Unable to install Google Chrome on the Orin Nano, attempted installing with sudo dpkg -i google-chrome-stable_current_amd64.deb and sudo apt install google-chrome-stable --fix-broken
Please check if installing chromium works. After clean re-flash, it asks if you would like to install chromium in first booting. Ideally you should be able to install chromium successfully.
For installing Chrome, would see if other users can share experience.
google-chrome-stable_current_amd64.deb on the Jetson Orin Nano?
Does it support aarch64 eventually?
amd64 means x86_64 not ARM64.
What do you see from:
apt search chromium-browser
Is this still an issue to support? Any result can be shared? Thanks
Chrome is not compatible with Jetson ARM64, and as was stated above chromium is not sufficient to accomplish the task.
