I use CSI IMX219 camera
I want to use “GST_ARGUS: 3264 x 1848 FR = 28.000001 fps” mode, because the FOV is larger.
I use C++ opencv, if i use
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)3264, height=(int)1848, format=(string)NV12, framerate=(fraction)28/1 ! nvvidconv flip-method=0 ! video/x-raw, width=(int)3264, height=(int)1848, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink drop=1
Get image and cv::resize to (480, 270)
cv::imshow , FPS: 5~8
if use
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)3264, height=(int)1848, format=(string)NV12, framerate=(fraction)28/1 ! nvvidconv flip-method=0 ! video/x-raw, width=(int)480, height=(int)270, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink drop=1
cv::imshow , FPS: 28
I want to show image(480, 270) with 28 FPS, but save image(3264, 1848), (cv::imwrite)
Is it possible to switch the resolution without turning off the camera?
(Because in “GST_ARGUS: 3264 x 1848 FR = 28.000001 fps” mode , an error occurs when turning off the camera( cam.release() ),
Error message: Segmentation fault (core dumped), and the camera cannot be turned on)
