[oclDeviceQuery] starting…
oclDeviceQuery Starting…
OpenCL SW Info:
WARNING: NVIDIA OpenCL platform not found - defaulting to first platform!
CL_PLATFORM_NAME: Apple
CL_PLATFORM_VERSION: OpenCL 1.0 (Dec 23 2010 17:30:26)
OpenCL SDK Revision: 7027912
OpenCL Device Info:
3 devices found supporting OpenCL:
Device GeForce GT 120
CL_DEVICE_NAME: GeForce GT 120
CL_DEVICE_VENDOR: NVIDIA
CL_DRIVER_VERSION: CLH 1.0
CL_DEVICE_VERSION: OpenCL 1.0
CL_DEVICE_TYPE: CL_DEVICE_TYPE_GPU
CL_DEVICE_MAX_COMPUTE_UNITS: 4
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
CL_DEVICE_MAX_WORK_ITEM_SIZES: 512 / 512 / 64
CL_DEVICE_MAX_WORK_GROUP_SIZE: 512
CL_DEVICE_MAX_CLOCK_FREQUENCY: 1400 MHz
CL_DEVICE_ADDRESS_BITS: 32
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 128 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 512 MByte
CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
CL_DEVICE_LOCAL_MEM_TYPE: local
CL_DEVICE_LOCAL_MEM_SIZE: 16 KByte
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64 KByte
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
CL_DEVICE_IMAGE_SUPPORT: 1
CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 8
CL_DEVICE_SINGLE_FP_CONFIG: INF-quietNaNs round-to-nearest
CL_DEVICE_IMAGE 2D_MAX_WIDTH 4096
2D_MAX_HEIGHT 4096
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
CL_DEVICE_EXTENSIONS: cl_khr_byte_addressable_store
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_APPLE_gl_sharing
cl_APPLE_SetMemObjectDestructor
cl_APPLE_ContextLoggingFunctions
CL_DEVICE_PREFERRED_VECTOR_WIDTH_ CHAR 1, SHORT 1, INT 1, LONG 1, FLOAT 1, DOUBLE 0
Device Quadro 4000
CL_DEVICE_NAME: Quadro 4000
CL_DEVICE_MAX_COMPUTE_UNITS: 24
CL_DEVICE_MAX_WORK_ITEM_SIZES: 1024 / 1024 / 64
CL_DEVICE_MAX_WORK_GROUP_SIZE: 1024
CL_DEVICE_MAX_CLOCK_FREQUENCY: 950 MHz
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 512 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 2048 MByte
CL_DEVICE_LOCAL_MEM_SIZE: 48 KByte
2D_MAX_HEIGHT 4096
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
cl_APPLE_gl_sharing
Device Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
CL_DEVICE_NAME: Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
CL_DEVICE_VENDOR: Intel
CL_DRIVER_VERSION: 1.0
CL_DEVICE_TYPE: CL_DEVICE_TYPE_CPU
CL_DEVICE_MAX_COMPUTE_UNITS: 8
CL_DEVICE_MAX_WORK_ITEM_SIZES: 1 / 1 / 1
CL_DEVICE_MAX_CLOCK_FREQUENCY: 2659 MHz
CL_DEVICE_ADDRESS_BITS: 64
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 1536 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 6144 MByte
CL_DEVICE_LOCAL_MEM_TYPE: global
CL_DEVICE_SINGLE_FP_CONFIG: denorms INF-quietNaNs round-to-nearest
CL_DEVICE_IMAGE 2D_MAX_WIDTH 8192
2D_MAX_HEIGHT 8192
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
CL_DEVICE_EXTENSIONS: cl_khr_fp64
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_APPLE_gl_sharing
CL_DEVICE_PREFERRED_VECTOR_WIDTH_ CHAR 16, SHORT 8, INT 4, LONG 2, FLOAT 4, DOUBLE 2
2D Image Formats Supported (51)
Channel Order Channel Type
1 CL_RGBA CL_UNORM_INT8
2 CL_ARGB CL_UNORM_INT8
3 CL_BGRA CL_UNORM_INT8
4 CL_RG CL_UNORM_INT8
5 CL_RA CL_UNORM_INT8
6 CL_R CL_UNORM_INT8
7 CL_A CL_UNORM_INT8
8 CL_RGBA CL_SNORM_INT16
9 CL_RG CL_SNORM_INT16
10 CL_RA CL_SNORM_INT16
11 CL_R CL_SNORM_INT16
12 CL_A CL_SNORM_INT16
13 CL_RGBA CL_UNORM_INT16
14 CL_RG CL_UNORM_INT16
15 CL_RA CL_UNORM_INT16
16 CL_R CL_UNORM_INT16
17 CL_A CL_UNORM_INT16
18 CL_RGBA CL_SIGNED_INT8
19 CL_RG CL_SIGNED_INT8
20 CL_RA CL_SIGNED_INT8
21 CL_R CL_SIGNED_INT8
22 CL_A CL_SIGNED_INT8
23 CL_RGBA CL_UNSIGNED_INT8
24 CL_ARGB CL_UNSIGNED_INT8
25 CL_BGRA CL_UNSIGNED_INT8
26 CL_RG CL_UNSIGNED_INT8
27 CL_RA CL_UNSIGNED_INT8
28 CL_R CL_UNSIGNED_INT8
29 CL_A CL_UNSIGNED_INT8
30 CL_RGBA CL_SIGNED_INT16
31 CL_RG CL_SIGNED_INT16
32 CL_RA CL_SIGNED_INT16
33 CL_R CL_SIGNED_INT16
34 CL_A CL_SIGNED_INT16
35 CL_RGBA CL_UNSIGNED_INT16
36 CL_RG CL_UNSIGNED_INT16
37 CL_RA CL_UNSIGNED_INT16
38 CL_R CL_UNSIGNED_INT16
39 CL_A CL_UNSIGNED_INT16
40 CL_RGBA CL_SIGNED_INT32
41 CL_RG CL_SIGNED_INT32
42 CL_RA CL_SIGNED_INT32
43 CL_R CL_SIGNED_INT32
44 CL_A CL_SIGNED_INT32
45 CL_RGBA CL_UNSIGNED_INT32
46 CL_RG CL_UNSIGNED_INT32
47 CL_RA CL_UNSIGNED_INT32
48 CL_R CL_UNSIGNED_INT32
49 CL_A CL_UNSIGNED_INT32
50 CL_RGBA CL_HALF_FLOAT
51 CL_RGBA CL_FLOAT
3D Image Formats Supported (51)
51 CL_RGBA CL_FLOAT
oclDeviceQuery, Platform Name = Apple, Platform Version = OpenCL 1.0 (Dec 23 2010 17:30:26), SDK Revision = 7027912, NumDevs = 3, Device = GeForce GT 120, Device = Quadro 4000, Device = Intel(R) Xeon(R) CPU W3520 @ 2.67GHz
System Info:
[oclDeviceQuery] test results…
PASSED
