Xavier NX
• DeepStream Version
6.0
4.6
• TensorRT Version
8.0.1
How do I change the json payload output for Gst-nvmsgconv?
Right now the default PAYLOAD_DEEPSTREAM_MINIMAL output is in the format of
"version": "4.0",
"id": "frame-id",
"@timestamp": "2018-04-11T04:59:59.828Z",
"sensorId": "sensor-id",
"objects": [
"957|1834|150|1918|215|Vehicle",
but I would like it to output something like this instead
"version": "4.0",
"id": "frame-id",
"objects": [
left: "1834"
top: "150"
width: "1918"
height: "215"
label: "Vehicle"
I narrowed down to the file deepstream/sources/libs/nvmsgconv/deepstream-schema/dsmeta_payload.cpp and the following function
gchar* generate_dsmeta_message_minimal (void *privData, void *frameMeta)
JsonNode *rootNode;
JsonObject *jobject;
JsonArray *jArray;
stringstream ss;
gchar *message = NULL;
jArray = json_array_new ();
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) frameMeta;
for (NvDsObjectMetaList *obj_l = frame_meta->obj_meta_list; obj_l; obj_l = obj_l->next) {
NvDsObjectMeta *obj_meta = (NvDsObjectMeta *) obj_l->data;
if (obj_meta == NULL) {
// Ignore Null object.
continue;
// bbox sub object
float scaleW = (float) frame_meta->source_frame_width /
(frame_meta->pipeline_width == 0) ? 1:frame_meta->pipeline_width;
float scaleH = (float) frame_meta->source_frame_height /
(frame_meta->pipeline_height == 0) ? 1:frame_meta->pipeline_height;
float left = obj_meta->rect_params.left * scaleW;
float top = obj_meta->rect_params.top * scaleH;
float width = obj_meta->rect_params.width * scaleW;
float height = obj_meta->rect_params.height * scaleH;
ss.str("");
ss.clear();
ss << "|" << left << "|" << top //the part that I've changed (removed object_id)
<< "|" << left + width << "|" << top + height
<< "|" << obj_meta->obj_label;
if(g_list_length(obj_meta->classifier_meta_list) > 0) {
ss << "|#";
//Add classifiers for the object, if any
for(NvDsClassifierMetaList *cl = obj_meta->classifier_meta_list; cl ; cl=cl->next) {
NvDsClassifierMeta *cl_meta = (NvDsClassifierMeta*) cl->data;
for(NvDsLabelInfoList *ll = cl_meta->label_info_list; ll ; ll=ll->next) {
NvDsLabelInfo *ll_meta = (NvDsLabelInfo*) ll->data;
ss<< "|" << ll_meta->result_label;
ss << "|" << obj_meta->confidence;
json_array_add_string_element (jArray, ss.str().c_str());
//generate timestamp
char ts[MAX_TIME_STAMP_LEN + 1];
generate_ts_rfc3339 (ts, MAX_TIME_STAMP_LEN);
//fetch sensor id
string sensorId="0";
NvDsPayloadPriv *privObj = (NvDsPayloadPriv *) privData;
auto idMap = privObj->sensorObj.find (frame_meta->source_id);
if (idMap != privObj->sensorObj.end()) {
NvDsSensorObject &obj = privObj->sensorObj[frame_meta->source_id];
sensorId = obj.id;
jobject = json_object_new ();
json_object_set_string_member (jobject, "version", "4.0");
json_object_set_int_member (jobject, "id", frame_meta->frame_num);
json_object_set_string_member (jobject, "@timestamp", ts);
json_object_set_string_member (jobject, "sensorId", sensorId.c_str());
json_object_set_array_member (jobject, "objects", jArray);
JsonArray *custMsgjArray = json_array_new ();
//Search for any custom message blob within frame usermeta list
for (NvDsUserMetaList *l = frame_meta->frame_user_meta_list; l; l = l->next) {
NvDsUserMeta *frame_usermeta = (NvDsUserMeta *) l->data;
if(frame_usermeta && frame_usermeta->base_meta.meta_type == NVDS_CUSTOM_MSG_BLOB) {
NvDsCustomMsgInfo *custom_blob = (NvDsCustomMsgInfo *) frame_usermeta->user_meta_data;
string msg = string((const char *) custom_blob->message, custom_blob->size);
json_array_add_string_element (custMsgjArray, msg.c_str());
if(json_array_get_length(custMsgjArray) > 0)
json_object_set_array_member (jobject, "customMessage", custMsgjArray);
else
json_array_unref(custMsgjArray);
rootNode = json_node_new (JSON_NODE_OBJECT);
json_node_set_object (rootNode, jobject);
message = json_to_string (rootNode, TRUE);
json_node_free (rootNode);
json_object_unref (jobject);
return message;
This is the output I get even after changing parts of the code above,
However, when I make changes to the segment of the code above no changes that I made will be reflected when I run the app. I did rebuild the library with “make” and “make install”. I’m running deepStream-test5-app through the official deepstream-l4t:6.0-iot docker image. Tried building my own docker image but the issue is still there. Am I just editing the wrong part of the code? Been stuck on this for awhile please assist me, thank you.
