Cbb causing a kernel panic
We are in the process of upgrading our device from JetPack 5.0.2 to JetPack 5.1.
We have the code ported to JetPack 5.1. When we boot using JetPack 5.1we are getting an error:
kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
and the device resets several times until it eventually boots.
We did not encounter this error in JetPack 5.02 and our application code has not changed.
I am looking for guidance on what causes this error so I can determine a solution to this on our device.
Malcolm
what steps did you take to upgrade the JetPack version?
Can you give the UART log when it boots up?
We checked out the JP5.1 as a new environment and then added our patch to the files in the kernel/ and hardware/ folders.
Attached is the serial log:
[ 7.287567] Extcon DP: HPD disabled
[ 7.287572] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 7.287584] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 7.292656] usb 1-2: Manufacturer: Microchip
[ 7.297696] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 7.322288] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.328313] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.328514] hub 1-2:1.0: USB hub found
[ 7.328604] hub 1-2:1.0: 7 ports detected
[ 7.331678] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[ 7.338595] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.342973] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.345003] tegra-se-nvhost 15820000.se: initialized
[ 7.350362] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 7.355892] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.363448] usb 2-3: New USB device found, idVendor=0424, idProduct=7216, bcdDevice= 6.22
[ 7.364902] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[ 7.370609] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.370619] usb 2-3: Product: USB7216 Smart Hub
[ 7.393020] CPU:0, Error: cbb-noc@2300000, irq=15
[ 7.393024] **************************************
[ 7.393026] CPU:0, Error:cbb-noc
[ 7.393030] Error Logger : 0
[ 7.393040] ErrLog0 : 0x80030000
[ 7.393042] Transaction Type : RD - Read, Incrementing
[ 7.393045] Error Code : SLV
[ 7.393047] Error Source : Target
[ 7.393050] Error Description : Target error detected by CBB slave
[ 7.393059] AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 7.393065] Packet header Lock : 0
[ 7.393067] Packet header Len1 : 3
[ 7.393070] NOC protocol version : version >= 2.7
[ 7.393073] ErrLog1 : 0x350e2c
[ 7.393076] ErrLog2 : 0x0
[ 7.393079] RouteId : 0x350e2c
[ 7.393082] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 7.393084] Targflow : host1x_p2pm/T/host1x_p2pm
[ 7.393087] TargSubRange : 7
[ 7.393089] SeqId : 0
[ 7.393093] ErrLog3 : 0x10180
[ 7.393095] ErrLog4 : 0x0
[ 7.393099] Address accessed : 0x15210180
[ 7.393102] ErrLog5 : 0xb09f851
[ 7.393105] Non-Modify : 0x1
[ 7.393108] AXI ID : 0x16
[ 7.393110] Master ID : CCPLEX
[ 7.393114] Security Group(GRPSEC): 0x7e
[ 7.393117] Cache : 0x1 – Bufferable
[ 7.393120] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 7.393123] FALCONSEC : 0x0
[ 7.393126] Virtual Queuing Channel(VQC): 0x0
[ 7.393130] **************************************
[ 7.393169] ------------[ cut here ]------------
[ 7.393172] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[ 7.393178] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 7.393183] Modules linked in:
[ 7.393204] CPU: 0 PID: 123 Comm: kworker/0:3 Not tainted 5.10.104-tegra-pcm-0.0.1 #9
[ 7.393207] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 7.393224] Workqueue: usb_hub_wq hub_event
Malcolm
just to make sure: The device is still able to boot into the system after encountering kernel panic right?
I will check it with our developer.
Yes. The device will boot. On occasion, I have seen it take 3 attempts, but it will boot. Its more likely to happen from a power on then a reboot.
Malcolm
Please upgrade tp jp5.1.1 and also check if this is related to the connection of the monitors.
We cannot upgrade right now.
Yes. There is an LCD connected when this occurs.
Please provide suggestions on how to correct this.
Malcolm
You can check rel-35.3.1 dtb and check the “bootloader-status” keyword. Add it to your dtb and try again.
HI
I did check the “bootloader-status”. Are you referring to having it defined in the file tegra194-soc-base.dtsi?
I do see it in that file under display@15210000, display@15210000, and display@15220000. They are all defined as bootloader-status = “disabled”;
When you mention “check the bootloader-status keyword”. is this where you are referring or is there another location where this should be added?
When I enable bootloader-status = “okay” for display@15210000 in tegra194-soc-base.dts, the LCD works during boot (I see the boot messages) , then goes off and there is no kernel panic, but the LCD is never comes back on.
Any suggestions on what to try?
Thanks for your help.
Malcolm
No, I mean add bootloader-status= disabled to your rel-35.2.1 device tree…
This will disable the boot logo but you shall not hit any kernel panic anymore.
Hi
I am not sure where in the device tree that this bootloader-status= disabled should be added.
We build your device tree where the top level file is tegra194-p3668-0001-p3509-0000.dts and many other dtsi’s are included.
Thanks for your help and patience with me on this.
Malcolm
What is the exact question here? It sounds like your comment conflicts to itself.
You said you saw it. Good. Now you should know where to add it.
Why you suddenly cannot tell where to add it again? Didn’t you just say you see it?
That’s what is confusing me. It has always been in the device tree. It is defined and is part of jetpack and the reboot is occurring.
So when you say:
“No, I mean add bootloader-status= disabled to your rel-35.2.1 device tree…”
Its already there and there is a reboot.
What do you mean then by add it.
Malcolm
Could you share a full boot up log with your error log so that we can tell whether that patch is related to your issue or not?
Also, I think this is a custom board but not devkit, right? If so, at least share a schematic or block diagram to tell the hardware connection of your display setup.
Thanks for reviewing.
Yes. This is a custom board. I would have to get permission to share a schematic. It is through a Microchip USB part. This hardware and configuration works in JetPack 5.0.2. When we upgraded to JetPack5.1.1 this kernel panic occurs. So it seem to relate to the kernel upgrade. I cannot determine what kernel change would cause the issue.
Here is the log:
[ 0.000000] Linux version 5.10.104-tegra-pcm-0.0.1 (elab@elab-ThinkCentre-M700) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot
3
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x259d4dc98 MEMATTR=0x259131018 ESRT=0x259162698 RNG=0x27c52e418 MEMRESERVE=0x259133f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000259162698 to 0x00000002591626d0.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000025860efff]
[ 0.000000] node 0: [mem 0x000000025860f000-0x00000002587b7fff]
[ 0.000000] node 0: [mem 0x00000002587b8000-0x000000025904ffff]
[ 0.000000] node 0: [mem 0x0000000259050000-0x000000025909ffff]
[ 0.000000] node 0: [mem 0x00000002590a0000-0x00000002590cffff]
[ 0.000000] node 0: [mem 0x00000002590d0000-0x00000002590fffff]
[ 0.000000] node 0: [mem 0x0000000259100000-0x000000025913ffff]
[ 0.000000] node 0: [mem 0x0000000259140000-0x000000025915ffff]
[ 0.000000] node 0: [mem 0x0000000259160000-0x000000025923ffff]
[ 0.000000] node 0: [mem 0x0000000259240000-0x00000002592dffff]
[ 0.000000] node 0: [mem 0x00000002592e0000-0x00000002592fffff]
[ 0.000000] node 0: [mem 0x0000000259300000-0x000000025934ffff]
[ 0.000000] node 0: [mem 0x0000000259350000-0x000000025939ffff]
[ 0.000000] node 0: [mem 0x00000002593a0000-0x00000002597affff]
[ 0.000000] node 0: [mem 0x00000002597b0000-0x00000002597fffff]
[ 0.000000] node 0: [mem 0x0000000259800000-0x000000025984ffff]
[ 0.000000] node 0: [mem 0x0000000259850000-0x0000000259d1ffff]
[ 0.000000] node 0: [mem 0x0000000259d20000-0x0000000259d2ffff]
[ 0.000000] node 0: [mem 0x0000000259d30000-0x0000000259eaffff]
[ 0.000000] node 0: [mem 0x0000000259eb0000-0x0000000259f4ffff]
[ 0.000000] node 0: [mem 0x0000000259f50000-0x000000025a04ffff]
[ 0.000000] node 0: [mem 0x000000025a050000-0x000000025a0effff]
[ 0.000000] node 0: [mem 0x000000025a0f0000-0x000000025a19ffff]
[ 0.000000] node 0: [mem 0x000000025a1a0000-0x000000025a23ffff]
[ 0.000000] node 0: [mem 0x000000025a240000-0x000000025ab4ffff]
[ 0.000000] node 0: [mem 0x000000025ab50000-0x000000025ad2ffff]
[ 0.000000] node 0: [mem 0x000000025ad30000-0x000000027c4dffff]
[ 0.000000] node 0: [mem 0x000000027c4e0000-0x000000027c52ffff]
[ 0.000000] node 0: [mem 0x000000027c530000-0x000000027fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1839269
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 n
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 6942100K/7473856K available (18880K kernel code, 3188K rwdata, 7232K rodata, 4032K init, 1586K bss, 466220K rese
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000637] Console: colour dummy device 80x25
[ 0.002091] printk: console [tty0] enabled
[ 0.002161] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.002219] pid_max: default: 32768 minimum: 301
[ 0.002428] LSM: Security Framework initializing
[ 0.002487] Yama: becoming mindful.
[ 0.002533] SELinux: Initializing.
[ 0.002750] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002788] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.006013] rcu: Hierarchical SRCU implementation.
[ 0.006244] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.007024] DTS File Name: /home/elab/Projects/jp_5_1_1/Linux_for_Tegra/kernelsrc/sources/kernel/kernel-5.10/arch/arm64/boot/dts/…/
s
[ 0.007080] DTB Build time: Jun 14 2023 16:29:33
[ 0.010315] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.010794] Remapping and enabling EFI services.
[ 0.012265] smp: Bringing up secondary CPUs …
[ 0.045166] Detected PIPT I-cache on CPU1
[ 0.045244] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.074504] Detected PIPT I-cache on CPU2
[ 0.074598] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.103984] Detected PIPT I-cache on CPU3
[ 0.104070] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.133594] Detected PIPT I-cache on CPU4
[ 0.133692] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.163190] Detected PIPT I-cache on CPU5
[ 0.163353] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.164788] smp: Brought up 1 node, 6 CPUs
[ 0.165062] SMP: Total of 6 processors activated.
[ 0.165077] CPU features: detected: Privileged Access Never
[ 0.165089] CPU features: detected: LSE atomic instructions
[ 0.165101] CPU features: detected: User Access Override
[ 0.165114] CPU features: detected: 32-bit EL0 Support
[ 0.165126] CPU features: detected: RAS Extension Support
[ 0.165139] CPU features: detected: CRC32 instructions
[ 0.165151] CPU features: detected: 32-bit EL1 Support
[ 0.232501] CPU: All CPU(s) started at EL2
[ 0.238024] devtmpfs: initialized
[ 0.297612] Registered cp15_barrier emulation handler
[ 0.297714] Registered setend emulation handler
[ 0.297733] KASLR enabled
[ 0.298023] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.298047] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.299290] pinctrl core: initialized pinctrl subsystem
[ 0.300277] DMI not present or invalid.
[ 0.300931] NET: Registered protocol family 16
[ 0.302865] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.303354] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.304052] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.304116] audit: initializing netlink subsys (disabled)
[ 0.304387] audit: type=2000 audit(0.300:1): state=initialized audit_enabled=0 res=1
[ 0.304850] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.304856] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.304871] thermal_sys: Registered thermal governor ‘pid_thermal_gov’
[ 0.307265] cpuidle: using governor menu
[ 0.307565] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.307989] ASID allocator initialised with 32768 entries
[ 0.308248] Serial: AMBA PL011 UART driver
[ 0.311810] Tegra reboot handler registered.
[ 0.394153] tegra194-pinctrl 2430000.pinmux: there is not valid maps for state drive
[ 0.396758] tegra194-pinctrl 2430000.pinmux: invalid function shutdown in map table
[ 0.397124] tegra194-pinctrl 2430000.pinmux: invalid group “pex_l5_clkreq_n” for function “pe5”
[ 0.397159] tegra194-pinctrl 2430000.pinmux: does not have pin group pex_l5_clkreq_n
[ 0.397173] tegra194-pinctrl 2430000.pinmux: could not map group config for “pex_l5_clkreq_n”
[ 0.397193] tegra194-pinctrl 2430000.pinmux: invalid group “pex_l5_rst_n” for function “pe5”
[ 0.397228] tegra194-pinctrl 2430000.pinmux: does not have pin group pex_l5_rst_n
[ 0.397240] tegra194-pinctrl 2430000.pinmux: could not map group config for “pex_l5_rst_n”
[ 0.403149] mc: mapped MMIO address: 0xffff800010580000 → 0x2c10000
[ 0.403180] mc: mapped MMIO address: 0xffff8000105a0000 → 0x2c20000
[ 0.403205] mc: mapped MMIO address: 0xffff8000105c0000 → 0x2c30000
[ 0.403229] mc: mapped MMIO address: 0xffff8000105e0000 → 0x2c40000
[ 0.403255] mc: mapped MMIO address: 0xffff800010600000 → 0x2c50000
[ 0.403278] mc: mapped MMIO address: 0xffff800010620000 → 0x2b80000
[ 0.403301] mc: mapped MMIO address: 0xffff800010640000 → 0x2b90000
[ 0.403324] mc: mapped MMIO address: 0xffff800010660000 → 0x2ba0000
[ 0.403346] mc: mapped MMIO address: 0xffff800010680000 → 0x2bb0000
[ 0.403369] mc: mapped MMIO address: 0xffff8000106a0000 → 0x1700000
[ 0.403409] mc: mapped MMIO address: 0xffff8000106c0000 → 0x1710000
[ 0.403435] mc: mapped MMIO address: 0xffff8000106e0000 → 0x1720000
[ 0.403473] mc: mapped MMIO address: 0xffff800010700000 → 0x1730000
[ 0.403497] mc: mapped MMIO address: 0xffff800010720000 → 0x1740000
[ 0.403565] mc: mapped MMIO address: 0xffff800010740000 → 0x1750000
[ 0.403590] mc: mapped MMIO address: 0xffff800010760000 → 0x1760000
[ 0.403616] mc: mapped MMIO address: 0xffff800010780000 → 0x1770000
[ 0.403706] mc-err: mcerr ops are set to t19x
[ 0.417394] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.417416] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.417431] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.417445] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.423880] ACPI: Interpreter disabled.
[ 0.425134] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.426443] iommu: Default domain type: Translated
[ 0.426533] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.426916] SCSI subsystem initialized
[ 0.427102] usbcore: registered new interface driver usbfs
[ 0.427146] usbcore: registered new interface driver hub
[ 0.427188] usbcore: registered new device driver usb
[ 0.427660] mc: Linux media interface: v0.10
[ 0.427743] videodev: Linux video capture interface: v2.00
[ 0.428077] pps_core: LinuxPPS API ver. 1 registered
[ 0.428088] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.428108] PTP clock support registered
[ 0.428328] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.428634] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.428719] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.429405] Registered efivars operations
[ 0.429770] FPGA manager framework
[ 0.429840] Advanced Linux Sound Architecture Driver Initialized.
[ 0.430443] Bluetooth: Core ver 2.22
[ 0.430484] NET: Registered protocol family 31
[ 0.430496] Bluetooth: HCI device and connection manager initialized
[ 0.430511] Bluetooth: HCI socket layer initialized
[ 0.430525] Bluetooth: L2CAP socket layer initialized
[ 0.430545] Bluetooth: SCO socket layer initialized
[ 0.432127] camchar: rtcpu character device driver loaded
[ 0.432861] clocksource: Switched to clocksource arch_sys_counter
[ 0.721874] VFS: Disk quotas dquot_6.6.0
[ 0.721946] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.722278] pnp: PnP ACPI: disabled
[ 0.734987] la/ptsa driver initialized.
[ 0.735107] NET: Registered protocol family 2
[ 0.735300] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.741036] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.741158] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.741412] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.741838] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.741953] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.742048] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.742225] NET: Registered protocol family 1
[ 0.742737] RPC: Registered named UNIX socket transport module.
[ 0.742750] RPC: Registered udp transport module.
[ 0.742780] RPC: Registered tcp transport module.
[ 0.742789] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.742803] PCI: CLS 0 bytes, default 64
[ 0.742996] Trying to unpack rootfs image as initramfs…
[ 0.956499] Freeing initrd memory: 9120K
[ 0.962035] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.962410] kvm [1]: IPA Size Limit: 40 bits
[ 0.962866] kvm [1]: vgic interrupt IRQ9
[ 0.963347] kvm [1]: VHE mode initialized successfully
[ 0.964853] Initialise system trusted keyrings
[ 0.965107] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.971409] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.972288] NFS: Registering the id_resolver key type
[ 0.972317] Key type id_resolver registered
[ 0.972327] Key type id_legacy registered
[ 0.972408] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.972425] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.972452] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.981408] NET: Registered protocol family 38
[ 0.981428] Key type asymmetric registered
[ 0.981462] Asymmetric key parser ‘x509’ registered
[ 0.981508] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.981691] io scheduler mq-deadline registered
[ 0.981704] io scheduler kyber registered
[ 0.987043] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[ 0.989878] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.989959] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.990013] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.990067] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 0.990119] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.995252] scrncapt: init (heads:4 wins:6 planes:4)
[ 0.995492] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 0.996458] EINJ: ACPI disabled.
[ 0.999439] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.999460] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.999471] tegra-pmc: ### PMC reset level: L0
[ 0.999479] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.999517] tegra-pmc: PMC Prod config success
[ 1.004605] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.013448] random: fast init done
[ 1.018224] printk: console [ttyTCU0] enabled
[ 2.526581] arm-smmu 10000000.iommu: probing hardware configuration…
[ 2.530573] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.535177] arm-smmu 10000000.iommu: stage 1 translation
[ 2.541009] arm-smmu 10000000.iommu: stage 2 translation
[ 2.546136] arm-smmu 10000000.iommu: nested translation
[ 2.551759] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.558901] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.570122] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.571825] arm-smmu 10000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.578669] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.586341] arm-smmu 12000000.iommu: probing hardware configuration…
[ 2.591447] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.596169] arm-smmu 12000000.iommu: stage 1 translation
[ 2.601947] arm-smmu 12000000.iommu: stage 2 translation
[ 2.607106] arm-smmu 12000000.iommu: nested translation
[ 2.612790] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.619972] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.630963] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.632832] arm-smmu 12000000.iommu: Stage-1: 48-bit VA → 48-bit IPA
[ 2.639649] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA → 48-bit PA
[ 2.646839] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.657378] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.659776] tegra_profiler: auth: init
[ 2.664347] THERMAL EST: found 3 subdevs
[ 2.667489] THERMAL EST num_resources: 0
[ 2.671588] [THERMAL EST subdev 0]
[ 2.674655] [THERMAL EST subdev 1]
[ 2.678324] [THERMAL EST subdev 2]
[ 2.681313] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.687830] THERMAL EST: thz register success.
[ 2.692033] THERMAL EST: end of probe, return err: 0
[ 2.697687] nvsciipc: loaded module
[ 2.704842] tun: Universal TUN/TAP device driver, 1.6
[ 2.707086] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.713336] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.718895] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.723577] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.729922] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.734941] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.741253] PPP generic driver version 2.4.2
[ 2.745638] PPP BSD Compression module registered
[ 2.750178] PPP Deflate Compression module registered
[ 2.755170] PPP MPPE Compression module registered
[ 2.760186] usbcore: registered new interface driver r8152
[ 2.765950] usbcore: registered new interface driver asix
[ 2.771028] usbcore: registered new interface driver ax88179_178a
[ 2.777416] usbcore: registered new interface driver cdc_ether
[ 2.783365] usbcore: registered new interface driver net1080
[ 2.788738] usbcore: registered new interface driver cdc_subset
[ 2.794746] usbcore: registered new interface driver zaurus
[ 2.800449] usbcore: registered new interface driver cdc_ncm
[ 2.806367] usbcore: registered new interface driver qmi_wwan
[ 2.811532] usbcore: registered new interface driver cdc_mbim
[ 2.817564] usbcore: registered new interface driver aqc111
[ 2.823400] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.829294] ohci-pci: OHCI PCI platform driver
[ 2.833758] ohci-platform: OHCI generic platform driver
[ 2.839340] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.845506] usbcore: registered new interface driver cdc_wdm
[ 2.850349] usbcore: registered new interface driver uas
[ 2.855565] usbcore: registered new interface driver usb-storage
[ 2.861532] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.867859] mousedev: PS/2 mouse device common for all mice
[ 2.872544] usbcore: registered new interface driver xpad
[ 2.880677] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.883587] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 2.891519] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.898105] i2c /dev entries driver
[ 2.901591] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.907141] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.912766] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.918036] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.923059] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.928941] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.934332] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.948269] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.949032] device-mapper: uevent: version 1.0.3
[ 2.951144] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.961707] cpuidle: Initializing cpuidle driver
[ 2.965290] sdhci: Secure Digital Host Controller Interface driver
[ 2.970140] sdhci: Copyright(c) Pierre Ossman
[ 2.974601] Synopsys Designware Multimedia Card Interface Driver
[ 2.980840] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.986818] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 2.987397] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 2.999776] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.021336] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 3.030704] vdd-1v0: supplied by regulator-dummy
[ 3.036081] vdd-1v8-hs: supplied by regulator-dummy
[ 3.040758] vdd-1v8-ls: supplied by regulator-dummy
[ 3.045520] vdd-1v8-ao: supplied by regulator-dummy
[ 3.049265] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.053828] vdd-rtc: supplied by regulator-dummy
[ 3.055638] spmic-ldo1: supplied by regulator-dummy
[ 3.057042] vdd-ao-3v3: supplied by regulator-dummy
[ 3.063249] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.069601] spmic-ldo4: supplied by regulator-dummy
[ 3.070998] vdd-usb-3v3: supplied by regulator-dummy
[ 3.077322] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.083617] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.089527] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.091376] gpio-510 (gpio_default): hogged as output/high
[ 3.093165] gpio-511 (gpio_default): hogged as output/high
[ 3.095836] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.231609] max77686-rtc max77620-rtc: registered as rtc0
[ 3.232873] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 3.233170] max77620 4-003c: max77620 probe successful
��rm_rail_debugfs_init: /rm/vdd_cpu: failed
debugfs initialized
��[ 3.918008] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.919060] hid: raw HID events driver (C) Jiri Kosina
[ 3.919751] usbcore: registered new interface driver usbhid
[ 3.919888] usbhid: USB HID core driver
[ 3.921558] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[ 3.922713] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[ 28.363532] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 28.438895] Camera-FW on t194-rce-safe ready SHA1=26f9e5f7 (crt 0.775 ms, total boot 76.167 ms)
��[ 4.007789] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.008359] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.009271] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.010041] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.011668] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xf
0
[ 4.012253] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0
0
[ 4.013000] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.014038] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[ 4.014329] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.016153] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=26f9e5f7dc48f7914a7654904022cf8ae53e1e9f
[ 4.024387] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 4.030633] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.035639] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.041748] denver_knobs_init:MTS_VERSION:55637613
[ 4.054177] t19x_cache tegra-cache: probed
[ 4.059266] optee: probing for conduit method.
[ 4.060117] optee: revision 3.19 (3f29c61f)
[ 4.061381] optee: dynamic shared memory is enabled
[ 4.063760] optee: initialized driver
[ 4.070721] nvpmodel: initialized successfully
[ 4.071448] tegra_hv: get_hvd: not initialized yet
[ 4.075043] user_ivc_mempool: hypervisor not present
[ 4.081147] usbcore: registered new interface driver snd-usb-audio
[ 4.087761] u32 classifier
[ 4.089052] input device check on
[ 4.092694] Actions configured
[ 4.096190] Initializing XFRM netlink socket
[ 4.101504] NET: Registered protocol family 10
[ 4.107875] Segment Routing with IPv6
[ 4.108638] NET: Registered protocol family 17
[ 4.113054] NET: Registered protocol family 15
[ 4.117331] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if yo
[ 4.130687] Bluetooth: RFCOMM socket layer initialized
[ 4.135323] Bluetooth: RFCOMM ver 1.11
[ 4.139201] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.145324] Bluetooth: HIDP socket layer initialized
[ 4.151077] 9pnet: Installing 9P2000 support
[ 4.154796] Key type dns_resolver registered
[ 4.160255] registered taskstats version 1
[ 4.163231] Loading compiled-in X.509 certificates
[ 4.201337] Loaded X.509 cert ‘Build time autogenerated kernel key: 4db54f2fb6c869d577b6b4ea55b934d8f7f1f0f2’
[ 4.204328] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 4.209905] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 4.210206] tegra194-pcie 14160000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 4.210566] tegra194-pcie 14160000.pcie: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 4.210919] tegra194-pcie 14160000.pcie: MEM 0x1740000000…0x17ffffffff → 0x0040000000
[ 5.325686] tegra194-pcie 14160000.pcie: Phy link never came up
[ 5.326251] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.326440] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.326587] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 5.326818] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 5.327112] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 5.327524] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 5.328124] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.354400] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.354698] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.357191] pcieport 0004:00:00.0: Adding to iommu group 6
[ 5.358980] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 5.360698] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 5.362235] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 5.363333] pci 0004:00:00.0: Removing from iommu group 6
[ 5.363620] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 5.368332] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[ 5.373893] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 5.374258] tegra194-pcie 141a0000.pcie: IO 0x003a100000…0x003a1fffff → 0x003a100000
[ 5.374566] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 5.374873] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000…0x1fffffffff → 0x0040000000
[ 5.484898] tegra194-pcie 141a0000.pcie: Link up
[ 5.494994] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 5.495165] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 5.495309] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 5.495541] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 5.495733] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 5.496003] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.496324] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.507597] pci 0005:01:00.0: [126f:2262] type 00 class 0x010802
[ 5.507958] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 5.522547] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 5.522822] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 5.523132] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 5.523298] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 5.523570] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.523874] pci 0005:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.524861] pcieport 0005:00:00.0: Adding to iommu group 7
[ 5.525585] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[ 5.526283] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[ 5.531295] nvme 0005:01:00.0: Adding to iommu group 7
[ 5.536597] nvme nvme0: pci function 0005:01:00.0
[ 5.540491] nvme 0005:01:00.0: enabling device (0000 → 0002)
[ 5.549700] nvme nvme0: missing or invalid SUBNQN field.
[ 5.558319] host1x 13e10000.host1x: Adding to iommu group 8
[ 5.561471] nvme nvme0: 6/0/0 default/read/poll queues
[ 5.573487] host1x 13e10000.host1x: initialized
[ 5.574227] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[ 5.574704] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.584695] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[ 5.591201] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.601348] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[ 5.608015] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.618132] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[ 5.624697] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.634473] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[ 5.641222] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.651556] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[ 5.658426] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 5.668452] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[ 5.675114] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 5.685428] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[ 5.692430] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 5.702213] falcon 15340000.vic: Adding to iommu group 17
[ 5.711666] falcon 15340000.vic: initialized
[ 5.712091] falcon 15380000.nvjpg: Adding to iommu group 17
[ 5.719814] falcon 15380000.nvjpg: initialized
[ 5.722216] falcon 154c0000.nvenc: Adding to iommu group 17
[ 5.731220] falcon 154c0000.nvenc: initialized
[ 5.732695] falcon 15a80000.nvenc1: Adding to iommu group 17
[ 5.741668] falcon 15a80000.nvenc1: initialized
[ 5.743020] nvdec 15480000.nvdec: Adding to iommu group 17
[ 5.753396] nvdec 15480000.nvdec: initialized
[ 5.753789] nvdec 15140000.nvdec1: Adding to iommu group 17
[ 5.763392] nvdec 15140000.nvdec1: initialized
[ 5.763776] tsec 15500000.tsec: Adding to iommu group 18
[ 5.770935] tsec 15500000.tsec: initialized
[ 5.772510] tsec 15100000.tsecb: Adding to iommu group 19
[ 5.780344] tsec 15100000.tsecb: initialized
[ 5.784235] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.811068] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.818728] gpio-374 (wifi-enable): hogged as output/high
[ 5.818971] gpio-431 (cam1-enable): hogged as output/high
[ 5.819190] gpio-432 (cam2-enable): hogged as output/high
[ 5.819426] gpio-440 (cam3-enable): hogged as output/high
[ 5.819629] gpio-428 (cam4-enable): hogged as output/high
[ 5.822877] gpio-443 (cam5-enable): hogged as output/high
[ 5.828217] gpio-447 (cam6-enable): hogged as output/high
[ 5.833767] gpio-484 (gmsl1-enable): hogged as output/high
[ 5.838832] gpio-485 (gmsl2-enable): hogged as output/high
[ 5.844539] gpio-486 (gmsl3-enable): hogged as output/high
[ 5.849575] gpio-427 (cp_por_ctrl): hogged as output/low
[ 5.855339] gpio-441 (usb0_id): hogged as input
[ 5.859808] gpio-390 (amp_stby): hogged as output/low
[ 5.864907] gpio-482 (seq_push_button): hogged as input
[ 5.871151] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 5.877282] gpio-319 (wifi2-enable): hogged as output/low
[ 5.881910] gpio-320 (key_switch): hogged as input
[ 5.886838] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 5.893702] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.899850] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 5.905473] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.911368] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 5.917079] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 5.923698] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=5010000, max_bw=5010000
[ 5.932373] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[ 5.941898] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.948896] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 5.955115] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 5.964049] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 5.972624] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 5.981635] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 5.990736] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 5.999947] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.008956] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[ 6.015368] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.024024] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 6.030332] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.039950] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 6.046443] pva 16000000.pva0: Adding to iommu group 22
[ 6.062571] pva 16000000.pva0: initialized
[ 6.064125] pva 16800000.pva1: Adding to iommu group 23
[ 6.070358] pva 16800000.pva1: initialized
[ 6.071847] nvdla 15880000.nvdla0: Adding to iommu group 24
[ 6.079193] nvdla 15880000.nvdla0: initialized
[ 6.079962] nvdla 158c0000.nvdla1: Adding to iommu group 25
[ 6.085192] nvdla 158c0000.nvdla1: initialized
[ 6.086900] tegradccommon 15200000.display-hub: host1x channel mapped
[ 6.087872] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[ 6.087892] tegradc 15200000.display: Adding to iommu group 26
[ 6.088976] tegradc 15210000.display: Adding to iommu group 26
[ 6.091116] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 6.099155] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 6.104974] tegradccommon 15200000.display-hub: dma mapping done
[ 6.111272] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 6.136057] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 6.141514] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 6.147012] tegra_cec 3960000.tegra_cec: probed
[ 6.152467] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 6.158855] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 6.164692] kfuse 3830000.kfuse: initialized
[ 6.168966] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.175009] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.181686] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.188158] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[ 6.197116] serial-tegra 3110000.serial: Adding to iommu group 2
[ 6.202667] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[ 6.211801] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.217691] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 6.232872] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 6.235355] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.240929] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.249177] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 6.257996] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[ 6.264269] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.271953] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.279383] usb usb1: Product: xHCI Host Controller
[ 6.284112] usb usb1: Manufacturer: Linux 5.10.104-tegra-pcm-0.0.1 xhci-hcd
[ 6.291200] usb usb1: SerialNumber: 3610000.xhci
[ 6.296547] hub 1-0:1.0: USB hub found
[ 6.299768] hub 1-0:1.0: 4 ports detected
[ 6.304258] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.309152] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.316759] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.324613] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.332606] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.339879] usb usb2: Product: xHCI Host Controller
[ 6.344575] usb usb2: Manufacturer: Linux 5.10.104-tegra-pcm-0.0.1 xhci-hcd
[ 6.351772] usb usb2: SerialNumber: 3610000.xhci
[ 6.357000] hub 2-0:1.0: USB hub found
[ 6.360376] hub 2-0:1.0: 4 ports detected
[ 6.371871] flex_usb:Probing the usb7216c
[ 6.371879] flex_usb:usb7216c bind address 2d
[ 6.372025] flex_usb:active mode aa5600
[ 6.372464] flex_usb:i2c data array : aa ,56, 0
[ 6.377057] flex_usb:set activemode as aa5600
[ 6.381220] flex_usb:reg_read:0 ,0, 6
[ 6.385529] flex_usb:reg_read:1 ,3, bf
[ 6.389223] flex_usb:reg_read:80 ,30, 0
[ 6.394306] flex_usb:reg_read:99 ,37, 0
[ 6.398473] flex_usb:vid 424
[ 6.401097] flex_usb:usb attach successful
[ 6.404557] pca953x 1-0070: supply vcc not found, using dummy regulator
[ 6.414940] pca953x 1-0070: using no AI
[ 6.420070] gpiochip3: registered GPIOs 297 to 304 on 1-0070
[ 6.430042] pca954x 2-0070: supply vcc-pullup not found, using dummy regulator
[ 6.431713] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 6.438465] pca954x 2-0070: device detect skipped.
[ 6.440045] random: crng init done
[ 6.448562] i2c i2c-2: Added multiplexed i2c bus 30
[ 6.453194] i2c i2c-2: Added multiplexed i2c bus 31
[ 6.458483] i2c i2c-2: Added multiplexed i2c bus 32
[ 6.461891] i2c i2c-2: Added multiplexed i2c bus 33
[ 6.466386] pca954x 2-0070: registered 4 multiplexed busses for I2C mux pca9544
[ 6.483173] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 6.488210] rtc-m41t80 8-0068: Oscillator failure, data is invalid.
[ 6.488555] rtc-m41t80 8-0068: registered as rtc2
[ 6.489716] i2c i2c-8: of_i2c: modalias failure on /i2c@31e0000/gpio@74
[ 6.496219] i2c i2c-8: Failed to create I2C device for /i2c@31e0000/gpio@74
[ 6.506418] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1906000 KHz, changing to: 1907200 KHz
[ 6.515143] tegra194-cpufreq ccplex: probed with BWMGR
[ 6.520449] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 6.520984] irq: IRQ268: trimming hierarchy from :pmc@c360000
[ 6.532974] irq: IRQ269: trimming hierarchy from :pmc@c360000
[ 6.537959] mmc0: CQHCI version 5.10
[ 6.543415] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 6.555018] tegra194-vi5 15c10000.vi: initialized
[ 6.556943] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.558347] nvethernet 2490000.ethernet: Adding to iommu group 27
[ 6.559717] tegradc 15200000.display: parse_dp_settings: No dp-lt-settings node
[ 6.566424] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 6.573106] tegradc 15200000.display: DT parsed successfully
[ 6.581345] nvethernet 2490000.ethernet: failed to read MDIO address
[ 6.586735] tegradc 15200000.display: Display dc.00000000c12fb80e registered with id=0
[ 6.592834] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.593346] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 6.602979] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.608998] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 6.609003] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 6.609024] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 6.616078] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.616089] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 6.624218] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 6.624271] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 6.631228] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 6.636996] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 6.640918] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 6.644900] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 6.644909] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 6.644915] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 6.645919] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 6.714453] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:3b:1a:1d
[ 6.727964] tegradc 15200000.display: probed
[ 6.739726] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 6.747060] Console: switching to colour frame buffer device 80x30
[ 6.747653] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 6.753371] tegradc 15200000.display: fb registered
[ 6.754090] mmc0: Command Queue Engine enabled
[ 6.754094] mmc0: periodic cache flush enabled
[ 6.754105] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.761939] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 6.762809] irq: IRQ271: trimming hierarchy from :pmc@c360000
[ 6.762911] irq: IRQ272: trimming hierarchy from :interrupt-controller@3881000
[ 6.763019] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.764184] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[ 6.812274] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[ 6.819640] tegra-se-nvhost 15810000.se: initialized
[ 6.820301] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 6.824176] tegradc 15210000.display: disp1 connected to head1->sor
[ 6.829870] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[ 6.831326] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 6.831344] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 6.834096] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 6.834631] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[ 6.835366] tegra-se-nvhost 15820000.se: initialized
[ 6.837321] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.837539] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 6.837701] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[ 6.838537] tegra-se-nvhost 15830000.se: initialized
[ 6.839849] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 6.840048] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[ 6.840842] tegra-se-nvhost 15840000.se: initialized
[ 6.842827] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 6.844415] tegra_actmon d230000.actmon: in actmon_register()…
[ 6.844575] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 6.845172] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 6.845679] hvc_sysfs: hypervisor is not present
[ 6.872865] ALSA device list:
[ 6.877265] tegradc 15210000.display: DT parsed successfully
[ 6.884094] No soundcards found.
[ 6.910595] usb 1-2: New USB device found, idVendor=0424, idProduct=4216, bcdDevice= 6.22
[ 6.914422] tegradc 15210000.display: Display dc.000000009dfd5b0a registered with id=1
[ 6.919354] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.919362] usb 1-2: Product: USB4216 Smart Hub
[ 6.925495] tegradc 15210000.display: vblank syncpt # 15 for dc 1
[ 6.931720] usb 1-2: Manufacturer: Microchip
[ 6.937035] tegradc 15210000.display: vpulse3 syncpt # 16 for dc 1
[ 7.006893] tegradc 15200000.display: blank - powerdown
[ 7.008651] hub 1-2:1.0: USB hub found
[ 7.011769] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 7.011772] Extcon DP: HPD disabled
[ 7.011776] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 7.011786] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 7.011794] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 7.015717] hub 1-2:1.0: 7 ports detected
[ 7.041881] tegradc 15210000.display: probed
[ 7.055727] tegradc 15210000.display: fb registered
[ 7.065074] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.069254] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.073754] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.080078] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 7.085574] usb 2-3: New USB device found, idVendor=0424, idProduct=7216, bcdDevice= 6.22
[ 7.093939] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.101181] usb 2-3: Product: USB7216 Smart Hub
[ 7.105628] usb 2-3: Manufacturer: Microchip
[ 7.112913] hub 2-3:1.0: USB hub found
[ 7.114367] hub 2-3:1.0: 4 ports detected
[ 7.130007] CPU:0, Error: cbb-noc@2300000, irq=15
[ 7.130110] **************************************
[ 7.130250] CPU:0, Error:cbb-noc
[ 7.130836] Error Logger : 0
[ 7.133977] ErrLog0 : 0x80030000
[ 7.137646] Transaction Type : RD - Read, Incrementing
[ 7.142901] Error Code : SLV
[ 7.146313] Error Source : Target
[ 7.149988] Error Description : Target error detected by CBB slave
[ 7.156816] AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 7.164248] Packet header Lock : 0
[ 7.167745] Packet header Len1 : 3
[ 7.168854] tegra_cec 3960000.tegra_cec: Can’t find physical address.
[ 7.171164] NOC protocol version : version >= 2.7
[ 7.171175] ErrLog1 : 0x350e28
[ 7.177418] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 7.182446] ErrLog2 : 0x0
[ 7.182449] RouteId : 0x350e28
[ 7.182452] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 7.182472] Targflow : host1x_p2pm/T/host1x_p2pm
[ 7.182478] TargSubRange : 7
[ 7.210548] SeqId : 0
[ 7.212988] ErrLog3 : 0x10180
[ 7.216661] ErrLog4 : 0x0
[ 7.219547] Address accessed : 0x15210180
[ 7.223922] ErrLog5 : 0xa09f851
[ 7.227334] Non-Modify : 0x1
[ 7.230488] AXI ID : 0x14
[ 7.233638] Master ID : CCPLEX
[ 7.237052] Security Group(GRPSEC): 0x7e
[ 7.241510] Cache : 0x1 – Bufferable
[ 7.245365] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 7.252361] FALCONSEC : 0x0
[ 7.255509] Virtual Queuing Channel(VQC): 0x0
[ 7.259976] **************************************
[ 7.265008] ------------[ cut here ]------------
[ 7.269514] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[ 7.276336] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 7.281498] Modules linked in:
[ 7.284217] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.104-tegra-pcm-0.0.1 #3
[ 7.291651] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 7.298316] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=–)
[ 7.304168] pc : tegra194_cbb_err_isr+0x19c/0x1b0
[ 7.308629] lr : tegra194_cbb_err_isr+0x11c/0x1b0
[ 7.313351] sp : ffff800010003b40
[ 7.317021] x29: ffff800010003b40 x28: 0000000000000001
[ 7.322276] x27: 0000000000000080 x26: ffffcb90c34b5b88
[ 7.327957] x25: ffffcb90c3e20e38 x24: 0000000000000001
[ 7.333139] x23: ffffcb90c37a7000 x22: ffffcb90c3c3ee30
[ 7.338809] x21: 000000000000000f x20: 0000000000000005
[ 7.343888] x19: ffffcb90c3c3ee20 x18: 0000000000000010
[ 7.349661] x17: 0000000000000007 x16: 000000000000000e
[ 7.354825] x15: ffffcb90c3ab2d30 x14: ffffffffffffffff
[ 7.360509] x13: ffff800090003737 x12: ffff80001000373f
[ 7.365934] x11: 0000000000000038 x10: 0101010101010101
[ 7.371446] x9 : ffff800010003a50 x8 : 2a2a2a2a2a2a2a2a
[ 7.376959] x7 : ffffcb90c2425de0 x6 : c0000000ffffefff
[ 7.382215] x5 : 0000000000057fa8 x4 : ffffcb90c3ac7aa8
[ 7.387897] x3 : 00000000ffffffff x2 : ffffcb90c1ece170
[ 7.393246] x1 : ffffcb90c3ab27c0 x0 : 0000000000010101
[ 7.398572] Call trace:
[ 7.400767] tegra194_cbb_err_isr+0x19c/0x1b0
[ 7.405071] __handle_irq_event_percpu+0x68/0x2a0
[ 7.409780] handle_irq_event_percpu+0x40/0xa0
[ 7.414338] handle_irq_event+0x50/0xf0
[ 7.418086] handle_fasteoi_irq+0xc0/0x170
[ 7.422128] generic_handle_irq+0x40/0x60
[ 7.426136] __handle_domain_irq+0x70/0xd0
[ 7.430337] efi_header_end+0xb0/0xf0
[ 7.433853] el1_irq+0xd0/0x180
[ 7.436811] __do_softirq+0xb4/0x3e8
[ 7.440488] irq_exit+0xc0/0xe0
[ 7.443217] __handle_domain_irq+0x74/0xd0
[ 7.447486] efi_header_end+0xb0/0xf0
[ 7.451162] el1_irq+0xd0/0x180
[ 7.453881] cpuidle_enter_state+0xb8/0x410
[ 7.457904] cpuidle_enter+0x40/0x60
[ 7.461579] call_cpuidle+0x44/0x80
[ 7.465353] do_idle+0x208/0x270
[ 7.468315] cpu_startup_entry+0x2c/0x70
[ 7.472427] rest_init+0xdc/0xe8
[ 7.475853] arch_call_rest_init+0x18/0x20
[ 7.480037] start_kernel+0x514/0x54c
[ 7.483630] Code: a9446bf9 a94573fb a8c67bfd d65f03c0 (d4210000)
[ 7.489858] —[ end trace 9cdac612eda570d5 ]—
[ 7.494385] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 7.501652] SMP: stopping secondary CPUs
[ 7.505776] Kernel Offset: 0x4b90b1d10000 from 0xffff800010000000
[ 7.511815] PHYS_OFFSET: 0xffff895f80000000
[ 7.515914] CPU features: 0x8240002,03802a30
[ 7.520634] Memory Limit: none
[ 7.523788] —[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]—
Just to clarify. I need the log from serial console since the beginning of boot up.
Also, please “attach” your log as a file here but not just copy and paste.
Also, you said that this was working on jp5.0.2. Could you confirm if that is true?
If it is, then it could be something else but not related to bootloader-status.
Hi
Yes. The same hardware and jp5.0.2 works well.
It was the change to 5.1.1 when the kernel panic occurred. I did try JetPack 5.1 and the same panic occurs.
boottopanic (65.6 KB)
Malcolm
Sorry, what does micro chip usb do here? This should be related to display part. Not sure why usb is related.
The microship part is a multiport USB. One of those ports is dedicated to the LCD. The LCD USB goes from the MicroChip device to a USB PD controller and the DP0_TXDn (where n = 0 to 3) pins NX module.
Hope that provides a bit of an overview.
Malcolm
