Dear Nvidia experts,
I would like to report a potential problem on the OpenCL Windows driver on many NVIDIA GPU.
Recently, my students and I are trying to tune an OpenCL lib called CLBlast to help the community to speed up the accelerating experience in AI and many more. But somehow, CLBlast tuner report that the device does not support -precision 16.
We know that NVIDIA has upgraded the OpenCL compiler to support cl_kr_fp16 flag as stated in section 2.8 of noted in 535.98-win11-win10-release-notes.pdf and previous releases.
But still, we could not produce the tuning results for FP16.
Copy clblast.dll in the lib directory to bin directory
execute any tuner such as “clbast_tuner_xgemm.exe -precision 16” command in the command line (not powershell).
In addition, the followings are all the test cases in case you would like to test all of them (you can create a .bat file and put the commands inside):
Platform Name NVIDIA CUDA
Number of devices 1
Device Name NVIDIA GeForce RTX 3080 Laptop GPU
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 3.0 CUDA
Device UUID 5c120e9c-9523-d810-c2c3-524b79718c2c
Driver UUID 5c120e9c-9523-d810-c2c3-524b79718c2c
Valid Device LUID No
Device LUID 6d69-637300000000
Device Node Mask 0
Device Numeric Version 0xc00000 (3.0.0)
Driver Version 525.105.17
Device OpenCL C Version OpenCL C 1.2
Device OpenCL C all versions OpenCL C 0x400000 (1.0.0)
OpenCL C 0x401000 (1.1.0)
OpenCL C 0x402000 (1.2.0)
OpenCL C 0xc00000 (3.0.0)
Device OpenCL C features __opencl_c_fp64 0xc00000 (3.0.0)
__opencl_c_images 0xc00000 (3.0.0)
__opencl_c_int64 0xc00000 (3.0.0)
__opencl_c_3d_image_writes 0xc00000 (3.0.0)
Latest conformance test passed v2022-10-05-00
Device Type GPU
Device Topology (NV) PCI-E, 0000:01:00.0
Device PCI bus info (KHR) PCI-E, 0000:01:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 48
Max clock frequency 1365MHz
Compute Capability (NV) 8.6
Device Partition (core)
Max number of sub-devices 1
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 1024x1024x64
Max work group size 1024
Preferred work group size multiple (device) 32
Preferred work group size multiple (kernel) 32
Warp size (NV) 32
Max sub-groups per work group 0
Preferred / native vector sizes
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Support is emulated in software No
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
External memory handle types Opaque FD
External semaphore import types Opaque FD
External semaphore export types Opaque FD
Global memory size 16899571712 (15.74GiB)
Error Correction support No
Max memory allocation 4224892928 (3.935GiB)
Unified memory for Host and Device No
Integrated memory (NV) No
Shared Virtual Memory (SVM) capabilities (core)
Coarse-grained buffer sharing Yes
Fine-grained buffer sharing No
Fine-grained system sharing No
Atomics No
Minimum alignment for any data type 128 bytes
Alignment of base address 4096 bits (512 bytes)
Preferred alignment for atomics
SVM 0 bytes
Global 0 bytes
Local 0 bytes
Atomic memory capabilities relaxed, work-group scope
Atomic fence capabilities relaxed, acquire/release, work-group scope
Max size for global variable 0
Preferred total size of global vars 0
Global Memory cache type Read/Write
Global Memory cache size 1376256 (1.312MiB)
Global Memory cache line size 128 bytes
Image support Yes
Max number of samplers per kernel 32
Max size for 1D images from buffer 268435456 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 0 bytes
Pitch alignment for 2D image buffers 0 pixels
Max 2D image size 32768x32768 pixels
Max 3D image size 16384x16384x16384 pixels
Max number of read image args 256
Max number of write image args 32
Max number of read/write image args 0
Pipe support No
Max number of pipe args 0
Max active pipe reservations 0
Max pipe packet size 0
Local memory type Local
Local memory size 49152 (48KiB)
Registers per block (NV) 65536
Max number of constant args 9
Max constant buffer size 65536 (64KiB)
Generic address space support No
Max size of kernel argument 4352 (4.25KiB)
Queue properties (on host)
Out-of-order execution Yes
Profiling Yes
Device enqueue capabilities (n/a)
Queue properties (on device)
Out-of-order execution No
Profiling No
Preferred size 0
Max size 0
Max queues on device 0
Max events on device 0
Prefer user sync for interop No
Profiling timer resolution 1000ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Non-uniform work-groups No
Work-group collective functions No
Sub-group independent forward progress No
Kernel execution timeout (NV) Yes
Concurrent copy and kernel execution (NV) Yes
Number of async copy engines 2
IL version (n/a)
ILs with version (n/a)
printf() buffer size 1048576 (1024KiB)
Built-in kernels (n/a)
Built-in kernels with version (n/a)
Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info cl_khr_external_semaphore cl_khr_external_memory cl_khr_external_semaphore_opaque_fd cl_khr_external_memory_opaque_fd
Device Extensions with Version cl_khr_global_int32_base_atomics 0x400000 (1.0.0)
cl_khr_global_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_local_int32_base_atomics 0x400000 (1.0.0)
cl_khr_local_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_fp64 0x400000 (1.0.0)
cl_khr_3d_image_writes 0x400000 (1.0.0)
cl_khr_byte_addressable_store 0x400000 (1.0.0)
cl_khr_icd 0x400000 (1.0.0)
cl_khr_gl_sharing 0x400000 (1.0.0)
cl_nv_compiler_options 0x400000 (1.0.0)
cl_nv_device_attribute_query 0x400000 (1.0.0)
cl_nv_pragma_unroll 0x400000 (1.0.0)
cl_nv_copy_opts 0x400000 (1.0.0)
cl_nv_create_buffer 0x400000 (1.0.0)
cl_khr_int64_base_atomics 0x400000 (1.0.0)
cl_khr_int64_extended_atomics 0x400000 (1.0.0)
cl_khr_device_uuid 0x400000 (1.0.0)
cl_khr_pci_bus_info 0x400000 (1.0.0)
cl_khr_external_semaphore 0x9000 (0.9.0)
cl_khr_external_memory 0x9000 (0.9.0)
cl_khr_external_semaphore_opaque_fd 0x9000 (0.9.0)
cl_khr_external_memory_opaque_fd 0x9000 (0.9.0)
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, …) NVIDIA CUDA
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, …) Success [NV]
clCreateContext(NULL, …) [default] Success [NV]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) Invalid device type for platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No platform
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1138 G /usr/lib/xorg/Xorg 4MiB |
(base) lgpt@lgpt-Precision-7560:~$
