Lan7800-usb-to-gigabit-phy-bandwidth-rate-is-too-low-only-about-250m/305730
Continuing the discussion from Solve the R35.3.1 Jetson agx orin LAN7800 USB to Gigabit PHY bandwidth rate is too low, only about 250M:
I ran into the same problem on Xavier NX. I upgraded jetpack to 5.1.5, but the problem is still there, no improvement. I tested it on PC and other platforms as he did, but only on jeton. I would like to ask if there are any solutions and investigation ideas that can be provided, or contact the engineer to repair the USB driver.
~0702
Sorry for the late response.
