Issue using nvdsanalytics plugin in deepstream 7.0 for ROI filtering, ROI displayed and working but all boxes are displayed/emmited
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 7.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) : 12.0
• Issue Type( questions, new requirements, bugs): bugs
How to reproduce the issue:
I have modified deepstream-test5 app from the samples, the pipeline performs the following things, its reads from a video file, runs the object detection and then object tracking, then one sink is defined to communicate with Kafka and one sink is define to save the annotated video, I am pasting the relevant configs also.
The issue is that when using nvdsanalytics plugin, I am creating an ROI and my objective is to filter out the object present in the ROI, but the output is showing all the boxes even though the ROI region is also printing and working(the color of the boxes are changing indicating that the roi is working), I am attaching the snap for this also.
The issue is that the detection and tracking outside roi is also dispalyed, Also in the message sent through kafka broker, I am not getting the ROI info. I wnat the ROI info in the messege also and the detetction and tracker I want inside ROI only.
message:
{‘version’: ‘4.0’, ‘id’: ‘751’, ‘@timestamp’: ‘2024-07-15T11:17:09.059Z’, ‘sensorId’: ‘reception_cam’, ‘objects’: [‘40|1200.14|466.08|1511.59|1077.61|person’, ‘19|697.351|234.036|856.034|648.037|person’, ‘3|1516.69|172.342|1634.59|520.933|person’, ‘18|1282.44|150.353|1402.37|545.614|person’, ‘44|1634.58|161.908|1708.5|269.14|person’, ‘34|982.16|111.978|1087.88|418.338|person’]}
main_config.yml
# SPDX-FileCopyrightText: Copyright (c) 2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: LicenseRef-NvidiaProprietary
# NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
# property and proprietary rights in and to this material, related
# documentation and any modifications thereto. Any use, reproduction,
# disclosure or distribution of this material and related documentation
# without an express license agreement from NVIDIA CORPORATION or
# its affiliates is strictly prohibited.
application:
  enable-perf-measurement: 1
  perf-measurement-interval-sec: 5
  #gie-kitti-output-dir: streamscl
source:
 csv-file-path: sources_5.csv
sink0:
  enable: 1
  #Type - 1=FakeSink 2=EglSink 3=File
  type: 1
  sync: 1
  source-id: 0
  gpu-id: 0
  nvbuf-memory-type: 0
sink1:
  enable: 1
  #Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvdrmvideosink 6=MsgConvBroker
  type: 6
  # msg2p-newapi: 1
  # frame-interval: 60
  msg-conv-config: dstest5_msgconv_sample_config.yml
  msg-conv-msg2p-new-api: 1
  #(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
  #(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
  #(256): PAYLOAD_RESERVED - Reserved type
  #(257): PAYLOAD_CUSTOM   - Custom schema payload
  msg-conv-payload-type: 1
  msg-conv-frame-interval: 1
  msg-broker-proto-lib: /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_kafka_proto.so
  #Provide your msg-broker-conn-str here
  msg-broker-conn-str: localhost;9092;quickstart-events
  # topic: <topic>
  #Optional:
  #msg-broker-config: ../../deepstream-test4/cfg_kafka.txt
sink2:
  enable: 1
  type: 3
  #1=mp4 2=mkv
  container: 1
  #1=h264 2=h265 3=mpeg4
  ## only SW mpeg4 is supported right now.
  codec: 1
  sync: 1
  bitrate: 2000000
  output-file:  /out_videos/nvds_analytics_roi_final_output9.mp4
  source-id: 0
osd:
  enable: 1
  gpu-id: 0
  border-width: 1
  text-size: 15
  text-color: 1;1;1;1
  text-bg-color: 0.3;0.3;0.3;1
  font: Arial
  show-clock: 0
  clock-x-offset: 800
  clock-y-offset: 820
  clock-text-size: 12
  clock-color: 1;0;0;0
streammux:
  gpu-id: 0
  ##Boolean property to inform muxer that sources are live
  live-source: 0
  batch-size: 1
  ##time out in usec, to wait after the first buffer is available
  ##to push the batch even if the complete batch is not formed
  batched-push-timeout: 40000
  ## Set muxer output width and height
  width: 1920
  height: 1080
  ##Enable to maintain aspect ratio wrt source, and allow black borders, works
  ##along with width, height properties
  enable-padding: 0
  ## If set to TRUE, system timestamp will be attached as ntp timestamp
  ## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
  # attach-sys-ts-as-ntp: 1
primary-gie:
  enable: 1
  gpu-id: 0
  batch-size: 4
  ## 0=FP32, 1=INT8, 2=FP16 mode
  bbox-border-color0: 1;0;0;1
  bbox-border-color1: 0;1;1;1
  bbox-border-color2: 0;1;1;1
  bbox-border-color3: 0;1;0;1
  interval: 0
  config-file: pgie_peoplenet_tao_config.txt
  #infer-raw-output-dir: ../../../../../samples/primary_detector_raw_output/
tracker:
  enable: 1
  # For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
  tracker-width: 960
  tracker-height: 544
  ll-lib-file: /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_nvmultiobjecttracker.so
  # ll-config-file required to set different tracker types
  # ll-config-file: ../../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
  # ll-config-file: ../../../../../samples/configs/deepstream-app/config_tracker_NvSORT.yml
  # ll-config-file: ../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
  # ll-config-file: ../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
  ll-config-file: ../../../../../samples/configs/deepstream-app/config_tracker_NvDeepSORT.yml
  gpu-id: 0
  display-tracking-id: 1
nvds-analytics:
  enable: 1
  config-file: nvdsanalytics_config.txt
tests:
  file-loop: 0
# SPDX-FileCopyrightText: Copyright (c) 2020 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# The values in the config file are overridden by values set through GObject
# properties.
[property]
enable=1
#Width height used for configuration to which below configs are configured
config-width=1920
config-height=1080
#osd-mode 0: Dont display any lines, rois and text
#         1: Display only lines, rois and static text i.e. labels
#         2: Display all info from 1 plus information about counts
osd-mode=2
#Set OSD font size that has to be displayed
display-font-size=12
## Per stream configuration
[roi-filtering-stream-0]
#enable or disable following feature
enable=1
#ROI to filter select objects, and remove from meta data
roi-RF=0;0;1000;0;1000;1000;0;1000
#remove objects in the ROI
inverse-roi=0
class-id=-1
# Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=peoplenet/resnet34_peoplenet_pruned_int8.etlt
labelfile-path=peoplenet/labels.txt
# model-engine-file=peoplenet/resnet34_peoplenet_pruned_int8.etlt_b1_gpu0_int8.engine
int8-calib-file=peoplenet/resnet34_peoplenet_pruned_int8.txt
#input-dims=3;544;960;0
infer-dims=3;544;960
uff-input-blob-name=input_1
batch-size=1
process-mode=1
model-color-format=0
network-mode=1
num-detected-classes=3
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[class-attrs-all]
pre-cluster-threshold=0.4
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
[class-attrs-1]
pre-cluster-threshold=1.4
eps=0.7
minBoxes=1
[class-attrs-2]
eps=0.7
minBoxes=1
All bboxes are added after pgie detection inference. if you don’t want to show the bboxes outside the ROI, Here are two solutions.
  1. you can add a nvdspreprocess plugin before pgie. nvdspreprocess can support ROI functionality. pgie will only give the bboxes in the nvdspreprocess ROI. please refer to sample deepstream-preprocess-test. deepstream-app also can support nvdspreprocess configurations. please refer to source30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.txt.
  2. nvdsanlytics plugin is opensource. you can modify it to customize. In this plugin, ROI coordinates are known, you can remove the bboxes outside the ROI by referring to this method.
As per your suggestion I tried the nvdspreprocess before pgie, now I am getting correct output, Now the issue is, I defined two roi’s for my usecase, I am getting the correct detection output and tracker output. But I am getting single message in the kafka per frame, how to segregate the information in the kafka message ROI wise respectively.
Sample message:
{‘version’: ‘4.0’, ‘id’: ‘362’, ‘@timestamp’: ‘2024-07-16T10:21:42.521Z’, ‘sensorId’: ‘reception_cam’, ‘objects’: [‘2|480.851|227.812|607.11|592.122|person’, ‘1|306.839|236.029|449.517|544.659|person’]}
There is no ROI info in the message that which box belongs to which ROI.
Sample Annotated frame:
Below is the ROI config file:
# SPDX-FileCopyrightText: Copyright (c) 2021-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# properties.
[property]
enable=1
    # list of component gie-id for which tensor is prepared
target-unique-ids=1
    # 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=0
    # 0=process on objects 1=process on frames
process-on-frame=1
    #uniquely identify the metadata generated by this element
unique-id=5
    # gpu-id to be used
gpu-id=0
    # if enabled maintain the aspect ratio while scaling
maintain-aspect-ratio=1
    # if enabled pad symmetrically with maintain-aspect-ratio enabled
symmetric-padding=1
    # processig width/height at which image scaled
processing-width=960
processing-height=544
    # max buffer in scaling buffer pool
scaling-buf-pool-size=6
    # max buffer in tensor buffer pool
tensor-buf-pool-size=6
    # tensor shape based on network-input-order
network-input-shape= 8;3;544;960
    # 0=RGB, 1=BGR, 2=GRAY
network-color-format=0
    # 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=0
    # tensor name same as input layer name
tensor-name=input_1
    # 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE 3=NVBUF_MEM_CUDA_UNIFIED
scaling-pool-memory-type=0
    # 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU 2=NvBufSurfTransformCompute_VIC
scaling-pool-compute-hw=0
    # Scaling Interpolation method
    # 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
    # 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
    # 6=NvBufSurfTransformInter_Default
scaling-filter=0
    # custom library .so path having custom functionality
custom-lib-path=/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so
    # custom tensor preparation function name having predefined input/outputs
    # check the default custom library nvdspreprocess_lib for more info
custom-tensor-preparation-function=CustomTensorPreparation
[user-configs]
   # Below parameters get used when using default custom library nvdspreprocess_lib
   # network scaling factor
pixel-normalization-factor=0.003921568
   # mean file path in ppm format
#mean-file=
   # array of offsets for each channel
#offsets=
[group-0]
src-ids=0
custom-input-transformation-function=CustomAsyncTransformation
process-on-roi=1
draw-roi=1
roi-params-src-0=0;0;600;1000;1000;0;500;1000
Main config file is same as earlier.
At default, deepstream will not send ROI to broker. but nvinfer plugin and nvconv low-level are opensource. you can modify the code to customize. here is a sample.
  1. In attach_metadata_detector of opt\nvidia\deepstream\deepstream\sources\gst-plugins\gst-nvinfer\gstnvinfer_meta_utils.cpp, you can add ROI information to object meta. for example, you can write ROI to misc_obj_info of NvDsObjectMeta. especially you need to rebuild code and copy so to /opt/nvidia/deepstream/deepstream/lib/gst-plugins/.
  2. in generate_dsmeta_message_minimal of \opt\nvidia\deepstream\deepstream\sources\libs\nvmsgconv\deepstream_schema\dsmeta_payload.cpp, you can add ROI of object meta to stringstream ss. especially you need to rebuild code and copy so to /opt/nvidia/deepstream/deepstream/lib.
