Solve the R35.3.1 Jetson agx orin LAN7800 USB to Gigabit PHY bandwidth rate is too low, only about 250M
Hardware environment: jetson agx orin
Software version: R35.3.1
Kernel version: 5.10.104
The questions are as follows:
At present, we want to use usb3.0+microchip usb to lan7800 Gigabit phy on the Jetson agx orin platform. LAN7800 driver uses lan78xx.ko which comes with linux kernel.
Now the kernel compilation is normal, the lan78xx.ko driver is loaded normally, and the usbn to eth0 network adapter appears normally after the system starts. After I manually configure a static ip for eth0, the network communication is normal (you can ping through the PC).
However, LAN7800 is a gigabit PHY, so I tested the network bandwidth, PC as the iperf3 server, Orin platform as the client; When I used the Iper3 tool to test the bandwidth, I found that it was only about 250M;
At present, it is known that the USB side works in USB3.0 mode, and the bandwidth is 5000M, which is enough to meet the working state of Gigabit Ethernet, but why the use of iper3 tools on the orin platform can only reach the bandwidth up and down 300M?
Run with jetson_clocks too during the test.
Please also update the firmware:
Jetson Linux 35.3.1 | NVIDIA Developer
overlay_usb_35.3.1.tbz2
Jetson/L4T/r35.3.x patches - eLinux.org
[USB] nvidia-agx-orin-usb-connection-issues
And execute sudo jetson_clocks during the test.
Hello.
Following your method, I downloaded overlay_usb_35.3.1.tbz2 and unziked it to get the xusb_sil_rel_fw and xusb_t234_prod.bin files, which I replaced into my development environment bootloder. And re-burned the firmware. When the system starts up, the sudo jetson_clocks command runs as instructed.
However, the problem does not seem to be improving. The iperf3 tool still measures the bandwidth at around 200M. The problem has not been solved.
What is the result of ethtool for this usb-ethernet interface?
What is the test environment? A port to port connection? or port to a switch?
These things should be clarified when doing a ethernet perf debug.
Hello:
In the current state, the LAN7800 adapter is directly connected to the USB, and the peer end is the PC host. Directly connect end-to-end without passing through the switch.
The ethtool status is shown as follows:
Is this a NV devkit or custom board?
Have you tried UDP test instead of TCP and see what is the throughput?
How about you directly upgrade the system to r35.5 and test again in case some old issue on rel-35.3.1?
Hello:
The tests are currently done on the custom board, but I have also done tests on the NV devkit, and the results are the same;
I have tried the UDP test, there has been a bandwidth of about 600M, but it is extremely unstable, most of the cases are about 200M;
However, this is extremely rare.
I also tried to upgrade the system to r35.5.0 and the results were the same;
When you test on NV devkit, do you have any type C cable connected on the type C port when doing the test?
Any dmesg to share when doing the test?
Do you have any other USB dongle to test there?
The connection status is shown as follows:
In addition, when I plug in the lan7800 adapter board in the usb interface, there will be a prompt as shown in the figure:
The above tests were performed on NV devkit
Share us the full dmesg and also in text. Do not share anything in screenshot.
lan7800_bug.txt (123.3 KB)
Could you just share a log and test result based on rel-35.5 NV devkit and do not modify anything in the software? Just use pure sdkmanager image.
For example, I don’t know why you need to update a device tree for devkit usecase.
This may not be related in the end but it is bad for us to check from remote. No one really know what did you do on your side.
Okay, I’ll upload the results when I’m done
You may run sudo tegrasts to check system loading. For some conditions, the performance is capped since the profiling is run on single CPU core.
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: Jetson AGX Orin
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x80823d518 SMBIOS=0xffff0000 SMBIOS 3.0=0x806bc0000 MEMATTR=0x8075ad018 ESRT=0x806808698 RNG=0x82a9fdd18 MEMRESERVE=0x8075aec18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x0000000806808698 to 0x00000008068086d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000081a800000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000837ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000803ffffff]
[    0.000000]   node   0: [mem 0x0000000804000000-0x00000008061bffff]
[    0.000000]   node   0: [mem 0x00000008061c0000-0x000000080651ffff]
[    0.000000]   node   0: [mem 0x0000000806520000-0x00000008066b3fff]
[    0.000000]   node   0: [mem 0x00000008066b4000-0x0000000806baffff]
[    0.000000]   node   0: [mem 0x0000000806bb0000-0x0000000806bcffff]
[    0.000000]   node   0: [mem 0x0000000806bd0000-0x00000008074bffff]
[    0.000000]   node   0: [mem 0x00000008074c0000-0x000000080750ffff]
[    0.000000]   node   0: [mem 0x0000000807510000-0x000000080756ffff]
[    0.000000]   node   0: [mem 0x0000000807570000-0x000000080758ffff]
[    0.000000]   node   0: [mem 0x0000000807590000-0x00000008075affff]
[    0.000000]   node   0: [mem 0x00000008075b0000-0x00000008075cffff]
[    0.000000]   node   0: [mem 0x00000008075d0000-0x000000080768ffff]
[    0.000000]   node   0: [mem 0x0000000807690000-0x000000080781ffff]
[    0.000000]   node   0: [mem 0x0000000807820000-0x000000080784ffff]
[    0.000000]   node   0: [mem 0x0000000807850000-0x000000080789ffff]
[    0.000000]   node   0: [mem 0x00000008078a0000-0x000000080790ffff]
[    0.000000]   node   0: [mem 0x0000000807910000-0x0000000807aeffff]
[    0.000000]   node   0: [mem 0x0000000807af0000-0x0000000807b7ffff]
[    0.000000]   node   0: [mem 0x0000000807b80000-0x0000000807cbffff]
[    0.000000]   node   0: [mem 0x0000000807cc0000-0x0000000807cfffff]
[    0.000000]   node   0: [mem 0x0000000807d00000-0x0000000807d4ffff]
[    0.000000]   node   0: [mem 0x0000000807d50000-0x0000000807d7ffff]
[    0.000000]   node   0: [mem 0x0000000807d80000-0x0000000807d8ffff]
[    0.000000]   node   0: [mem 0x0000000807d90000-0x000000080837ffff]
[    0.000000]   node   0: [mem 0x0000000808380000-0x000000080841ffff]
[    0.000000]   node   0: [mem 0x0000000808420000-0x000000080851ffff]
[    0.000000]   node   0: [mem 0x0000000808520000-0x00000008085bffff]
[    0.000000]   node   0: [mem 0x00000008085c0000-0x000000080866ffff]
[    0.000000]   node   0: [mem 0x0000000808670000-0x000000080870ffff]
[    0.000000]   node   0: [mem 0x0000000808710000-0x000000080901ffff]
[    0.000000]   node   0: [mem 0x0000000809020000-0x00000008091fffff]
[    0.000000]   node   0: [mem 0x0000000809200000-0x000000082a9affff]
[    0.000000]   node   0: [mem 0x000000082a9b0000-0x000000082a9fffff]
[    0.000000]   node   0: [mem 0x000000082aa00000-0x000000082e7fffff]
[    0.000000]   node   0: [mem 0x000000082ea00000-0x000000082edfffff]
[    0.000000]   node   0: [mem 0x0000000836000000-0x0000000837ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000837ffffff]
[    0.000000] On node 0 totalpages: 8064000
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 118272 pages used for memmap
[    0.000000]   Normal zone: 7539712 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[    0.000000] pcpu-alloc: s90200 r8192 d32680 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7937536
[    0.000000] Kernel command line: root=PARTUUID=1493da93-d004-4174-9462-4f847b60aeaf rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 31046776K/32256000K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 947080K reserved, 262144K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000704] Console: colour dummy device 80x25
[    0.000890] printk: console [tty0] enabled
[    0.000933] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000943] pid_max: default: 32768 minimum: 301
[    0.001008] LSM: Security Framework initializing
[    0.001032] Yama: becoming mindful.
[    0.001053] SELinux:  Initializing.
[    0.001141] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.001188] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002935] rcu: Hierarchical SRCU implementation.
[    0.003029] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.003762] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
[    0.003773] DTB Build time: Mar 19 2023 08:08:40
[    0.005282] Tegra Revision: A01 SKU: 0xd2 CPU Process: 0 SoC Process: 0
[    0.005582] Remapping and enabling EFI services.
[    0.006797] smp: Bringing up secondary CPUs ...
[    0.035516] Detected PIPT I-cache on CPU1
[    0.035549] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.035586] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.064247] Detected PIPT I-cache on CPU2
[    0.064256] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.064270] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.092875] Detected PIPT I-cache on CPU3
[    0.092884] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.092898] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.123560] Detected PIPT I-cache on CPU4
[    0.123580] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.123609] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.152280] Detected PIPT I-cache on CPU5
[    0.152289] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.152303] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.180935] Detected PIPT I-cache on CPU6
[    0.180944] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.180959] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.209588] Detected PIPT I-cache on CPU7
[    0.209598] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.209612] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.209669] smp: Brought up 1 node, 8 CPUs
[    0.209715] SMP: Total of 8 processors activated.
[    0.209720] CPU features: detected: Privileged Access Never
[    0.209723] CPU features: detected: LSE atomic instructions
[    0.209726] CPU features: detected: User Access Override
[    0.209729] CPU features: detected: 32-bit EL0 Support
[    0.209732] CPU features: detected: Common not Private translations
[    0.209735] CPU features: detected: RAS Extension Support
[    0.209737] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.209741] CPU features: detected: CRC32 instructions
[    0.209743] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.246093] CPU: All CPU(s) started at EL2
[    0.248447] devtmpfs: initialized
[    0.265947] Registered cp15_barrier emulation handler
[    0.265959] Registered setend emulation handler
[    0.265966] KASLR enabled
[    0.266092] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.266106] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.267478] pinctrl core: initialized pinctrl subsystem
[    0.268026] SMBIOS 3.0.0 present.
[    0.268034] DMI: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 3.1-32827747 03/19/2023
[    0.268310] NET: Registered protocol family 16
[    0.268971] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.269178] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.269376] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.269402] audit: initializing netlink subsys (disabled)
[    0.269483] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=0 res=1
[    0.269650] thermal_sys: Registered thermal governor 'step_wise'
[    0.269652] thermal_sys: Registered thermal governor 'power_allocator'
[    0.269657] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.272029] cpuidle: using governor menu
[    0.272137] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.272225] ASID allocator initialised with 32768 entries
[    0.272324] Serial: AMBA PL011 UART driver
[    0.274075] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.274105] Tegra reboot handler registered.
[    0.292485] mc: mapped MMIO address: 0xffff800011110000 -> 0x2c10000
[    0.292499] mc: mapped MMIO address: 0xffff800011130000 -> 0x2c20000
[    0.292506] mc: mapped MMIO address: 0xffff800011150000 -> 0x2c30000
[    0.292514] mc: mapped MMIO address: 0xffff800011170000 -> 0x2c40000
[    0.292521] mc: mapped MMIO address: 0xffff800011190000 -> 0x2c50000
[    0.292528] mc: mapped MMIO address: 0xffff8000111b0000 -> 0x2b80000
[    0.292535] mc: mapped MMIO address: 0xffff8000111d0000 -> 0x2b90000
[    0.292542] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2ba0000
[    0.292551] mc: mapped MMIO address: 0xffff800011210000 -> 0x2bb0000
[    0.292557] mc: mapped MMIO address: 0xffff800011230000 -> 0x1700000
[    0.292565] mc: mapped MMIO address: 0xffff800011250000 -> 0x1710000
[    0.292572] mc: mapped MMIO address: 0xffff800011270000 -> 0x1720000
[    0.292579] mc: mapped MMIO address: 0xffff800011290000 -> 0x1730000
[    0.292587] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x1740000
[    0.292596] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x1750000
[    0.292602] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x1760000
[    0.292608] mc: mapped MMIO address: 0xffff800011310000 -> 0x1770000
[    0.292619] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.292644] mc-err: mcerr ops are set to t23x
[    0.293330] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[    1.487498] printk: console [ttyAMA0] enabled
[    1.495808] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.502522] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.509223] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.515922] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.524443] ACPI: Interpreter disabled.
[    1.529484] vdd-av1v1-hub: supplied by vdd-5v-sys
[    1.534381] vbusA-cvb: supplied by vdd-5v-sys
[    1.538855] vbusB-cvb: supplied by vdd-5v-sys
[    1.543342] vdd-usbc1-vbus: supplied by vdd-5v-sys
[    1.548245] vdd-usbc2-vbus: supplied by vdd-5v-sys
[    1.553327] iommu: Default domain type: Translated
[    1.558236] eventlib_kernel: keventlib is initialized, test id: 0
[    1.564503] SCSI subsystem initialized
[    1.568314] usbcore: registered new interface driver usbfs
[    1.573813] usbcore: registered new interface driver hub
[    1.579134] usbcore: registered new device driver usb
[    1.584375] mc: Linux media interface: v0.10
[    1.588651] videodev: Linux video capture interface: v2.00
[    1.594293] pps_core: LinuxPPS API ver. 1 registered
[    1.599256] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.608393] PTP clock support registered
[    1.612517] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.619683] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.627351] Registered efivars operations
[    1.631491] FPGA manager framework
[    1.634932] Advanced Linux Sound Architecture Driver Initialized.
[    1.641285] Bluetooth: Core ver 2.22
[    1.644866] NET: Registered protocol family 31
[    1.649309] Bluetooth: HCI device and connection manager initialized
[    1.655667] Bluetooth: HCI socket layer initialized
[    1.660546] Bluetooth: L2CAP socket layer initialized
[    1.665602] Bluetooth: SCO socket layer initialized
[    1.670958] camchar: rtcpu character device driver loaded
[    1.676575] clocksource: Switched to clocksource arch_sys_counter
[    1.834658] VFS: Disk quotas dquot_6.6.0
[    1.838629] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.845663] pnp: PnP ACPI: disabled
[    1.851005] la/ptsa driver initialized.
[    1.854892] NET: Registered protocol family 2
[    1.859452] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.869185] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.877933] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.886220] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.894118] TCP: Hash tables configured (established 262144 bind 65536)
[    1.900832] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.907766] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.915211] NET: Registered protocol family 1
[    1.919873] RPC: Registered named UNIX socket transport module.
[    1.925807] RPC: Registered udp transport module.
[    1.930512] RPC: Registered tcp transport module.
[    1.935215] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.941665] PCI: CLS 0 bytes, default 64
[    1.945729] Trying to unpack rootfs image as initramfs...
[    2.074003] Freeing initrd memory: 9120K
[    2.080183] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    2.088186] kvm [1]: IPA Size Limit: 48 bits
[    2.092475] kvm [1]: GICv3: no GICV resource entry
[    2.097266] kvm [1]: disabling GICv2 emulation
[    2.101722] kvm [1]: GIC system register CPU interface enabled
[    2.107631] kvm [1]: vgic interrupt IRQ9
[    2.111668] kvm [1]: VHE mode initialized successfully
[    2.117509] Initialise system trusted keyrings
[    2.122041] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    2.130617] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.136739] NFS: Registering the id_resolver key type
[    2.141803] Key type id_resolver registered
[    2.145985] Key type id_legacy registered
[    2.150024] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.156731] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.164135] ntfs: driver 2.1.32 [Flags: R/W].
[    2.180178] NET: Registered protocol family 38
[    2.184626] Key type asymmetric registered
[    2.188722] Asymmetric key parser 'x509' registered
[    2.193617] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    2.201078] io scheduler mq-deadline registered
[    2.205610] io scheduler kyber registered
[    2.213932] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.219534] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.225123] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.230709] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    2.238953] tegra_dc_assign_hw_data: no matching compatible node
[    2.244970] tegradccommon module_init failed
[    2.249239] tegradc module_init failed
[    2.253243] EINJ: ACPI disabled.
[    2.258030] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.264913] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.270226] tegra-pmc: ### PMC reset level: L0
[    2.274667] tegra-pmc: ### PMC reset status reg: 0x0
[    2.280893] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.303465] random: fast init done
[    2.304522] printk: console [ttyTCU0] enabled
[    3.893803] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.901783] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.906628] arm-smmu 12000000.iommu: 	stage 1 translation
[    3.912184] arm-smmu 12000000.iommu: 	stage 2 translation
[    3.917727] arm-smmu 12000000.iommu: 	nested translation
[    3.923188] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    3.930595] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    3.939452] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    3.946157] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.952860] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.960435] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.967126] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.971950] arm-smmu 10000000.iommu: 	stage 1 translation
[    3.977493] arm-smmu 10000000.iommu: 	stage 2 translation
[    3.983028] arm-smmu 10000000.iommu: 	nested translation
[    3.988474] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    3.995889] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    4.004699] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    4.011410] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    4.018108] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    4.025223] arm-smmu 8000000.iommu: probing hardware configuration...
[    4.031831] arm-smmu 8000000.iommu: SMMUv2 with:
[    4.036563] arm-smmu 8000000.iommu: 	stage 1 translation
[    4.042011] arm-smmu 8000000.iommu: 	stage 2 translation
[    4.047457] arm-smmu 8000000.iommu: 	nested translation
[    4.052820] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    4.060152] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    4.068916] arm-smmu 8000000.iommu: 	Supported page sizes: 0x00001000
[    4.075531] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    4.082138] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    4.089489] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    4.099046] tegra_profiler: version: 1.151, samples/io: 51/30
[    4.105008] tegra_profiler: auth: init
[    4.109177] nvsciipc: loaded module
[    4.114351] tun: Universal TUN/TAP device driver, 1.6
[    4.120048] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    4.127462] hns3: Copyright (c) 2017 Huawei Corporation.
[    4.132978] e1000e: Intel(R) PRO/1000 Network Driver
[    4.138068] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.144152] igb: Intel(R) Gigabit Ethernet Network Driver
[    4.149694] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.155567] PPP generic driver version 2.4.2
[    4.160001] PPP BSD Compression module registered
[    4.164834] PPP Deflate Compression module registered
[    4.170038] PPP MPPE Compression module registered
[    4.174976] usbcore: registered new interface driver r8152
[    4.180615] usbcore: registered new interface driver asix
[    4.186158] usbcore: registered new interface driver ax88179_178a
[    4.192427] usbcore: registered new interface driver cdc_ether
[    4.198430] usbcore: registered new interface driver net1080
[    4.204244] usbcore: registered new interface driver cdc_subset
[    4.210329] usbcore: registered new interface driver zaurus
[    4.216068] usbcore: registered new interface driver cdc_ncm
[    4.221889] usbcore: registered new interface driver aqc111
[    4.227723] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.234080] ohci-pci: OHCI PCI platform driver
[    4.238648] ohci-platform: OHCI generic platform driver
[    4.244346] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    4.250600] usbcore: registered new interface driver uas
[    4.256067] usbcore: registered new interface driver usb-storage
[    4.262392] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    4.268497] mousedev: PS/2 mouse device common for all mice
[    4.274266] usbcore: registered new interface driver xpad
[    4.281798] tegra_rtc c2a0000.rtc: registered as rtc1
[    4.287266] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:32 UTC (32)
[    4.295513] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    4.301931] i2c /dev entries driver
[    4.305575] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    4.311383] tegra-i2c c240000.i2c: Adding to iommu group 2
[    4.317087] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    4.322770] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    4.328443] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    4.334113] tegra-i2c c250000.i2c: Adding to iommu group 2
[    4.339786] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    4.345519] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    4.353326] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[    4.361890] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[    4.371447] device-mapper: uevent: version 1.0.3
[    4.376269] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.386015] sdhci: Secure Digital Host Controller Interface driver
[    4.392358] sdhci: Copyright(c) Pierre Ossman
[    4.396820] Synopsys Designware Multimedia Card Interface Driver
[    4.403046] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.409013] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    4.409414] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[    4.409794] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.411311] tegra-bpmp bpmp: firmware: 463f4d5b75234b74bb7f-1377b684fe5
[    4.413768] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.414726] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[    4.420857] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.450550] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[    6.972281] hid: raw HID events driver (C) Jiri Kosina
[    6.978038] usbcore: registered new interface driver usbhid
[    6.983779] usbhid: USB HID core driver
[    6.988485] tegra-dce d800000.dce: Adding to iommu group 5
[    6.995422] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    7.004324] tegra234-aon c000000.aon: Adding to iommu group 6
[    7.010925] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    7.013779]  c000000.aon:hsp: probed
[    7.019895] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    7.032364] tegra234-aon c000000.aon: init done
[    7.032781] tegra23x-psc e860000.psc: Adding to iommu group 7
[    7.037057] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    7.043436] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[    7.049973] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    7.056317] tegra23x-psc e860000.psc: init done
[    7.065253] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    7.065254] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    7.070137] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[    7.078327] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    7.078458] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    7.087968] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    7.093743] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    7.093744] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    7.104916] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    7.110459] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    7.118585] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    7.161914] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    7.173347] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    7.185154] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    7.197748] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    7.210589] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    7.223103] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[    7.229956] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    7.242309] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=97e50cbff52bc4b542b2989187109c001c01cf77
[    7.255905] t19x_cache tegra-cache: probed
[    7.260461] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    7.273347] optee: probing for conduit method.
[    7.277946] optee: revision 3.19 (3f29c61f)
[    7.278696] optee: dynamic shared memory is enabled
[    7.288132] optee: initialized driver
[    7.305389] nvpmodel: initialized successfully
[    7.310082] tegra_hv: get_hvd: not initialized yet
[    7.315040] user_ivc_mempool: hypervisor not present
[    7.320986] usbcore: registered new interface driver snd-usb-audio
[    7.328165] u32 classifier
[    7.330955]     input device check on
[    7.334726]     Actions configured
[    7.338362] Initializing XFRM netlink socket
[    7.343183] NET: Registered protocol family 10
[    7.349328] Segment Routing with IPv6
[    7.353150] NET: Registered protocol family 17
[    7.357745] NET: Registered protocol family 15
[    7.362366] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    7.376197] Bluetooth: RFCOMM socket layer initialized
[    7.381501] Bluetooth: RFCOMM ver 1.11
[    7.385377] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.391466] Bluetooth: HIDP socket layer initialized
[    7.397538] 9pnet: Installing 9P2000 support
[    7.402006] Key type dns_resolver registered
[    7.407147] registered taskstats version 1
[    7.411383] Loading compiled-in X.509 certificates
[    7.427513] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[    7.438144] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[    7.451103] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.460010] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[    7.472273] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    7.479269] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[    7.491279] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    7.497789] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[    7.523498] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[    7.535683] host1x 13e40000.host1x: Adding to iommu group 13
[    7.560985] host1x 13e40000.host1x: initialized
[    7.566120] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[    7.574217] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    7.586230] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[    7.594259] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    7.606213] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[    7.614216] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    7.626247] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[    7.634260] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    7.646217] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[    7.654255] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    7.666237] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[    7.674265] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    7.686278] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[    7.694302] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    7.706273] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[    7.714293] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    7.726296] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[    7.734346] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    7.746323] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[    7.754358] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    7.766338] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[    7.774379] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    7.786359] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[    7.794400] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    7.806400] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[    7.814425] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    7.826435] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[    7.834482] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    7.846482] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[    7.854509] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    7.866497] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[    7.874510] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    7.886531] falcon 15340000.vic: Adding to iommu group 30
[    7.897488] falcon 15340000.vic: initialized
[    7.902247] falcon 15380000.nvjpg: Adding to iommu group 31
[    7.911525] falcon 15380000.nvjpg: initialized
[    7.916250] falcon 15540000.nvjpg1: Adding to iommu group 32
[    7.925719] falcon 15540000.nvjpg1: initialized
[    7.930518] falcon 154c0000.nvenc: Adding to iommu group 33
[    7.941308] falcon 154c0000.nvenc: initialized
[    7.946019] falcon 15a50000.ofa: Adding to iommu group 34
[    7.954926] falcon 15a50000.ofa: initialized
[    7.959462] nvdec 15480000.nvdec: Adding to iommu group 35
[    7.971825] nvdec 15480000.nvdec: initialized
[    7.976434] tsec 15500000.tsec: Adding to iommu group 36
[    7.987172] tsec 15500000.tsec: initialized
[    7.994545] gic 2a41000.agic-controller: GIC IRQ controller registered
[    8.011477] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    8.028500] gpio-394 (camera-control-output-low): hogged as output/low
[    8.035267] gpio-397 (camera-control-output-low): hogged as output/low
[    8.042030] gpio-487 (camera-control-output-low): hogged as output/low
[    8.048783] gpio-486 (camera-control-output-low): hogged as output/low
[    8.056625] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    8.064316] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    8.071302] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    8.077789] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    8.084259] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    8.090481] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    8.098775] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    8.107335] tegra194-isp5 14800000.isp: Adding to iommu group 37
[    8.116306] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    8.125989] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    8.132553] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[    8.140782] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[    8.148954] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    8.158993] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    8.165821] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    8.175846] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    8.182660] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    8.192689] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    8.199519] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[    8.208243] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    8.219638] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[    8.228312] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    8.239677] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[    8.248343] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    8.259707] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[    8.268364] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    8.279739] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[    8.288400] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    8.299756] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[    8.308399] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    8.319761] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[    8.328426] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    8.339795] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[    8.348471] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    8.359836] pva 16000000.pva0: Adding to iommu group 48
[    8.384864] pva 16000000.pva0: initialized
[    8.397152] nvdla 15880000.nvdla0: Adding to iommu group 49
[    8.412286] nvdla 15880000.nvdla0: initialized
[    8.418747] nvdla 158c0000.nvdla1: Adding to iommu group 50
[    8.433750] nvdla 158c0000.nvdla1: initialized
[    8.440121] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    8.447329] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    8.454895] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    8.461537] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    8.468347] serial-tegra 3100000.serial: Adding to iommu group 2
[    8.475072] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[    8.484993] serial-tegra 3110000.serial: Adding to iommu group 2
[    8.491647] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[    8.501340] serial-tegra 3130000.serial: Adding to iommu group 2
[    8.507858] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[    8.534611] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[    8.544373] tegra-xusb 3610000.xhci: xHCI Host Controller
[    8.549984] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    8.558631] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    8.568240] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[    8.574733] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    8.583245] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.590678] usb usb1: Product: xHCI Host Controller
[    8.595693] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    8.601974] usb usb1: SerialNumber: 3610000.xhci
[    8.608078] hub 1-0:1.0: USB hub found
[    8.612009] hub 1-0:1.0: 4 ports detected
[    8.616475] tegra-xusb 3610000.xhci: xHCI Host Controller
[    8.622041] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    8.629830] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    8.637391] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    8.645903] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    8.653335] usb usb2: Product: xHCI Host Controller
[    8.658353] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[    8.664635] usb usb2: SerialNumber: 3610000.xhci
[    8.669996] hub 2-0:1.0: USB hub found
[    8.673874] hub 2-0:1.0: 4 ports detected
[    8.696682] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    8.719957] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2052000 KHz, changing to: 2112000 KHz
[    8.734082] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2177000 KHz, changing to: 2188800 KHz
[    8.745932] tegra194-cpufreq e000000.ccplex: probed with ICC
[    8.752966] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    8.763057] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    8.763252] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    8.772384] mmc0: CQHCI version 5.10
[    8.775177] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    8.787552] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    8.796262] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    8.813447] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[    8.819620] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    8.821119] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[    8.872576] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[    8.912580] tegra194-pcie 14100000.pcie: Link up
[    8.919172] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    8.926000] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.931666] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    8.941510] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    8.952343] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    8.960280] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    8.966628] pci 0001:00:00.0: PME# supported from D0 D3hot
[    8.977101] mmc0: Command Queue Engine enabled
[    8.977368] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    8.981677] mmc0: periodic cache flush enabled
[    8.988016] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.992413] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    8.998344] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    9.004985] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    9.013115] pci 0001:01:00.0: supports D1 D2
[    9.017262] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[    9.021098] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    9.040239] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    9.047677] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    9.054068] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    9.062079] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    9.068415] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    9.073848] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    9.080152] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    9.087547] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    9.096340] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    9.096418] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    9.105353] pcieport 0001:00:00.0: Adding to iommu group 9
[    9.113499] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    9.119389] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[    9.126455] usb 1-3: Product: Bluetooth Radio
[    9.132603] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[    9.136848] usb 1-3: Manufacturer: Realtek
[    9.143469] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    9.146782] usb 1-3: SerialNumber: 00e04c000001
[    9.154336] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    9.165094] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    9.173815] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    9.173962]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    9.182497] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    9.189650] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    9.244575] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[    9.252993] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.260337] usb 2-3: Product: 4-Port USB 3.0 Hub
[    9.265086] usb 2-3: Manufacturer: Generic
[    9.282071] hub 2-3:1.0: USB hub found
[    9.288155] hub 2-3:1.0: 4 ports detected
[    9.360728] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[    9.539103] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[    9.547524] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.554865] usb 1-4: Product: 4-Port USB 2.0 Hub
[    9.559609] usb 1-4: Manufacturer: Generic
[    9.566214] hub 1-4:1.0: USB hub found
[    9.571396] hub 1-4:1.0: 4 ports detected
[   10.289683] tegra194-pcie 14160000.pcie: Phy link never came up
[   10.295858] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[   10.302673] pci_bus 0004:00: root bus resource [bus 00-ff]
[   10.308312] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[   10.318407] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[   10.329243] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[   10.337160] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[   10.343498] pci 0004:00:00.0: PME# supported from D0 D3hot
[   10.357402] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[   10.362808] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   10.371766] pcieport 0004:00:00.0: Adding to iommu group 10
[   10.377729] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[   10.383926] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[   10.389909] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[   10.395999] pci 0004:00:00.0: Removing from iommu group 10
[   10.401647] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[   10.409068] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[   10.415549] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[   10.415731] vdd-3v3-pcie: supplied by vdd-3v3-sys
[   10.420766] avdd-cam-2v8: supplied by vdd-3v3-sys
[   10.425696] vdd-dp: supplied by vdd-3v3-sys
[   10.430160] vdd-3v3-sd: supplied by vdd-3v3-sys
[   10.435111] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[   10.442518] tegra194-isp5 14800000.isp: initialized
[   10.452487] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[   10.458939] (NULL device *): fops function table already registered
[   10.467285] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[   10.474340] sdhci-tegra 3400000.sdhci: Got CD GPIO
[   10.474347] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[   10.496842] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[   10.597814] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[   10.604998] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[   10.613686] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[   10.622369] tegra194-pcie 141a0000.pcie:      MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[   11.542978] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[   11.738153] tegra194-pcie 141a0000.pcie: Phy link never came up
[   11.744339] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[   11.751154] pci_bus 0005:00: root bus resource [bus 00-ff]
[   11.756793] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[   11.766899] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[   11.777739] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[   11.785655] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[   11.791982] pci 0005:00:00.0: PME# supported from D0 D3hot
[   11.805863] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[   11.811256] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   11.820209] pcieport 0005:00:00.0: Adding to iommu group 11
[   11.826173] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[   11.832373] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[   11.838344] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[   11.844421] pci 0005:00:00.0: Removing from iommu group 11
[   11.850067] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[   11.857906] nvethernet 6810000.ethernet: Adding to iommu group 51
[   11.864497] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[   11.872650] nvethernet 6810000.ethernet: failed to read MDIO address
[   11.879199] nvethernet 6810000.ethernet: setting to default DMA bit mask
[   11.886114] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[   12.283854] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:94:6b:a9
[   12.291832] -->macsec_probe()
[   12.291844] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[   12.299627] <--macsec_probe()
[   12.299629] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[   12.311496] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[   12.320229] irq: IRQ305: trimming hierarchy from :pmc@c360000
[   12.326198] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[   12.333868] irq: IRQ307: trimming hierarchy from :pmc@c360000
[   12.339824] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   12.347412] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[   12.354152] tegra-se-nvhost 15810000.se: initialized
[   12.370825] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[   12.377200] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[   12.383870] tegra-se-nvhost 15820000.se: initialized
[   12.389958] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[   12.396321] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[   12.402847] tegra-se-nvhost 15840000.se: initialized
[   12.408984] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[   12.415861] tegra_actmon d230000.actmon: in actmon_register()...
[   12.422189] tegra_actmon d230000.actmon: bwmgr_disable = 1
[   12.428226] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[   12.436600] hvc_sysfs: hypervisor is not present
[   12.510887] random: crng init done
[   12.577286] ALSA device list:
[   12.580337]   No soundcards found.
[   12.584422] Freeing unused kernel memory: 3968K
[   12.589153] Run /init as init process
[   12.592914]   with arguments:
[   12.592915]     /init
[   12.592916]   with environment:
[   12.592916]     HOME=/
[   12.592917]     TERM=linux
[   12.592918]     mminit_loglevel=4
[   12.604618] Root device found: PARTUUID=1493da93-d004-4174-9462-4f847b60aeaf
[   13.757684] EXT4-fs (mmcblk0p1): 17 orphan inodes deleted
[   13.763250] EXT4-fs (mmcblk0p1): recovery complete
[   13.897592] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   13.908415] Rootfs mounted over PARTUUID=1493da93-d004-4174-9462-4f847b60aeaf
[   13.932470] Switching from initrd to actual rootfs
[   14.049000] systemd[1]: System time before build time, advancing clock.
[   14.091651] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[   14.115305] systemd[1]: Detected architecture arm64.
[   14.144814] systemd[1]: Set hostname to <tegra-ubuntu>.
[   14.330367] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   14.343420] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   14.353024] systemd[1]: Created slice system-modprobe.slice.
[   14.359511] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   14.366285] systemd[1]: Created slice User and Session Slice.
[   14.372333] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   14.380434] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   14.390227] systemd[1]: Reached target User and Group Name Lookups.
[   14.396747] systemd[1]: Reached target Slices.
[   14.401375] systemd[1]: Reached target Mounting snaps.
[   14.406715] systemd[1]: Reached target Mounted snaps.
[   14.411973] systemd[1]: Reached target Swap.
[   14.423038] systemd[1]: Listening on RPCbind Server Activation Socket.
[   14.429898] systemd[1]: Listening on Syslog Socket.
[   14.435097] systemd[1]: Listening on fsck to fsckd communication Socket.
[   14.442108] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   14.449092] systemd[1]: Listening on Journal Audit Socket.
[   14.454865] systemd[1]: Listening on Journal Socket (/dev/log).
[   14.461145] systemd[1]: Listening on Journal Socket.
[   14.466439] systemd[1]: Listening on udev Control Socket.
[   14.472115] systemd[1]: Listening on udev Kernel Socket.
[   14.478626] systemd[1]: Mounting Huge Pages File System...
[   14.485282] systemd[1]: Mounting POSIX Message Queue File System...
[   14.492582] systemd[1]: Mounting RPC Pipe File System...
[   14.499073] systemd[1]: Mounting Kernel Debug File System...
[   14.505908] systemd[1]: Mounting Kernel Trace File System...
[   14.513060] systemd[1]: Starting Journal Service...
[   14.519423] systemd[1]: Starting Set the console keyboard layout...
[   14.526975] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   14.536982] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   14.544178] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   14.553806] systemd[1]: Starting Load Kernel Module efi_pstore...
[   14.561396] systemd[1]: Starting Load Kernel Module pstore_blk...
[   14.568855] systemd[1]: Starting Load Kernel Module pstore_zone...
[   14.576467] systemd[1]: Starting Load Kernel Module ramoops...
[   14.583698] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   14.591906] systemd[1]: Started Nameserver information manager.
[   14.598294] systemd[1]: Reached target Network (Pre).
[   14.604300] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   14.613689] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   14.632069] systemd[1]: Starting Load Kernel Modules...
[   14.638481] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.646464] systemd[1]: Starting udev Coldplug all Devices...
[   14.647549] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   14.647617] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   14.664889] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000833000000,16777216
[   14.666955] systemd[1]: Started Journal Service.
[   14.674756] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[   14.687522] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[   14.687524] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   14.705425] nvmap_page_pool_init: Total RAM pages: 7830502
[   14.711071] nvmap_page_pool_init: nvmap page pool size: 978812 pages (3823 MB)
[   14.711140] nvmap_background_zero_thread: PP zeroing thread starting.
[   14.711293] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[   14.714527] misc nvmap: created heap fsi base 0x0000000833000000 size (16384KiB)
[   14.761472] systemd-journald[279]: Received client request to flush runtime journal.
[   14.780759] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   15.680811] nvidia: loading out-of-tree module taints kernel.
[   15.692244] nv_platform 13800000.display: Adding to iommu group 55
[   15.706988] platform 13800000.display:nvdisplay-niso: Adding to iommu group 56
[   15.714065] spi-tegra114 3210000.spi: Adding to iommu group 2
[   15.715738] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64  35.3.1  Release Build  (buildbrain@mobile-u64-6289-d7000)  Sun Mar 19 08:09:33 PDT 2023
[   15.729768] irq: IRQ308: trimming hierarchy from :pmc@c360000
[   15.740260] spi-tegra114 3230000.spi: Adding to iommu group 2
[   15.749502] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   15.763115] irq: IRQ309: trimming hierarchy from :pmc@c360000
[   15.763128] nct1008_nct72 4-004c: starting parse dt
[   15.763182] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[   15.763186] nct1008_nct72 4-004c: success parsing dt
[   15.763318] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[   15.765191] cpu-throttle-alert cooling device registered.
[   15.766644] gpu-throttle-alert cooling device registered.
[   15.766970] cv0-throttle-alert cooling device registered.
[   15.767249] cv1-throttle-alert cooling device registered.
[   15.767530] cv2-throttle-alert cooling device registered.
[   15.767795] soc0-throttle-alert cooling device registered.
[   15.768050] soc1-throttle-alert cooling device registered.
[   15.768291] soc2-throttle-alert cooling device registered.
[   15.770913] tegra-hda 3510000.hda: Adding to iommu group 57
[   15.776158] nvadsp 2993000.adsp: Adding to iommu group 58
[   15.776343] nvadsp 2993000.adsp: in probe()...
[   15.778935] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   15.784238] hot-surface-alert cooling device registered.
[   15.799349] nct1008_nct72 4-004c: LOC shutdown limit 107
[   15.800297] nct1008_nct72 4-004c: EXT shutdown limit 107
[   15.840682] nct1008_nct72 4-004c: initial LOC temp: 54000
[   15.841203] nct1008_nct72 4-004c: initial EXT temp: 60750
[   15.842184] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[   15.844116] nct1008_nct72 4-004c: nct1008_probe: initialized
[   15.881372] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   15.881627] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   15.883583] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   15.883719] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   15.956651] using random self ethernet address
[   15.961257] using random host ethernet address
[   16.041064] tegra-asoc: sound: Adding to iommu group 58
[   16.041342] irq: IRQ311: trimming hierarchy from :pmc@c360000
[   16.072579] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   16.080219] ucsi_ccg 1-0008: Port-0: no role switch found
[   16.136488] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[   16.136544] tegra210_adsp_audio_probe: platform probe started
[   16.139347] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   16.139580] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   16.139802] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   16.140029] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   16.140256] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   16.140481] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   16.140484] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   16.140486] tegra210-adsp tegra210-adsp: using adma channel page 0
[   16.140545] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   16.175838] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   16.189738] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   16.198136] usbcore: registered new interface driver btusb
[   16.210636] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[   16.211045] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   16.238868] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[   16.238874] rtk_btcoex: rtk_btcoex_init: version: 1.2
[   16.238876] rtk_btcoex: create workqueue
[   16.238955] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[   16.239005] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[   16.239007] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[   16.239008] rtk_btusb: patch_add
[   16.239009] rtk_btusb: auto suspend is disabled
[   16.239011] rtk_btusb: pid = 0x3549
[   16.239012] rtk_btusb: patch_add: Reset gEVersion to 0xff
[   16.239018] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[   16.239203] rtk_btusb: btusb_probe: done
[   16.239219] rtk_btusb: btusb_open start
[   16.239220] rtk_btusb: btusb_open hdev->promisc ==0
[   16.239221] rtk_btusb: download_patch start
[   16.239222] rtk_btusb: chip type value: 0x73
[   16.239223] rtk_btusb: HCI reset.
[   16.239271] usbcore: registered new interface driver rtk_btusb
[   16.248783] cryptd: max_cpu_qlen set to 1000
[   16.250325] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[   16.250331] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[   16.250333] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   16.250338] rtk_btusb: load_firmware start
[   16.250339] rtk_btusb: lmp_version = 0x8822
[   16.250341] rtk_btusb: config filename rtl8822cu_config
[   16.251834] rtk_btusb: no bdaddr file /opt/bdaddr
[   16.251842] rtk_btusb: 55 ab 23 87 00 00
[   16.251850] rtk_btusb: Config file length 6, new length 6
[   16.251852] rtk_btusb: fw name is  rtl8822cu_fw
[   16.257672] rtk_btusb: This is not 8723a, use new patch style!
[   16.257682] rtk_btusb: rtk_get_eversion: gEVersion 255
[   16.259342] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[   16.259351] rtk_btusb: load_firmware: New gEVersion 3
[   16.259354] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[   16.259356] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[   16.259357] rtk_btusb: fw_version = 0x9a8cbc9
[   16.259358] rtk_btusb: number_of_total_patch = 3
[   16.259358] rtk_btusb: chipID 4
[   16.259359] rtk_btusb: patch_length 0x8590
[   16.259360] rtk_btusb: start_offset 0x00005d00
[   16.259361] rtk_btusb: Svn version: 1940234490
[   16.259362] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[   16.259363] rtk_btusb: buf_len = 0x8596
[   16.259375] rtk_btusb: fw: exists, config file: exists
[   16.259376] rtk_btusb: load_firmware done
[   16.259391] rtk_btusb: download_data start
[   16.386754] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input5
[   16.429317] rtk_btusb: download_data done
[   16.429324] rtk_btusb: HCI reset.
[   16.440320] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   16.440322] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   16.440324] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   16.440334] rtk_btusb: Rtk patch end 0
[   16.440338] rtk_btusb: btusb_open set HCI_RUNNING
[   16.440375] rtk_btcoex: Open BTCOEX
[   16.440377] rtk_btusb: btusb_open end
[   16.443328] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   16.443331] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   16.463320] rtk_btusb: btusb_notify: hci0 evt 3
[   16.493080] loop: module loaded
[   16.496423] tegra210-adsp tegra210-adsp: Loaded app wire
[   16.496431] tegra210-adsp tegra210-adsp: Loaded app apm
[   16.496433] tegra210-adsp tegra210-adsp: Loaded app adma
[   16.496435] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   16.496440] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000145f6394
[   16.527440] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   16.959896] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.959913] Bluetooth: BNEP socket layer initialized
[   17.184402] Mass Storage Function, version: 2009/09/11
[   17.184410] LUN: removable file: (no medium)
[   17.187007] using random self ethernet address
[   17.191654] using random host ethernet address
[   17.334123] pstore: Using crash dump compression: deflate
[   17.334160] printk: console [ramoops-1] enabled
[   17.334161] pstore: Registered ramoops as persistent store backend
[   17.334163] ramoops: using 0x200000@0x82e800000, ecc: 0
[   17.478715] nvgpu: 17000000.ga10b                 tpc_pg_mask_store:1067 [INFO]  no value change, same mask already set
[   17.567536] irq: IRQ313: trimming hierarchy from :interrupt-controller@f400000-1
[   17.568103] hwmon hwmon6: temp1_input not attached to any thermal zone
[   17.692844] nvgpu: 17000000.ga10b                  gk20a_scale_init:539  [INFO]  enabled scaling for GPU
[   18.316616] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[   18.768387] rndis0: HOST MAC 02:43:94:d3:13:64
[   18.768399] rndis0: MAC 02:43:94:d3:13:65
[   18.768978] usb0: HOST MAC 02:43:94:d3:13:66
[   18.768984] usb0: MAC 02:43:94:d3:13:67
[   18.953536] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[   18.958408] l4tbr0: port 1(rndis0) entered blocking state
[   18.958435] l4tbr0: port 1(rndis0) entered disabled state
[   18.958756] device rndis0 entered promiscuous mode
[   18.969911] l4tbr0: port 2(usb0) entered blocking state
[   18.969956] l4tbr0: port 2(usb0) entered disabled state
[   18.970277] device usb0 entered promiscuous mode
[   19.041156] zram: Added device: zram0
[   19.041483] zram: Added device: zram1
[   19.041956] zram: Added device: zram2
[   19.042323] zram: Added device: zram3
[   19.043105] zram: Added device: zram4
[   19.044862] zram: Added device: zram5
[   19.048412] zram: Added device: zram6
[   19.048885] zram: Added device: zram7
[   19.117261] zram0: detected capacity change from 0 to 2004611072
[   19.156697] Adding 1957624k swap on /dev/zram0.  Priority:5 extents:1 across:1957624k SS
[   19.163645] zram1: detected capacity change from 0 to 2004611072
[   19.204725] Adding 1957624k swap on /dev/zram1.  Priority:5 extents:1 across:1957624k SS
[   19.207923] zram2: detected capacity change from 0 to 2004611072
[   19.244685] Adding 1957624k swap on /dev/zram2.  Priority:5 extents:1 across:1957624k SS
[   19.248000] zram3: detected capacity change from 0 to 2004611072
[   19.292758] Adding 1957624k swap on /dev/zram3.  Priority:5 extents:1 across:1957624k SS
[   19.296220] zram4: detected capacity change from 0 to 2004611072
[   19.332855] Adding 1957624k swap on /dev/zram4.  Priority:5 extents:1 across:1957624k SS
[   19.336146] zram5: detected capacity change from 0 to 2004611072
[   19.361065] Adding 1957624k swap on /dev/zram5.  Priority:5 extents:1 across:1957624k SS
[   19.364241] zram6: detected capacity change from 0 to 2004611072
[   19.412632] Adding 1957624k swap on /dev/zram6.  Priority:5 extents:1 across:1957624k SS
[   19.415672] zram7: detected capacity change from 0 to 2004611072
[   19.440837] Adding 1957624k swap on /dev/zram7.  Priority:5 extents:1 across:1957624k SS
[   21.098499] fuse: init (API version 7.32)
[   21.480733] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.3.1  Release Build  (buildbrain@mobile-u64-6289-d7000)  Sun Mar 19 08:09:35 PDT 2023
[   21.712132] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[   21.713317] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[   21.718625] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[   21.746404] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   21.746847] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
[   23.603418] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[   23.603442] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[   23.603456] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[   23.603553] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[   23.603568] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[   23.603580] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[   23.603683] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[   23.603732] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[   23.603762] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[   23.603791] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[   23.603991] l4tbr0: port 1(rndis0) entered blocking state
[   23.603999] l4tbr0: port 1(rndis0) entered forwarding state
[   23.604135] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   24.951933] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[   44.536757] vdd-12v-sys: disabling
[   44.536801] vdd-3v3-ftdi: disabling
[   70.541446] usb 2-3.2: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[   70.567111] usb 2-3.2: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[   70.567125] usb 2-3.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   70.879949] lan78xx 2-3.2:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[   71.293018] usbcore: registered new interface driver lan78xx
[   74.654618] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[  136.258614] cpufreq: cpu4,cur:1406000,set:1728000,set ndiv:135
It is enumerated as SuperSpeed. This looks expected. Please check with the vendor to see if there is any debug message you can enable in the driver. And also suggest upgrade to Jetpack 5.1.4 or 6.0GA. Certain issues are discovered and fixed in later releases.
I have done the following tests:
  1. Connect the lan7800 adapter board to the USB port on another PC. Perform an end-to-end test on the two PCS. The bandwidth is about 900 MB.
  2. Connect the lan7800 switch board to the VM and perform an end-to-end test with the PC in ubuntu20.04. The bandwidth is about 800 MB.
  3. The same test was carried out on Orin platform R35.3.1 system and R35.5.0 system, and the effect was less than expected.
We keep talking about r35.5 release but all the log you used so far is rel-35.3.1 log.
Unfortunately, we don’t debug on old release directly. Please follow above suggestion to upgrade BSP first and share correct log/info. Otherwise we cannot help.
root@tegra-ubuntu:/home/wanji# dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.192-tegra (buildbrain@mobile-u64-6519-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Mon Feb 19 20:19:53 PST 2024
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: Jetson AGX Orin Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x824626598 SMBIOS=0xffff0000 SMBIOS 3.0=0x828640000 MEMATTR=0x822df0018 ESRT=0x822df2598 RNG=0x8168a0018 MEMRESERVE=0x81721cc18
[    0.000000] random: crng init done
[    0.000000] esrt: Reserving ESRT space from 0x0000000822df2598 to 0x0000000822df25d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000806400000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000833ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000008193ccfff]
[    0.000000]   node   0: [mem 0x00000008193cd000-0x00000008197abfff]
[    0.000000]   node   0: [mem 0x00000008197ac000-0x0000000826c8ffff]
[    0.000000]   node   0: [mem 0x0000000826c90000-0x0000000828bcffff]
[    0.000000]   node   0: [mem 0x0000000828bd0000-0x000000082d2fffff]
[    0.000000]   node   0: [mem 0x000000082d310000-0x000000082d31ffff]
[    0.000000]   node   0: [mem 0x0000000832000000-0x0000000833ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000833ffffff]
[    0.000000] On node 0 totalpages: 8057616
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 118016 pages used for memmap
[    0.000000]   Normal zone: 7533328 pages, LIFO batch:63
[    0.000000] On node 0, zone Normal: 16 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] pcpu-alloc: s90392 r8192 d32488 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 7931408
[    0.000000] Kernel command line: root=PARTUUID=6fc683d1-9b5d-4155-a2bd-b0bc54baebf3 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 31031136K/32230464K available (18560K kernel code, 3168K rwdata, 7196K rodata, 3968K init, 1417K bss, 937184K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000711] Console: colour dummy device 80x25
[    0.000852] printk: console [tty0] enabled
[    0.000891] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000901] pid_max: default: 32768 minimum: 301
[    0.000954] LSM: Security Framework initializing
[    0.000977] Yama: becoming mindful.
[    0.000995] SELinux:  Initializing.
[    0.001073] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.001122] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002730] rcu: Hierarchical SRCU implementation.
[    0.002813] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.003530] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0004-p3737-0000.dts
[    0.003539] DTB Build time: Feb 19 2024 20:32:32
[    0.005132] Tegra Revision: A01 SKU: 0xd2 CPU Process: 0 SoC Process: 0
[    0.005447] Remapping and enabling EFI services.
[    0.006318] smp: Bringing up secondary CPUs ...
[    0.035024] Detected PIPT I-cache on CPU1
[    0.035062] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.035091] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.063736] Detected PIPT I-cache on CPU2
[    0.063746] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.063760] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.092362] Detected PIPT I-cache on CPU3
[    0.092371] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.092384] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.123042] Detected PIPT I-cache on CPU4
[    0.123063] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[    0.123090] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[    0.151750] Detected PIPT I-cache on CPU5
[    0.151759] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[    0.151774] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[    0.180398] Detected PIPT I-cache on CPU6
[    0.180407] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[    0.180421] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.209049] Detected PIPT I-cache on CPU7
[    0.209058] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[    0.209073] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.209125] smp: Brought up 1 node, 8 CPUs
[    0.209168] SMP: Total of 8 processors activated.
[    0.209173] CPU features: detected: Privileged Access Never
[    0.209176] CPU features: detected: LSE atomic instructions
[    0.209179] CPU features: detected: User Access Override
[    0.209182] CPU features: detected: 32-bit EL0 Support
[    0.209185] CPU features: detected: Common not Private translations
[    0.209188] CPU features: detected: RAS Extension Support
[    0.209190] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.209194] CPU features: detected: CRC32 instructions
[    0.209197] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.227724] spectre-bhb mitigation disabled by command line option
[    0.245465] CPU: All CPU(s) started at EL2
[    0.247859] devtmpfs: initialized
[    0.266481] Registered cp15_barrier emulation handler
[    0.266495] Registered setend emulation handler
[    0.266502] KASLR enabled
[    0.266631] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.266644] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.268076] pinctrl core: initialized pinctrl subsystem
[    0.268769] NET: Registered protocol family 16
[    0.269598] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.269801] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.270002] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.270030] audit: initializing netlink subsys (disabled)
[    0.270121] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=0 res=1
[    0.270297] thermal_sys: Registered thermal governor 'step_wise'
[    0.270299] thermal_sys: Registered thermal governor 'power_allocator'
[    0.270304] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.272794] cpuidle: using governor menu
[    0.272904] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.272986] ASID allocator initialised with 32768 entries
[    0.273066] Serial: AMBA PL011 UART driver
[    0.274770] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.274795] Tegra reboot handler registered.
[    0.293607] mc: mapped MMIO address: 0xffff800011130000 -> 0x2c10000
[    0.293620] mc: mapped MMIO address: 0xffff800011150000 -> 0x2c20000
[    0.293627] mc: mapped MMIO address: 0xffff800011170000 -> 0x2c30000
[    0.293634] mc: mapped MMIO address: 0xffff800011190000 -> 0x2c40000
[    0.293640] mc: mapped MMIO address: 0xffff8000111b0000 -> 0x2c50000
[    0.293648] mc: mapped MMIO address: 0xffff8000111d0000 -> 0x2b80000
[    0.293655] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2b90000
[    0.293664] mc: mapped MMIO address: 0xffff800011210000 -> 0x2ba0000
[    0.293670] mc: mapped MMIO address: 0xffff800011230000 -> 0x2bb0000
[    0.293677] mc: mapped MMIO address: 0xffff800011250000 -> 0x1700000
[    0.293684] mc: mapped MMIO address: 0xffff800011270000 -> 0x1710000
[    0.293691] mc: mapped MMIO address: 0xffff800011290000 -> 0x1720000
[    0.293698] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x1730000
[    0.293707] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x1740000
[    0.293713] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x1750000
[    0.293719] mc: mapped MMIO address: 0xffff800011310000 -> 0x1760000
[    0.293725] mc: mapped MMIO address: 0xffff800011330000 -> 0x1770000
[    0.293735] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.293774] mc-err: mcerr ops are set to t23x
[    0.294429] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 80, base_baud = 0) is a SBSA
[    1.306264] printk: console [ttyAMA0] enabled
[    1.314568] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.321281] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.327985] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.334685] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.343131] ACPI: Interpreter disabled.
[    1.348160] vdd-av1v1-hub: supplied by vdd-5v-sys
[    1.353060] vbusA-cvb: supplied by vdd-5v-sys
[    1.357518] vbusB-cvb: supplied by vdd-5v-sys
[    1.361992] vdd-usbc1-vbus: supplied by vdd-5v-sys
[    1.366892] vdd-usbc2-vbus: supplied by vdd-5v-sys
[    1.372102] iommu: Default domain type: Translated
[    1.377013] eventlib_kernel: keventlib is initialized, test id: 0
[    1.383270] SCSI subsystem initialized
[    1.387086] usbcore: registered new interface driver usbfs
[    1.392587] usbcore: registered new interface driver hub
[    1.397907] usbcore: registered new device driver usb
[    1.403147] mc: Linux media interface: v0.10
[    1.407424] videodev: Linux video capture interface: v2.00
[    1.413063] pps_core: LinuxPPS API ver. 1 registered
[    1.418027] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.427168] PTP clock support registered
[    1.431318] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.438475] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.446139] Registered efivars operations
[    1.450273] FPGA manager framework
[    1.453712] Advanced Linux Sound Architecture Driver Initialized.
[    1.460068] Bluetooth: Core ver 2.22
[    1.463651] NET: Registered protocol family 31
[    1.468096] Bluetooth: HCI device and connection manager initialized
[    1.474458] Bluetooth: HCI socket layer initialized
[    1.479336] Bluetooth: L2CAP socket layer initialized
[    1.484395] Bluetooth: SCO socket layer initialized
[    1.489791] camchar: rtcpu character device driver loaded
[    1.495418] clocksource: Switched to clocksource arch_sys_counter
[    1.665745] VFS: Disk quotas dquot_6.6.0
[    1.669714] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.676907] pnp: PnP ACPI: disabled
[    1.682357] la/ptsa driver initialized.
[    1.686248] NET: Registered protocol family 2
[    1.690806] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.700538] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.709284] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    1.717573] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.725468] TCP: Hash tables configured (established 262144 bind 65536)
[    1.732165] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.739096] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    1.746535] NET: Registered protocol family 1
[    1.751167] RPC: Registered named UNIX socket transport module.
[    1.757099] RPC: Registered udp transport module.
[    1.761802] RPC: Registered tcp transport module.
[    1.766504] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.772953] PCI: CLS 0 bytes, default 64
[    1.776984] Trying to unpack rootfs image as initramfs...
[    1.910184] Freeing initrd memory: 9548K
[    1.916412] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.924379] kvm [1]: IPA Size Limit: 48 bits
[    1.928669] kvm [1]: GICv3: no GICV resource entry
[    1.933461] kvm [1]: disabling GICv2 emulation
[    1.937926] kvm [1]: GIC system register CPU interface enabled
[    1.943829] kvm [1]: vgic interrupt IRQ9
[    1.947864] kvm [1]: VHE mode initialized successfully
[    1.953646] Initialise system trusted keyrings
[    1.958233] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    1.966788] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.972958] NFS: Registering the id_resolver key type
[    1.978031] Key type id_resolver registered
[    1.982214] Key type id_legacy registered
[    1.986253] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.992964] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.000371] ntfs: driver 2.1.32 [Flags: R/W].
[    2.016232] NET: Registered protocol family 38
[    2.020680] Key type asymmetric registered
[    2.024776] Asymmetric key parser 'x509' registered
[    2.029670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    2.037129] io scheduler mq-deadline registered
[    2.041662] io scheduler kyber registered
[    2.050435] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.056041] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.061628] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.067213] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    2.075505] tegra_dc_assign_hw_data: no matching compatible node
[    2.081514] tegradccommon module_init failed
[    2.085782] tegradc module_init failed
[    2.089784] EINJ: ACPI disabled.
[    2.094706] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.101588] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.106901] tegra-pmc: ### PMC reset level: L0
[    2.111342] tegra-pmc: ### PMC reset status reg: 0x0
[    2.117569] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.534780] printk: console [ttyTCU0] enabled
[    3.543971] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.551968] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.556801] arm-smmu 12000000.iommu:         stage 1 translation
[    3.562348] arm-smmu 12000000.iommu:         stage 2 translation
[    3.567892] arm-smmu 12000000.iommu:         nested translation
[    3.573348] arm-smmu 12000000.iommu:         stream matching with 128 register groups
[    3.580757] arm-smmu 12000000.iommu:         128 context banks (0 stage-2 only)
[    3.589685] arm-smmu 12000000.iommu:         Supported page sizes: 0x00001000
[    3.596380] arm-smmu 12000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    3.603069] arm-smmu 12000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    3.610578] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.617270] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.622089] arm-smmu 10000000.iommu:         stage 1 translation
[    3.627617] arm-smmu 10000000.iommu:         stage 2 translation
[    3.633150] arm-smmu 10000000.iommu:         nested translation
[    3.638597] arm-smmu 10000000.iommu:         stream matching with 128 register groups
[    3.646000] arm-smmu 10000000.iommu:         128 context banks (0 stage-2 only)
[    3.654866] arm-smmu 10000000.iommu:         Supported page sizes: 0x00001000
[    3.661558] arm-smmu 10000000.iommu:         Stage-1: 48-bit VA -> 48-bit IPA
[    3.668237] arm-smmu 10000000.iommu:         Stage-2: 48-bit IPA -> 48-bit PA
[    3.675365] arm-smmu 8000000.iommu: probing hardware configuration...
[    3.681966] arm-smmu 8000000.iommu: SMMUv2 with:
[    3.686693] arm-smmu 8000000.iommu:  stage 1 translation
[    3.692132] arm-smmu 8000000.iommu:  stage 2 translation
[    3.697579] arm-smmu 8000000.iommu:  nested translation
[    3.702936] arm-smmu 8000000.iommu:  stream matching with 128 register groups
[    3.710252] arm-smmu 8000000.iommu:  128 context banks (0 stage-2 only)
[    3.719027] arm-smmu 8000000.iommu:  Supported page sizes: 0x00001000
[    3.725628] arm-smmu 8000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    3.732232] arm-smmu 8000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    3.739525] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    3.749274] tegra_profiler: version: 1.151, samples/io: 51/30
[    3.755236] tegra_profiler: auth: init
[    3.759366] nvsciipc: loaded module
[    3.764523] tun: Universal TUN/TAP device driver, 1.6
[    3.770184] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    3.777597] hns3: Copyright (c) 2017 Huawei Corporation.
[    3.783064] e1000e: Intel(R) PRO/1000 Network Driver
[    3.788155] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.794231] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.799758] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.805632] PPP generic driver version 2.4.2
[    3.810072] PPP BSD Compression module registered
[    3.814897] PPP Deflate Compression module registered
[    3.820089] PPP MPPE Compression module registered
[    3.825028] usbcore: registered new interface driver r8152
[    3.830658] usbcore: registered new interface driver asix
[    3.836211] usbcore: registered new interface driver ax88179_178a
[    3.842468] usbcore: registered new interface driver cdc_ether
[    3.848468] usbcore: registered new interface driver net1080
[    3.854274] usbcore: registered new interface driver cdc_subset
[    3.860354] usbcore: registered new interface driver zaurus
[    3.866078] usbcore: registered new interface driver cdc_ncm
[    3.871892] usbcore: registered new interface driver aqc111
[    3.877716] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.884066] ohci-pci: OHCI PCI platform driver
[    3.888646] ohci-platform: OHCI generic platform driver
[    3.894311] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    3.900537] usbcore: registered new interface driver uas
[    3.906001] usbcore: registered new interface driver usb-storage
[    3.912311] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    3.918387] mousedev: PS/2 mouse device common for all mice
[    3.924118] usbcore: registered new interface driver xpad
[    3.931512] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.936983] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[    3.945208] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.951617] i2c /dev entries driver
[    3.955258] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.961032] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.966731] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.972402] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.978073] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.983740] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.989402] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    3.995124] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    4.002827] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[    4.011391] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[    4.020041] pps pps0: new PPS source ktimer
[    4.024332] pps pps0: ktimer PPS source registered
[    4.029252] pps_ldisc: PPS line discipline registered
[    4.035275] device-mapper: uevent: version 1.0.3
[    4.040090] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.049806] sdhci: Secure Digital Host Controller Interface driver
[    4.056149] sdhci: Copyright(c) Pierre Ossman
[    4.060617] Synopsys Designware Multimedia Card Interface Driver
[    4.066857] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.072816] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    4.073160] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.073271] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[    4.092546] tegra-bpmp bpmp: firmware: a414c625926dbe27334a-fcc6f4f897a
[    4.101087] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.106723] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[    4.121652] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.127589] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[    5.920934] hid: raw HID events driver (C) Jiri Kosina
[    5.926484] usbcore: registered new interface driver usbhid
[    5.932218] usbhid: USB HID core driver
[    5.936762] tegra-dce d800000.dce: Adding to iommu group 5
[    5.943959] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    5.952801] tegra234-aon c000000.aon: Adding to iommu group 6
[    5.959433] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    5.959436] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.960212]  c000000.aon:hsp: probed
[    5.980860] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    5.981272] tegra234-aon c000000.aon: init done
[    5.987903] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    5.992862] tegra23x-psc e860000.psc: Adding to iommu group 7
[    6.001379] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    6.001381] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    6.001399] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    6.008050] tegra23x-psc e860000.psc: ext_cfg base:00000000ecf49622
[    6.015691] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    6.015819] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    6.024492] tegra23x-psc e860000.psc: init done
[    6.033263] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    6.033264] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    6.033286] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    6.040050] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 8
[    6.047496] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    6.056799] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    6.111144] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    6.120326] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    6.131963] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    6.143386] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    6.155096] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    6.167673] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    6.180501] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    6.192682] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (119)
[    6.199502] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    6.207876] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=55ecd57df677fd722e795b49ccb283f065b222a1
[    6.221586] t19x_cache tegra-cache: probed
[    6.226021] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    6.238195] optee: probing for conduit method.
[    6.242791] optee: revision 3.22 (e3b12903)
[    6.301532] optee: dynamic shared memory is enabled
[    6.310959] optee: initialized driver
[    6.327895] nvpmodel: initialized successfully
[    6.332616] tegra_hv: get_hvd: not initialized yet
[    6.337554] user_ivc_mempool: hypervisor not present
[    6.343518] usbcore: registered new interface driver snd-usb-audio
[    6.350691] u32 classifier
[    6.353491]     input device check on
[    6.357258]     Actions configured
[    6.360910] Initializing XFRM netlink socket
[    6.365770] NET: Registered protocol family 10
[    6.371670] Segment Routing with IPv6
[    6.375487] NET: Registered protocol family 17
[    6.380080] NET: Registered protocol family 15
[    6.384706] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    6.398853] Bluetooth: RFCOMM socket layer initialized
[    6.404160] Bluetooth: RFCOMM ver 1.11
[    6.408035] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.414129] Bluetooth: HIDP socket layer initialized
[    6.419985] 9pnet: Installing 9P2000 support
[    6.424456] Key type dns_resolver registered
[    6.429654] registered taskstats version 1
[    6.433886] Loading compiled-in X.509 certificates
[    6.449768] Loaded X.509 cert 'Build time autogenerated kernel key: d4a16382d2d8ce9df91e7e6b52beaf43d53de57f'
[    6.460449] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[    6.473091] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.481275] tegra194-pcie 14160000.pcie: Adding to iommu group 10
[    6.493448] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.500362] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[    6.512236] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    6.518746] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[    6.544174] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12
[    6.556239] host1x 13e40000.host1x: Adding to iommu group 13
[    6.585948] host1x 13e40000.host1x: initialized
[    6.591033] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[    6.599125] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    6.611136] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[    6.619188] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    6.631208] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[    6.639255] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    6.651276] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[    6.659266] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.671247] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[    6.679224] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.691202] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[    6.699185] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.711159] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[    6.719153] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.731170] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[    6.739170] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.751162] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[    6.759170] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    6.771157] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[    6.779189] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    6.791170] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[    6.799170] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    6.811149] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[    6.819111] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    6.831111] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[    6.839121] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    6.851108] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[    6.859119] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    6.871124] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[    6.879111] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    6.891141] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[    6.899151] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    6.911163] falcon 15340000.vic: Adding to iommu group 30
[    6.921848] falcon 15340000.vic: initialized
[    6.926585] falcon 15380000.nvjpg: Adding to iommu group 31
[    6.935296] falcon 15380000.nvjpg: initialized
[    6.940025] falcon 15540000.nvjpg1: Adding to iommu group 32
[    6.949176] falcon 15540000.nvjpg1: initialized
[    6.953998] falcon 154c0000.nvenc: Adding to iommu group 33
[    6.964219] falcon 154c0000.nvenc: initialized
[    6.968948] falcon 15a50000.ofa: Adding to iommu group 34
[    6.977512] falcon 15a50000.ofa: initialized
[    6.982070] nvdec 15480000.nvdec: Adding to iommu group 35
[    6.994346] nvdec 15480000.nvdec: initialized
[    6.998957] tsec 15500000.tsec: Adding to iommu group 36
[    7.009774] tsec 15500000.tsec: initialized
[    7.017145] gic 2a41000.agic-controller: GIC IRQ controller registered
[    7.034153] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    7.050699] gpio-394 (camera-control-output-low): hogged as output/low
[    7.057462] gpio-397 (camera-control-output-low): hogged as output/low
[    7.064226] gpio-487 (camera-control-output-low): hogged as output/low
[    7.070984] gpio-486 (camera-control-output-low): hogged as output/low
[    7.078784] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    7.086336] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    7.093305] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    7.099889] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    7.106436] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    7.112670] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    7.121026] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    7.129632] tegra194-isp5 14800000.isp: Adding to iommu group 37
[    7.138556] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    7.148240] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    7.154849] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[    7.162932] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[    7.170931] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[    7.180926] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    7.187741] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[    7.197726] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    7.204525] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    7.214498] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    7.221335] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40
[    7.230058] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[    7.241428] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41
[    7.250083] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[    7.261458] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42
[    7.270060] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[    7.281437] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43
[    7.290045] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[    7.301425] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44
[    7.310048] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[    7.321430] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45
[    7.330046] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[    7.341416] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46
[    7.350046] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[    7.361429] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47
[    7.370038] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[    7.381421] pva 16000000.pva0: Adding to iommu group 48
[    7.405758] pva 16000000.pva0: initialized
[    7.419675] nvdla 15880000.nvdla0: Adding to iommu group 49
[    7.435383] nvdla 15880000.nvdla0: initialized
[    7.441656] nvdla 158c0000.nvdla1: Adding to iommu group 50
[    7.456546] nvdla 158c0000.nvdla1: initialized
[    7.462797] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    7.469850] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    7.477359] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    7.483987] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    7.490740] serial-tegra 3100000.serial: Adding to iommu group 2
[    7.497383] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 26, base_baud = 0) is a TEGRA_UART
[    7.506778] serial-tegra 3110000.serial: Adding to iommu group 2
[    7.513304] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 78, base_baud = 0) is a TEGRA_UART
[    7.523002] serial-tegra 3130000.serial: Adding to iommu group 2
[    7.529480] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 79, base_baud = 0) is a TEGRA_UART
[    7.556481] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    7.566245] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.571826] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    7.580462] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    7.590071] tegra-xusb 3610000.xhci: irq 236, io mem 0x03610000
[    7.596411] tegra-xusb 3610000.xhci: xHCI Host Controller
[    7.601974] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    7.609773] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    7.617417] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    7.625927] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.633361] usb usb1: Product: xHCI Host Controller
[    7.638383] usb usb1: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.644665] usb usb1: SerialNumber: 3610000.xhci
[    7.650203] hub 1-0:1.0: USB hub found
[    7.654097] hub 1-0:1.0: 4 ports detected
[    7.658528] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.667032] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.674473] usb usb2: Product: xHCI Host Controller
[    7.679507] usb usb2: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[    7.685781] usb usb2: SerialNumber: 3610000.xhci
[    7.691101] hub 2-0:1.0: USB hub found
[    7.694991] hub 2-0:1.0: 4 ports detected
[    7.721555] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    7.746359] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[    7.758973] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2014000 KHz, changing to: 2035200 KHz
[    7.770764] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    7.778291] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.786391] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    7.787147] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    7.798491] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.807187] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.815879] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.820010] mmc0: CQHCI version 5.10
[    7.833826] irq: IRQ303: trimming hierarchy from :interrupt-controller@f400000-1
[    7.841484] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[    7.855420] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    7.911419] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[    7.931420] tegra194-pcie 14100000.pcie: Link up
[    7.938240] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.945076] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.950718] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.960553] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.971419] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.979354] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.985690] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.996381] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    8.002724] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    8.008665] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.017123] pci 0001:01:00.0: supports D1 D2
[    8.021528] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    8.033111] mmc0: Command Queue Engine enabled
[    8.033205] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    8.037685] mmc0: periodic cache flush enabled
[    8.037691] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    8.045139] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    8.050084] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[    8.056249] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    8.062833] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[    8.067379] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    8.089058] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.094457] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    8.100756] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    8.108136] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    8.116854] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    8.116931] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    8.125266] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.125267] usb 1-3: Product: Bluetooth Radio
[    8.125268] usb 1-3: Manufacturer: Realtek
[    8.125268] usb 1-3: SerialNumber: 00e04c000001
[    8.155124] pcieport 0001:00:00.0: Adding to iommu group 9
[    8.161173] pcieport 0001:00:00.0: PME: Signaling with IRQ 64
[    8.167427] pcieport 0001:00:00.0: AER: enabled with IRQ 64
[    8.173977] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    8.180455]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    8.181791] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    8.194527] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    8.203219] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    8.211919] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    8.219701] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    8.250591] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[    8.259009] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.266356] usb 2-3: Product: 4-Port USB 3.0 Hub
[    8.271105] usb 2-3: Manufacturer: Generic
[    8.283934] hub 2-3:1.0: USB hub found
[    8.289419] hub 2-3:1.0: 4 ports detected
[    8.367574] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[    8.544269] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[    8.552704] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.560051] usb 1-4: Product: 4-Port USB 2.0 Hub
[    8.564802] usb 1-4: Manufacturer: Generic
[    8.572178] hub 1-4:1.0: USB hub found
[    8.577628] hub 1-4:1.0: 4 ports detected
[    9.011912] usb 2-3.2: new SuperSpeed Gen 1 USB device number 3 using tegra-xusb
[    9.044528] usb 2-3.2: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[    9.053125] usb 2-3.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    9.335961] tegra194-pcie 14160000.pcie: Phy link never came up
[    9.342128] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    9.348930] pci_bus 0004:00: root bus resource [bus 00-ff]
[    9.354563] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    9.364669] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    9.375505] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    9.383429] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    9.389761] pci 0004:00:00.0: PME# supported from D0 D3hot
[    9.404040] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    9.409445] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.418438] pcieport 0004:00:00.0: Adding to iommu group 10
[    9.424447] pcieport 0004:00:00.0: PME: Signaling with IRQ 66
[    9.430869] pcieport 0004:00:00.0: AER: enabled with IRQ 66
[    9.436836] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    9.442925] pci 0004:00:00.0: Removing from iommu group 10
[    9.448574] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    9.456018] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    9.462480] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[    9.462573] vdd-3v3-pcie: supplied by vdd-3v3-sys
[    9.467591] avdd-cam-2v8: supplied by vdd-3v3-sys
[    9.472515] vdd-dp: supplied by vdd-3v3-sys
[    9.476968] vdd-3v3-sd: supplied by vdd-3v3-sys
[    9.482034] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[    9.488643] tegra194-isp5 14800000.isp: initialized
[    9.495902] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    9.502346] (NULL device *): fops function table already registered
[    9.511200] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    9.518213] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    9.518321] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[    9.538917] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 303
[    9.640675] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    9.647861] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    9.656548] tegra194-pcie 141a0000.pcie:      MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[    9.665238] tegra194-pcie 141a0000.pcie:      MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[   10.577132] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[   10.780992] tegra194-pcie 141a0000.pcie: Phy link never came up
[   10.787166] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[   10.793970] pci_bus 0005:00: root bus resource [bus 00-ff]
[   10.799611] pci_bus 0005:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[   10.809715] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[   10.820543] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[   10.828464] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[   10.834813] pci 0005:00:00.0: PME# supported from D0 D3hot
[   10.849089] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[   10.854489] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   10.863467] pcieport 0005:00:00.0: Adding to iommu group 11
[   10.869457] pcieport 0005:00:00.0: PME: Signaling with IRQ 68
[   10.876237] pcieport 0005:00:00.0: AER: enabled with IRQ 68
[   10.882194] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[   10.888275] pci 0005:00:00.0: Removing from iommu group 11
[   10.893922] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[   10.901606] nvethernet 6810000.ethernet: Adding to iommu group 51
[   10.908172] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[   10.916331] nvethernet 6810000.ethernet: failed to read MDIO address
[   10.922887] nvethernet 6810000.ethernet: setting to default DMA bit mask
[   10.929797] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[   11.327292] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:94:6b:a9
[   11.335288] -->macsec_probe()
[   11.335304] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[   11.343092] <--macsec_probe()
[   11.343095] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[   11.352653] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[   11.361419] irq: IRQ305: trimming hierarchy from :pmc@c360000
[   11.367390] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[   11.375064] irq: IRQ307: trimming hierarchy from :pmc@c360000
[   11.381022] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   11.388680] tegra-se-nvhost 15810000.se: Adding to iommu group 52
[   11.395265] tegra-se-nvhost 15810000.se: initialized
[   11.411339] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[   11.417697] tegra-se-nvhost 15820000.se: Adding to iommu group 53
[   11.424229] tegra-se-nvhost 15820000.se: initialized
[   11.431618] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[   11.437976] tegra-se-nvhost 15840000.se: Adding to iommu group 54
[   11.444518] tegra-se-nvhost 15840000.se: initialized
[   11.451451] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[   11.458295] tegra_actmon d230000.actmon: in actmon_register()...
[   11.464618] tegra_actmon d230000.actmon: bwmgr_disable = 1
[   11.470630] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[   11.479019] hvc_sysfs: hypervisor is not present
[   11.615226] ALSA device list:
[   11.618281]   No soundcards found.
[   11.622336] Freeing unused kernel memory: 3968K
[   11.627039] Run /init as init process
[   11.630803]   with arguments:
[   11.630804]     /init
[   11.630805]   with environment:
[   11.630806]     HOME=/
[   11.630807]     TERM=linux
[   11.630807]     mminit_loglevel=4
[   11.642632] Root device found: PARTUUID=6fc683d1-9b5d-4155-a2bd-b0bc54baebf3
[   12.384267] EXT4-fs (mmcblk0p1): 7 orphan inodes deleted
[   12.389756] EXT4-fs (mmcblk0p1): recovery complete
[   12.400158] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   12.413360] Rootfs mounted over PARTUUID=6fc683d1-9b5d-4155-a2bd-b0bc54baebf3
[   12.427519] Switching from initrd to actual rootfs
[   12.526415] systemd[1]: System time before build time, advancing clock.
[   12.572963] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[   12.596550] systemd[1]: Detected architecture arm64.
[   12.631152] systemd[1]: Set hostname to <tegra-ubuntu>.
[   12.820663] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   12.833646] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   12.843163] systemd[1]: Created slice system-modprobe.slice.
[   12.849343] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   12.856061] systemd[1]: Created slice User and Session Slice.
[   12.862089] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.870168] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.879968] systemd[1]: Reached target User and Group Name Lookups.
[   12.886463] systemd[1]: Reached target Slices.
[   12.891077] systemd[1]: Reached target Mounting snaps.
[   12.896405] systemd[1]: Reached target Mounted snaps.
[   12.901649] systemd[1]: Reached target Swap.
[   12.906323] systemd[1]: Listening on RPCbind Server Activation Socket.
[   12.913188] systemd[1]: Listening on Syslog Socket.
[   12.918344] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.925339] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.932299] systemd[1]: Listening on Journal Audit Socket.
[   12.938071] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.944334] systemd[1]: Listening on Journal Socket.
[   12.949598] systemd[1]: Listening on udev Control Socket.
[   12.955262] systemd[1]: Listening on udev Kernel Socket.
[   12.961731] systemd[1]: Mounting Huge Pages File System...
[   12.968396] systemd[1]: Mounting POSIX Message Queue File System...
[   12.975705] systemd[1]: Mounting RPC Pipe File System...
[   12.982113] systemd[1]: Mounting Kernel Debug File System...
[   12.988878] systemd[1]: Mounting Kernel Trace File System...
[   12.995886] systemd[1]: Starting Journal Service...
[   13.002031] systemd[1]: Starting Set the console keyboard layout...
[   13.009434] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   13.019253] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   13.026228] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   13.035700] systemd[1]: Starting Load Kernel Module efi_pstore...
[   13.042951] systemd[1]: Starting Load Kernel Module pstore_blk...
[   13.050361] systemd[1]: Starting Load Kernel Module pstore_zone...
[   13.057775] systemd[1]: Starting Load Kernel Module ramoops...
[   13.064789] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   13.072905] systemd[1]: Started Nameserver information manager.
[   13.079201] systemd[1]: Reached target Network (Pre).
[   13.085198] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   13.094558] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   13.113021] systemd[1]: Starting Load Kernel Modules...
[   13.119298] systemd[1]: Starting Remount Root and Kernel File Systems...
[   13.126806] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   13.127195] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   13.127337] systemd[1]: Starting udev Coldplug all Devices...
[   13.145244] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x0000000838e00000,16777216
[   13.147256] systemd[1]: Started Journal Service.
[   13.154830] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[   13.154838] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[   13.154839] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[   13.154844] nvmap_page_pool_init: Total RAM pages: 7826699
[   13.154844] nvmap_page_pool_init: nvmap page pool size: 978337 pages (3821 MB)
[   13.154896] nvmap_background_zero_thread: PP zeroing thread starting.
[   13.155010] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[   13.158015] misc nvmap: created heap fsi base 0x0000000838e00000 size (16384KiB)
[   13.225371] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   13.262027] systemd-journald[283]: Received client request to flush runtime journal.
[   13.536934] nvidia: loading out-of-tree module taints kernel.
[   13.556112] spi-tegra114 3210000.spi: Adding to iommu group 2
[   13.558524] spi-tegra114 3230000.spi: Adding to iommu group 2
[   13.572813] irq: IRQ308: trimming hierarchy from :pmc@c360000
[   13.582926] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[   13.606038] irq: IRQ309: trimming hierarchy from :pmc@c360000
[   13.606056] nct1008_nct72 4-004c: starting parse dt
[   13.606106] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[   13.606107] nct1008_nct72 4-004c: success parsing dt
[   13.606195] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[   13.606436] nvvrs11 4-0020: NVVRS11 Vendor ID: 0x11
[   13.608339] cpu-throttle-alert cooling device registered.
[   13.609799] gpu-throttle-alert cooling device registered.
[   13.610118] cv0-throttle-alert cooling device registered.
[   13.610756] nvvrs11 4-0020: NVVRS11 Model Rev: 0x81
[   13.610760] nvvrs11 4-0020: NVVRS11 probe successful
[   13.610847] cv1-throttle-alert cooling device registered.
[   13.611231] cv2-throttle-alert cooling device registered.
[   13.611778] soc0-throttle-alert cooling device registered.
[   13.612048] soc1-throttle-alert cooling device registered.
[   13.612329] soc2-throttle-alert cooling device registered.
[   13.613992] hot-surface-alert cooling device registered.
[   13.617120] nvvrs11 4-0022: NVVRS11 Vendor ID: 0x11
[   13.618248] tegra-hda 3510000.hda: Adding to iommu group 55
[   13.618720] nvvrs11 4-0022: NVVRS11 Model Rev: 0x81
[   13.618724] nvvrs11 4-0022: NVVRS11 probe successful
[   13.630366] nv_platform 13800000.display: Adding to iommu group 56
[   13.631234] platform 13800000.display:nvdisplay-niso: Adding to iommu group 57
[   13.635514] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64  35.5.0  Release Build  (buildbrain@mobile-u64-6519-d7000)  Mon Feb 19 20:34:12 PST 2024
[   13.652814] nct1008_nct72 4-004c: LOC shutdown limit 107
[   13.653456] nct1008_nct72 4-004c: EXT shutdown limit 107
[   13.658549] nvadsp 2993000.adsp: Adding to iommu group 58
[   13.660313] nvadsp 2993000.adsp: in probe()...
[   13.660977] nvadsp 2993000.adsp: nvadsp_app_module_probe
[   13.681851] using random self ethernet address
[   13.687067] using random host ethernet address
[   13.689980] nct1008_nct72 4-004c: initial LOC temp: 54000
[   13.692183] nct1008_nct72 4-004c: initial EXT temp: 60500
[   13.693228] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[   13.694041] nct1008_nct72 4-004c: nct1008_probe: initialized
[   13.740421] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   13.740602] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   13.740702] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   13.740775] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   13.930952] tegra-asoc: sound: Adding to iommu group 58
[   13.956052] irq: IRQ311: trimming hierarchy from :pmc@c360000
[   13.986975] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[   13.987234] tegra210_adsp_audio_probe: platform probe started
[   13.987590] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   13.987637] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   13.987827] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   13.995387] ucsi_ccg 1-0008: Port-0: no role switch found
[   13.996609] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   13.996851] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   13.997074] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   13.997154] cdi_tsc c6a0000.tsc_sig_gen: CDI TSC probing...
[   13.997254] cdi_tsc_probe: Initializing the driver
[   13.997295] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   13.997300] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   13.997301] tegra210-adsp tegra210-adsp: using adma channel page 0
[   13.997370] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   13.997854] cdi_tsc_probe: Successfully initialized the tsc char driver
[   14.061685] rtl88x2ce 0001:01:00.0: Adding to iommu group 9
[   14.062099] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[   14.071705] loop: module loaded
[   14.081757] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   14.082055] usbcore: registered new interface driver btusb
[   14.090285] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[   14.100962] cryptd: max_cpu_qlen set to 1000
[   14.103004] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[   14.103008] rtk_btcoex: rtk_btcoex_init: version: 1.2
[   14.103010] rtk_btcoex: create workqueue
[   14.104379] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[   14.104443] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[   14.104445] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[   14.104447] rtk_btusb: patch_add
[   14.104449] rtk_btusb: auto suspend is disabled
[   14.104452] rtk_btusb: pid = 0x3549
[   14.104454] rtk_btusb: patch_add: Reset gEVersion to 0xff
[   14.104462] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[   14.104607] rtk_btusb: btusb_probe: done
[   14.104636] usbcore: registered new interface driver rtk_btusb
[   14.105826] rtk_btusb: btusb_open start
[   14.105829] rtk_btusb: btusb_open hdev->promisc ==0
[   14.105831] rtk_btusb: download_patch start
[   14.105833] rtk_btusb: chip type value: 0x73
[   14.105836] rtk_btusb: HCI reset.
[   14.117331] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[   14.117339] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[   14.117341] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   14.117343] rtk_btusb: load_firmware start
[   14.117345] rtk_btusb: lmp_version = 0x8822
[   14.117483] rtk_btusb: config filename rtl8822cu_config
[   14.120679] rtk_btusb: no bdaddr file /opt/bdaddr
[   14.120689] rtk_btusb: 55 ab 23 87 00 00
[   14.120697] rtk_btusb: Config file length 6, new length 6
[   14.120699] rtk_btusb: fw name is  rtl8822cu_fw
[   14.149019] rtk_btusb: This is not 8723a, use new patch style!
[   14.149030] rtk_btusb: rtk_get_eversion: gEVersion 255
[   14.150263] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[   14.150272] rtk_btusb: load_firmware: New gEVersion 3
[   14.150274] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[   14.150276] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[   14.150277] rtk_btusb: fw_version = 0x9a8cbc9
[   14.150278] rtk_btusb: number_of_total_patch = 3
[   14.150279] rtk_btusb: chipID 4
[   14.150280] rtk_btusb: patch_length 0x8590
[   14.150280] rtk_btusb: start_offset 0x00005d00
[   14.150281] rtk_btusb: Svn version: 1940234490
[   14.150282] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[   14.150283] rtk_btusb: buf_len = 0x8596
[   14.150297] rtk_btusb: fw: exists, config file: exists
[   14.150298] rtk_btusb: load_firmware done
[   14.150317] rtk_btusb: download_data start
[   14.297262] lan78xx 2-3.2:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[   14.321870] input: NVIDIA Jetson AGX Orin APE Headset Jack as /devices/platform/sound/sound/card1/input5
[   14.342437] tegra210-adsp tegra210-adsp: Loaded app wire
[   14.342444] tegra210-adsp tegra210-adsp: Loaded app apm
[   14.342446] tegra210-adsp tegra210-adsp: Loaded app adma
[   14.342447] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   14.342450] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000f26cc108
[   14.345728] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.345742] Bluetooth: BNEP socket layer initialized
[   14.353265] rtk_btusb: download_data done
[   14.353271] rtk_btusb: HCI reset.
[   14.365259] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[   14.365263] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[   14.365265] rtk_btusb: patch_entry->lmp_sub = 0x8822
[   14.365273] rtk_btusb: Rtk patch end 0
[   14.365275] rtk_btusb: btusb_open set HCI_RUNNING
[   14.365291] rtk_btcoex: Open BTCOEX
[   14.365292] rtk_btusb: btusb_open end
[   14.367266] rtk_btcoex: BTCOEX hci_rev 0x09a8
[   14.367269] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[   14.368523] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   14.387257] rtk_btusb: btusb_notify: hci0 evt 3
[   14.410638] Mass Storage Function, version: 2009/09/11
[   14.410647] LUN: removable file: (no medium)
[   14.413122] using random self ethernet address
[   14.417727] using random host ethernet address
[   14.613622] nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x8
[   14.613628] nvvrs_pseq 4-003c: Clearing interrupts
[   14.663942] pstore: Using crash dump compression: deflate
[   14.663980] printk: console [ramoops-1] enabled
[   14.663982] pstore: Registered ramoops as persistent store backend
[   14.663984] ramoops: using 0x200000@0x82d370000, ecc: 0
[   14.837100] irq: IRQ314: trimming hierarchy from :interrupt-controller@f400000-1
[   14.837642] hwmon hwmon6: temp1_input not attached to any thermal zone
[   14.906566] nvgpu: 17000000.ga10b                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   15.571606] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[   15.573384] rndis0: HOST MAC 02:43:94:d3:13:64
[   15.573389] rndis0: MAC 02:43:94:d3:13:65
[   15.574053] usb0: HOST MAC 02:43:94:d3:13:66
[   15.574056] usb0: MAC 02:43:94:d3:13:67
[   15.577140] usbcore: registered new interface driver lan78xx
[   15.656898] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[   15.937503] l4tbr0: port 1(rndis0) entered blocking state
[   15.937521] l4tbr0: port 1(rndis0) entered disabled state
[   15.937708] device rndis0 entered promiscuous mode
[   15.944353] l4tbr0: port 2(usb0) entered blocking state
[   15.944368] l4tbr0: port 2(usb0) entered disabled state
[   15.944530] device usb0 entered promiscuous mode
[   16.124397] lan78xx 2-3.2:1.0 eth1: Link is Down
[   16.334632] zram: Added device: zram0
[   16.334809] zram: Added device: zram1
[   16.335700] zram: Added device: zram2
[   16.336788] zram: Added device: zram3
[   16.338205] zram: Added device: zram4
[   16.338491] zram: Added device: zram5
[   16.339725] zram: Added device: zram6
[   16.340300] zram: Added device: zram7
[   16.395179] zram0: detected capacity change from 0 to 2003636224
[   16.435721] Adding 1956672k swap on /dev/zram0.  Priority:5 extents:1 across:1956672k SS
[   16.438814] zram1: detected capacity change from 0 to 2003636224
[   16.483552] Adding 1956672k swap on /dev/zram1.  Priority:5 extents:1 across:1956672k SS
[   16.486839] zram2: detected capacity change from 0 to 2003636224
[   16.515845] Adding 1956672k swap on /dev/zram2.  Priority:5 extents:1 across:1956672k SS
[   16.518979] zram3: detected capacity change from 0 to 2003636224
[   16.571815] Adding 1956672k swap on /dev/zram3.  Priority:5 extents:1 across:1956672k SS
[   16.574997] zram4: detected capacity change from 0 to 2003636224
[   16.623600] Adding 1956672k swap on /dev/zram4.  Priority:5 extents:1 across:1956672k SS
[   16.627154] zram5: detected capacity change from 0 to 2003636224
[   16.679475] Adding 1956672k swap on /dev/zram5.  Priority:5 extents:1 across:1956672k SS
[   16.682709] zram6: detected capacity change from 0 to 2003636224
[   16.719515] Adding 1956672k swap on /dev/zram6.  Priority:5 extents:1 across:1956672k SS
[   16.722817] zram7: detected capacity change from 0 to 2003636224
[   16.767536] Adding 1956672k swap on /dev/zram7.  Priority:5 extents:1 across:1956672k SS
[   17.444044] lan78xx 2-3.2:1.0 eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[   17.444109] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   18.553421] fuse: init (API version 7.32)
[   18.860801] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  35.5.0  Release Build  (buildbrain@mobile-u64-6519-d7000)  Mon Feb 19 20:34:14 PST 2024
[   19.123828] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   22.244448] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[   22.244476] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[   22.244492] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[   22.244602] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[   22.244620] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[   22.244634] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[   22.244677] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[   22.244851] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[   22.244927] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[   22.244941] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[   22.245049] l4tbr0: port 1(rndis0) entered blocking state
[   22.245054] l4tbr0: port 1(rndis0) entered forwarding state
[   22.245374] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[   24.169020] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[   42.423594] vdd-12v-sys: disabling
[   42.423630] vdd-3v3-ftdi: disabling
