CBB error kernel panic still found on JP5.1.1
CBB error kernel panic still found on JP5.1.1, R35.3.1
▒▒[ 3.050264] CPU:0, Error: cbb-noc@2300000, irq=15
[ 3.090341] **************************************
[ 3.090501] CPU:0, Error:cbb-noc
[ 3.090607] Error Logger : 0
[ 3.090692] ErrLog0 : 0x80030000
[ 3.090796] Transaction Type : RD - Read, Incrementing
[ 3.090942] Error Code : SLV
[ 3.091030] Error Source : Target
[ 3.091121] Error Description : Target error detected by CBB slave
[ 3.091284] AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 3.091481] Packet header Lock : 0
[ 3.091572] Packet header Len1 : 3
[ 3.091662] NOC protocol version : version >= 2.7
[ 3.091782] ErrLog1 : 0x350e2c
[ 3.091865] ErrLog2 : 0x0
[ 3.091935] RouteId : 0x350e2c
[ 3.092019] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 3.092138] Targflow : host1x_p2pm/T/host1x_p2pm
[ 3.092267] TargSubRange : 7
[ 3.092348] SeqId : 0
[ 3.092442] ErrLog3 : 0x101c
[ 3.092521] ErrLog4 : 0x0
[ 3.092606] Address accessed : 0x1520101c
[ 3.092738] ErrLog5 : 0xb09f851
[ 3.092989] Non-Modify : 0x1
[ 3.095456] AXI ID : 0x16
[ 3.098347] Master ID : CCPLEX
[ 3.101672] Security Group(GRPSEC): 0x7e
[ 3.106130] Cache : 0x1 – Bufferable
[ 3.110074] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 3.117156] FALCONSEC : 0x0
[ 3.120305] Virtual Queuing Channel(VQC): 0x0
[ 3.124685] **************************************
[ 3.129965] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[ 3.136061] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 3.141654] Modules linked in:
[ 3.144633] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.104-tegra #1
[ 3.151199] Hardware name: NVIDIA Jetson Xavier NX, BIOS 07/17/2023
[ 3.162134] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=–)
[ 3.167746] pc : tegra194_cbb_err_isr+0x19c/0x1b0
[ 3.172461] lr : tegra194_cbb_err_isr+0x11c/0x1b0
[ 3.177443] sp : ffff800010003df0
[ 3.180598] x29: ffff800010003df0 x28: 0000000000000001
[ 3.186368] x27: 0000000000000080 x26: ffffdee115931b08
[ 3.191794] x25: ffffdee11627ae38 x24: 0000000000000001
[ 3.197219] x23: ffffdee115c16000 x22: ffffdee11609e7b0
[ 3.202296] x21: 000000000000000f x20: 0000000000000005
[ 3.207811] x19: ffffdee11609e7a0 x18: 0000000000000010
[ 3.213235] x17: 0000000000006270 x16: 0000000000004350
[ 3.218831] x15: ffffdee115f12bf0 x14: 0720072007200720
[ 3.224343] x13: 0720072007200720 x12: 0720072007200720
[ 3.229856] x11: 0720072007200720 x10: 0720072007200720
[ 3.235116] x9 : 0720072007200720 x8 : 07200720072a072a
[ 3.240623] x7 : 072a072a072a072a x6 : c0000000ffffefff
[ 3.246391] x5 : 0000000000057fa8 x4 : ffffdee115f27968
[ 3.251820] x3 : 00000000ffffffff x2 : ffffdee1143edd60
[ 3.257154] x1 : ffffdee115f12680 x0 : 0000000100010001
[ 3.262236] Call trace:
[ 3.264949] tegra194_cbb_err_isr+0x19c/0x1b0
[ 3.269250] __handle_irq_event_percpu+0x68/0x2a0
[ 3.273781] handle_irq_event_percpu+0x40/0xa0
[ 3.277987] handle_irq_event+0x50/0xf0
[ 3.281750] handle_fasteoi_irq+0xc0/0x170
[ 3.285793] generic_handle_irq+0x40/0x60
[ 3.289798] __handle_domain_irq+0x70/0xd0
[ 3.294001] efi_header_end+0xb0/0xf0
[ 3.297501] el1_irq+0xd0/0x180
[ 3.300478] cpuidle_enter_state+0xb8/0x410
[ 3.304675] cpuidle_enter+0x40/0x60
[ 3.308432] call_cpuidle+0x44/0x80
[ 3.311931] do_idle+0x208/0x270
[ 3.315344] cpu_startup_entry+0x30/0x70
[ 3.319108] rest_init+0xdc/0xe8
[ 3.322089] arch_call_rest_init+0x18/0x20
[ 3.326286] start_kernel+0x514/0x54c
[ 3.329878] Code: a9446bf9 a94573fb a8c67bfd d65f03c0 (d4210000)
[ 3.335842] —[ end trace 024104ac590c1905 ]—
[ 3.340807] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 3.348079] SMP: stopping secondary CPUs
[ 3.351963] Kernel Offset: 0x5ee104230000 from 0xffff800010000000
[ 3.358051] PHYS_OFFSET: 0xfffffd3340000000
[ 3.362162] CPU features: 0x8240002,03802a30
[ 3.366621] Memory Limit: none
[ 3.369779] —[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]—
Custom board? devkit?
開機的時候UEFI logo有出現嗎?
多常發生一次?
Custom board, hasn’t run test on devkit.
UEFI logo is showed. When it happened, it will reboot triggered by watchdog.
Yes we know watchdog will happen. Is boot logo a must-have one for your product?
If boot logo can be bypass, what’s the workaround? Thanks.
你可以參考另外兩個head的device tree設定 “bootloader-status = disabled”
這個加上之後boot logo會被關閉
但可以確保這個問題不會發生
@WayneWWW Do you have any plan to fix it? in next which release? thanks.
This issue won’t really get fixed. We only have several workaround patch to make it won’t easier happened.
For example, add this to your display driver code.
diff --git a/drivers/video/tegra/dc/dc.c b/drivers/video/tegra/dc/dc.c
index 1cedba9..86058c2 100644
--- a/drivers/video/tegra/dc/dc.c
+++ b/drivers/video/tegra/dc/dc.c
@@ -6374,6 +6374,10 @@
 		pr_debug("dc->fb_mem not initialized\n");
 		return false;
+		return false;
 	return (dc->fb_mem->start != 0);
 EXPORT_SYMBOL(tegra_is_bl_display_initialized);
Thanks for your comments, compared to the workaround "“bootloader-status = disabled”, which one has better experience to customer, Thanks.
if your customer does not need logo, then disable boot logo can 100% bypass this error.
