We are using the source packages from https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v3.0/sources/public_sources.tbz2.
the kernel source is the downloaded file kernel_src.tbz2, and the network driver source in kernel_oot_modules_src.tbz2.
It is necessary to apply the following patch to the kernel source; otherwise, the network interface cannot be up. The patch is as follows:
diff --git a/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000.dtsi b/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000.dtsi
index 007947449..6520e771d 100644
--- a/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000.dtsi
+++ b/hardware/nvidia/t23x/nv-public/nv-platform/tegra234-p3737-0000.dtsi
@@ -62,26 +62,10 @@
nvidia,max-platform-mtu = <16383>;
/* 1=enable, 0=disable */
nvidia,pause_frames = <1>;
- phy-handle = <&mgbe0_aqr113c_phy>;
+ /* 1:10G, 0:5G */
+ nvidia,uphy-gbe-mode = <1>;
/* 0:XFI 10G, 1:XFI 5G, 2:USXGMII 10G, 3:USXGMII 5G */
nvidia,phy-iface-mode = <0>;
- nvidia,phy-reset-gpio = <&gpio TEGRA234_MAIN_GPIO(Y, 1) 0>;
- nvidia,mdio_addr = <0>;
- mdio {
- compatible = "nvidia,eqos-mdio";
- #address-cells = <1>;
- #size-cells = <0>;
- mgbe0_aqr113c_phy: phy@0 {
- compatible = "ethernet-phy-ieee802.3-c45";
- reg = <0x0>;
- nvidia,phy-rst-pdelay-msec = <150>; /* msec */
- nvidia,phy-rst-duration-usec = <221000>; /* usec */
- interrupt-parent = <&gpio>;
- interrupts = <TEGRA234_MAIN_GPIO(Y, 3) IRQ_TYPE_LEVEL_LOW>;
nvpps {
diff --git a/hardware/nvidia/t23x/nv-public/tegra234-p3737-0000+p3701-0000.dts b/hardware/nvidia/t23x/nv-public/tegra234-p3737-0000+p3701-0000.dts
index 575970de0..8e5b58671 100644
--- a/hardware/nvidia/t23x/nv-public/tegra234-p3737-0000+p3701-0000.dts
+++ b/hardware/nvidia/t23x/nv-public/tegra234-p3737-0000+p3701-0000.dts
@@ -167,20 +167,10 @@
ethernet@6800000 {
status = "okay";
- phy-handle = <&mgbe0_phy>;
- phy-mode = "10gbase-r";
- mdio {
- mgbe0_phy: phy@0 {
- reg = <0x0>;
- #phy-cells = <0>;
+ nvidia,if-name = "eth1";
+ fixed-link {
+ speed = <10000>;
+ full-duplex;
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.136-voyager-1.0-tegra (root@13619bb65dba) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Wed Dec 11 07:47:55 Asia 2024 ()
[ 0.000000] Machine model: NVIDIA Jetson AGX Orin Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x82804f198 SMBIOS=0xffff0000 SMBIOS 3.0=0x827a20000 MEMATTR=0x821be4018 ESRT=0x821c77098 RNG=0x814ed0018 MEMRESERVE=0x815a13c18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x0000000821c77098 to 0x0000000821c770d0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000804000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000833ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x828cc9800-0x828ccbfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000833ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000818ae3fff]
[ 0.000000] node 0: [mem 0x0000000818ae4000-0x0000000818c2bfff]
[ 0.000000] node 0: [mem 0x0000000818c2c000-0x000000082610ffff]
[ 0.000000] node 0: [mem 0x0000000826110000-0x000000082804ffff]
[ 0.000000] node 0: [mem 0x0000000828050000-0x000000082c5fffff]
[ 0.000000] node 0: [mem 0x000000082c600000-0x000000082c7fffff]
[ 0.000000] node 0: [mem 0x000000082c800000-0x000000082cd6ffff]
[ 0.000000] node 0: [mem 0x000000082d700000-0x000000082d7fffff]
[ 0.000000] node 0: [mem 0x0000000832000000-0x0000000833ffffff]
[ 0.000000] mminit::pageflags_layout_widths Section 0 Node 4 Zone 2 Lastcpupid 16 Kasantag 0 Flags 24
[ 0.000000] mminit::pageflags_layout_shifts Section 21 Node 4 Zone 2 Lastcpupid 16 Kasantag 0
[ 0.000000] mminit::pageflags_layout_pgshifts Section 0 Node 60 Zone 58 Lastcpupid 42 Kasantag 0
[ 0.000000] mminit::pageflags_layout_nodezoneid Node/Zone ID: 64 -> 58
[ 0.000000] mminit::pageflags_layout_usage location: 64 -> 42 layout 42 -> 24 unused 24 -> 0 page-flags
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[ 0.000000] mminit::memmap_init Initialising map node 0 zone 0 pfns 524288 -> 1048576
[ 0.000000] mminit::memmap_init Initialising map node 0 zone 2 pfns 1048576 -> 8601600
[ 0.000000] On node 0, zone Normal: 2448 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 18432 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] pcpu-alloc: s80408 r8192 d30184 u118784 alloc=29*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] mminit::zonelist general 0:DMA = 0:DMA
[ 0.000000] mminit::zonelist general 0:Normal = 0:Normal 0:DMA
[ 0.000000] mminit::zonelist thisnode 0:DMA = 0:DMA
[ 0.000000] mminit::zonelist thisnode 0:Normal = 0:Normal 0:DMA
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7930224
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x82C610000 bl_prof_ro_ptr=65536@0x82C600000", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 31146208K/32225728K available (19392K kernel code, 4376K rwdata, 17256K rodata, 8128K init, 530K bss, 817376K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000519] Console: colour dummy device 80x25
[ 0.000540] printk: console [tty0] enabled
[ 0.000674] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000692] pid_max: default: 32768 minimum: 301
[ 0.000757] LSM: Security Framework initializing
[ 0.000802] Yama: becoming mindful.
[ 0.000841] SELinux: Initializing.
[ 0.001079] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001183] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003722] rcu: Hierarchical SRCU implementation.
[ 0.008934] Tegra Revision: A01 SKU: 210 CPU Process: 0 SoC Process: 0
[ 0.009233] Remapping and enabling EFI services.
[ 0.010361] smp: Bringing up secondary CPUs ...
[ 0.011220] Detected PIPT I-cache on CPU1
[ 0.011315] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.011379] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.012126] Detected PIPT I-cache on CPU2
[ 0.012140] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.012161] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.012847] Detected PIPT I-cache on CPU3
[ 0.012859] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.012877] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.015606] Detected PIPT I-cache on CPU4
[ 0.015633] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.015665] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.016368] Detected PIPT I-cache on CPU5
[ 0.016381] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.016402] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.017053] Detected PIPT I-cache on CPU6
[ 0.017067] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.017087] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.017784] Detected PIPT I-cache on CPU7
[ 0.017797] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.017817] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.017887] smp: Brought up 1 node, 8 CPUs
[ 0.017895] SMP: Total of 8 processors activated.
[ 0.017900] CPU features: detected: 32-bit EL0 Support
[ 0.017902] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.017907] CPU features: detected: Common not Private translations
[ 0.017909] CPU features: detected: CRC32 instructions
[ 0.017911] CPU features: detected: Data cache clean to Point of Persistence
[ 0.017913] CPU features: detected: Generic authentication (architected algorithm)
[ 0.017914] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.017915] CPU features: detected: LSE atomic instructions
[ 0.017917] CPU features: detected: Privileged Access Never
[ 0.017919] CPU features: detected: RAS Extension Support
[ 0.017923] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.045183] spectre-bhb mitigation disabled by command line option
[ 0.071842] CPU: All CPU(s) started at EL2
[ 0.077063] devtmpfs: initialized
[ 0.095470] KASLR enabled
[ 0.095687] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.095716] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.100639] pinctrl core: initialized pinctrl subsystem
[ 0.101657] SMBIOS 3.6.0 present.
[ 0.101670] DMI: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.3.0-gcid-36191598 05/06/2024
[ 0.102263] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.104303] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.104671] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.105016] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.105074] audit: initializing netlink subsys (disabled)
[ 0.105214] audit: type=2000 audit(0.100:1): state=initialized audit_enabled=0 res=1
[ 0.106769] thermal_sys: Registered thermal governor 'step_wise'
[ 0.106773] thermal_sys: Registered thermal governor 'user_space'
[ 0.106774] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.110733] cpuidle: using governor menu
[ 0.110917] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.111025] ASID allocator initialised with 32768 entries
[ 0.113023] Serial: AMBA PL011 UART driver
[ 0.123665] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 118, base_baud = 0) is a SBSA
[ 0.123709] printk: console [ttyAMA0] enabled
[ 0.134980] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.143660] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.143666] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.143668] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.143669] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.144602] cryptd: max_cpu_qlen set to 1000
[ 0.146357] ACPI: Interpreter disabled.
[ 0.148412] iommu: Default domain type: Translated
[ 0.148419] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.148706] SCSI subsystem initialized
[ 0.148796] libata version 3.00 loaded.
[ 0.148878] vgaarb: loaded
[ 0.149045] usbcore: registered new interface driver usbfs
[ 0.149070] usbcore: registered new interface driver hub
[ 0.149087] usbcore: registered new device driver usb
[ 0.149497] pps_core: LinuxPPS API ver. 1 registered
[ 0.149504] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.149516] PTP clock support registered
[ 0.149581] EDAC MC: Ver: 3.0.0
[ 0.150601] Registered efivars operations
[ 0.151217] FPGA manager framework
[ 0.151313] Advanced Linux Sound Architecture Driver Initialized.
[ 0.152287] clocksource: Switched to clocksource arch_sys_counter
[ 0.188738] VFS: Disk quotas dquot_6.6.0
[ 0.188803] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.189048] pnp: PnP ACPI: disabled
[ 0.192460] NET: Registered PF_INET protocol family
[ 0.193004] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.195396] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.195436] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.195471] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.195686] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.197057] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.197283] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.197358] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.197604] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.198030] RPC: Registered named UNIX socket transport module.
[ 0.198035] RPC: Registered udp transport module.
[ 0.198035] RPC: Registered tcp transport module.
[ 0.198036] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.198050] PCI: CLS 0 bytes, default 64
[ 0.198322] Unpacking initramfs...
[ 0.209315] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.209627] kvm [1]: IPA Size Limit: 48 bits
[ 0.209666] kvm [1]: GICv3: no GICV resource entry
[ 0.209674] kvm [1]: disabling GICv2 emulation
[ 0.209696] kvm [1]: GIC system register CPU interface enabled
[ 0.209793] kvm [1]: vgic interrupt IRQ9
[ 0.209972] kvm [1]: VHE mode initialized successfully
[ 0.213277] Initialise system trusted keyrings
[ 0.213450] workingset: timestamp_bits=42 max_order=23 bucket_order=0
[ 0.217186] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.217653] NFS: Registering the id_resolver key type
[ 0.217683] Key type id_resolver registered
[ 0.217685] Key type id_legacy registered
[ 0.217746] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.217767] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.217793] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.218000] 9p: Installing v9fs 9p2000 file system support
[ 0.230043] Key type asymmetric registered
[ 0.230049] Asymmetric key parser 'x509' registered
[ 0.230124] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.230132] io scheduler mq-deadline registered
[ 0.230138] io scheduler kyber registered
[ 0.241350] EINJ: ACPI disabled.
[ 0.254348] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.256208] SuperH (H)SCI(F) driver initialized
[ 0.256559] msm_serial: driver initialized
[ 0.257189] printk: console [ttyTCU0] enabled
[ 0.258074] arm-smmu 8000000.iommu: probing hardware configuration...
[ 0.258080] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.258085] arm-smmu 8000000.iommu: stage 1 translation
[ 0.258089] arm-smmu 8000000.iommu: stage 2 translation
[ 0.258093] arm-smmu 8000000.iommu: nested translation
[ 0.258100] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.258107] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.258138] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.258141] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.258147] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.259155] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.259158] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.259160] arm-smmu 10000000.iommu: stage 1 translation
[ 0.259161] arm-smmu 10000000.iommu: stage 2 translation
[ 0.259162] arm-smmu 10000000.iommu: nested translation
[ 0.259166] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.259168] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.259172] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.259173] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.259174] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.259528] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.259533] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.259534] arm-smmu 12000000.iommu: stage 1 translation
[ 0.259535] arm-smmu 12000000.iommu: stage 2 translation
[ 0.259535] arm-smmu 12000000.iommu: nested translation
[ 0.259538] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.259540] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.259545] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.259546] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.259547] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.268236] loop: module loaded
[ 0.269035] megasas: 07.717.02.00-rc1
[ 0.273032] tun: Universal TUN/TAP device driver, 1.6
[ 0.273656] thunder_xcv, ver 1.0
[ 0.273688] thunder_bgx, ver 1.0
[ 0.273706] nicpf, ver 1.0
[ 0.274553] hclge is initializing
[ 0.274587] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.274592] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.274628] e1000: Intel(R) PRO/1000 Network Driver
[ 0.274633] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.274658] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.274663] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.274687] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.274694] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.274716] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.274721] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.274934] sky2: driver version 1.30
[ 0.275600] VFIO - User Level meta-driver version: 0.3
[ 0.277136] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.277163] ehci-pci: EHCI PCI platform driver
[ 0.277194] ehci-platform: EHCI generic platform driver
[ 0.277276] ehci-orion: EHCI orion driver
[ 0.277349] ehci-exynos: EHCI Exynos driver
[ 0.277410] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.277426] ohci-pci: OHCI PCI platform driver
[ 0.277450] ohci-platform: OHCI generic platform driver
[ 0.277532] ohci-exynos: OHCI Exynos driver
[ 0.277951] usbcore: registered new interface driver usb-storage
[ 0.279819] i2c_dev: i2c /dev entries driver
[ 0.281140] pps pps0: new PPS source ktimer
[ 0.281151] pps pps0: ktimer PPS source registered
[ 0.281157] pps_ldisc: PPS line discipline registered
[ 0.283286] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.285273] sdhci: Secure Digital Host Controller Interface driver
[ 0.285279] sdhci: Copyright(c) Pierre Ossman
[ 0.285722] Synopsys Designware Multimedia Card Interface Driver
[ 0.286351] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.287479] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.288435] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.288987] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.290412] tegra-bpmp bpmp: firmware: 2aafe334513692db071c-3b0e1a33cf8
[ 0.383172] Freeing initrd memory: 11440K
[ 1.785877] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 1.785908] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 1.785911] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 1.786147] hid: raw HID events driver (C) Jiri Kosina
[ 1.786507] usbcore: registered new interface driver usbhid
[ 1.786511] usbhid: USB HID core driver
[ 1.790391] optee: probing for conduit method.
[ 1.790440] optee: revision 3.22 (e7b5ff3f)
[ 1.849849] optee: dynamic shared memory is enabled
[ 1.850110] optee: initialized driver
[ 1.852677] usbcore: registered new interface driver snd-usb-audio
[ 1.854168] NET: Registered PF_PACKET protocol family
[ 1.854433] 9pnet: Installing 9P2000 support
[ 1.854541] Key type dns_resolver registered
[ 1.855675] printk: console [tty0]: printing thread started
[ 1.856493] printk: console [ttyTCU0]: printing thread started
[ 1.857234] printk: console [ttyAMA0]: printing thread started
[ 1.857329] Loading compiled-in X.509 certificates
[ 1.870198] Loaded X.509 cert 'Build time autogenerated kernel key: 1865142e48e9d396de717c29c27247841ab4438a'
[ 1.924897] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 1.927028] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 1.929383] serial-tegra 3100000.serial: RX in PIO mode
[ 1.929389] serial-tegra 3100000.serial: TX in PIO mode
[ 1.929528] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 1.931441] serial-tegra 3110000.serial: RX in PIO mode
[ 1.931448] serial-tegra 3110000.serial: TX in PIO mode
[ 1.931566] 3110000.serial: ttyTHS2 at MMIO 0x3110000 (irq = 207, base_baud = 0) is a TEGRA_UART
[ 1.937007] tegra_rtc c2a0000.rtc: registered as rtc1
[ 1.937025] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.937682] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 1.945394] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 1.950501] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 1.955497] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 1.960405] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 1.966133] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 1.972310] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 1.980037] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 2.011222] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 2.014359] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2012000 KHz, changing to: 2035200 KHz
[ 2.016957] sdhci-tegra 3460000.mmc: Adding to iommu group 2
[ 2.017988] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 2.019009] irq: IRQ234: trimming hierarchy from :bus@0:pmc@c360000
[ 2.019072] irq: IRQ235: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 2.019117] irq: IRQ236: trimming hierarchy from :bus@0:pmc@c360000
[ 2.019174] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.426160] ALSA device list:
[ 2.426164] No soundcards found.
[ 2.428356] mmc0: CQHCI version 5.10
[ 2.464219] mmc0: SDHCI controller on 3460000.mmc [3460000.mmc] using ADMA 64-bit
[ 2.478430] mmc1: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 2.479310] Freeing unused kernel memory: 8128K
[ 2.479529] Run /init as init process
[ 2.479531] with arguments:
[ 2.479533] /init
[ 2.479534] with environment:
[ 2.479534] HOME=/
[ 2.479535] TERM=linux
[ 2.479535] bl_prof_dataptr=2031616@0x82C610000
[ 2.479536] bl_prof_ro_ptr=65536@0x82C600000
[ 2.491181] Checking overlayfs setting...
[ 2.500522] Overlayfs is disabled...
[ 2.506430] Root device found: mmcblk0p1
[ 2.570685] mmc0: Command Queue Engine enabled
[ 2.570695] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.570956] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 2.571879] mmc1: new HS200 MMC card at address 0001
[ 2.572049] mmcblk1: mmc1:0001 DJUD4R 119 GiB
[ 2.572851] mmcblk1boot0: mmc1:0001 DJUD4R 31.9 MiB
[ 2.573304] mmcblk1boot1: mmc1:0001 DJUD4R 31.9 MiB
[ 2.573676] mmcblk1rpmb: mmc1:0001 DJUD4R 4.00 MiB, chardev (511:0)
[ 2.574566] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 2.574994] mmcblk0boot0: mmc0:0001 G1M15M 31.5 MiB
[ 2.575357] mmcblk0boot1: mmc0:0001 G1M15M 31.5 MiB
[ 2.575675] mmcblk0rpmb: mmc0:0001 G1M15M 4.00 MiB, chardev (511:1)
[ 2.659762] Found dev node: /dev/mmcblk0p1
[ 2.676592] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 2.680369] Rootfs mounted over mmcblk0p1
[ 2.692142] Switching from initrd to actual rootfs
[ 2.856851] systemd[1]: System time before build time, advancing clock.
[ 3.097370] NET: Registered PF_INET6 protocol family
[ 3.098680] Segment Routing with IPv6
[ 3.098687] In-situ OAM (IOAM) with IPv6
[ 3.160337] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.160652] systemd[1]: Detected architecture arm64.
[ 3.255962] systemd[1]: Hostname set to <gen4orin1>.
[ 3.272419] systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog
[ 3.272435] systemd[1]: Set hardware watchdog to 2min.
[ 3.454688] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[ 3.479389] systemd[1]: Configuration file /etc/systemd/system/sys_test_server.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.498606] systemd[1]: /etc/systemd/system/nvs-service.service:41: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.506071] systemd[1]: /etc/systemd/system/nvargus-daemon.service:42: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[ 3.556484] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.557895] systemd[1]: Created slice Slice /system/modprobe.
[ 3.599721] systemd[1]: Created slice Slice /system/serial-getty.
[ 3.642215] systemd[1]: Created slice User and Session Slice.
[ 3.686048] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.735107] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.790844] systemd[1]: Reached target Slice Units.
[ 3.831713] systemd[1]: Reached target Mounting snaps.
[ 3.886157] systemd[1]: Reached target Mounted snaps.
[ 3.939976] systemd[1]: Reached target Swaps.
[ 3.997986] systemd[1]: Reached target Local Verity Protected Volumes.
[ 4.050744] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 4.090689] systemd[1]: Listening on Syslog Socket.
[ 4.135551] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.184368] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.256579] systemd[1]: Listening on Journal Audit Socket.
[ 4.362645] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.415467] systemd[1]: Listening on Journal Socket.
[ 4.452004] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.452253] systemd[1]: Listening on udev Control Socket.
[ 4.464752] systemd[1]: Listening on udev Kernel Socket.
[ 4.465725] systemd[1]: Mounting Huge Pages File System...
[ 4.466713] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.467664] systemd[1]: Mounting Kernel Debug File System...
[ 4.468867] systemd[1]: Mounting Kernel Trace File System...
[ 4.500468] systemd[1]: Starting Journal Service...
[ 4.501716] systemd[1]: Starting Set the console keyboard layout...
[ 4.502874] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.504105] systemd[1]: Starting Load Kernel Module configfs...
[ 4.505292] systemd[1]: Starting Load Kernel Module drm...
[ 4.536855] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 4.537998] systemd[1]: Starting Load Kernel Module fuse...
[ 4.543084] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 4.544651] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 4.571225] systemd[1]: Started Nameserver information manager.
[ 4.571498] systemd[1]: Reached target Preparation for Network.
[ 4.571711] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 4.602732] systemd[1]: Starting Load Kernel Modules...
[ 4.603759] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.604755] systemd[1]: Starting Coldplug All udev Devices...
[ 4.625605] systemd[1]: Started Journal Service.
[ 4.627458] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null). Quota mode: none.
[ 4.658928] fuse: init (API version 7.34)
[ 4.669997] systemd-journald[237]: Received client request to flush runtime journal.
[ 4.699932] nvsciipc: loading out-of-tree module taints kernel.
[ 4.701108] nvsciipc: loaded module
[ 4.766795] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 4.767382] nvmap_co_device_init: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 4.767393] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 4.767405] nvmap_page_pool_init: Total RAM pages: 7856980
[ 4.767407] nvmap_page_pool_init: nvmap page pool size: 982122 pages (3836 MB)
[ 4.767744] nvmap_background_zero_thread: PP zeroing thread starting.
[ 4.767770] nvmap_heap_create: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 4.767798] nvmap_heap_create: fsi :dma coherent mem declare 0x000000082f000000,16777216
[ 4.767800] nvmap_heap_create: created heap fsi base 0x000000082f000000 size (16384KiB)
[ 4.831928] tegra-host1x 13e00000.host1x: Adding to iommu group 4
[ 4.833114] host1x-context host1x-ctx.0: Adding to iommu group 5
[ 4.833227] host1x-context host1x-ctx.1: Adding to iommu group 6
[ 4.833320] host1x-context host1x-ctx.2: Adding to iommu group 7
[ 4.833412] host1x-context host1x-ctx.3: Adding to iommu group 8
[ 4.833499] host1x-context host1x-ctx.4: Adding to iommu group 9
[ 4.833586] host1x-context host1x-ctx.5: Adding to iommu group 10
[ 4.833667] host1x-context host1x-ctx.6: Adding to iommu group 11
[ 4.833751] host1x-context host1x-ctx.7: Adding to iommu group 12
[ 4.833841] host1x-context host1x-ctx.8: Adding to iommu group 13
[ 4.833930] host1x-context host1x-ctx.9: Adding to iommu group 14
[ 4.834016] host1x-context host1x-ctx.10: Adding to iommu group 15
[ 4.834099] host1x-context host1x-ctx.11: Adding to iommu group 16
[ 4.834184] host1x-context host1x-ctx.12: Adding to iommu group 17
[ 4.834270] host1x-context host1x-ctx.13: Adding to iommu group 18
[ 4.834356] host1x-context host1x-ctx.14: Adding to iommu group 19
[ 4.834444] host1x-context host1x-ctx.15: Adding to iommu group 20
[ 5.272919] spi-tegra114 3210000.spi: Adding to iommu group 1
[ 5.275312] spi-tegra114 3230000.spi: Adding to iommu group 1
[ 5.288496] Inserting ivc_ext.ko module
[ 5.318383] at24 0-0050: 256 byte 24c02 EEPROM, read-only
[ 5.319532] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[ 5.319827] nvvrs11 4-0020: NVVRS11 Model Rev: 0xE1
[ 5.319829] nvvrs11 4-0020: NVVRS11 probe successful
[ 5.321736] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[ 5.324211] nvvrs11 4-0022: NVVRS11 Model Rev: 0xE1
[ 5.324213] nvvrs11 4-0022: NVVRS11 probe successful
[ 5.325434] tegra-soc-hwpm f100000.hwpm: Adding to iommu group 21
[ 5.331772] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 5.332059] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[ 5.332503] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 5.354828] tegra194-pcie 141a0000.pcie: Adding to iommu group 22
[ 5.400928] tsec 15500000.tsec: Adding to iommu group 23
[ 5.420116] nvpps c6a0000.nvpps: nvpps_probe
[ 5.420220] nvpps c6a0000.nvpps: primary-emac found ethernet@6800000
[ 5.420234] nvpps c6a0000.nvpps: primary emac base address 0x6810000
[ 5.420237] nvpps c6a0000.nvpps: using ptp notifier method on emac ethernet@6800000
[ 5.420238] nvpps c6a0000.nvpps: tsc_res_ns(32)
[ 5.420248] nvpps c6a0000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[ 5.420809] nvpps c6a0000.nvpps: nvpps cdev(506:0)
[ 5.420839] nvpps c6a0000.nvpps: TSC config ptx 0x113
[ 5.473925] gic 2a41000.interrupt-controller: GIC IRQ controller registered
[ 5.473978] tegra-aconnect bus@0:aconnect@2900000: Tegra ACONNECT bus registered
[ 5.480858] tegra194-pcie 141a0000.pcie: host bridge /bus@0/pcie@141a0000 ranges:
[ 5.480881] tegra194-pcie 141a0000.pcie: MEM 0x2800000000..0x2b27ffffff -> 0x2800000000
[ 5.480887] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 5.480890] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 5.481246] tegra194-pcie 141a0000.pcie: iATU unroll: enabled
[ 5.481249] tegra194-pcie 141a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 5.483951] tegra234-aon c000000.aon: Adding to iommu group 24
[ 5.484474] c000000.aon:hsp: probed
[ 5.484591] tegra234-aon c000000.aon: init done
[ 5.508669] thermal-trip-event cpu-throttle-alert: cooling device registered.
[ 5.508838] thermal-trip-event gpu-throttle-alert: cooling device registered.
[ 5.508971] thermal-trip-event cv0-throttle-alert: cooling device registered.
[ 5.509102] thermal-trip-event cv1-throttle-alert: cooling device registered.
[ 5.509233] thermal-trip-event cv2-throttle-alert: cooling device registered.
[ 5.509364] thermal-trip-event soc0-throttle-alert: cooling device registered.
[ 5.509486] thermal-trip-event soc1-throttle-alert: cooling device registered.
[ 5.509608] thermal-trip-event soc2-throttle-alert: cooling device registered.
[ 5.510328] thermal-trip-event hot-surface-alert: cooling device registered.
[ 5.517990] tegra-dce d800000.dce: Adding to iommu group 25
[ 5.518368] dce: dce_ipc_channel_init:311 Invalid Channel State [0x0] for ch_type [2]
[ 5.518562] dce: tegra_dce_probe:245 Found display consumer device
[ 5.519053] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x5]
[ 5.519059] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x5]
[ 5.519312] dce: dce_admin_send_cmd_ver:456 version : [0x3] err : [0x0]
[ 5.519511] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x1]
[ 5.519517] dce: dce_admin_setup_clients_ipc:585 Channel Reset Complete for Type [1] ...
[ 5.519519] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
[ 5.519713] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x2]
[ 5.519717] dce: dce_mailbox_set_full_interrupt:157 Intr bit set multiple times for MB : [0x2]
[ 5.519719] dce: dce_admin_setup_clients_ipc:585 Channel Reset Complete for Type [3] ...
[ 5.520693] dce: dce_start_boot_flow:166 DCE_BOOT_DONE
[ 5.532040] CAN device driver interface
[ 5.547242] tegra-hda 3510000.hda: Adding to iommu group 26
[ 5.549096] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 27
[ 5.549987] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.556596] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee027f size=131712
[ 5.556633] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.556662] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x512]=0x1900-0x1b80 TX[1x512]=0x1b80-0x1e00
[ 5.556683] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1e00-0x3e80 TX[1x8192]=0x3e80-0x5f00
[ 5.556703] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5f00-0xaf80 TX[64x320]=0xaf80-0x10000
[ 5.556728] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0x10000-0x18080 TX[512x64]=0x18080-0x20100
[ 5.556748] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20100-0x201c0 TX[1x64]=0x201c0-0x20280
[ 5.556881] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (232)
[ 5.556883] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.557144] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=e2238c99959d2df9350d393f04e1f44e5bef98cb
[ 5.557272] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[ 5.557274] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[ 5.557275] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[ 5.557276] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivc channel driver missing
[ 5.557277] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivc channel driver missing
[ 5.557278] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[ 5.557289] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557295] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557297] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557300] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557308] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557310] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557311] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.557312] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 5.588299] tegra194-pcie 141a0000.pcie: Link up
[ 5.598744] tegra194-pcie 141a0000.pcie: Link up
[ 5.598833] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 5.598837] pci_bus 0005:00: root bus resource [io 0x0000-0xfffff] (bus address [0x3a100000-0x3a1fffff])
[ 5.598840] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 5.598843] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 5.598844] pci_bus 0005:00: root bus resource [mem 0x2800000000-0x2b27ffffff pref]
[ 5.598887] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 5.599028] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 5.602595] pci 0005:01:00.0: [11f8:4328] type 00 class 0x068000
[ 5.603316] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00ffffff 64bit pref]
[ 5.603586] pci 0005:01:00.0: reg 0x18: [mem 0x00000000-0x03ffffff 64bit pref]
[ 5.603816] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x03ffffff 64bit pref]
[ 5.604204] pci 0005:01:00.0: enabling Extended Tags
[ 5.604296] [RCE] TCU debug prints will be routed to traces.
[ 5.606183] pci 0005:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.607216] irq: IRQ253: trimming hierarchy from :bus@0:pmc@c360000
[ 5.607781] pci 0005:01:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0005:00:00.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 5.607954] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 5.607956] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 5.607959] ucsi_ccg: probe of 1-0008 failed with error -121
[ 5.608462] pci 0005:01:00.1: [11f8:4328] type 00 class 0x088000
[ 5.608818] pci 0005:01:00.1: reg 0x10: [mem 0x00000000-0x007fffff 64bit]
[ 5.609532] pci 0005:01:00.1: enabling Extended Tags
[ 5.610773] pci 0005:01:00.1: PME# supported from D0 D3hot D3cold
[ 5.614479] pci 0005:00:00.0: BAR 15: assigned [mem 0x2800000000-0x2809ffffff 64bit pref]
[ 5.614484] pci 0005:00:00.0: BAR 14: assigned [mem 0x2b28000000-0x2b287fffff]
[ 5.614487] pci 0005:01:00.0: BAR 2: assigned [mem 0x2800000000-0x2803ffffff 64bit pref]
[ 5.614638] pci 0005:01:00.0: BAR 4: assigned [mem 0x2804000000-0x2807ffffff 64bit pref]
[ 5.614798] pci 0005:01:00.0: BAR 0: assigned [mem 0x2808000000-0x2808ffffff 64bit pref]
[ 5.615059] pci 0005:01:00.1: BAR 0: assigned [mem 0x2b28000000-0x2b287fffff 64bit]
[ 5.615190] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 5.615201] pci 0005:00:00.0: bridge window [mem 0x2b28000000-0x2b287fffff]
[ 5.615203] pci 0005:00:00.0: bridge window [mem 0x2800000000-0x2809ffffff 64bit pref]
[ 5.615329] pcieport 0005:00:00.0: Adding to iommu group 22
[ 5.615421] pcieport 0005:00:00.0: PME: Signaling with IRQ 205
[ 5.615540] pcieport 0005:00:00.0: AER: enabled with IRQ 205
[ 5.616593] tegra194-pcie 14100000.pcie: Adding to iommu group 28
[ 5.618421] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 5.618439] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 5.618444] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 5.618446] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.618700] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 5.618702] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 5.623174] TT CAN feature is not supported
[ 5.623686] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
| mram size |0x00001000|
[ 5.624981] Release 3.2.3 from 09.06.2018
[ 5.625153] net can0: mttcan device registered (regs=00000000e4aaa61e, irq=212)
[ 5.626654] TT CAN feature is not supported
[ 5.627038] Message RAM Configuration
| base addr |0x0c322000|
[ 5.628367] Release 3.2.3 from 09.06.2018
[ 5.628576] net can1: mttcan device registered (regs=000000007d545ef5, irq=213)
[ 5.667150] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 5.704106] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/bus@0/3510000.hda/sound/card0/input1
[ 5.705839] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/bus@0/3510000.hda/sound/card0/input2
[ 5.705900] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/bus@0/3510000.hda/sound/card0/input3
[ 5.705944] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/bus@0/3510000.hda/sound/card0/input4
[ 5.710181] tsec 15500000.tsec: tsec fw req success in 100 ms
[ 5.711657] nvethernet 6800000.ethernet: Adding to iommu group 29
[ 5.713319] nvethernet 6800000.ethernet: failed to read skip mac reset flag, default 0
[ 5.713326] nvethernet 6800000.ethernet: failed to read MDIO address
[ 5.713332] nvethernet 6800000.ethernet: setting to default DMA bit mask
[ 5.719679] nvethernet 6800000.ethernet: failed to get phy reset gpio error: -2
[ 5.724826] nvethernet 6800000.ethernet: Ethernet MAC address: 3c:6d:66:0c:02:4d
[ 5.725598] -->macsec_probe()
[ 5.725637] -->macsec_get_platform_res()
[ 5.725669] <--macsec_get_platform_res()
[ 5.725670] -->macsec_enable_car()
[ 5.725891] <--macsec_enable_car()
[ 5.725901] <--macsec_probe()
[ 5.725903] nvethernet 6800000.ethernet: Macsec not enabled
[ 5.725904] nvethernet 6800000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 5.726247] tsec 15500000.tsec: RISC-V boot using kernel allocated Mem
[ 5.731643] nvethernet 6800000.ethernet: eth1 (HW ver: 31) created with 10 DMA channels
[ 5.732729] tsec 15500000.tsec: RISC-V boot success
[ 5.758410] mc: Linux media interface: v0.10
[ 5.761106] nv_platform 13800000.display: Adding to iommu group 30
[ 5.762146] platform 13800000.display:nvdisplay-niso: Adding to iommu group 31
[ 5.885268] scare-pigeon 13e00000.host1x:vi0-thi@15f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 5.887616] scare-pigeon 13e00000.host1x:vi1-thi@14f00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 5.889280] scare-pigeon 13e00000.host1x:isp-thi@14b00000: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 5.920255] videodev: Linux video capture interface: v2.00
[ 5.941408] nvdla 15880000.nvdla0: Adding to iommu group 32
[ 5.988131] nvdla 15880000.nvdla0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 5.988429] nvdla 158c0000.nvdla1: Adding to iommu group 33
[ 6.016474] nvdla 158c0000.nvdla1: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 6.022725] pva 16000000.pva0: Adding to iommu group 34
[ 6.040364] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 6.041978] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 2025-04-07T10:05:53 UTC (1744020353)
[ 6.066155] platform 2901000.i2s: Fixing up cyclic dependency with 8-001c
[ 6.073670] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 35
[ 6.073784] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 6.074498] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 36
[ 6.074565] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 6.074827] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 37
[ 6.074890] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 6.075117] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 38
[ 6.075179] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 6.075397] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 39
[ 6.075461] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 6.075738] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 40
[ 6.075803] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 6.076054] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 41
[ 6.076122] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 6.088969] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 42
[ 6.089384] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 6.093454] pva 16000000.pva0: pdata->version is HW_GEN2
[ 6.095513] tegra-se 15820000.se: Adding to iommu group 43
[ 6.098091] tegra-se 15840000.se: Adding to iommu group 44
[ 6.098794] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[ 6.102426] tegra-se 15820000.se: registered AES algorithms
[ 6.103351] tegra-se 15840000.se: registered HASH algorithms
[ 6.104555] pva 16000000.pva0: Completed nvhost_client_device_init
[ 6.110995] pva 16000000.pva0: syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 6.372928] tegra-vic 15340000.vic: Adding to iommu group 45
[ 6.377135] tegra210-admaif 290f000.admaif: Adding to iommu group 46
[ 6.433516] tegra-nvdec 15480000.nvdec: Adding to iommu group 47
[ 6.450350] tegra-nvenc 154c0000.nvenc: Adding to iommu group 48
[ 6.473384] tegra-nvjpg 15380000.nvjpg: Adding to iommu group 49
[ 6.473861] tegra194-vi5 13e00000.host1x:vi0@15c00000: Adding to iommu group 50
[ 6.474178] tegra194-isp5 14800000.isp: Adding to iommu group 51
[ 6.474837] driver not enabled, cannot register any devices
[ 6.476434] driver not enabled, cannot register any devices
[ 6.476610] tegra194-vi5 13e00000.host1x:vi1@14c00000: Adding to iommu group 52
[ 6.476771] (NULL device *): fops function table already registered
[ 6.476939] driver not enabled, cannot register any devices
[ 6.477690] driver not enabled, cannot register any devices
[ 6.478482] tegra-nvjpg 15540000.nvjpg: Adding to iommu group 53
[ 6.481859] tegra-ofa 15a50000.ofa: Adding to iommu group 54
[ 6.482686] drm drm: [drm] Cannot find any crtc or sizes
[ 6.482839] [drm] Initialized tegra 1.0.99 20120330 for drm on minor 0
[ 6.725744] tegra194-pcie 14100000.pcie: Phy link never came up
[ 7.583476] nvgpu: 17000000.gpu nvgpu_nvhost_syncpt_init:122 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 7.724283] tegra194-pcie 14100000.pcie: Phy link never came up
[ 7.724383] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.724387] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 7.724389] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 7.724392] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 7.724393] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 7.724441] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 7.724608] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 7.729389] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 7.729527] pcieport 0001:00:00.0: Adding to iommu group 28
[ 7.729638] pcieport 0001:00:00.0: PME: Signaling with IRQ 201
[ 7.729781] pcieport 0001:00:00.0: AER: enabled with IRQ 201
[ 7.731519] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 7.731911] pci 0001:00:00.0: Removing from iommu group 28
[ 7.731933] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 7.733766] tegra194-pcie 14160000.pcie: Adding to iommu group 55
[ 7.735594] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 7.735610] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 7.735616] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 7.735619] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 7.735920] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 7.735922] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 7.840296] tegra194-pcie 14160000.pcie: Link up
[ 7.841781] tegra194-pcie 14160000.pcie: Link up
[ 7.841869] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 7.841874] pci_bus 0004:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x36100000-0x361fffff])
[ 7.841877] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.841880] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 7.841882] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 7.841925] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 7.842074] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 7.844914] pci 0004:01:00.0: [14e4:a00b] type 00 class 0x020000
[ 7.845091] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 7.845196] pci 0004:01:00.0: reg 0x18: [mem 0x00000000-0x0003ffff 64bit]
[ 7.845301] pci 0004:01:00.0: reg 0x20: [mem 0x00000000-0x0000ffff 64bit]
[ 7.846195] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[ 7.846558] pci 0004:01:00.0: reg 0x1ac: [mem 0x00000000-0x0000ffff 64bit]
[ 7.846560] pci 0004:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0002ffff 64bit] (contains BAR0 for 3 VFs)
[ 7.846665] pci 0004:01:00.0: reg 0x1b4: [mem 0x00000000-0x0003ffff 64bit]
[ 7.846667] pci 0004:01:00.0: VF(n) BAR2 space: [mem 0x00000000-0x000bffff 64bit] (contains BAR2 for 3 VFs)
[ 7.846771] pci 0004:01:00.0: reg 0x1bc: [mem 0x00000000-0x0000ffff 64bit]
[ 7.846773] pci 0004:01:00.0: VF(n) BAR4 space: [mem 0x00000000-0x0002ffff 64bit] (contains BAR4 for 3 VFs)
[ 7.858780] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24281fffff]
[ 7.858788] pci 0004:01:00.0: BAR 2: assigned [mem 0x2428000000-0x242803ffff 64bit]
[ 7.858871] pci 0004:01:00.0: BAR 9: assigned [mem 0x2428040000-0x24280fffff 64bit]
[ 7.858907] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428100000-0x242810ffff 64bit]
[ 7.858989] pci 0004:01:00.0: BAR 4: assigned [mem 0x2428110000-0x242811ffff 64bit]
[ 7.859072] pci 0004:01:00.0: BAR 7: assigned [mem 0x2428120000-0x242814ffff 64bit]
[ 7.859108] pci 0004:01:00.0: BAR 11: assigned [mem 0x2428150000-0x242817ffff 64bit]
[ 7.859143] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 7.859147] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24281fffff]
[ 7.859285] pcieport 0004:00:00.0: Adding to iommu group 55
[ 7.859382] pcieport 0004:00:00.0: PME: Signaling with IRQ 203
[ 7.859488] pcieport 0004:00:00.0: AER: enabled with IRQ 203
[ 7.859805] irq: IRQ286: trimming hierarchy from :bus@0:pmc@c360000
[ 7.860273] rt5640 8-001c: Device with ID register 0xffff0000 is not rt5640/39
[ 8.141123] brcm-xgbe-pf 0004:01:00.0: Adding to iommu group 55
[ 8.141278] brcm-xgbe-pf 0004:01:00.0: enabling device (0000 -> 0002)
[ 8.141441] brcm-xgbe-pf 0004:01:00.0: xgmac ioremap done
[ 8.142513] brcm-xgbe-pf 0004:01:00.0: multi MSI/MSI-X enablement passed ret=13
[ 8.142567] Detected BCM8989X B0 Chip
[ 8.142573] BCM8989X-B0 Firmware Rev = 0x50a0
[ 8.143838] brcm-xgbe-pf 0004:01:00.0 eth2: net device enabled
[ 8.143841] brcm-xgbe-pf 0004:01:00.0: xgbe_config_netdev done
[ 8.143888] brcm_xgbe: driver version: 2.0.1
[ 8.228678] loop0: detected capacity change from 0 to 8
[ 8.255903] nv_nvsciipc_init.sh[659]: found /dev/nvsciipc
[ 8.274271] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.283207] nvsciipc: set_db start
[ 8.283231] nvsciipc: set_db done
[ 8.306270] br0: port 1(eth2) entered blocking state
[ 8.306285] br0: port 1(eth2) entered disabled state
[ 8.306518] device eth2 entered promiscuous mode
[ 8.307270] br0: port 2(eth1) entered blocking state
[ 8.307277] br0: port 2(eth1) entered disabled state
[ 8.307369] device eth1 entered promiscuous mode
[ 8.315105] SBMR Programmed is 0x3f3f0809
[ 8.356659] nvethernet 6800000.ethernet: [xpcs_lane_bring_up][477][type:0x4][loga-0x0] PCS block lock SUCCESS
[ 8.357169] br0: port 2(eth1) entered blocking state
[ 8.357174] br0: port 2(eth1) entered forwarding state
[ 8.357486] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[ 8.357876] nvethernet 6800000.ethernet eth1: Link is Up - 10Gbps/Full - flow control off
[ 8.622402] pstore: Using crash dump compression: deflate
[ 8.622480] printk: console [ramoops-1]: printing thread started
[ 8.622492] printk: console [ramoops-1] enabled
[ 8.622494] pstore: Registered ramoops as persistent store backend
[ 8.622495] ramoops: using 0x200000@0x82cdf0000, ecc: 0
[ 8.886308] nvgpu: 17000000.gpu gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 9.284318] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[ 9.284430] br0: port 1(eth2) entered blocking state
[ 9.284444] br0: port 1(eth2) entered forwarding state
[ 9.578752] zram: Added device: zram0
[ 9.579437] zram: Added device: zram1
[ 9.579662] zram: Added device: zram2
[ 9.579889] zram: Added device: zram3
[ 9.582196] zram: Added device: zram4
[ 9.584077] zram: Added device: zram5
[ 9.585667] zram: Added device: zram6
[ 9.585823] zram: Added device: zram7
[ 9.615213] zram0: detected capacity change from 0 to 3928496
[ 9.629504] Adding 1964244k swap on /dev/zram0. Priority:5 extents:1 across:1964244k SS
[ 9.633012] zram1: detected capacity change from 0 to 3928496
[ 9.637972] Adding 1964244k swap on /dev/zram1. Priority:5 extents:1 across:1964244k SS
[ 9.640044] zram2: detected capacity change from 0 to 3928496
[ 9.645152] Adding 1964244k swap on /dev/zram2. Priority:5 extents:1 across:1964244k SS
[ 9.647085] zram3: detected capacity change from 0 to 3928496
[ 9.652805] Adding 1964244k swap on /dev/zram3. Priority:5 extents:1 across:1964244k SS
[ 9.654733] zram4: detected capacity change from 0 to 3928496
[ 9.660141] Adding 1964244k swap on /dev/zram4. Priority:5 extents:1 across:1964244k SS
[ 9.662466] zram5: detected capacity change from 0 to 3928496
[ 9.667495] Adding 1964244k swap on /dev/zram5. Priority:5 extents:1 across:1964244k SS
[ 9.669519] zram6: detected capacity change from 0 to 3928496
[ 9.674217] Adding 1964244k swap on /dev/zram6. Priority:5 extents:1 across:1964244k SS
[ 9.676189] zram7: detected capacity change from 0 to 3928496
[ 9.681421] Adding 1964244k swap on /dev/zram7. Priority:5 extents:1 across:1964244k SS
[ 10.366065] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 540.3.0 Release Build (root@13619bb65dba) Wed Dec 11 07:51:53 Asia 2024
[ 10.623287] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 12.800918] rfkill: input handler disabled
