After loading the driver, I used the v4l2 command to print the frame rate, which was fine. As shown in the picture below:
When I use argus_camera to preview the camera, I get a black screen. I looked at dmesg and nothing went wrong. View the tarce log as follows:
kworker/2:0-25 [002] .... 722.739980: rtcpu_nvcsi_intr: tstamp:23096988950 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739980: rtcpu_nvcsi_intr: tstamp:23096988950 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739980: rtcpu_nvcsi_intr: tstamp:23096989758 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739980: rtcpu_nvcsi_intr: tstamp:23096989758 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739980: rtcpu_nvcsi_intr: tstamp:23096989758 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739981: rtcpu_nvcsi_intr: tstamp:23096989758 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739981: rtcpu_nvcsi_intr: tstamp:23096990567 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739981: rtcpu_nvcsi_intr: tstamp:23096990567 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739981: rtcpu_nvcsi_intr: tstamp:23096990567 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739981: rtcpu_nvcsi_intr: tstamp:23096990567 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739981: rtcpu_nvcsi_intr: tstamp:23096991374 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739982: rtcpu_nvcsi_intr: tstamp:23096991374 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739982: rtcpu_nvcsi_intr: tstamp:23096991374 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739983: rtcpu_nvcsi_intr: tstamp:23096991374 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739983: rtcpu_nvcsi_intr: tstamp:23096992184 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739983: rtcpu_nvcsi_intr: tstamp:23096992184 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739983: rtcpu_nvcsi_intr: tstamp:23096992184 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739984: rtcpu_nvcsi_intr: tstamp:23096992184 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739984: rtcpu_nvcsi_intr: tstamp:23096992993 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739984: rtcpu_nvcsi_intr: tstamp:23096992993 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739984: rtcpu_nvcsi_intr: tstamp:23096992993 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739985: rtcpu_nvcsi_intr: tstamp:23096992993 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739985: rtcpu_nvcsi_intr: tstamp:23096993797 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739985: rtcpu_nvcsi_intr: tstamp:23096993797 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739985: rtcpu_nvcsi_intr: tstamp:23096993797 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739985: rtcpu_nvcsi_intr: tstamp:23096993797 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739986: rtcpu_nvcsi_intr: tstamp:23096994626 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739986: rtcpu_nvcsi_intr: tstamp:23096994626 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739986: rtcpu_nvcsi_intr: tstamp:23096994626 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739986: rtcpu_nvcsi_intr: tstamp:23096994626 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739986: rtcpu_nvcsi_intr: tstamp:23096995429 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739987: rtcpu_nvcsi_intr: tstamp:23096995429 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739987: rtcpu_nvcsi_intr: tstamp:23096995429 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000044
kworker/2:0-25 [002] .... 722.739987: rtcpu_nvcsi_intr: tstamp:23096995429 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000044
trace.txt (37.5 KB)
hope I can get your help. Thank you.
