• Hardware Platform (Jetson / GPU) Orin NX
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 36.4
• TensorRT Version 10.3.0.30
I am trying to integrate a custom audio classification model into DeepStream, but I am experiencing discrepancies in inference results compared to those obtained in the Colab environment.
Model details:
Model: ResNet50 trained on log-Mel spectrograms (128 mel, n_fft=2048, hop=512, top_db=80)
Format: ONNX (FP32), input shape [1,1,635,128]. (same as SONYC in the samples)
Preprocessing in Colab: normalization with mean and std calculated on the dataset
DeepStream configuration:
Plugin: nvinferaudio
audio-framesize=220050 (5s)
audio-hopsize=44100 (1s)
audio-transform=melsdb
net-scale-factor=1.0
offsets=0.0
Despite aligning the preprocessing parameters between Colab and DeepStream, the predictions obtained in DeepStream are inconsistent with those in Colab.
How can I correctly export my audio classification model for use in DeepStream, ensuring that preprocessing and normalization are handled consistently between the training and inference environments?
Thank you in advance for your assistance.
