Impressed with what I could do on my 8400 GS I just got a system with an 8800GTX, using an Xeon Dual core - running Ubuntu.
I’ve just finished installing the SDK, and when I run deviceQuery I get :
There is no device supporting CUDA.
Device 0: "Device Emulation (CPU)"
Major revision number: -1
Minor revision number: -1
Total amount of global memory: -1 bytes
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1350000 kilohertz
I see other people have this problem, and found clues in the nvidia installer log. I see nothing in /var/log/. This is what I get when i run ldd against deviceQuery:
ldd deviceQuery
libcudart.so => /usr/local/cuda/lib/libcudart.so (0x00002aae1af30000)
libGL.so.1 => /usr/lib/libGL.so.1 (0x00002aae1b165000)
libGLU.so.1 => /usr/lib/libGLU.so.1 (0x00002aae1b328000)
libglut.so.3 => /usr/lib/libglut.so.3 (0x00002aae1b5ac000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00002aae1b7f1000)
libm.so.6 => /lib/libm.so.6 (0x00002aae1bafc000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00002aae1bd7d000)
libc.so.6 => /lib/libc.so.6 (0x00002aae1bf8c000)
libdl.so.2 => /lib/libdl.so.2 (0x00002aae1c2e7000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00002aae1c4eb000)
librt.so.1 => /lib/librt.so.1 (0x00002aae1c707000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00002aae1c910000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00002aae1cb21000)
/lib64/ld-linux-x86-64.so.2 (0x00002aae1ad12000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00002aae1ce33000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00002aae1d035000)
Any hints of where to look next?
