During system boot sometimes I am get the next kernel panic after CPU:0, Error:cbb-noc.
What is the cause to this error and that is the cbb?
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.120-tegra (user@ubuntu4production) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Oct 31 08:59:19 IST 2023
[ 0.000000] Machine model: Jetson-AGX
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x859dc6b18 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x8585c0000 MEMATTR=0x8590da018 ESRT=0x85913e498 RNG=0x87c265218 MEMRESERVE=0x8590dcf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000085913e498 to 0x000000085913e4d0.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a0969fff]
[ 0.000000] node 0: [mem 0x00000000a096a000-0x00000000a096bfff]
[ 0.000000] node 0: [mem 0x00000000a096d000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000085782ffff]
[ 0.000000] node 0: [mem 0x0000000857830000-0x000000085809ffff]
[ 0.000000] node 0: [mem 0x00000008580a0000-0x000000085818bfff]
[ 0.000000] node 0: [mem 0x000000085818c000-0x0000000858375fff]
[ 0.000000] node 0: [mem 0x0000000858376000-0x000000085850ffff]
[ 0.000000] node 0: [mem 0x0000000858510000-0x000000085851ffff]
[ 0.000000] node 0: [mem 0x0000000858520000-0x00000008585bffff]
[ 0.000000] node 0: [mem 0x00000008585c0000-0x00000008585cffff]
[ 0.000000] node 0: [mem 0x00000008585d0000-0x00000008590dffff]
[ 0.000000] node 0: [mem 0x00000008590e0000-0x000000085912ffff]
[ 0.000000] node 0: [mem 0x0000000859130000-0x000000085922ffff]
[ 0.000000] node 0: [mem 0x0000000859230000-0x000000085940ffff]
[ 0.000000] node 0: [mem 0x0000000859410000-0x000000085943ffff]
[ 0.000000] node 0: [mem 0x0000000859440000-0x000000085950ffff]
[ 0.000000] node 0: [mem 0x0000000859510000-0x000000085960ffff]
[ 0.000000] node 0: [mem 0x0000000859610000-0x00000008598cffff]
[ 0.000000] node 0: [mem 0x00000008598d0000-0x0000000859f3ffff]
[ 0.000000] node 0: [mem 0x0000000859f40000-0x0000000859fdffff]
[ 0.000000] node 0: [mem 0x0000000859fe0000-0x000000085a10ffff]
[ 0.000000] node 0: [mem 0x000000085a110000-0x000000085a24ffff]
[ 0.000000] node 0: [mem 0x000000085a250000-0x000000085a2dffff]
[ 0.000000] node 0: [mem 0x000000085a2e0000-0x000000085a32ffff]
[ 0.000000] node 0: [mem 0x000000085a330000-0x000000085a35ffff]
[ 0.000000] node 0: [mem 0x000000085a360000-0x000000085a3fffff]
[ 0.000000] node 0: [mem 0x000000085a400000-0x000000085a44ffff]
[ 0.000000] node 0: [mem 0x000000085a450000-0x000000085a4effff]
[ 0.000000] node 0: [mem 0x000000085a4f0000-0x000000085a9cffff]
[ 0.000000] node 0: [mem 0x000000085a9d0000-0x000000085abaffff]
[ 0.000000] node 0: [mem 0x000000085abb0000-0x000000087c21ffff]
[ 0.000000] node 0: [mem 0x000000087c220000-0x000000087c26ffff]
[ 0.000000] node 0: [mem 0x000000087c270000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90328 r8192 d32552 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8032420
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=efifb:off nospectre_bh
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 31667620K/32639676K available (18560K kernel code, 3164K rwdata, 7164K rodata, 3968K init, 1418K bss, 906520K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000672] Console: colour dummy device 80x25
[ 0.001801] printk: console [tty0] enabled
[ 0.001858] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001886] pid_max: default: 32768 minimum: 301
[ 0.002160] LSM: Security Framework initializing
[ 0.002233] Yama: becoming mindful.
[ 0.002274] SELinux: Initializing.
[ 0.002495] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002554] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.006056] rcu: Hierarchical SRCU implementation.
[ 0.006279] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.007097] DTS File Name: /home/user/work/beSom/besomlinuxkernel/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000i
[ 0.007166] DTB Build time: Nov 5 2023 11:27:11
[ 0.009691] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.009943] Remapping and enabling EFI services.
[ 0.012110] smp: Bringing up secondary CPUs ...
[ 0.041144] Detected PIPT I-cache on CPU1
[ 0.041215] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.070720] Detected PIPT I-cache on CPU2
[ 0.070822] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.100378] Detected PIPT I-cache on CPU3
[ 0.100472] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.130149] Detected PIPT I-cache on CPU4
[ 0.130239] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.159973] Detected PIPT I-cache on CPU5
[ 0.160068] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.189886] Detected PIPT I-cache on CPU6
[ 0.190066] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[ 0.219710] Detected PIPT I-cache on CPU7
[ 0.219799] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[ 0.220503] smp: Brought up 1 node, 8 CPUs
[ 0.220662] SMP: Total of 8 processors activated.
[ 0.220718] CPU features: detected: Privileged Access Never
[ 0.220736] CPU features: detected: LSE atomic instructions
[ 0.220746] CPU features: detected: User Access Override
[ 0.220756] CPU features: detected: 32-bit EL0 Support
[ 0.220765] CPU features: detected: RAS Extension Support
[ 0.220775] CPU features: detected: CRC32 instructions
[ 0.220784] CPU features: detected: 32-bit EL1 Support
[ 0.255071] spectre-bhb mitigation disabled by command line option
[ 0.287024] CPU: All CPU(s) started at EL2
[ 0.296251] devtmpfs: initialized
[ 0.337930] Registered cp15_barrier emulation handler
[ 0.338047] Registered setend emulation handler
[ 0.338068] KASLR enabled
[ 0.338289] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.338314] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.339506] pinctrl core: initialized pinctrl subsystem
[ 0.340288] SMBIOS 3.0.0 present.
[ 0.340309] DMI: Unknown Jetson-AGX/Jetson-AGX, BIOS 4.1-33958178 08/01/2023
[ 0.341032] NET: Registered protocol family 16
[ 0.343585] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.345106] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.346664] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.346724] audit: initializing netlink subsys (disabled)
[ 0.347043] audit: type=2000 audit(0.344:1): state=initialized audit_enabled=0 res=1
[ 0.347412] thermal_sys: Registered thermal governor 'step_wise'
[ 0.347418] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.347432] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.349618] cpuidle: using governor menu
[ 0.350016] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.350571] ASID allocator initialised with 32768 entries
[ 0.350822] Serial: AMBA PL011 UART driver
[ 0.353580] Tegra reboot handler registered.
[ 0.413067] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[ 0.413101] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[ 0.413123] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[ 0.413144] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[ 0.413165] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[ 0.413185] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[ 0.413207] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[ 0.413227] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[ 0.413256] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[ 0.413279] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[ 0.413299] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[ 0.413321] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[ 0.413342] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[ 0.413362] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[ 0.413382] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[ 0.413408] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[ 0.413432] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[ 0.413499] mc-err: mcerr ops are set to t19x
[ 0.424234] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.424255] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.424265] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.424274] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.430583] ACPI: Interpreter disabled.
[ 0.431213] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.432824] iommu: Default domain type: Translated
[ 0.432904] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.433297] SCSI subsystem initialized
[ 0.433466] usbcore: registered new interface driver usbfs
[ 0.433499] usbcore: registered new interface driver hub
[ 0.433526] usbcore: registered new device driver usb
[ 0.433852] mc: Linux media interface: v0.10
[ 0.433875] videodev: Linux video capture interface: v2.00
[ 0.434143] pps_core: LinuxPPS API ver. 1 registered
[ 0.434153] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.434171] PTP clock support registered
[ 0.434341] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.434637] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.434710] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.435198] Registered efivars operations
[ 0.441141] FPGA manager framework
[ 0.441216] Advanced Linux Sound Architecture Driver Initialized.
[ 0.441750] Bluetooth: Core ver 2.22
[ 0.441782] NET: Registered protocol family 31
[ 0.441792] Bluetooth: HCI device and connection manager initialized
[ 0.441804] Bluetooth: HCI socket layer initialized
[ 0.441815] Bluetooth: L2CAP socket layer initialized
[ 0.441832] Bluetooth: SCO socket layer initialized
[ 0.443241] camchar: rtcpu character device driver loaded
[ 0.444020] clocksource: Switched to clocksource arch_sys_counter
[ 0.872466] VFS: Disk quotas dquot_6.6.0
[ 0.872590] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.873490] pnp: PnP ACPI: disabled
[ 0.888778] la/ptsa driver initialized.
[ 0.889024] NET: Registered protocol family 2
[ 0.889388] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.904172] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.904536] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.905854] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.906470] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.906669] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.907137] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.907758] NET: Registered protocol family 1
[ 0.908682] RPC: Registered named UNIX socket transport module.
[ 0.908701] RPC: Registered udp transport module.
[ 0.908715] RPC: Registered tcp transport module.
[ 0.908754] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.908774] PCI: CLS 0 bytes, default 64
[ 0.909065] Trying to unpack rootfs image as initramfs...
[ 1.218499] Freeing initrd memory: 9552K
[ 1.224880] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.225526] kvm [1]: IPA Size Limit: 40 bits
[ 1.226136] kvm [1]: vgic interrupt IRQ9
[ 1.226754] kvm [1]: VHE mode initialized successfully
[ 1.228656] Initialise system trusted keyrings
[ 1.228944] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.236655] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.237813] NFS: Registering the id_resolver key type
[ 1.237851] Key type id_resolver registered
[ 1.237865] Key type id_legacy registered
[ 1.237985] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.238009] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.238045] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.248514] NET: Registered protocol family 38
[ 1.248537] Key type asymmetric registered
[ 1.248552] Asymmetric key parser 'x509' registered
[ 1.248607] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 1.248859] io scheduler mq-deadline registered
[ 1.248877] io scheduler kyber registered
[ 1.259742] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.259827] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.259935] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.267580] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.267873] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.269366] EINJ: ACPI disabled.
[ 1.273645] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.273671] tegra-pmc: ### PMC reset source: MAINSWRST
[ 1.273686] tegra-pmc: ### PMC reset level: L1
[ 1.273699] tegra-pmc: ### PMC reset status reg: 0x2d
[ 1.273750] tegra-pmc: PMC Prod config success
[ 1.279149] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.758599] printk: console [ttyTCU0] enabled
[ 2.764952] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.769499] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.774049] arm-smmu 10000000.iommu: stage 1 translation
[ 2.779191] arm-smmu 10000000.iommu: stage 2 translation
[ 2.784897] arm-smmu 10000000.iommu: nested translation
[ 2.790174] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.797343] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.808546] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.810685] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.817097] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.824657] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.830155] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.834858] arm-smmu 12000000.iommu: stage 1 translation
[ 2.840111] arm-smmu 12000000.iommu: stage 2 translation
[ 2.845789] arm-smmu 12000000.iommu: nested translation
[ 2.850964] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.858145] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.869080] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.871498] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.877826] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.885514] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.896279] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.898292] tegra_profiler: auth: init
[ 2.902755] THERMAL EST: found 3 subdevs
[ 2.906177] THERMAL EST num_resources: 0
[ 2.909761] [THERMAL EST subdev 0]
[ 2.913340] [THERMAL EST subdev 1]
[ 2.916753] [THERMAL EST subdev 2]
[ 2.919725] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.926245] THERMAL EST: thz register success.
[ 2.930721] THERMAL EST: end of probe, return err: 0
[ 2.935733] nvsciipc: loaded module
[ 2.943392] tun: Universal TUN/TAP device driver, 1.6
[ 2.945645] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.951539] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.957094] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.962253] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.968102] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.973629] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.979852] PPP generic driver version 2.4.2
[ 2.984069] PPP BSD Compression module registered
[ 2.988344] PPP Deflate Compression module registered
[ 2.993851] PPP MPPE Compression module registered
[ 2.998909] usbcore: registered new interface driver r8152
[ 3.004121] usbcore: registered new interface driver asix
[ 3.009722] usbcore: registered new interface driver ax88179_178a
[ 3.015574] usbcore: registered new interface driver cdc_ether
[ 3.021530] usbcore: registered new interface driver net1080
[ 3.027127] usbcore: registered new interface driver cdc_subset
[ 3.033419] usbcore: registered new interface driver zaurus
[ 3.038885] usbcore: registered new interface driver cdc_ncm
[ 3.044543] usbcore: registered new interface driver aqc111
[ 3.050179] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.056514] ohci-pci: OHCI PCI platform driver
[ 3.060553] ohci-platform: OHCI generic platform driver
[ 3.066595] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 3.072845] usbcore: registered new interface driver uas
[ 3.077130] usbcore: registered new interface driver usb-storage
[ 3.083254] mousedev: PS/2 mouse device common for all mice
[ 3.088316] usbcore: registered new interface driver xpad
[ 3.096784] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.099122] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22)
[ 3.106851] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.113445] i2c /dev entries driver
[ 3.116988] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 3.122827] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 3.128200] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 3.133399] tegra-i2c 3190000.i2c: Adding to iommu group 1
[ 3.138676] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 3.143981] tegra-i2c 31c0000.i2c: Adding to iommu group 1
[ 3.149447] tegra-i2c 31e0000.i2c: Adding to iommu group 1
[ 3.160442] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 3.162206] device-mapper: uevent: version 1.0.3
[ 3.166666] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 3.176701] cpuidle: Initializing cpuidle driver
[ 3.180757] sdhci: Secure Digital Host Controller Interface driver
[ 3.185650] sdhci: Copyright(c) Pierre Ossman
[ 3.189849] Synopsys Designware Multimedia Card Interface Driver
[ 3.196021] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.201903] sdhci-tegra 3460000.sdhci: Adding to iommu group 2
[ 3.207920] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.215006] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.232267] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 3.235520] max77620 4-003c: Backup battery charging support disabled
[ 3.241060] vdd-1v0: supplied by regulator-dummy
[ 3.246328] vdd-1v8-hs: supplied by regulator-dummy
[ 3.250890] vdd-1v8-ls: supplied by regulator-dummy
[ 3.255455] vdd-1v8-ao: supplied by regulator-dummy
[ 3.259180] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.263390] vdd-rtc: supplied by regulator-dummy
[ 3.264864] spmic-ldo1: supplied by regulator-dummy
[ 3.268393] vdd-ao-3v3: supplied by regulator-dummy
[ 3.278390] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.284426] spmic-ldo4: supplied by regulator-dummy
[ 3.285498] vdd-usb-3v3: supplied by regulator-dummy
[ 3.293235] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.299228] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.304490] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.305818] gpio-510 (gpio_default): hogged as output/high
[ 3.308429] gpio-511 (gpio_default): hogged as output/high
[ 3.315504] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.453972] max77686-rtc max77620-rtc: registered as rtc0
[ 3.455248] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 3.455564] max77620 4-003c: max77620 probe successful
��debugfs initialized
��[ 4.244184] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.245030] hid: raw HID events driver (C) Jiri Kosina
[ 4.245595] usbcore: registered new interface driver usbhid
[ 4.245740] usbhid: USB HID core driver
[ 4.247469] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 3
[ 4.248543] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[ 23.313313] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 23.388466] Camera-FW on t194-rce-safe ready SHA1=058eec60 (crt 0.775 ms, total boot 75.958 ms)
��[ 4.334414] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.335124] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.336168] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.336779] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.338388] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.338981] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.339565] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.341210] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[ 4.341445] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.343308] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=058eec606b43624552a5258fda5b4f3967bdfde1
[ 4.349788] tegra_aon c1a0000.aon: Adding to iommu group 4
[ 4.356368] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.361119] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.368229] denver_knobs_init:MTS_VERSION:55637613
[ 4.384335] t19x_cache tegra-cache: probed
[ 4.386343] optee: probing for conduit method.
��C: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 4.387161] optee: revision 3.21 (d8269f24)
[ 4.503520] optee: dynamic shared memory is enabled
[ 4.504441] optee: initialized driver
[ 4.507384] nvpmodel: initialized successfully
[ 4.507937] tegra_hv: get_hvd: not initialized yet
[ 4.508270] user_ivc_mempool: hypervisor not present
[ 4.509442] usbcore: registered new interface driver snd-usb-audio
[ 4.510830] u32 classifier
[ 4.510977] input device check on
[ 4.511106] Actions configured
[ 4.511461] Initializing XFRM netlink socket
[ 4.512463] NET: Registered protocol family 10
[ 4.515102] Segment Routing with IPv6
[ 4.515308] NET: Registered protocol family 17
[ 4.515492] NET: Registered protocol family 15
[ 4.515703] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.516615] Bluetooth: RFCOMM socket layer initialized
[ 4.516882] Bluetooth: RFCOMM ver 1.11
[ 4.517050] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.517268] Bluetooth: HIDP socket layer initialized
[ 4.518139] 9pnet: Installing 9P2000 support
[ 4.518350] Key type dns_resolver registered
[ 4.519598] registered taskstats version 1
[ 4.522628] Loading compiled-in X.509 certificates
[ 4.559731] Loaded X.509 cert 'Build time autogenerated kernel key: 5f24770c0d67f6c2af76b3b51c1bfb2872300121'
[ 4.561372] tegra194-pcie 14180000.pcie: Adding to iommu group 5
[ 4.567109] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 4.567408] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 4.567712] tegra194-pcie 14180000.pcie: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 4.568020] tegra194-pcie 14180000.pcie: MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[ 4.684046] tegra194-pcie 14180000.pcie: Link up
[ 4.694299] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 4.694470] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.694598] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 4.694804] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 4.694975] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 4.695247] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 4.695545] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.701787] pci 0000:01:00.0: [126f:2262] type 00 class 0x010802
[ 4.702141] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 4.709057] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[ 4.709300] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[ 4.709588] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.709746] pci 0000:00:00.0: bridge window [mem 0x1b40000000-0x1b400fffff]
[ 4.709952] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.710214] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 4.713082] pcieport 0000:00:00.0: Adding to iommu group 5
[ 4.718777] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[ 4.724281] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[ 4.730300] nvme 0000:01:00.0: Adding to iommu group 5
[ 4.735281] nvme nvme0: pci function 0000:01:00.0
[ 4.739816] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.740542] tegra194-pcie 14100000.pcie: Adding to iommu group 6
[ 4.751283] nvme nvme0: missing or invalid SUBNQN field.
[ 4.752867] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 4.763689] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 4.772191] tegra194-pcie 14100000.pcie: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 4.780458] tegra194-pcie 14100000.pcie: MEM 0x1230000000..0x123fffffff -> 0x0040000000
[ 4.799041] nvme nvme0: 8/0/0 default/read/poll queues
[ 5.888043] tegra194-pcie 14100000.pcie: Phy link never came up
[ 5.888390] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.888561] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.888680] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.888905] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 5.889064] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 5.889334] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.889645] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.900469] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.900646] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.901339] pcieport 0001:00:00.0: Adding to iommu group 6
[ 5.901869] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[ 5.902640] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[ 5.903292] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 5.903789] pci 0001:00:00.0: Removing from iommu group 6
[ 5.904059] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 5.905481] tegra194-pcie 14140000.pcie: Adding to iommu group 7
[ 5.910933] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[ 5.916483] tegra194-pcie 14140000.pcie: IO 0x0034100000..0x00341fffff -> 0x0034100000
[ 5.924971] tegra194-pcie 14140000.pcie: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 5.933338] tegra194-pcie 14140000.pcie: MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[ 7.040056] tegra194-pcie 14140000.pcie: Phy link never came up
[ 7.040398] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[ 7.040555] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 7.040692] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 7.040888] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 7.041049] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 7.041328] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 7.041630] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.052403] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 7.052620] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.053317] pcieport 0003:00:00.0: Adding to iommu group 7
[ 7.053834] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[ 7.054490] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[ 7.055154] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 7.055642] pci 0003:00:00.0: Removing from iommu group 7
[ 7.055822] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 7.057296] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[ 7.061950] tegra194-pcie 141a0000.pcie: supply vddio-pex-ctl not found, using dummy regulator
[ 7.071244] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 7.077061] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 7.085369] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 7.093832] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 8.184063] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 8.184405] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 8.184570] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 8.184689] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 8.184886] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 8.185061] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 8.185337] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 8.185628] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.195634] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 8.195852] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.196564] pcieport 0005:00:00.0: Adding to iommu group 8
[ 8.197105] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[ 8.197807] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[ 8.198467] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 8.198935] pci 0005:00:00.0: Removing from iommu group 8
[ 8.199126] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 8.212761] host1x 13e10000.host1x: Adding to iommu group 9
[ 8.225390] host1x 13e10000.host1x: initialized
[ 8.226059] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[ 8.226496] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 8.227235] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[ 8.233667] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 8.244111] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[ 8.250794] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 8.260554] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[ 8.267400] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 8.276840] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[ 8.283804] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 8.293816] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[ 8.301124] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 8.310770] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[ 8.318057] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 8.327653] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[ 8.334697] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 8.344634] falcon 15340000.vic: Adding to iommu group 18
[ 8.354478] falcon 15340000.vic: initialized
[ 8.354876] falcon 15380000.nvjpg: Adding to iommu group 18
[ 8.362933] falcon 15380000.nvjpg: initialized
[ 8.364781] falcon 154c0000.nvenc: Adding to iommu group 18
[ 8.374710] falcon 154c0000.nvenc: initialized
[ 8.374990] falcon 15a80000.nvenc1: Adding to iommu group 18
[ 8.384640] falcon 15a80000.nvenc1: initialized
[ 8.385590] nvdec 15480000.nvdec: Adding to iommu group 18
[ 8.395717] nvdec 15480000.nvdec: initialized
[ 8.396075] nvdec 15140000.nvdec1: Adding to iommu group 18
[ 8.405995] nvdec 15140000.nvdec1: initialized
[ 8.406272] tsec 15500000.tsec: Adding to iommu group 19
[ 8.414076] tsec 15500000.tsec: initialized
[ 8.415305] tsec 15100000.tsecb: Adding to iommu group 20
[ 8.423269] tsec 15100000.tsecb: initialized
[ 8.426702] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 8.443483] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 8.448346] gpio-374 (wifi-enable): hogged as output/high
[ 8.449262] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 8.450734] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 8.456497] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.462844] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.468356] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 8.474970] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[ 8.482788] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 8.489919] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 8.496053] driver not enabled, cannot register any devices
[ 8.501775] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[ 8.508160] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.516728] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 8.523270] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.532318] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 8.538940] pva 16000000.pva0: Adding to iommu group 23
[ 8.561826] pva 16000000.pva0: initialized
[ 8.563619] pva 16800000.pva1: Adding to iommu group 24
[ 8.572193] pva 16800000.pva1: initialized
[ 8.573907] nvdla 15880000.nvdla0: Adding to iommu group 25
[ 8.582234] nvdla 15880000.nvdla0: initialized
[ 8.582886] nvdla 158c0000.nvdla1: Adding to iommu group 26
[ 8.589894] nvdla 158c0000.nvdla1: initialized
[ 8.590834] tegradccommon 15200000.display-hub: host1x channel mapped
[ 8.591011] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 8.591227] tegradccommon 15200000.display-hub: dma mapping done
[ 8.598016] tegradc 15200000.display: Adding to iommu group 27
[ 8.606387] tegradc 15200000.display: disp0 connected to head0->sor2
[ 8.609951] generic_infoframe_type: 0x87
[ 8.610236] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[ 8.613684] tegradc 15200000.display: DT parsed successfully
[ 8.614259] tegradc 15210000.display: Adding to iommu group 27
[ 8.621165] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 8.621400] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 8.627014] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 8.633054] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 8.658154] tegra_cec 3960000.tegra_cec: probed
[ 8.662957] tegra-gpcdma 2600000.dma: Adding to iommu group 1
[ 8.662982] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 8.668553] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 8.676383] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 8.676388] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 8.691401] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 8.699893] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 8.704921] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 8.712201] kfuse 3830000.kfuse: initialized
[ 8.718420] tegradc 15200000.display: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 8.722633] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.731506] tegradc 15200000.display: dc_probe: failed hotplug init, -517
[ 8.732125] tegradc 15210000.display: disp0 connected to head1->sor
[ 8.738155] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.744999] generic_infoframe_type: 0x87
[ 8.751228] serial-tegra 3100000.serial: Adding to iommu group 1
[ 8.757596] tegradc 15210000.display: DT parsed successfully
[ 8.761694] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[ 8.767291] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 8.790140] serial-tegra 3110000.serial: Adding to iommu group 1
[ 8.796160] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[ 8.804981] serial-tegra 3140000.serial: Adding to iommu group 1
[ 8.810729] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 8.825317] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 8.829000] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.834530] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.842471] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 8.851347] tegra-xusb 3610000.xhci: irq 189, io mem 0x03610000
[ 8.857342] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.865389] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.872561] usb usb1: Product: xHCI Host Controller
[ 8.877790] usb usb1: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 8.884115] usb usb1: SerialNumber: 3610000.xhci
[ 8.888811] hub 1-0:1.0: USB hub found
[ 8.892627] hub 1-0:1.0: 4 ports detected
[ 8.897004] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.902044] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.909393] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.916951] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.925236] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.932493] usb usb2: Product: xHCI Host Controller
[ 8.937237] usb usb2: Manufacturer: Linux 5.10.120-tegra xhci-hcd
[ 8.943703] usb usb2: SerialNumber: 3610000.xhci
[ 8.948743] hub 2-0:1.0: USB hub found
[ 8.952146] hub 2-0:1.0: 4 ports detected
[ 8.978472] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2265000 KHz, changing to: 2265600 KHz
[ 8.979437] tegra194-cpufreq ccplex: probed with BWMGR, cl:4
[ 8.980396] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 8.983029] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 8.986666] driver not enabled, cannot register any devices
[ 8.993565] mmc0: CQHCI version 5.10
[ 8.997542] tegra194-vi5 15c10000.vi: initialized
[ 9.000704] driver not enabled, cannot register any devices
[ 9.006939] tegradc 15200000.display: disp0 connected to head0->sor2
[ 9.008305] nvethernet 2490000.ethernet: Adding to iommu group 28
[ 9.012500] generic_infoframe_type: 0x87
[ 9.019011] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 9.022332] tegradc 15200000.display: DT parsed successfully
[ 9.030707] nvethernet 2490000.ethernet: failed to read MDIO address
[ 9.036102] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 9.042480] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 9.042485] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 9.042489] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 9.042502] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 9.051445] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 9.057522] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 9.057552] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 9.063595] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 9.070380] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 9.076146] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 9.078776] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 9.092005] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 9.096083] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 9.103989] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 9.103994] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 9.163768] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 9.164148] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:9a:7e:da
[ 9.170370] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 8x4 (on 0x0mm) pclk=148350937
[ 9.175978] usb 1-2: new full-speed USB device number 2 using tegra-xusb
[ 9.189257] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 9.194975] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 9.209976] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 9.217734] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 9.228013] CPU:0, Error: cbb-noc@2300000, irq=15
[ 9.229361] irq: IRQ273: trimming hierarchy from :pmc@c360000
[ 9.229957] **************************************
[ 9.229963] CPU:0, Error:cbb-noc
[ 9.235553] irq: IRQ274: trimming hierarchy from :interrupt-controller@3881000
[ 9.240200] Error Logger : 0
[ 9.240209] ErrLog0 : 0x80030000
[ 9.240212] Transaction Type : RD - Read, Incrementing
[ 9.240214] Error Code : SLV
[ 9.240216] Error Source : Target
[ 9.240218] Error Description : Target error detected by CBB slave
[ 9.240231] Packet header Lock : 0
[ 9.243820] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 9.250787] Packet header Len1 : 3
[ 9.250790] NOC protocol version : version >= 2.7
[ 9.250793] ErrLog1 : 0x352420
[ 9.250795] ErrLog2 : 0x0
[ 9.250797] RouteId : 0x352420
[ 9.250800] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 9.250805] Targflow : host1x_p2pm/T/host1x_p2pm
[ 9.255088] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[ 9.257525] TargSubRange : 18
[ 9.257527] SeqId : 0
[ 9.257530] ErrLog3 : 0x8045c
[ 9.257532] ErrLog4 : 0x0
[ 9.257536] Address accessed : 0x15b8045c
[ 9.257538] ErrLog5 : 0x809f851
[ 9.257540] Non-Modify : 0x1
[ 9.257543] AXI ID : 0x10
[ 9.257545] Master ID : CCPLEX
[ 9.257547] Security Group(GRPSEC): 0x7e
[ 9.257566] Cache : 0x1 -- Bufferable
[ 9.359290] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 9.366283] FALCONSEC : 0x0
[ 9.369445] Virtual Queuing Channel(VQC): 0x0
[ 9.374158] **************************************
[ 9.379016] ------------[ cut here ]------------
[ 9.383439] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[ 9.389829] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 9.395335] Modules linked in:
[ 9.398056] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.120-tegra #1
[ 9.404699] Hardware name: Unknown Jetson-AGX/Jetson-AGX, BIOS 4.1-33958178 08/01/2023
[ 9.412924] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 9.418791] pc : tegra194_cbb_err_isr+0x19c/0x1b0
[ 9.423510] lr : tegra194_cbb_err_isr+0x11c/0x1b0
[ 9.427981] sp : ffff800010003df0
[ 9.431648] x29: ffff800010003df0 x28: 0000000000000001
[ 9.436900] x27: 0000000000000080 x26: ffffbbfe30b5a850
[ 9.442328] x25: ffffbbfe314aae38 x24: 0000000000000001
[ 9.448008] x23: ffffbbfe30e47008 x22: ffffbbfe312cf258
[ 9.453174] x21: 000000000000000f x20: 0000000000000005
[ 9.458783] x19: ffffbbfe312cf248 x18: 0000000000000010
[ 9.464025] x17: 0000001000002000 x16: 0000000036d1dfa2
[ 9.469708] x15: ffffbbfe31142bf0 x14: 0720072007200720
[ 9.474790] x13: 0720072007200720 x12: 0720072007200720
[ 9.480127] x11: 0720072007200720 x10: 0720072007200720
[ 9.485895] x9 : 0720072007200720 x8 : 07200720072a072a
[ 9.491150] x7 : 072a072a072a072a x6 : c0000000ffffefff
[ 9.496673] x5 : 0000000000057fa8 x4 : ffffbbfe31157a48
[ 9.502344] x3 : 00000000ffffffff x2 : ffffbbfe2f5d0d70
[ 9.507425] x1 : ffffbbfe31142680 x0 : 0000000100010001
[ 9.512762] Call trace:
[ 9.515217] tegra194_cbb_err_isr+0x19c/0x1b0
[ 9.519517] __handle_irq_event_percpu+0x68/0x2a0
[ 9.524311] handle_irq_event_percpu+0x40/0xa0
[ 9.528772] handle_irq_event+0x50/0xf0
[ 9.532277] handle_fasteoi_irq+0xc0/0x170
[ 9.536560] generic_handle_irq+0x40/0x60
[ 9.540584] __handle_domain_irq+0x70/0xd0
[ 9.544787] efi_header_end+0xb0/0xf0
[ 9.548027] el1_irq+0xd0/0x180
[ 9.551278] cpuidle_enter_state+0xb8/0x410
[ 9.555462] cpuidle_enter+0x40/0x60
[ 9.558959] call_cpuidle+0x44/0x80
[ 9.562201] do_idle+0x208/0x270
[ 9.565871] cpu_startup_entry+0x2c/0x70
[ 9.569636] rest_init+0xdc/0xe8
[ 9.572618] arch_call_rest_init+0x18/0x20
[ 9.577072] start_kernel+0x500/0x538
[ 9.580146] Code: a9446bf9 a94573fb a8c67bfd d65f03c0 (d4210000)
[ 9.586360] ---[ end trace 9d59be9ab961a823 ]---
[ 9.591334] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 9.598601] SMP: stopping secondary CPUs
[ 9.602740] Kernel Offset: 0x3bfe1f410000 from 0xffff800010000000
[ 9.608833] PHYS_OFFSET: 0xffffae29c0000000
[ 9.612688] CPU features: 0x18240002,03802a30
[ 9.617150] Memory Limit: none
[ 9.620562] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
