CAST operator in ONNX model to convert INT32 to other types for DLA
Description
im converting pytorch to onnx model then to tensorrt. while converting to trt, i got these errors:
-Please explicitly use CAST operator in ONNX model or add an identity layer to convert INT32 to other types for DLA.
-DLA Layer /model.0/conv/Conv does not support dynamic shapes in any dimension.
-DLA only supports FP16 and Int8 precision type. Switching this layer’s device type to GPU.
i added code lines for casting to fp16 on the pt2onnx file, but i still get the errors
Environment
TensorRT Version: 8.2.5.1
GPU Type: Jetson AGX Orin
Nvidia Driver Version: 35.1.0
CUDA Version: 11.4
CUDNN Version: 8.9.4.25
Operating System + Version: Ubuntu 20.04
PyTorch Version (if applicable): 1.14
Relevant Files
pt to onnx code:
pt2onnx.py (5.7 KB)
onnx to trt trtexec file:
onnx2trt.sh (704 Bytes)
Thank you
Please check the below links, as they might answer your concerns.
We are moving this post to the Jetson AGX Orin forum to get better help.
