr: tstamp:9369228680 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000004
kworker/4:2-580 [004] … 282.407987: rtcpu_nvcsi_intr: tstamp:9369229353 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x10000000
kworker/4:2-580 [004] … 282.407987: rtcpu_nvcsi_intr: tstamp:9369229353 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00001000
Looks like the MIPI signal problem.
It could be the incorrect pix_clk_hz/serdes_pix_clk_hz cause improper settle time cause the problem.
This tell the crc and ecc error.
Below tell the SOT (Start Of Transfer) error
what is the reg name? How to confirm the name of this register
We connected 4 cameras externally, but only CSI0 reported this error.
Then I think you need to check the HW.
How do I find the description of this register in the data sheet?
Check the REG NVCSI_PHY_0_CILA_INTR_0_STATUS_CILA_0 in TRM.
How can I find the corresponding register name based on the corresponding error message?
How can I debug this problem? Is there any time parameter that can be adjusted?
