• Hardware Platform (GPU) • DeepStream Version 8.0.0 • TensorRT Version 10.9.0 • NVIDIA GPU Driver Version 580.95.05 • Issue Type: question • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Running a source stream with nvinfer and nvtracker prior to the nvdsanalytics element with the config attached below • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi there,
I am trying to configure multiple ignore regions with nvdsanalytics on a single stream with “inverse-roi=1”. I want to have tracks be filtered out if they occur in any one of the defined rois, however I am noticing a weird behavior where in order to be filtered out, a track must occur in all regions
What I have noticed is that:
When I only have one roi, the tracks are excluded correctly (only tracks inside of the region are excluded)
When I have multiple rois (and they do not overlap) and “inverse-roi=0” only tracks inside of the two separate regions are included
When I have multiple rois and “inverse-roi=1” only tracks that occur in all defined roi regions are excluded i.e. if there are no rois that overlap, not tracks will be filtered
I’ve attached my config below and an image of this occurring:
Please find the explanation of ‘inverse-roi’ in the doc. In the screenshot the count of test-2 is 2 because two boats are outside of roi-test-2. the count of test-1 is 3 because three boats are outside of test1. could you elaborate on the issue in the screenshot? Thanks!
do you mean there is no issue on the screenshot display and the issue is in user_meta_data->roiStatus? could you use share the related roiStatus information of the screenshot? Thanks!
Admittedly I am still very new to deepstream and it’s intricacies.
My goal is to have a list of objects that do not exist in any of the set roi regions essentially fitting ignore regions of the image. My initial thought are to set inverse-roi to false and on the appsink end filter out for bboxes that have len(roiStatus) > 0.
Would there be another simpler solution I am missing?
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
