You try to use a model that was created with version 2.5.1, however, your version is 2.2.2. This might cause unexpected behavior or errors. In that case, try to update to the latest version.
How do I do this? Which file do I need to replace? Do I have to install something?
I have the same issue.
It was fine previously but when I started it up today I had this too.
Not sure what changed, I can’t see anything different.
For context, this message comes up on start-up. I’m using model Mistral 7B int4.
Following this I get the error:
TypeError: Pooling.init() got an unexpected keyword argument ‘pooling_mode_weightedmean_tokens’
This originates from the file:
C:\Users*\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\sentence_transformers\models\Pooling.py:120 in load
