GStreamer appsink issues on Orin Nano
I’m having issues with trying to get a GStreamer pipeline working on my Orin Nano from an IMX219 Camera connected to CSI port 0. I am trying to use CV2:VideoCapture, with CAP_GSTREAMER set, in the Python bindings to set up the GStreamer pipeline, but unfortunately, it hangs silently.
The pipeline I have is:
            f"nvarguscamerasrc sensor-id={1} ! "
            f"'video/x-raw(memory:NVMM), width={width}, height={height}, "
            f"format=(string)NV12, framerate=(fraction){framerate}/1 !"
            f"nvvidconv ! "
            f"video/x-raw, format=BGRx ! "
            f"videoconvert ! "
            f"video/x-raw, format=BGR ! "
            f"queue ! "
            f"appsink drop=1'"
where width & height are 244 and framerate is 30.
Using a similar pipeline from the cli:
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)422, height=(int)422' ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! queue ! appsink drop=1
gives this output:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 4
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:03.489415662
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
Freeing pipeline ...
However, if I try and run the pipeline from python GStreamer it hangs silently. After force closing the process, GStreamer will fail with this warning until reboot on the cli (and still just hangs when calling CV2:VideoCapture)
warning: erroneous pipeline: no element "nvarguscamerasrc"
Restarting the nvargus-deamon does not fix this error. Similarly, trying to use the x264 encoder (or any other that is installed) will also fail with the corresponding similar error. I am also aware that the Orin Nano does not have a hardware encoder.
If I try to use either of the pipelines referenced in this answer I am able to create an mkv file successfully.
Setup:
Nvidia Orin Nano running headless on the dev-board
L4T Version
cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug  1 19:57:35 UTC 2023
OpenCV version
apt list | grep "opencv"
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
cl-opencv-apps/focal 1.12.0-3build3 all
gstreamer1.0-opencv/focal-updates 1.16.3-0ubuntu1 arm64
libgstreamer-opencv1.0-0/focal-updates,now 1.16.3-0ubuntu1 arm64 [installed,automatic]
libopencv-apps-dev/focal 1.12.0-3build3 arm64
libopencv-apps1d/focal 1.12.0-3build3 arm64
libopencv-calib3d-dev/focal 4.2.0+dfsg-5 arm64
libopencv-calib3d4.2/focal 4.2.0+dfsg-5 arm64
libopencv-contrib-dev/focal 4.2.0+dfsg-5 arm64
libopencv-contrib4.2/focal 4.2.0+dfsg-5 arm64
libopencv-core-dev/focal 4.2.0+dfsg-5 arm64
libopencv-core4.2/focal,now 4.2.0+dfsg-5 arm64 [installed,automatic]
libopencv-dev/stable,now 4.5.4-8-g3e4c170df4 arm64 [installed,automatic]
libopencv-dnn-dev/focal 4.2.0+dfsg-5 arm64
libopencv-dnn4.2/focal 4.2.0+dfsg-5 arm64
libopencv-features2d-dev/focal 4.2.0+dfsg-5 arm64
libopencv-features2d4.2/focal 4.2.0+dfsg-5 arm64
libopencv-flann-dev/focal 4.2.0+dfsg-5 arm64
libopencv-flann4.2/focal 4.2.0+dfsg-5 arm64
libopencv-highgui-dev/focal 4.2.0+dfsg-5 arm64
libopencv-highgui4.2/focal 4.2.0+dfsg-5 arm64
libopencv-imgcodecs-dev/focal 4.2.0+dfsg-5 arm64
libopencv-imgcodecs4.2/focal 4.2.0+dfsg-5 arm64
libopencv-imgproc-dev/focal 4.2.0+dfsg-5 arm64
libopencv-imgproc4.2/focal 4.2.0+dfsg-5 arm64
libopencv-ml-dev/focal 4.2.0+dfsg-5 arm64
libopencv-ml4.2/focal 4.2.0+dfsg-5 arm64
libopencv-objdetect-dev/focal 4.2.0+dfsg-5 arm64
libopencv-objdetect4.2/focal 4.2.0+dfsg-5 arm64
libopencv-photo-dev/focal 4.2.0+dfsg-5 arm64
libopencv-photo4.2/focal 4.2.0+dfsg-5 arm64
libopencv-python/stable 4.5.4-8-g3e4c170df4 arm64
libopencv-samples/stable 4.5.4-8-g3e4c170df4 arm64
libopencv-shape-dev/focal 4.2.0+dfsg-5 arm64
libopencv-shape4.2/focal 4.2.0+dfsg-5 arm64
libopencv-stitching-dev/focal 4.2.0+dfsg-5 arm64
libopencv-stitching4.2/focal 4.2.0+dfsg-5 arm64
libopencv-superres-dev/focal 4.2.0+dfsg-5 arm64
libopencv-superres4.2/focal 4.2.0+dfsg-5 arm64
libopencv-ts-dev/focal 4.2.0+dfsg-5 arm64
libopencv-video-dev/focal 4.2.0+dfsg-5 arm64
libopencv-video4.2/focal 4.2.0+dfsg-5 arm64
libopencv-videoio-dev/focal 4.2.0+dfsg-5 arm64
libopencv-videoio4.2/focal 4.2.0+dfsg-5 arm64
libopencv-videostab-dev/focal 4.2.0+dfsg-5 arm64
libopencv-videostab4.2/focal 4.2.0+dfsg-5 arm64
libopencv-viz-dev/focal 4.2.0+dfsg-5 arm64
libopencv-viz4.2/focal 4.2.0+dfsg-5 arm64
libopencv4.2-java/focal 4.2.0+dfsg-5 all
libopencv4.2-jni/focal 4.2.0+dfsg-5 arm64
libopencv/stable,now 4.5.4-8-g3e4c170df4 arm64 [installed,automatic]
node-opencv/focal 6.0.0+git20190322.db093cb2-7 arm64
nvidia-opencv-dev/stable 5.1.2-b104 arm64
nvidia-opencv/stable 5.1.2-b104 arm64
opencv-data/focal 4.2.0+dfsg-5 all
opencv-doc/focal 4.2.0+dfsg-5 all
opencv-licenses/stable 4.5.4-8-g3e4c170df4 arm64
python3-opencv-apps/focal 1.12.0-3build3 all
python3-opencv/focal 4.2.0+dfsg-5 arm64
ros-opencv-apps/focal 1.12.0-3build3 arm64
GStreamer Version
gst-launch-1.0 --gst-version
GStreamer Core Library version 1.16.3
OpenCV Python build information
print(cv2.getBuildInformation())
General configuration for OpenCV 4.6.0 =====================================
  Version control:               unknown
  Extra modules:
    Location (extra):            /croot/opencv-suite_1691620390108/work/opencv_contrib-4.6.0/modules
    Version control (extra):     unknown
  Platform:
    Timestamp:                   2023-08-09T22:58:34Z
    Host:                        Linux 5.10.184-175.749.amzn2.aarch64 aarch64
    CMake:                       3.26.4
    CMake generator:             Ninja
    CMake build tool:            /croot/opencv-suite_1691620390108/_build_env/bin/ninja
    Configuration:               Release
  CPU/HW features:
    Baseline:                    NEON FP16
  C/C++:
    Built as dynamic libs?:      YES
    C++ standard:                11
    C++ Compiler:                /croot/opencv-suite_1691620390108/_build_env/bin/aarch64-conda-linux-gnu-c++  (ver 11.2.0)
    C++ flags (Release):         -fvisibility-inlines-hidden -std=c++11 -fmessage-length=0 -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O3 -pipe -isystem /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/include -fdebug-prefix-map=/croot/opencv-suite_1691620390108/work=/usr/local/src/conda/opencv-suite-4.6.0 -fdebug-prefix-map=/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac=/usr/local/src/conda-prefix -D__STDC_CONSTANT_MACROS   -fsigned-char -W -Wall -Wreturn-type -Wnon-virtual-dtor -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fopenmp -O3 -DNDEBUG  -DNDEBUG
    C++ flags (Debug):           -fvisibility-inlines-hidden -std=c++11 -fmessage-length=0 -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O3 -pipe -isystem /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/include -fdebug-prefix-map=/croot/opencv-suite_1691620390108/work=/usr/local/src/conda/opencv-suite-4.6.0 -fdebug-prefix-map=/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac=/usr/local/src/conda-prefix -D__STDC_CONSTANT_MACROS   -fsigned-char -W -Wall -Wreturn-type -Wnon-virtual-dtor -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fopenmp -g  -DDEBUG -D_DEBUG
    C Compiler:                  /croot/opencv-suite_1691620390108/_build_env/bin/aarch64-conda-linux-gnu-cc
    C flags (Release):           -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O3 -pipe -isystem /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/include -fdebug-prefix-map=/croot/opencv-suite_1691620390108/work=/usr/local/src/conda/opencv-suite-4.6.0 -fdebug-prefix-map=/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac=/usr/local/src/conda-prefix   -fsigned-char -W -Wall -Wreturn-type -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fopenmp -O3 -DNDEBUG  -DNDEBUG
    C flags (Debug):             -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O3 -pipe -isystem /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/include -fdebug-prefix-map=/croot/opencv-suite_1691620390108/work=/usr/local/src/conda/opencv-suite-4.6.0 -fdebug-prefix-map=/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac=/usr/local/src/conda-prefix   -fsigned-char -W -Wall -Wreturn-type -Waddress -Wsequence-point -Wformat -Wformat-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fopenmp -g  -DDEBUG -D_DEBUG
    Linker flags (Release):      -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-rpath,/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib -Wl,-rpath-link,/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib -L/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib  -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined
    Linker flags (Debug):        -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,-rpath,/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib -Wl,-rpath-link,/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib -L/croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib  -Wl,--gc-sections -Wl,--as-needed -Wl,--no-undefined
    ccache:                      NO
    Precompiled headers:         NO
    Extra dependencies:          dl m pthread rt
    3rdparty dependencies:
  OpenCV modules:
    To be built:                 alphamat aruco bgsegm bioinspired calib3d ccalib core cvv datasets dpm face features2d flann freetype fuzzy gapi hdf hfs highgui img_hash imgcodecs imgproc intensity_transform line_descriptor ml objdetect optflow phase_unwrapping photo plot python3 quality rapid reg rgbd saliency shape stereo stitching structured_light superres surface_matching tracking video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
    Disabled:                    world
    Disabled by dependency:      barcode dnn_objdetect dnn_superres mcc text wechat_qrcode
    Unavailable:                 cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev dnn java julia matlab ovis python2 sfm ts viz
    Applications:                -
    Documentation:               NO
    Non-free algorithms:         NO
  GUI:                           QT5
    QT:                          YES (ver 5.15.2 )
      QT OpenGL support:         NO
  Media I/O:
    ZLib:                        /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib/libz.so (ver 1.2.13)
    JPEG:                        /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib/libjpeg.so (ver 90)
    PNG:                         /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib/libpng.so (ver 1.6.37)
    TIFF:                        /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib/libtiff.so (ver 42 / 4.2.0)
    JPEG 2000:                   OpenJPEG (ver 2.3.0)
    OpenEXR:                     build (ver 2.3.0)
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    GStreamer:                   YES (1.14.1)
    v4l/v4l2:                    YES (linux/videodev2.h)
  Parallel framework:            OpenMP
  Trace:                         YES (built-in)
  Other third-party libraries:
    Eigen:                       YES (ver 3.3.7)
    Custom HAL:                  YES (carotene (ver 0.0.1))
  Python 3:
    Interpreter:                 /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/bin/python3 (ver 3.8.17)
    Libraries:                   /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib/libpython3.8.so (ver 3.8.17)
    numpy:                       /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/lib/python3.8/site-packages/numpy/core/include (ver 1.21.5)
    install path:                lib/python3.8/site-packages/cv2/python-3.8
  Python (for build):            /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac/bin/python
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
  Install to:                    /croot/opencv-suite_1691620390108/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_plac
Thank you for your help!
Do you use Orin Nano developer kit? And do you use Raspberry Pi camera v2? Orin Nano developer kit + Raspberry Pi camera v2 should work well. It you use imx219 from other vendor, it is not supported by default and you would need to port sensor driver and device tree.
The IMX219 model I have is this one from Seeed.
Also, I am able to record video from the camera using a file sink, so could it still be a compatibility error?
The only other camera I have is the RPi global shutter, should I try to use that instead?
Well, I have no Orin Nano nor Seeed CAMERA IMX219 8MP 160, so you’ll probably get more accurate advice from camera vendor.
If you want to investigate further by yourself, you may check these:
1 Is your camera detected by linux kernel with a driver that can probe it ?
IMX219 camera would have a control path with I2C, and a data path with MIPI/CSI. Details for your hardware would be passed to kernel trough device tree.
First check if control path allows to probe device. For that after boot you may have a look to kernel messages and get relevant ones with:
sudo dmesg | egrep -i "imx219|i2c|cam"
If you have only one camera connected, it may report error for no camera probed on the second connector (Note the different I2C bus for each).
As @DaneLLL mentioned, default support is for Adafruit RPi v2 camera. For other camera models, some changes may have to be applied. Your vendor would better tell here. Note that jetson-io script may be used for setting the I2C IO config.
If it looks ok, you would have driver to have created video node /dev/video0 for first camera (and so on, USB UVC cams would be numbered afterwards).
ls -l /dev/video*
2 If ok so far, let’s try V4L API
You would use v4l2-ctl (can be apt installed from package v4l-utils)
See what formats are reported as supported:
v4l2-ctl -d /dev/video0 --list-formats-ext
# Try capture one frame:
v4l2-ctl -d /dev/video0 --set-ctrl=bypass_mode=0,sensor_mode=0 --stream-mmap --stream-count=1 --stream
-to=frame.RG10
# Try video capture (frames not saved, sent to /dev/null):
(See this for decoding RAW RG10 frame)
3 If it works so far, you would try Argus from gstreamer:
# Assuming you have a local GUI session opened:
gst-launch-1.0 nvarguscamerasrc ! nvvidconv ! autovideosink
4 Misc
You would share the working pipeline.
Probably not a better idea, as this would involve another sensor driver with additional issues.
This would use second camera. If you only have one working, this would probably fail. Try sensor-id=0 for first camera.
Please try Honey_Patouceul’s suggestion. And if you can launch the camera in gst-launch-1.0 command, please then try this sample:
[Gstreamer] nvvidconv, BGR as INPUT - #4 by DaneLLL
