I have finally get into the installing process, however it stuck at “Downloading Dependencies…”
I am at the same spot you are, I came here hoping to find out how long this normally takes. It’s not stuck, I started this session when I launched the installation. As you can see 5gb and almost 3 hours later the progress bar has barely moved at all.
Hi, wanted to quickly check if the issues resolved for the either of you. I have been facing the same problem.
I have pretty fast internet. I felt stuck on “Downloading Dependencies…” after about 10 minutes, but while I was looking up the issue and reading this post, progress went from ~5% to complete. So just hang in in there, check task manager for network activity. It’s probably working.
Same thing happened to me. When it did jump through my CPU usage shot to 100% and was un usable for about a min. My CPU is the Ryzen 7 7800X3D.
I have a gigabyte windforce OC 12 gb gddr6x geforce RTX 4070 desktop card, msi motherboard, amd ryzen 7 5800X 3.8GHZ cpu, 64 gb ram, 2 ssd drives and setup keeps saying nvidia installer failed constantly no matter what I do and I have fiber optic internet too and I contacted NVIDIA about this and they are trying to find solution for me on this as this app is not installing at all on my gaming desktop Pc. I have version 0.2.1 also and am using version 566.36 of latest nvidia graphics driver too. I need help.
I have had the same issue where it was stuck on dependencies but then I had restarted the installation after a few restarts and started working beyond that point
Pleased you were able to resolve @Waleed-2025. For future ChatRTX queries or issues, we recommend you follow the process laid out in this topic: SUPPORT for ChatRTX Users
