你好,
我们的jetson agx orin /jetson orin nx (jetpack6.2)最近打不开chromium, 之前是正常的,从命令启动,刚开始报出无权限,加上sudo 后还是报错,打不开浏览器。尝试过烧完系统后做初始化设置时的安装,也做过命令安装都是不行。请问该怎么解决?谢谢
user@user-desktop:~/Desktop$ chromium
2025/07/16 10:07:36.578143 cmd_run.go:1344: WARNING: cannot create user data directory: failed to verify SELinux context of /home/nexgemo/snap: exec: “matchpathcon”: executable file not found in $PATH
cannot set capabilities: Operation not permitted
user@user-desktop:~/Desktop$ sudo chromium
2025/07/16 10:07:42.679508 cmd_run.go:1344: WARNING: cannot create user data directory: failed to verify SELinux context of /root/snap: exec: “matchpathcon”: executable file not found in $PATH
update.go:85: cannot change mount namespace according to change mount (/var/lib/snapd/hostfs/usr/local/share/doc /usr/local/share/doc none bind,ro 0 0): cannot write to “/var/lib/snapd/hostfs/usr/local/share/doc” because it would affect the host in “/var/lib/snapd”
update.go:85: cannot change mount namespace according to change mount (/var/lib/snapd/hostfs/usr/share/cups/doc-root /usr/share/cups/doc-root none bind,ro 0 0): cannot write to “/var/lib/snapd/hostfs/usr/share/cups/doc-root” because it would affect the host in “/var/lib/snapd”
update.go:85: cannot change mount namespace according to change mount (/var/lib/snapd/hostfs/usr/share/gimp/2.0/help /usr/share/gimp/2.0/help none bind,ro 0 0): cannot write to “/var/lib/snapd/hostfs/usr/share/gimp/2.0/help” because it would affect the host in “/var/lib/snapd”
update.go:85: cannot change mount namespace according to change mount (/var/lib/snapd/hostfs/usr/share/libreoffice/help /usr/share/libreoffice/help none bind,ro 0 0): cannot write to “/var/lib/snapd/hostfs/usr/share/libreoffice/help” because it would affect the host in “/var/lib/snapd”
update.go:85: cannot change mount namespace according to change mount (/var/lib/snapd/hostfs/usr/share/sphinx_rtd_theme /usr/share/sphinx_rtd_theme none bind,ro 0 0): cannot write to “/var/lib/snapd/hostfs/usr/share/sphinx_rtd_theme” because it would affect the host in “/var/lib/snapd”
update.go:85: cannot change mount namespace according to change mount (/var/lib/snapd/hostfs/usr/share/xubuntu-docs /usr/share/xubuntu-docs none bind,ro 0 0): cannot write to “/var/lib/snapd/hostfs/usr/share/xubuntu-docs” because it would affect the host in “/var/lib/snapd”
[4911:4911:0716/100744.020997:ERROR:content/browser/zygote_host/zygote_host_impl_linux.cc:105] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
