Dear support,
We have USB problem by working with AGX Xavier evaluation board.
Everything is running fine but at some point the USB completely stops working. all USBs don’t answer. Pls see attached dmseg log line [ 657.320325]
[ 657.320325] tegra-xusb 3610000.xhci: xHCI host not responding to stop endpoint command.
dmesgLog_17-11-2020.txt (81.9 KB)
We face this issue suddenly after successfully working - our application perform captures by using ximea camera (connection via USB-C) with external PS, another one USB-A is connected to FPGA with external PS also, and T7 touch SSD device connected to USB-C (we save on SSD device our captures). SSD device doesn’t have external PS.
After Jetson reboot all continue work without problem…
Could you pls help us to resolve this problem?
we work with the following version:
NVIDIA Jetson AGX Xavier [16GB]
L4T 32.3.1 [ JetPack 4.3 ]
Ubuntu 18.04.5 LTS
Kernel Version: 4.9.140-rt93-tegra
CUDA 10.2.89
CUDA Architecture: 7.2
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.0.0.180
TensorRT: 7.1.3.0
Vision Works: 1.6.0.501
VPI: 0.3.7
