Changes in default json format created by generate_event_message_minimal
NVIDIA-SMI 525.105.17 Driver Version: 525.105.17 CUDA Version: 12.0
deepstream-6.2
“version” : “4.0”,
“id” : “2197”,
“@timestamp” : “2023-06-08T08:29:24.927Z”,
“sensorId” : “cam0”,
“objects” : [
“0|1232.87|153.384|1384.16|364.948|jet_bridge_disconnected”,
“2|844.068|172.347|1094.17|535.746|airplane_front”
in above format , i want to add specifically description variable by fetching from dstest5_msgconv_sample_config.txt ,
for that what changes needs to be done in generate_event_message_minimal function of eventmsg_payload.cpp
output should looks like this
“version” : “4.0”,
“id” : “2197”,
“Description”:‘Aisle Camera’
‘location’:45.293701447;-75.8303914499;48.1557479338
“objects” : [
nvmsgconv plugin and low level lib are opensource, you can modify nvmsgconv.cpp in deepstream sdk, after modifying, you need to rebuild the code and replace the old lib.
