cat /etc/os-release
PRETTY_NAME="Ubuntu 22.04.4 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.4 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
uname -a
Linux wong-desktop 5.15.148-tegra #1 SMP PREEMPT Thu Sep 12 21:01:54 PDT 2024 aarch64 aarch64 aarch64 GNU/Linux
gstreamer log:
$ gst-launch-1.0 nvarguscamerasrc ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
Redistribute latency...
Got EOS from element "pipeline0".
Execution ended after 0:00:04.016130848
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
(Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 277)
(Argus) Error FileOperationFailed: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 350)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
(Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 379)
(Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error FileOperationFailed: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 92)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 92)
GST_ARGUS: Done Success
Freeing pipeline ...
trace:
# tracer: nop
# entries-in-buffer/entries-written: 4525/4525 #P:6
# _-------=> irqs-off
# / _------=> need-resched
# | / _-----=> need-resched-lazy
# || / _----=> hardirq/softirq
# ||| / _---=> preempt-depth
# |||| / _--=> preempt-lazy-depth
# ||||| / _-=> migrate-disable
# |||||| / delay
# TASK-PID CPU# ||||||| TIMESTAMP FUNCTION
nvargus-daemon-2278 [000] ....... 72.778813: tegra_channel_open: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.778910: tegra_channel_close: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.779833: tegra_channel_open: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.779880: tegra_channel_close: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803260: tegra_channel_open: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803292: tegra_channel_close: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803712: tegra_channel_open: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803730: tegra_channel_close: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803741: tegra_channel_open: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803826: tegra_channel_close: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803853: tegra_channel_open: vi-output, imx219 9-0010
nvargus-daemon-2278 [000] ....... 72.803948: tegra_channel_close: vi-output, imx219 9-0010
CaptureSchedule-2294 [001] ....... 72.994280: tegra_channel_open: vi-output, imx219 9-0010
CaptureSchedule-2294 [001] ....... 72.995210: tegra_channel_set_power: imx219 9-0010 : 0x1
CaptureSchedule-2294 [001] ....... 72.995220: camera_common_s_power: status : 0x1
CaptureSchedule-2294 [001] ....... 73.005347: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
CaptureSchedule-2294 [001] ....... 73.005352: csi_s_power: enable : 0x1
CaptureSchedule-2294 [001] ....... 73.005606: tegra_channel_set_stream: enable : 0x1
CaptureSchedule-2294 [001] ....... 73.007015: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
CaptureSchedule-2294 [001] ....... 73.007018: csi_s_stream: enable : 0x1
CaptureSchedule-2294 [001] ....... 73.007020: tegra_channel_set_stream: imx219 9-0010 : 0x1
CaptureSchedule-2294 [001] ....... 73.030937: vi_task_submit: class_id:48 ch:1 syncpt_id:44 syncpt_thresh:0 pid:2294 tid:847
CaptureSchedule-2294 [001] ....... 73.064230: vi_task_submit: class_id:48 ch:1 syncpt_id:44 syncpt_thresh:0 pid:2294 tid:847
CaptureSchedule-2294 [001] ....... 73.064359: vi_task_submit: class_id:48 ch:1 syncpt_id:44 syncpt_thresh:0 pid:2294 tid:847
kworker/5:5-294 [005] ....... 73.064504: rtcpu_vinotify_event: tstamp:3085536174 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:98735648224 data:0x799da00010000000
kworker/5:5-294 [005] ....... 73.064507: rtcpu_vinotify_event: tstamp:3085536436 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:98735690336 data:0x0000000031000001
kworker/5:5-294 [005] ....... 73.064508: rtcpu_vinotify_event: tstamp:3085536721 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x0b frame:0 vi_tstamp:98735712416 data:0x0000000007020001
kworker/5:5-294 [005] ....... 73.064511: rtcpu_nvcsi_intr: tstamp:3086477416 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000080
kworker/5:5-294 [005] ....... 73.064512: rtcpu_nvcsi_intr: tstamp:3086477416 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000080
kworker/5:5-294 [005] ....... 73.064512: rtcpu_nvcsi_intr: tstamp:3086478307 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000080
kworker/5:5-294 [005] ....... 73.064513: rtcpu_nvcsi_intr: tstamp:3086478307 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064513: rtcpu_nvcsi_intr: tstamp:3086479181 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064514: rtcpu_nvcsi_intr: tstamp:3086479181 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064515: rtcpu_nvcsi_intr: tstamp:3086480033 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064515: rtcpu_nvcsi_intr: tstamp:3086480033 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064516: rtcpu_nvcsi_intr: tstamp:3086480947 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064516: rtcpu_nvcsi_intr: tstamp:3086480947 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064517: rtcpu_nvcsi_intr: tstamp:3086481812 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064518: rtcpu_nvcsi_intr: tstamp:3086481812 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064518: rtcpu_nvcsi_intr: tstamp:3086482664 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064519: rtcpu_nvcsi_intr: tstamp:3086482664 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064519: rtcpu_nvcsi_intr: tstamp:3086483521 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064520: rtcpu_nvcsi_intr: tstamp:3086483521 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064520: rtcpu_nvcsi_intr: tstamp:3086484376 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064521: rtcpu_nvcsi_intr: tstamp:3086484376 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064522: rtcpu_nvcsi_intr: tstamp:3086485234 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064522: rtcpu_nvcsi_intr: tstamp:3086485234 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064522: rtcpu_nvcsi_intr: tstamp:3086486089 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064523: rtcpu_nvcsi_intr: tstamp:3086486089 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064523: rtcpu_nvcsi_intr: tstamp:3086486943 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064524: rtcpu_nvcsi_intr: tstamp:3086486943 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064524: rtcpu_nvcsi_intr: tstamp:3086487795 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064524: rtcpu_nvcsi_intr: tstamp:3086487795 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064525: rtcpu_nvcsi_intr: tstamp:3086488665 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064525: rtcpu_nvcsi_intr: tstamp:3086488665 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064526: rtcpu_nvcsi_intr: tstamp:3086489513 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064526: rtcpu_nvcsi_intr: tstamp:3086489513 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064527: rtcpu_nvcsi_intr: tstamp:3086490361 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064528: rtcpu_nvcsi_intr: tstamp:3086490361 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064528: rtcpu_nvcsi_intr: tstamp:3086491213 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.064528: rtcpu_nvcsi_intr: tstamp:3086491213 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120497: rtcpu_vinotify_event: tstamp:3086620746 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:98768930240 data:0x799d9d0010000000
kworker/5:5-294 [005] ....... 73.120497: rtcpu_vinotify_event: tstamp:3086621047 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:98768972960 data:0x0000000031000002
kworker/5:5-294 [005] ....... 73.120498: rtcpu_nvcsi_intr: tstamp:3087521222 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000080
kworker/5:5-294 [005] ....... 73.120499: rtcpu_nvcsi_intr: tstamp:3087521222 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120500: rtcpu_nvcsi_intr: tstamp:3087522116 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120500: rtcpu_nvcsi_intr: tstamp:3087522116 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120501: rtcpu_nvcsi_intr: tstamp:3087523008 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120502: rtcpu_nvcsi_intr: tstamp:3087523008 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120502: rtcpu_nvcsi_intr: tstamp:3087523873 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120503: rtcpu_nvcsi_intr: tstamp:3087523873 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120504: rtcpu_nvcsi_intr: tstamp:3087524740 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120505: rtcpu_nvcsi_intr: tstamp:3087524740 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120505: rtcpu_nvcsi_intr: tstamp:3087525601 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120506: rtcpu_nvcsi_intr: tstamp:3087525601 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120507: rtcpu_nvcsi_intr: tstamp:3087526458 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120507: rtcpu_nvcsi_intr: tstamp:3087526458 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120508: rtcpu_nvcsi_intr: tstamp:3087527315 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120508: rtcpu_nvcsi_intr: tstamp:3087527315 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120509: rtcpu_nvcsi_intr: tstamp:3087528175 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120509: rtcpu_nvcsi_intr: tstamp:3087528175 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120509: rtcpu_nvcsi_intr: tstamp:3087529035 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120510: rtcpu_nvcsi_intr: tstamp:3087529035 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120510: rtcpu_nvcsi_intr: tstamp:3087529897 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120511: rtcpu_nvcsi_intr: tstamp:3087529897 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120511: rtcpu_nvcsi_intr: tstamp:3087530753 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120512: rtcpu_nvcsi_intr: tstamp:3087530753 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120512: rtcpu_nvcsi_intr: tstamp:3087531606 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120512: rtcpu_nvcsi_intr: tstamp:3087531606 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120513: rtcpu_nvcsi_intr: tstamp:3087532458 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120513: rtcpu_nvcsi_intr: tstamp:3087532458 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120514: rtcpu_nvcsi_intr: tstamp:3087533316 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120514: rtcpu_nvcsi_intr: tstamp:3087533316 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120515: rtcpu_nvcsi_intr: tstamp:3087534172 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120515: rtcpu_nvcsi_intr: tstamp:3087534172 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120516: rtcpu_nvcsi_intr: tstamp:3087535033 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.120516: rtcpu_nvcsi_intr: tstamp:3087535033 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176510: rtcpu_nvcsi_intr: tstamp:3088564935 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176513: rtcpu_nvcsi_intr: tstamp:3088564935 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176514: rtcpu_nvcsi_intr: tstamp:3088565824 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000080
kworker/5:5-294 [005] ....... 73.176515: rtcpu_nvcsi_intr: tstamp:3088565824 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176516: rtcpu_nvcsi_intr: tstamp:3088566696 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176516: rtcpu_nvcsi_intr: tstamp:3088566696 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176517: rtcpu_nvcsi_intr: tstamp:3088567551 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176518: rtcpu_nvcsi_intr: tstamp:3088567551 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176519: rtcpu_nvcsi_intr: tstamp:3088568407 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176520: rtcpu_nvcsi_intr: tstamp:3088568407 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176521: rtcpu_nvcsi_intr: tstamp:3088569256 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176522: rtcpu_nvcsi_intr: tstamp:3088569256 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176523: rtcpu_nvcsi_intr: tstamp:3088570110 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176524: rtcpu_nvcsi_intr: tstamp:3088570110 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176524: rtcpu_nvcsi_intr: tstamp:3088570960 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000088
kworker/5:5-294 [005] ....... 73.176525: rtcpu_nvcsi_intr: tstamp:3088570960 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000088
we are using RPI IMX219 on both camera port, same error.
