I am working on tiny yolov3 model on Deepstream with custom dataset.
When I try objectDetector_Yolo project, I change the network model with yolov3 network trained with classes.
I changed the code as follow:
config_infer_primary_yoloV3._tiny.txt
num-detected-classes=80 =>> num-detected-classes=1
label.txt
person
nvdsparsebbox_Yolo.cpp
static const int NUM_CLASSES_YOLO = 80; =>> static const int NUM_CLASSES_YOLO = 1;
However, when running deepstream-app -c deepstream_app_config_yoloV3_tiny.txt , I can load the model and build the TensorRT Engine, but still have an error of class mismatch. Can you help me?
vamsisiddharthasiddhu2041@linux:/opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo$ deepstream-app -c deepstream_app_config_yoloV3_tiny.txt
Unknown or legacy key specified ‘is-classifier’ for group [property]
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:00:05.438217137 32204 0x1f530600 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/yolov3/yolov3-tiny-608_fp16.trt
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT 000_net 3x608x608
1 OUTPUT kFLOAT 016_convolutional 18x19x19
2 OUTPUT kFLOAT 023_convolutional 18x38x38
0:00:05.438408651 32204 0x1f530600 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/yolov3/yolov3-tiny-608_fp16.trt
0:00:05.461123141 32204 0x1f530600 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/config_infer_primary_yoloV3_tiny.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:167>: Pipeline running
WARNING: Num classes mismatch. Configured:1, detected by network: 80
I am enclosing Screenshot of the error. Please help me to sort out this error. Thanks in advance.
