Classifier sgie model skipped for some frames when used with tracker
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0
• TensorRT Version 7
• NVIDIA GPU Driver Version (valid for GPU only) 440
• Issue Type( questions, new requirements, bugs) question
In deepstream-app, I’m using analytics_done_buf_prob function to access tenor metata. check this question: (How to get classifier tensor metadata in deepstream-app?)
The model structure is:
pgie: yolov3 (using implementation provided by nvidia)
sgie0: works on id 2 (works on car id 2)
sgie1: works on id 0 (works on person id 0)
sgie2: works on id 2 (works on car id 2)
If I use tracker, then the model sgie1 is not run on every frame i.e. if I print the meta->unique_id, then I get the following:
Here,
const guint sgie1_unique_id = 2;
const guint sgie2_unique_id = 3;
const guint sgie3_unique_id = 4;
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 2
As you can see, the sgie2 (unique_id 3) is not printed as frequent as it should. If I disable the tracker, this is the result:
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 2
meta->unique_id: 4
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 4
meta->unique_id: 2
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 3
meta->unique_id: 2
meta->unique_id: 4
Now, the sgie2 model (the model working on person) is executed as expected. Here, I’m using the official video.
Why it’s happening? In fact, it wasn’t happening when I was using deepstream-infer-tensor-meta-test app, I was using sgie_pad_buffer_probe function there to extract tensor metadata.
For dumping tensor data, we have one property set in deepstream-app, output-tensor-meta, set it to 1, and you can refer to sources/gst-plugins/gst-nvinfer/gstnvinfer_meta_utils.cpp::attach_tensor_output_meta how it does.
yes, I already have output-tensor-meta enabled. I think I got the reason why classifier is not running from the documentation
When the plugin is operating as a secondary classifier along with the tracker, it tries to improve performance by avoiding re-inferencing on the same objects in every frame. It does this by caching the classification output in a map with the object’s unique ID as the key. The object is inferred upon only w hen it is first seen in a frame (based on its object ID) or when the size (bounding box area) of the object increases by 20% or more. This optimization is possible only when the tracker is added as an upstream element.
But I’m surprised why wasn’t it happening in deepstream-infer-tensor-meta-test app. There classifier was running for every frame even with tracker.
deepstream-infer-tensor-meta-test app do not have tracker.
Actually, I added the tracker myself, the pipeline was like this:
streammux, pgie, queue, nvtracker, sgie1, queue5,
          sgie2, queue6, sgie3, queue2, tiler, queue3, filter1, nvvidconv, queue4, filter2, nvosd,
          nvvidconv1, filter3, videoconvert, filter4, x264enc, qtmux
I have one last question, what does this line mean? (maybe this has something to do with it)
Or maybe it was because the tracker was running in a different thread.
It means after pgie and before secondary gie. you may try to compare the difference between deepstream-app and deepstream-infer-tensor-meta-test first to narrow down.
