• Hardware Platform (Jetson / GPU) T4
• DeepStream Version deepstream-6.1-base
• NVIDIA GPU Driver Version (valid for GPU only) 515
• Issue Type( questions, new requirements, bugs) Question
I have a couple of questions regarding the nvmsgconv plugin.
What do the sensorX, placeX, analyticsX parameters in the config file stand for? How do these map to streams?
I get how one sensor might map to a stream, but what does the place property stand for?
See deepstream_python_apps/dstest4_msgconv_config.txt at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub. -
How do I get the ROI information? I’m using the
msg2p-newapi = 1property to generate the payloads automatically, but this output doesn’t seem to contain any information about the ROI from the analytics module. However, this is displayed in the display output just fine (with an ROI next to the label).
"messageid" : "75463717-0ce8-4725-8ffc-3c2ef3de2b35",
"mdsversion" : "1.0",
"@timestamp" : "2022-11-17T15:33:10.774Z",
"place" : {
"id" : "1",
"name" : "",
"type" : "eindhoven",
"location" : {
"lat" : 6.9440426243327043e-310,
"lon" : 6.9527302074313974e-310,
"alt" : 6.9527302074329784e-310
"place-sub-field" : {
"id" : "",
"name" : "",
"level" : "",
"coordinate" : {
"x" : 6.9527302074345594e-310,
"y" : 4.0921449562245752e-316,
"z" : 6.9527302074302117e-310
"sensor" : {
"id" : "ip_camera",
"type" : "Camera",
"description" : "\"Camera 1\"",
"location" : {
"lat" : 0.0,
"lon" : 1.018557979673212e-312,
"alt" : 0.0
"coordinate" : {
"x" : 0.0,
"y" : 0.0,
"z" : 2.5251749918613155e-312
"analyticsModule" : {
"id" : "AONI",
"description" : "\"Filtering by Areas of No Interest\"",
"source" : "CVAT",
"version" : "1.0"
"object" : {
"id" : "5",
"speed" : 0.0,
"direction" : 0.0,
"orientation" : 0.0,
"person" : {
"confidence" : 0.87863659858703613
"bbox" : {
"topleftx" : 0,
"toplefty" : 0,
"bottomrightx" : 0,
"bottomrighty" : 0
"location" : {
"coordinate" : {
"event" : {
"id" : "1edca851-c9ba-4d2f-8932-7243ccca188d",
"type" : ""
"videoPath" : ""
Furthermore, I only want to publish objects that are within the ROI. However, I’m getting payloads for all objects. How can I filter out objects outside the ROI?
