Hi I’m testing OpenCL SDK with a 8800GT and so far I have seen only two minor bugs on deviceQuery:
First it reports as CL_DEVICE_EXTENSIONS: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
where l_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics must not be since it doesn’t support
shared memory atomics (cuda jargon)
also Mhz tab in Linux reports 0 or 1Mhz where in Windows correctly reports the speed (1500mhz)…
