Classification model with the gpu setup and docker
Hi — I wanted to share the investigation results and confirm the approach we’re taking for the SGIE classifiers in DeepStream.
Summary
We identified that the ResNet18 classifiers (color/lid/load) were trained using ImageNet normalization:
(pixel/255 − mean) / std
but in DeepStream only the scaling step was applied:
pixel/255
This caused an input distribution mismatch and resulted in the classifiers always predicting class 0.
Training Setup
  • Dataset format: ImageFolder
  • Classes
    • Color: 3
    • Lid: 2
    • Load: 4
  • Model: ResNet18 pretrained (ImageNet1K)
  • Preprocessing:
    • Resize → 224×224
    • ToTensor
    • Normalize
      mean = [0.485, 0.456, 0.406]
      std = [0.229, 0.224, 0.225]
  • Loss: CrossEntropy
  • Optimizer: Adam (lr=0.001)
Export + TensorRT
We exported ONNX models (opset 18) and generated corrected versions embedding normalization layers:
*_with_std.onnx
Engine build:
trtexec --onnx=.onnx
–saveEngine=.engine
–fp32
DeepStream Pipeline
  • PGIE
    • YOLOv7 detector
    • gie-unique-id = 1
  • SGIE
    • Color → id=2
    • Lid → id=3
    • Load → id=4
Original preprocessing:
net-scale-factor=1/255
model-color-format=RGB
infer-dims=3;224;224
This lacked mean/std normalization.
Config Changes Applied
Updated SGIE configs to use corrected ONNX:
ds_sgie1_c2g_config.txt
→ resnet18_color_v2_fixed_with_std.onnx
ds_sgie2_c2g_config.txt
→ resnet18_lid_v4_fixed_with_std.onnx
ds_sgie3_c2g_config.txt
→ resnet18_load_fixed_with_std.onnx
No other pipeline changes made.
Expected Result
  • Previously → all predictions class 0
  • Now → varied predictions across classes
  • Metadata flow unchanged:
    obj_meta → classifier_meta_list → label extraction
Questions
Could you please confirm:
1️⃣ Is embedding normalization inside the ONNX model the recommended approach for our deployment setup, or should we instead replicate mean/std normalization via DeepStream preprocessing/config?
2️⃣ Are there any additional DeepStream parameters you would like us to validate before final deployment?
Sorry for the long delay because a holiday.
Since your model has different mean/std values ​​for different channels, you need to insert nvdspreprocess into the pipeline.
We provide a GPU-accelerated preprocess custom-impl library. please refer to this repository.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
