GPU - GTX 1050, 3GB
CPU - Corei5 9thGen, 16GB RAM, Thread(s) per core: 2, Core(s) per socket: 4
Stream -
Resolution - 1920x1080
FPS - 15fps
Bitrate - 1536kbps
I’m trying to encode and decode rtsp streams using Video Code SDK .
There are 2 combinations -
1. Encode on CPU and Decode on GPU
Works fine but takes a lot of CPU usage.
Pipeline -
ffmpeg_cmd = [“ffmpeg”, “-y”,"-vsync", “0”, “-hwaccel_output_format”,“cuvid”, “-c:v”, “h264_cuvid”, “-i”,RTSP_STREAM,
“-f”,“rawvideo”, “-c:v”,“h264_nvenc”, “-pix_fmt”,“yuv420p”, “-”]
2. Encode and decode on GPU
Low CPU Usage but I receive bad noisy frames.
Pipeline-
ffmpeg_cmd = [“ffmpeg”, “-y”,"-vsync", “0”, “-hwaccel_output_format”,“cuvid”,“-c:v”, “h264_cuvid”, “-i”,RTSP_STREAM, “-f”,“rawvideo”, “-pix_fmt”,“yuv420p”, “-”]
One thing I observed, when I work with CPU encoding, for -
x = ffmpeg.stdout.read(int(w* h *6//4))
x grabs data for each frame and then moves on to the next steps in converting from yuv_2_rgb.
However, in GPU streaming, the pipeline takes bad data after 300-500 frames
CODE -
import subprocess as sp
import numpy as np
import cv2
def yuv_2_rgb_math(ffmpeg):
w = 1920
h = 1080
k = w*h
ys = []
us = []
vs = []
x = ffmpeg.stdout.read(int(w*h*6//4)) # read bytes of single frames
y = np.frombuffer(x[0:k], dtype=np.uint8).reshape((h, w))
u = np.frombuffer(x[k:k+k//4], dtype=np.uint8).reshape((h//2, w//2))
v = np.frombuffer(x[k+k//4:], dtype=np.uint8).reshape((h//2, w//2))
u = np.reshape(cv2.resize(np.expand_dims(u, -1), (w, h)), (h, w))
v = np.reshape(cv2.resize(np.expand_dims(v, -1), (w, h)), (h, w))
ys.append(y)
us.append(u)
vs.append(v)
y = np.array(ys, dtype=np.float32)
u = np.array(us, dtype=np.float32)
v = np.array(vs, dtype=np.float32)
r = y+1.371*(v-128)
g = y+0.338* (u-128)-0.698*(v-128)
b = y+1.732*(u-128)
result = np.stack([b, g, r], axis=-1)
result = np.clip(result, 0, 255)
return result.astype(np.uint8)
def main(ffmpeg_cmd):
ffmpeg = sp.Popen(ffmpeg_cmd, stdout=sp.PIPE, bufsize=10)
while True:
image = yuv_2_rgb_math(ffmpeg,count)
image = np.concatenate(image, axis=0)
cv2.imwrite('Input Feed.jpg', image)
