I’ve been looking to change the resolution of a camera output egl stream in runtime. I’m using Icameraprovider class from argus samples for camera initialization and Iegloutputstreamsettings class to get the stream attributes which is also taken from the argus samples. Now I’ve declared the value as static and tried to change the resolution value during runtime. But the changed value is not taken during runtime. I cant find where im wrong. Is it because I’m using the consumerthread class which is again from the argus samples which has threadinitialize, threadexecute and threadshutdown processes that has while() ? or is it anything I’ve not known. Do guide me to solve this problem.
Thank you
Roopkumar
