irq: IRQ256: trimming hierarchy from :pmc@c360000
[ 8.472410] **************************************
[ 8.472413] * For more Internal Decode Help
[ 8.472416] * NVIDIA userID is required to access
[ 8.472418] **************************************
[ 8.472443] CPU:0, Error:CBB-NOC
[ 8.478110] irq: IRQ257: trimming hierarchy from :interrupt-controller@3881000
[ 8.483255] Error Logger : 0
[ 8.483265] ErrLog0 : 0x80030000
[ 8.483268] Transaction Type : RD - Read, Incrementing
[ 8.483270] Error Code : SLV
[ 8.483276] Error Source : Target
[ 8.487580] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 8.490868] Error Description : Target error detected by CBB slave
[ 8.490878] AXI2APB_4 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 8.490883] Packet header Lock : 0
[ 8.490888] Packet header Len1 : 3
[ 8.496490] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[ 8.500060] NOC protocol version : version >= 2.7
[ 8.500081] ErrLog1 : 0x352426
[ 8.500088] ErrLog2 : 0x0
[ 8.575569] RouteId : 0x352426
[ 8.578892] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 8.583618] Targflow : host1x_p2pm/T/host1x_p2pm
[ 8.588608] TargSubRange : 18
[ 8.592016] SeqId : 0
[ 8.594731] ErrLog3 : 0x4045c
[ 8.597885] ErrLog4 : 0x0
[ 8.601032] Address accessed : 0x15b4045c
[ 8.605405] ErrLog5 : 0x989f851
[ 8.608817] Non-Modify : 0x1
[ 8.612144] AXI ID : 0x13
[ 8.615309] Master ID : CCPLEX
[ 8.618704] Security Group(GRPSEC): 0x7e
[ 8.622650] Cache : 0x1 -- Bufferable
[ 8.626848] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 8.633757] FALCONSEC : 0x0
[ 8.636904] Virtual Queuing Channel(VQC): 0x0
[ 8.641289] **************************************
[ 8.646345] ------------[ cut here ]------------
[ 8.651082] kernel BUG at /dvs/git/dirty/git-master_linux/kernel/nvidia/drivers/platform/tegra/cbb/tegra19x_cbb.c:553!
[ 8.661586] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 8.666663] Modules linked in:
[ 8.670072] CPU: 0 PID: 7 Comm: kworker/u12:0 Not tainted 5.10.65-tegra #1
[ 8.676723] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 8.682966] Workqueue: events_unbound async_run_entry_fn
[ 8.688709] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 8.694748] pc : tegra194_cbb_error_isr+0x198/0x1b0
[ 8.699474] lr : tegra194_cbb_error_isr+0xcc/0x1b0
[ 8.704460] sp : ffff80001214bb40
[ 8.707793] x29: ffff80001214bb40 x28: 0000000000000001
[ 8.713471] x27: ffff8000117c1308 x26: 0000000000000080
[ 8.718636] x25: ffff800012119440 x24: 0000000000000001
[ 8.724406] x23: ffff800011a16000 x22: 000000000000000f
[ 8.729917] x21: ffff800011f94fe0 x20: 0000000000000005
[ 8.735429] x19: ffff800011f950b8 x18: 0000000000000010
[ 8.740599] x17: 0000000000004350 x16: 0000000000000068
[ 8.745937] x15: ffff000080165c70 x14: ffffffffffffffff
[ 8.751360] x13: ffff80009214b737 x12: ffff80001214b73f
[ 8.756697] x11: 0000000000000038 x10: 0101010101010101
[ 8.762211] x9 : ffff80001214ba50 x8 : 2a2a2a2a2a2a2a2a
[ 8.767893] x7 : ffff8000106c56d0 x6 : c0000000ffffefff
[ 8.773230] x5 : 0000000000057fa8 x4 : ffff800011d278a0
[ 8.778662] x3 : 00000000ffffffff x2 : ffff8000101b6d10
[ 8.783737] x1 : ffff000080165700 x0 : 0000000100010100
[ 8.789330] Call trace:
[ 8.791787] tegra194_cbb_error_isr+0x198/0x1b0
[ 8.796350] __handle_irq_event_percpu+0x60/0x2a0
[ 8.800884] handle_irq_event_percpu+0x3c/0xa0
[ 8.805362] handle_irq_event+0x4c/0xf0
[ 8.809107] handle_fasteoi_irq+0xbc/0x170
[ 8.812876] generic_handle_irq+0x3c/0x60
[ 8.816918] __handle_domain_irq+0x6c/0xc0
[ 8.821359] efi_header_end+0xa8/0xf0
[ 8.824601] el1_irq+0xd0/0x180
[ 8.827848] __do_softirq+0xb0/0x3e0
[ 8.831509] irq_exit+0xc0/0xe0
[ 8.834481] __handle_domain_irq+0x70/0xc0
[ 8.838507] efi_header_end+0xa8/0xf0
[ 8.842180] el1_irq+0xd0/0x180
[ 8.844902] tegra_hda_get_dev_id+0x68/0x2a0
[ 8.849461] tegra_hda_init+0x230/0x430
[ 8.853383] tegra_dc_hdmi_init+0x814/0xba0
[ 8.857234] tegra_dc_set_out+0x2e0/0x4b0
[ 8.861257] tegra_dc_probe+0xaf4/0x15c0
[ 8.865196] platform_drv_probe+0x58/0xb0
[ 8.869156] really_probe+0xf4/0x3d0
[ 8.873070] driver_probe_device+0x5c/0xc0
[ 8.877197] __device_attach_driver+0x88/0xc0
[ 8.881558] bus_for_each_drv+0x88/0xe0
[ 8.885320] __device_attach_async_helper+0xbc/0xe0
[ 8.890221] async_run_entry_fn+0x48/0x150
[ 8.894421] process_one_work+0x1c0/0x4a0
[ 8.898291] worker_thread+0x50/0x420
[ 8.902207] kthread+0x148/0x170
[ 8.905274] ret_from_fork+0x10/0x18
[ 8.908976] Code: a9425bf5 a9446bf9 a8c67bfd d65f03c0 (d4210000)
[ 8.915081] ---[ end trace ea723d517378892e ]---
[ 8.919714] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 8.927151] SMP: stopping secondary CPUs
[ 8.931359] Kernel Offset: disabled
[ 8.935018] CPU features: 0x8240002,03002a30
[ 8.939217] Memory Limit: none
[ 8.950388] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
[End]
[Uploading: 004-ERROR-R2(1).log...]()
[Uploading: 004-OK-R2(1).log...]()
[Uploading: tegra194-p3668-0001-p3509-0000-R34(1).dts...]()
[Jetson Xavier NX (Developer Edition) not starting (blank screen)](https://forums.developer.nvidia.com/t/jetson-xavier-nx-developer-edition-not-starting-blank-screen/218514)[Hello everyone, do you have code encryption software for NVIDIA Jeston motherboard](https://forums.developer.nvidia.com/t/hello-everyone-do-you-have-code-encryption-software-for-nvidia-jeston-motherboard/182079)
Is that issue on your custom board or even devkit?
