when trying to get a new L4T 34.1.1 based image (/w Kernel 5.10+) to run with our custom .cfg (on custom carrier board), there seem to be randomly thrown kernel panics during boot up.
This is happening in aprox. 30-40% of all boot attempts, and it is thrown always in conjunction with CBB-NOC@0x2300000,irq=15 (see logs).
There were no such problems with the respective L4T 32.5.1 based image, and we made no modifications on the config items beside aligning our config to the new jetson-xavier-devkit.cfg.
As already mentioned in No support for t194 SOC Family in tegra-defconfig with L4T 34.1.x? - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums, it seems that the kernel cfg option for tegra19x does not work.
Nevertheless, the moderator assured that tegra19x support is available with the default kernel config (in which the corresponding option for tegra19x is not selected!!!), and thus we tried with tegra_defconfig.
No, it seems to clearify that there seems to be some major issue with tegra19x support (what could lead to such an heavy behaviour), or some general and hard bug on IRQ level in other parts of the defconfig.
A short excerpt of the log part for the panic:
[   22.860604] CPU:0, Error:CBB-NOC@0x2300000,irq=15
[   22.870756] **************************************
[   22.870937] * For more Internal Decode Help
[   22.871145] *     http://nv/cbberr
[   22.871268] * NVIDIA userID is required to access
[   22.871442] **************************************
[   22.871624] CPU:0, Error:CBB-NOC
[   22.871781] 	Error Logger		: 0
[   22.871958] 	ErrLog0			: 0x80030000
[   22.872092] 	  Transaction Type	: RD  - Read, Incrementing
[   22.872283] 	  Error Code		: SLV
[   22.872418] 	  Error Source		: Target
[   22.873558] 	  Error Description	: Target error detected by CBB slave
[   22.880151] 	  AXI2APB_4 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[   22.887742] 	  Packet header Lock	: 0
[   22.891232] 	  Packet header Len1	: 3
[   22.894905] 	  NOC protocol version	: version >= 2.7
[   22.899890] 	ErrLog1			: 0x351626
[   22.903130] 	ErrLog2			: 0x0
[   22.905755] 	  RouteId		: 0x351626
[   22.909176] 	  InitFlow		: ccroc_p2ps/I/ccroc_p2ps
[   22.914413] 	  Targflow		: host1x_p2pm/T/host1x_p2pm
[   22.918968] 	  TargSubRange		: 11
[   22.922462] 	  SeqId			: 0
[   22.925265] 	ErrLog3			: 0x30124
[   22.928536] 	ErrLog4			: 0x0
[   22.931143] 	  Address accessed	: 0x155f0124
[   22.935680] 	ErrLog5			: 0x989f851
[   22.939088] 	  Non-Modify		: 0x1
[   22.942501] 	  AXI ID		: 0x13
[   22.945656] 	  Master ID		: CCPLEX
[   22.948722] 	  Security Group(GRPSEC): 0x7e
[   22.952925] 	  Cache			: 0x1 -- Bufferable
[   22.957379] 	  Protection		: 0x2 -- Unprivileged, Non-Secure, Data Access
[   22.964204] 	  FALCONSEC		: 0x0
[   22.967382] 	  Virtual Queuing Channel(VQC): 0x0
[   22.971995] 	**************************************
[   22.976807] ------------[ cut here ]------------
[   22.981533] kernel BUG at /Linux_for_Tegra/l4t_new/sources/kernel/nvidia/drivers/platform/tegra/cbb/tegra19x_cbb.c:553!
[   22.992302] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[   22.997637] Modules linked in:
[   23.000539] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.65-tegra #2
[   23.007164] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS r34.1-975eef6 05/16/2022
[   23.019439] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[   23.025510] pc : tegra194_cbb_error_isr+0x198/0x1b0
[   23.030744] lr : tegra194_cbb_error_isr+0xcc/0x1b0
[   23.035432] sp : ffff800010003df0
[   23.039042] x29: ffff800010003df0 x28: 0000000000000001
[   23.044189] x27: ffffcad10588c598 x26: 0000000000000080
[   23.049605] x25: ffffcad1061c9420 x24: 0000000000000001
[   23.055378] x23: ffffcad105ad6000 x22: 000000000000000f
[   23.060456] x21: ffffcad106044e60 x20: 0000000000000005
[   23.066230] x19: ffffcad106044f38 x18: 0000000000000010
[   23.071397] x17: ffffcad104d1d970 x16: 0000000000000068
[   23.077169] x15: ffffcad105dc2b30 x14: 0720072007200720
[   23.082421] x13: 0720072007200720 x12: 0720072007200720
[   23.088108] x11: 0720072007200720 x10: 0720072007200720
[   23.093371] x9 : 0720072007200720 x8 : 07200720072a072a
[   23.099053] x7 : 072a072a072a072a x6 : c0000000ffffefff
[   23.104120] x5 : 0000000000057fa8 x4 : ffffcad105dd78a0
[   23.109549] x3 : 00000000ffffffff x2 : ffffcad1042a6d10
[   23.115138] x1 : ffffcad105dc25c0 x0 : 0000000100010001
[   23.120481] Call trace:
[   23.122960]  tegra194_cbb_error_isr+0x198/0x1b0
[   23.127502]  __handle_irq_event_percpu+0x60/0x2a0
[   23.132031]  handle_irq_event_percpu+0x3c/0xa0
[   23.136234]  handle_irq_event+0x4c/0xf0
[   23.140258]  handle_fasteoi_irq+0xbc/0x170
[   23.144318]  generic_handle_irq+0x3c/0x60
[   23.148302]  __handle_domain_irq+0x6c/0xc0
[   23.152512]  efi_header_end+0xa8/0xf0
[   23.155780]  el1_irq+0xd0/0x180
[   23.158734]  cpuidle_enter_state+0xb4/0x400
[   23.162925]  cpuidle_enter+0x3c/0x50
[   23.166455]  call_cpuidle+0x40/0x70
[   23.169921]  do_idle+0x1fc/0x260
[   23.173586]  cpu_startup_entry+0x2c/0x70
[   23.177116]  rest_init+0xd8/0xe4
[   23.180611]  arch_call_rest_init+0x14/0x1c
[   23.184816]  start_kernel+0x4c0/0x4f4
[   23.188153] Code: a9425bf5 a9446bf9 a8c67bfd d65f03c0 (d4210000)
[   23.194300] ---[ end trace b8452aa19fc46e1e ]---
[   23.198715] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[   23.206494] SMP: stopping secondary CPUs
[   23.210450] Kernel Offset: 0x4ad0f40f0000 from 0xffff800010000000
[   23.216464] PHYS_OFFSET: 0xffffd2bec0000000
[   23.220585] CPU features: 0x8240002,03002a30
[   23.224816] Memory Limit: none
[   23.242394] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
Second error message variant is:
[   22.828355] CPU:0, Error:CBB-NOC@0x2300000,irq=15
[   22.828593] **************************************
[   22.828779] * For more Internal Decode Help
[   22.828930] *     http://nv/cbberr
[   22.829076] * NVIDIA userID is required to access
[   22.829218] **************************************
[   22.829395] CPU:0, Error:CBB-NOC
[   22.829545] 	Error Logger		: 0
[   22.829685] 	ErrLog0			: 0x80030000
[   22.829820] 	  Transaction Type	: RD  - Read, Incrementing
[   22.833597] 	  Error Code		: SLV
[   22.836922] 	  Error Source		: Target
[   22.840760] 	  Error Description	: Target error detected by CBB slave
[   22.847087] 	  AXI2APB_4 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[   22.854681] 	  Packet header Lock	: 0
[   22.858172] 	  Packet header Len1	: 3
[   22.861891] 	  NOC protocol version	: version >= 2.7
[   22.866586] 	ErrLog1			: 0x35162c
[   22.869815] 	ErrLog2			: 0x0
[   22.872959] 	  RouteId		: 0x35162c
[   22.876118] 	  InitFlow		: ccroc_p2ps/I/ccroc_p2ps
[   22.881359] 	  Targflow		: host1x_p2pm/T/host1x_p2pm
[   22.885912] 	  TargSubRange		: 11
[   22.889411] 	  SeqId			: 0
[   22.891949] 	ErrLog3			: 0x30124
[   22.895198] 	ErrLog4			: 0x0
[   22.898372] 	  Address accessed	: 0x155f0124
[   22.902546] 	ErrLog5			: 0xb09f851
[   22.906040] 	  Non-Modify		: 0x1
[   22.909185] 	  AXI ID		: 0x16
[   22.912347] 	  Master ID		: CCPLEX
[   22.915668] 	  Security Group(GRPSEC): 0x7e
[   22.919896] 	  Cache			: 0x1 -- Bufferable
[   22.924114] 	  Protection		: 0x2 -- Unprivileged, Non-Secure, Data Access
[   22.930892] 	  FALCONSEC		: 0x0
[   22.934050] 	  Virtual Queuing Channel(VQC): 0x0
[   22.938678] 	**************************************
[   22.943802] ------------[ cut here ]------------
[   22.948227] kernel BUG at /Linux_for_Tegra/l4t_new/sources/kernel/nvidia/drivers/platform/tegra/cbb/tegra19x_cbb.c:553!
[   22.958991] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[   22.964583] Modules linked in:
[   22.967758] CPU: 0 PID: 121 Comm: kworker/0:3 Not tainted 5.10.65-tegra #2
[   22.974384] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS r34.1-975eef6 05/16/2022
[   22.987219] Workqueue: events deferred_probe_work_func
[   22.992404] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[   22.998212] pc : tegra194_cbb_error_isr+0x198/0x1b0
[   23.003471] lr : tegra194_cbb_error_isr+0xcc/0x1b0
[   23.008322] sp : ffff800010003b40
[   23.011396] x29: ffff800010003b40 x28: 0000000000000001
[   23.016820] x27: ffffb2b7ee88c598 x26: 0000000000000080
[   23.022585] x25: ffffb2b7ef1c9420 x24: 0000000000000001
[   23.027922] x23: ffffb2b7eead6000 x22: 000000000000000f
[   23.033181] x21: ffffb2b7ef044e60 x20: 0000000000000005
[   23.038857] x19: ffffb2b7ef044f38 x18: 0000000000000010
[   23.043951] x17: 0000000000000007 x16: 0000000000000068
[   23.049455] x15: ffff2237921abf70 x14: 0720072007200720
[   23.054882] x13: 0720072007200720 x12: 0720072007200720
[   23.060303] x11: 0720072007200720 x10: 0720072007200720
[   23.066078] x9 : 0720072007200720 x8 : 07200720072a072a
[   23.071241] x7 : 072a072a072a072a x6 : c0000000ffffefff
[   23.076842] x5 : 0000000000057fa8 x4 : ffffb2b7eedd78a0
[   23.082002] x3 : 00000000ffffffff x2 : ffffb2b7ed2a6d10
[   23.087599] x1 : ffff2237921aba00 x0 : 0000000100010100
[   23.092934] Call trace:
[   23.095396]  tegra194_cbb_error_isr+0x198/0x1b0
[   23.099953]  __handle_irq_event_percpu+0x60/0x2a0
[   23.104488]  handle_irq_event_percpu+0x3c/0xa0
[   23.108723]  handle_irq_event+0x4c/0xf0
[   23.112715]  handle_fasteoi_irq+0xbc/0x170
[   23.116773]  generic_handle_irq+0x3c/0x60
[   23.120764]  __handle_domain_irq+0x6c/0xc0
[   23.124967]  efi_header_end+0xa8/0xf0
[   23.128471]  el1_irq+0xd0/0x180
[   23.131432]  __do_softirq+0xb0/0x3e0
[   23.135120]  irq_exit+0xc0/0xe0
[   23.138087]  __handle_domain_irq+0x70/0xc0
[   23.141857]  efi_header_end+0xa8/0xf0
[   23.145566]  el1_irq+0xd0/0x180
[   23.148527]  tegra_dpaux_update.isra.0+0x30/0x50
[   23.153060]  tegra_dpaux_pinctrl_set_mux+0xf8/0x130
[   23.158133]  pinmux_enable_setting+0x10c/0x280
[   23.162422]  pinctrl_commit_state+0x94/0x170
[   23.166722]  pinctrl_select_state+0x34/0x50
[   23.170916]  pinctrl_bind_pins+0x14c/0x160
[   23.175141]  really_probe+0x8c/0x3d0
[   23.178691]  driver_probe_device+0x5c/0xc0
[   23.182829]  __device_attach_driver+0x88/0xc0
[   23.186832]  bus_for_each_drv+0x88/0xe0
[   23.190937]  __device_attach+0xf0/0x150
[   23.194621]  device_initial_probe+0x24/0x30
[   23.198817]  bus_probe_device+0x9c/0xb0
[   23.202956]  deferred_probe_work_func+0x88/0xc0
[   23.207571]  process_one_work+0x1c0/0x4a0
[   23.211789]  worker_thread+0x1f8/0x420
[   23.215444]  kthread+0x148/0x170
[   23.219035]  ret_from_fork+0x10/0x18
[   23.222739] Code: a9425bf5 a9446bf9 a8c67bfd d65f03c0 (d4210000)
[   23.228948] ---[ end trace 2f85a3e4cbe9a331 ]---
[   23.233470] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[   23.240822] SMP: stopping secondary CPUs
[   23.244930] Kernel Offset: 0x32b7dd0f0000 from 0xffff800010000000
[   23.250792] PHYS_OFFSET: 0xffffddcac0000000
[   23.254928] CPU features: 0x8240002,03002a30
[   23.259535] Memory Limit: none
[   23.278059] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
Note the different call trace (CPU_Idle vs. dpaux).
The issue is also occuring with the default L4T-SDCard Image and/or the L4T DevKit Default Flash Config (jetson-xavier-nx-devkit.cfg), so it is probably no issue with our config.
Any ideas on that? Is the problem known? How can we get more information on whats happening (especially regarding irq15)? Or is Jetson Xavier NX in fact not yet fully supported?
This is very urgent because our customer needs support for Kernel 5 as fast as possible and cannot continue their business if it won’t work under the new kernel.
nosscall+sdmmc.txt (98.1 KB)
nosscall+nosdmmc+eepromoff.txt (387.9 KB)
