Thanks for reply @WayneWWW.
I’m currently using standard jetson-inference files such as glDisplay.cpp, which has Beginrender() below:
* Copyright (c) 2017, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include "glDisplay.h"
// Constructor
glDisplay::glDisplay()
mWindowX = 0;
mScreenX = NULL;
mVisualX = NULL;
mContextGL = NULL;
mDisplayX = NULL;
mWidth = 0;
mHeight = 0;
mAvgTime = 1.0f;
mBgColor[0] = 0.0f;
mBgColor[1] = 0.0f;
mBgColor[2] = 0.0f;
mBgColor[3] = 1.0f;
clock_gettime(CLOCK_REALTIME, &mLastTime);
// Destructor
glDisplay::~glDisplay()
glXDestroyContext(mDisplayX, mContextGL);
// Create
glDisplay* glDisplay::Create( const char* title, float r, float g, float b, float a )
glDisplay* vp = new glDisplay();
if( !vp )
return NULL;
if( !vp->initWindow() )
printf("[OpenGL] failed to create X11 Window.\n");
delete vp;
return NULL;
if( !vp->initGL() )
printf("[OpenGL] failed to initialize OpenGL.\n");
delete vp;
return NULL;
GLenum err = glewInit();
if (GLEW_OK != err)
printf("[OpenGL] GLEW Error: %s\n", glewGetErrorString(err));
delete vp;
return NULL;
if( title != NULL )
vp->SetTitle(title);
vp->SetBackgroundColor(r, g, b, a);
printf("[OpenGL] glDisplay display window initialized\n");
return vp;
#define DEFAULT_TITLE "NVIDIA Jetson | JetPack-L4T"
// Create
glDisplay* glDisplay::Create( float r, float g, float b, float a )
return Create(DEFAULT_TITLE, r, g, b, a);
// initWindow
bool glDisplay::initWindow()
if( !mDisplayX )
mDisplayX = XOpenDisplay(0);
if( !mDisplayX )
printf( "[OpenGL] failed to open X11 server connection." );
return false;
if( !mDisplayX )
printf( "InitWindow() - no X11 server connection." );
return false;
// retrieve screen info
const int screenIdx = DefaultScreen(mDisplayX);
const int screenWidth = DisplayWidth(mDisplayX, screenIdx);
const int screenHeight = DisplayHeight(mDisplayX, screenIdx);
printf("default X screen %i: %i x %i\n", screenIdx, screenWidth, screenHeight);
Screen* screen = XScreenOfDisplay(mDisplayX, screenIdx);
if( !screen )
printf("failed to retrieve default Screen instance\n");
return false;
Window winRoot = XRootWindowOfScreen(screen);
// get framebuffer format
static int fbAttribs[] =
GLX_X_RENDERABLE, True,
GLX_DRAWABLE_TYPE, GLX_WINDOW_BIT,
GLX_RENDER_TYPE, GLX_RGBA_BIT,
GLX_X_VISUAL_TYPE, GLX_TRUE_COLOR,
GLX_RED_SIZE, 8,
GLX_GREEN_SIZE, 8,
GLX_BLUE_SIZE, 8,
GLX_ALPHA_SIZE, 8,
GLX_DEPTH_SIZE, 24,
GLX_STENCIL_SIZE, 8,
GLX_DOUBLEBUFFER, True,
GLX_SAMPLE_BUFFERS, 0,
GLX_SAMPLES, 0,
None
int fbCount = 0;
GLXFBConfig* fbConfig = glXChooseFBConfig(mDisplayX, screenIdx, fbAttribs, &fbCount);
if( !fbConfig || fbCount == 0 )
return false;
// get a 'visual'
XVisualInfo* visual = glXGetVisualFromFBConfig(mDisplayX, fbConfig[0]);
if( !visual )
return false;
// populate windows attributes
XSetWindowAttributes winAttr;
winAttr.colormap = XCreateColormap(mDisplayX, winRoot, visual->visual, AllocNone);
winAttr.background_pixmap = None;
winAttr.border_pixel = 0;
winAttr.event_mask = StructureNotifyMask|KeyPressMask|KeyReleaseMask|PointerMotionMask|ButtonPressMask|ButtonReleaseMask;
// create window
Window win = XCreateWindow(mDisplayX, winRoot, 0, 0, screenWidth, screenHeight, 0,
visual->depth, InputOutput, visual->visual, CWBorderPixel|CWColormap|CWEventMask, &winAttr);
if( !win )
return false;
XStoreName(mDisplayX, win, DEFAULT_TITLE);
XMapWindow(mDisplayX, win);
// cleanup
mWindowX = win;
mScreenX = screen;
mVisualX = visual;
mWidth = screenWidth;
mHeight = screenHeight;
XFree(fbConfig);
return true;
void glDisplay::SetTitle( const char* str )
XStoreName(mDisplayX, mWindowX, str);
// initGL
bool glDisplay::initGL()
mContextGL = glXCreateContext(mDisplayX, mVisualX, 0, True);
if( !mContextGL )
return false;
GL(glXMakeCurrent(mDisplayX, mWindowX, mContextGL));
return true;
// MakeCurrent
void glDisplay::BeginRender()
GL(glClearColor(mBgColor[0], mBgColor[1], mBgColor[2], mBgColor[3]));
GL(glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT|GL_STENCIL_BUFFER_BIT));
GL(glViewport(0, 0, mWidth, mHeight));
GL(glMatrixMode(GL_PROJECTION));
GL(glLoadIdentity());
GL(glOrtho(0.0f, mWidth, mHeight, 0.0f, 0.0f, 1.0f));
// timeDiff
static timespec timeDiff( const timespec& start, const timespec& end)
timespec temp;
if ((end.tv_nsec-start.tv_nsec)<0) {
temp.tv_sec = end.tv_sec-start.tv_sec-1;
temp.tv_nsec = 1000000000+end.tv_nsec-start.tv_nsec;
} else {
temp.tv_sec = end.tv_sec-start.tv_sec;
temp.tv_nsec = end.tv_nsec-start.tv_nsec;
return temp;
// Refresh
void glDisplay::EndRender()
glXSwapBuffers(mDisplayX, mWindowX);
// measure framerate
timespec currTime;
clock_gettime(CLOCK_REALTIME, &currTime);
const timespec diffTime = timeDiff(mLastTime, currTime);
const float ns = 1000000000 * diffTime.tv_sec + diffTime.tv_nsec;
mAvgTime = mAvgTime * 0.8f + ns * 0.2f;
mLastTime = currTime;
#define MOUSE_MOVE 0
#define MOUSE_BUTTON 1
#define MOUSE_WHEEL 2
#define MOUSE_DOUBLE 3
#define KEY_STATE 4
#define KEY_CHAR 5
// OnEvent
void glDisplay::onEvent( uint msg, int a, int b )
switch(msg)
case MOUSE_MOVE:
//mMousePos.Set(a,b);
break;
case MOUSE_BUTTON:
/*if( mMouseButton[a] != (bool)b )
mMouseButton[a] = b;
if( b )
mMouseDownEvent = true;
// ignore right-mouse up events
if( !(a == 1 && !b) )
mMouseEvent = true;
break;
case MOUSE_DOUBLE:
/*mMouseDblClick = b;
if( b )
mMouseEvent = true;
break;
case MOUSE_WHEEL:
//mMouseWheel = a;
break;
case KEY_STATE:
//mKeys[a] = b;
break;
case KEY_CHAR:
//mKeyText = a;
break;
//if( msg == MOUSE_MOVE || msg == MOUSE_BUTTON || msg == MOUSE_DOUBLE || msg == MOUSE_WHEEL )
// mMouseEventLast = time();
// UserEvents()
void glDisplay::UserEvents()
// reset input states
/*mMouseEvent = false;
mMouseDownEvent = false;
mMouseDblClick = false;
mMouseWheel = 0;
mKeyText = 0;*/
XEvent evt;
while( XEventsQueued(mDisplayX, QueuedAlready) > 0 )
XNextEvent(mDisplayX, &evt);
switch( evt.type )
case KeyPress: onEvent(KEY_STATE, evt.xkey.keycode, 1); break;
case KeyRelease: onEvent(KEY_STATE, evt.xkey.keycode, 0); break;
case ButtonPress: onEvent(MOUSE_BUTTON, evt.xbutton.button, 1); break;
case ButtonRelease: onEvent(MOUSE_BUTTON, evt.xbutton.button, 0); break;
case MotionNotify:
XWindowAttributes attr;
XGetWindowAttributes(mDisplayX, evt.xmotion.root, &attr);
onEvent(MOUSE_MOVE, evt.xmotion.x_root + attr.x, evt.xmotion.y_root + attr.y);
break;
